The current stable version is 2.18.9. Some people occasionally report that it's not running well after upgrading on Windows 10, so before you really do it, download the portable edition and try to run it, maybe copy the AirVPN settings file to the directory the portable is in, if you want to test with your settings.
If you don't have any problems, you can safely install the new version over the old. :)
V2.18 not working properly on my edition of Win 10 (64bit version 1909 build 18363.778.) V2.16 is fine, am about to roll back to that version...
@twill Open your own thread if you wish to troubleshoot 2.18. There are a number of workarounds available. ;)
