SoftEtherVPN Configuration Failure
Hey Guys.
i wanted to try a new VPN Client Manager and read about SoftetherVPN.
Ive tried serval configurations, but its everytime failing and i dont find a solution for it.
Here is a picture about my config:
https://prnt.sc/s39h1j
Edited ... by dstny
Those settings don't look like ones for OpenVPN at all. For example, there should be a way to select the cipher suite instead of encrypt with SSL or not. The authentication option is dead wrong, too, authentication is done via certificates and I don't see a way to select them here. Check again if the profile you selected is really for OpenVPN connections.
