Not connected, Your IP: 216.73.217.74
For some reason my airvpn is starting so slow it takes like 10 min to connect to eddie
I tried to reinstall and restart my pc no luck with that
Update Eddie first, please. Current stable version is 2.18.9. Report back if it solved it or not.
If not, connect, then in Logs tab click the lifebelt icon and paste or upload the output here. If you choose to paste it, consider using LOG formatting; it's the top left button in the post editor. Thank you.
Thanks it's working fast now didn't think of the updates lol
