wwworld
Eddie UI - Don't Connect with Servers
Hallo,
hello,
mein Eddie UI verbindet sich nicht mit dem Server. Was kann ich tun?
my Eddie UI don't connect with the server. What can i do?
Ich nutz Windows 8.1 64 Bit. Die Version von Eddie 2.18.9
Ich use Windows 8.1 64 Bit. The Version from Eddie is 2.18.9
Hier ist mein Log:
Here is my Log:
. 2020.04.06 21:03:44 - Eddie version: 2.18.9 / windows_x64, System: Windows, Name: Windows 8.1 Pro, Version: Microsoft Windows NT 6.3.9600.0, Mono/.Net: v4.0.30319
. 2020.04.06 21:03:44 - Command line arguments (1): path="home"
. 2020.04.06 21:03:45 - Raise system privileges
. 2020.04.06 21:03:46 - Profile path: C:\Users\Sebastian Wetjen\AppData\Local\Eddie\default.profile
. 2020.04.06 21:03:47 - Reading options from C:\Users\Sebastian Wetjen\AppData\Local\Eddie\default.profile
. 2020.04.06 21:03:49 - Tun Driver - 0901: 9.24.2; wintun: Not found
. 2020.04.06 21:03:49 - OpenVPN - Version: 2.4.8 - OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2020.04.06 21:03:49 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2020.04.06 21:03:49 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2020.04.06 21:03:49 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe)
. 2020.04.06 21:03:49 - Recovery. Unexpected crash?
. 2020.04.06 21:03:50 - Routes, added a new route, 2001:ac8:38:3:7b25:8919:4d97:4e23 for gateway fde6:7a:7d20:ce2::1
. 2020.04.06 21:03:50 - Routes, removed an existing route, 128.127.105.184 for gateway 10.23.162.1
. 2020.04.06 21:03:50 - Routes, added a new route, 185.206.225.51 for gateway 10.16.226.1
I 2020.04.06 21:03:51 - Ready
. 2020.04.06 21:03:52 - Collect information about AirVPN completed
I 2020.04.06 21:03:54 - Session starting.
I 2020.04.06 21:03:54 - Checking authorization ...
. 2020.04.06 21:03:55 - IPv6 disabled with packet filtering.
! 2020.04.06 21:03:55 - Connecting to Fomalhaut (Norway, Oslo)
. 2020.04.06 21:03:55 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.04.06 21:03:55 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.04.06 21:03:55 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.04.06 21:03:55 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.04.06 21:03:55 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.04.06 21:03:55 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.04.06 21:03:55 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.04.06 21:03:55 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.206.225.53:443
. 2020.04.06 21:03:55 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.04.06 21:03:55 - OpenVPN > UDP link local (bound): [AF_INET]192.168.2.108:1194
. 2020.04.06 21:03:55 - OpenVPN > UDP link remote: [AF_INET]185.206.225.53:443
. 2020.04.06 21:03:55 - OpenVPN > TLS: Initial packet from [AF_INET]185.206.225.53:443, sid=160721a1 564f5516
. 2020.04.06 21:03:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.04.06 21:03:55 - OpenVPN > VERIFY KU OK
. 2020.04.06 21:03:55 - OpenVPN > Validating certificate extended key usage
. 2020.04.06 21:03:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.04.06 21:03:55 - OpenVPN > VERIFY EKU OK
. 2020.04.06 21:03:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Fomalhaut, emailAddress=info@airvpn.org
. 2020.04.06 21:03:57 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.04.06 21:03:57 - OpenVPN > [Fomalhaut] Peer Connection Initiated with [AF_INET]185.206.225.53:443
. 2020.04.06 21:03:58 - OpenVPN > SENT CONTROL [Fomalhaut]: 'PUSH_REQUEST' (status=1)
. 2020.04.06 21:03:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.16.226.1,dhcp-option DNS6 fde6:7a:7d20:ce2::1,tun-ipv6,route-gateway 10.16.226.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:ce2::10e8/64 fde6:7a:7d20:ce2::1,ifconfig 10.16.226.234 255.255.255.0,peer-id 7,cipher AES-256-GCM'
. 2020.04.06 21:03:58 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.04.06 21:03:58 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:ce2::1'
. 2020.04.06 21:03:58 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2020.04.06 21:03:58 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:ce2::10e8/64 fde6:7a:7d20:ce2::1'
. 2020.04.06 21:03:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.04.06 21:03:58 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.04.06 21:03:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.04.06 21:03:58 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.04.06 21:03:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.04.06 21:03:58 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.04.06 21:03:58 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.04.06 21:03:58 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.04.06 21:03:58 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.04.06 21:03:58 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.04.06 21:03:58 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.04.06 21:03:58 - OpenVPN > interactive service msg_channel=0
. 2020.04.06 21:03:58 - OpenVPN > ROUTE_GATEWAY 192.168.2.1/255.255.255.0 I=21 HWADDR=00:50:b6:12:31:5a
. 2020.04.06 21:03:58 - OpenVPN > open_tun
. 2020.04.06 21:03:59 - OpenVPN > TAP-WIN32 device [LAN-Verbindung] opened: \\.\Global\{645FB144-9789-4207-97F5-A72856A885D3}.tap
. 2020.04.06 21:03:59 - OpenVPN > TAP-Windows Driver Version 9.24
. 2020.04.06 21:03:59 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.16.226.0/10.16.226.234/255.255.255.0 [SUCCEEDED]
. 2020.04.06 21:03:59 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.16.226.234/255.255.255.0 on interface {645FB144-9789-4207-97F5-A72856A885D3} [DHCP-serv: 10.16.226.254, lease-time: 31536000]
. 2020.04.06 21:03:59 - OpenVPN > Successful ARP Flush on interface [38] {645FB144-9789-4207-97F5-A72856A885D3}
. 2020.04.06 21:04:04 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2020.04.06 21:04:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 185.206.225.53 MASK 255.255.255.255 192.168.2.1
. 2020.04.06 21:04:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2020.04.06 21:04:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2020.04.06 21:04:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.16.226.1
. 2020.04.06 21:04:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2020.04.06 21:04:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.16.226.1
. 2020.04.06 21:04:04 - Interface LAN-Verbindung metric changed from Automatic to 3, layer IPv4
. 2020.04.06 21:04:04 - Interface LAN-Verbindung metric changed from Automatic to 3, layer IPv6
. 2020.04.06 21:04:04 - DNS leak protection with packet filtering enabled.
. 2020.04.06 21:04:05 - DNS IPv4 of a network adapter forced (LAN-Verbindung, from automatic to 10.16.226.1)
W 2020.04.06 21:04:05 - Routes, add 185.206.225.51 for gateway 10.16.226.1 failed: Exception: exit:0; out:; err:Hinzuf�gen der Route fehlgeschlagen: Das Objekt ist bereits vorhanden.
. 2020.04.06 21:04:05 - Unable to compute route for 2001:ac8:38:3:7b25:8919:4d97:4e23: IPv6 VPN gateway not available.
. 2020.04.06 21:04:05 - Flushing DNS
W 2020.04.06 21:04:05 - Waiting TUN interface
. 2020.04.06 21:04:17 - Above log line repeated 5 times more
W 2020.04.06 21:04:17 - Tunnel not ready in 10 seconds, contact our support. Last interface status: Down
. 2020.04.06 21:04:17 - OpenVPN > Initialization Sequence Completed
! 2020.04.06 21:04:17 - Disconnecting
. 2020.04.06 21:04:17 - Sending soft termination signal
. 2020.04.06 21:04:20 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.04.06 21:04:22 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 185.206.225.53 MASK 255.255.255.255 192.168.2.1
. 2020.04.06 21:04:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2020.04.06 21:04:22 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.16.226.1
. 2020.04.06 21:04:22 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.16.226.1
. 2020.04.06 21:04:22 - OpenVPN > Closing TUN/TAP interface
. 2020.04.06 21:04:22 - OpenVPN > TAP: DHCP address released
. 2020.04.06 21:04:22 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2020.04.06 21:04:22 - Connection terminated.
. 2020.04.06 21:04:23 - IPv6 restored with packet filtering.
. 2020.04.06 21:04:23 - DNS IPv4 of a network adapter restored to original settings (LAN-Verbindung, to automatic)
. 2020.04.06 21:04:23 - DNS leak protection with packet filtering disabled.
. 2020.04.06 21:04:23 - Interface LAN-Verbindung metric restored from 3 to Automatic, layer IPv4
. 2020.04.06 21:04:23 - Interface LAN-Verbindung metric restored from 3 to Automatic, layer IPv6
I 2020.04.06 21:04:23 - Cancel requested.
! 2020.04.06 21:04:23 - Session terminated.
Gruß wwworld
regards wwworld
Edited ... by giganerd
Apply LOG formatting to logs
Could you please link to this thread in the 2.18.9 release thread? Bugs are being collected there.
