Not connected, Your IP: 216.73.216.124
rgrdgr
ANSWERED eddie-cli: split-tunneling
I'm trying to exclude some sites from the VPN.  Normally I'd do this via the openvpn config file, and I'd see some instructions on doing this via the GUI.  However, I have no access to a GUI on this machine.  How can i do this using eddie-cli?  Or eddie-ui -cli?
Well, to not quote the rude four-letter thing, there's man eddie-ui ;)
out refers to "out of tunnel".
--routes.custom
              Custom routes. Format: '{ip or range},{in/out},{note (optional)};...'. Separate multiple routes with ;. Example: '1.2.3.4,in;2.3.4.5/23,out,'test'
Thanks!  In my own defense, I'm using eddie-cli:
> man eddie-cli
No manual entry for eddie-cli
Looks like I can switch to eddie-ui and use the -cli option, although I'm not sure that gains me anything.
eddie-cli was removed some versions ago; which one are you running? Maybe an update is due? ;)
eddie-cli = eddie-ui -cli. You neither gain nor lose anything.
Both the eddie-ui version I grabbed earlier today and eddie-cli say 2.16.3.  FYI, there is still a link to eddie-cli from eddie.website.  Perhaps rumors of its demise have been exaggerated.  ;)
Ah okay, I wasn't aware the standalone CLI version was still called eddie-cli. I only noticed the eddie-ui packages having cli removed and the versions merged into eddie-ui. Well, we never stop learning, thanks. :)
Does the routes.custom thing work as expected?
Hmm, no it doesn't look like it.  I'm running eddie-ui with this command:
/usr/bin/eddie-ui --cli --connect --server=XXX --login=uuu --password=ppp --routes.custom='69.16.179.29,out;69.16.179.28,out'
Neither destination gets added to my routing table, and if I use traceroute they go through the vpn.
Maybe I should make my own script to modify the routing table and invoke it with --event.vpn.up.filename.
Interesting. Can you maybe test 2.18.x? You can use the portable, in case you don't want to override the stable.
Is this how you exclude a website from the VPN? I particularly do not want my Internet TV included in the VPN because it really slows down. Thank you.
You can only exclude IP addresses.
You might be able to do it by IP addresses. I don't actually do this anymore - it was much easier to use docker containers to do the split tunneling.  I have one container for OpenVPN and then everything I want to tunnel uses that container for its network.  But I only had a few services I wanted to tunnel.
