deffonotsean 0 Posted ... Hi I've recently installed the Eddi GUI and cannot seem to connect to any server. Once I attempt to connect to one, eventually the connection restarts and attempts another server, which it also cannot connect to. Would appreciate any advice, thanks. Log: Eddie System/Environment Report - 21/03/2020 05:51 PM UTC Eddie version: 2.16.3 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Education OS version: Microsoft Windows NT 10.0.17763.0 OS architecture: x64 Mono /.Net Framework: v4.0.30319 OpenVPN driver: TAP-Windows Adapter V9, version 9.24.2 OpenVPN: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe) SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) curl: 7.68.0 (C:\Program Files\AirVPN\curl.exe) Profile path: C:\Users\Sean\AppData\Local\AirVPN\default.xml Data path: C:\Users\Sean\AppData\Local\AirVPN Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (1 args) path="home" Network Lock Active: No Connected to VPN: No Detected DNS: 8.8.4.4, 8.8.8.8 Test DNS IPv4: Ok Test DNS IPv6: Failed Test Ping IPv4: 8 ms Test Ping IPv6: -1 ms Test HTTP IPv4: Ok Test HTTP IPv6: Error:curl: (6) Could not resolve host: ipv6.eddie.website Test HTTPS: Ok ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True openvpn.directives: client dev tun auth-nocache resolv-retry infinite nobind persist-key persist-tun verb 3 connect-retry-max 1 ping 10 ping-exit 32 explicit-exit-notify 5 ip-win32 netsh ---------------------------- Logs: . 2020.03.21 18:44:11 - Eddie version: 2.16.3 / windows_x64, System: Windows, Name: Windows 10 Education, Version: Microsoft Windows NT 10.0.17763.0, Mono/.Net: v4.0.30319 . 2020.03.21 18:44:11 - Reading options from C:\Users\Sean\AppData\Local\AirVPN\default.xml . 2020.03.21 18:44:11 - Command line arguments (1): path="home" . 2020.03.21 18:44:11 - Profile path: C:\Users\Sean\AppData\Local\AirVPN\default.xml . 2020.03.21 18:44:15 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.24.2 . 2020.03.21 18:44:15 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2020.03.21 18:44:15 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe) . 2020.03.21 18:44:15 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) . 2020.03.21 18:44:15 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe) . 2020.03.21 18:44:15 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem . 2020.03.21 18:44:15 - Updating systems & servers data ... I 2020.03.21 18:44:15 - Ready . 2020.03.21 18:44:16 - Systems & servers data update completed I 2020.03.21 18:46:13 - Session starting. I 2020.03.21 18:46:13 - Checking authorization ... ! 2020.03.21 18:46:14 - Connecting to Piscium (Netherlands, Alblasserdam) . 2020.03.21 18:46:14 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2020.03.21 18:46:14 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.03.21 18:46:14 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.03.21 18:46:14 - Connection to OpenVPN Management Interface . 2020.03.21 18:46:14 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2020.03.21 18:46:14 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.21 18:46:14 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.21 18:46:14 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.21 18:46:14 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.21 18:46:14 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]134.19.179.133:443 . 2020.03.21 18:46:14 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.03.21 18:46:14 - OpenVPN > UDP link local: (not bound) . 2020.03.21 18:46:14 - OpenVPN > UDP link remote: [AF_INET]134.19.179.133:443 . 2020.03.21 18:46:14 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2020.03.21 18:46:46 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2020.03.21 18:46:46 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.03.21 18:46:51 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2020.03.21 18:46:51 - Disconnecting . 2020.03.21 18:46:51 - Connection terminated. I 2020.03.21 18:46:54 - Checking authorization ... ! 2020.03.21 18:46:54 - Connecting to Alterf (Netherlands, Alblasserdam) . 2020.03.21 18:46:54 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2020.03.21 18:46:54 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.03.21 18:46:54 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.03.21 18:46:54 - Connection to OpenVPN Management Interface . 2020.03.21 18:46:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2020.03.21 18:46:54 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.21 18:46:54 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.21 18:46:54 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.21 18:46:54 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.21 18:46:54 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.172:443 . 2020.03.21 18:46:54 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.03.21 18:46:54 - OpenVPN > UDP link local: (not bound) . 2020.03.21 18:46:54 - OpenVPN > UDP link remote: [AF_INET]213.152.161.172:443 . 2020.03.21 18:46:55 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2020.03.21 18:47:26 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2020.03.21 18:47:26 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.03.21 18:47:31 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2020.03.21 18:47:31 - Disconnecting . 2020.03.21 18:47:31 - Connection terminated. I 2020.03.21 18:47:34 - Checking authorization ... ! 2020.03.21 18:47:35 - Connecting to Garnet (Netherlands, Alblasserdam) . 2020.03.21 18:47:35 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2020.03.21 18:47:35 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.03.21 18:47:35 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.03.21 18:47:35 - Connection to OpenVPN Management Interface . 2020.03.21 18:47:35 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2020.03.21 18:47:35 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.21 18:47:35 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.21 18:47:35 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.21 18:47:35 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.21 18:47:35 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.76:443 . 2020.03.21 18:47:35 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.03.21 18:47:35 - OpenVPN > UDP link local: (not bound) . 2020.03.21 18:47:35 - OpenVPN > UDP link remote: [AF_INET]213.152.162.76:443 . 2020.03.21 18:47:35 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2020.03.21 18:48:07 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2020.03.21 18:48:07 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.03.21 18:48:12 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2020.03.21 18:48:12 - Disconnecting . 2020.03.21 18:48:12 - Connection terminated. I 2020.03.21 18:48:15 - Checking authorization ... ! 2020.03.21 18:48:15 - Connecting to Maasym (Netherlands, Alblasserdam) . 2020.03.21 18:48:16 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2020.03.21 18:48:16 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.03.21 18:48:16 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.03.21 18:48:16 - Connection to OpenVPN Management Interface . 2020.03.21 18:48:16 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2020.03.21 18:48:16 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.21 18:48:16 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.21 18:48:16 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.21 18:48:16 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.21 18:48:16 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.106:443 . 2020.03.21 18:48:16 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.03.21 18:48:16 - OpenVPN > UDP link local: (not bound) . 2020.03.21 18:48:16 - OpenVPN > UDP link remote: [AF_INET]213.152.162.106:443 . 2020.03.21 18:48:16 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2020.03.21 18:48:47 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2020.03.21 18:48:47 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.03.21 18:48:52 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2020.03.21 18:48:52 - Disconnecting . 2020.03.21 18:48:52 - Connection terminated. I 2020.03.21 18:48:55 - Checking authorization ... ! 2020.03.21 18:48:55 - Connecting to Matar (Netherlands, Alblasserdam) . 2020.03.21 18:48:56 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2020.03.21 18:48:56 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.03.21 18:48:56 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.03.21 18:48:56 - Connection to OpenVPN Management Interface . 2020.03.21 18:48:56 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2020.03.21 18:48:56 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.21 18:48:56 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.21 18:48:56 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.21 18:48:56 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.21 18:48:56 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]109.232.227.140:443 . 2020.03.21 18:48:56 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.03.21 18:48:56 - OpenVPN > UDP link local: (not bound) . 2020.03.21 18:48:56 - OpenVPN > UDP link remote: [AF_INET]109.232.227.140:443 . 2020.03.21 18:48:56 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2020.03.21 18:49:28 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2020.03.21 18:49:28 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.03.21 18:49:33 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2020.03.21 18:49:33 - Disconnecting . 2020.03.21 18:49:33 - Connection terminated. I 2020.03.21 18:49:36 - Checking authorization ... ! 2020.03.21 18:49:36 - Connecting to Sheliak (Netherlands, Alblasserdam) . 2020.03.21 18:49:37 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2020.03.21 18:49:37 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.03.21 18:49:37 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.03.21 18:49:37 - Connection to OpenVPN Management Interface . 2020.03.21 18:49:37 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2020.03.21 18:49:37 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.21 18:49:37 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.21 18:49:37 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.21 18:49:37 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.21 18:49:37 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.116:443 . 2020.03.21 18:49:37 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.03.21 18:49:37 - OpenVPN > UDP link local: (not bound) . 2020.03.21 18:49:37 - OpenVPN > UDP link remote: [AF_INET]213.152.162.116:443 . 2020.03.21 18:49:37 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2020.03.21 18:50:08 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2020.03.21 18:50:08 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.03.21 18:50:13 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2020.03.21 18:50:13 - Disconnecting . 2020.03.21 18:50:13 - Connection terminated. I 2020.03.21 18:50:16 - Checking authorization ... ! 2020.03.21 18:50:17 - Connecting to Cygnus (Netherlands, Alblasserdam) . 2020.03.21 18:50:17 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2020.03.21 18:50:17 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.03.21 18:50:17 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.03.21 18:50:17 - Connection to OpenVPN Management Interface . 2020.03.21 18:50:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2020.03.21 18:50:17 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.21 18:50:17 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.21 18:50:17 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.21 18:50:17 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.21 18:50:17 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.246:443 . 2020.03.21 18:50:17 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.03.21 18:50:17 - OpenVPN > UDP link local: (not bound) . 2020.03.21 18:50:17 - OpenVPN > UDP link remote: [AF_INET]213.152.161.246:443 . 2020.03.21 18:50:17 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2020.03.21 18:50:49 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2020.03.21 18:50:49 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.03.21 18:50:55 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2020.03.21 18:50:55 - Disconnecting . 2020.03.21 18:50:55 - Connection terminated. I 2020.03.21 18:50:58 - Checking authorization ... ! 2020.03.21 18:50:58 - Connecting to Hydrus (Netherlands, Alblasserdam) . 2020.03.21 18:50:58 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2020.03.21 18:50:58 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.03.21 18:50:58 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.03.21 18:50:58 - Connection to OpenVPN Management Interface . 2020.03.21 18:50:58 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2020.03.21 18:50:58 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.21 18:50:58 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.21 18:50:58 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.03.21 18:50:58 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.03.21 18:50:58 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.12:443 . 2020.03.21 18:50:58 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.03.21 18:50:58 - OpenVPN > UDP link local: (not bound) . 2020.03.21 18:50:58 - OpenVPN > UDP link remote: [AF_INET]213.152.162.12:443 . 2020.03.21 18:50:58 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 ---------------------------- Network Interfaces and Routes: { "support_ipv4": true, "support_ipv6": true, "routes": [ { "address": "0.0.0.0\/0", "interface": "{E2ADDAA2-5A58-4AF2-AB60-4D65DCAA0ED9}", "gateway": "192.168.0.1", "metric": "45" }, { "address": "127.0.0.0\/8", "interface": "{BFD88B57-0500-11EA-B93B-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.0.0.1", "interface": "{BFD88B57-0500-11EA-B93B-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.255.255.255", "interface": "{BFD88B57-0500-11EA-B93B-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "192.168.0.0\/24", "interface": "{E2ADDAA2-5A58-4AF2-AB60-4D65DCAA0ED9}", "gateway": "link", "metric": "301" }, { "address": "192.168.0.101", "interface": "{E2ADDAA2-5A58-4AF2-AB60-4D65DCAA0ED9}", "gateway": "link", "metric": "301" }, { "address": "192.168.0.255", "interface": "{E2ADDAA2-5A58-4AF2-AB60-4D65DCAA0ED9}", "gateway": "link", "metric": "301" }, { "address": "224.0.0.0\/4", "interface": "{BFD88B57-0500-11EA-B93B-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "224.0.0.0\/4", "interface": "{E2ADDAA2-5A58-4AF2-AB60-4D65DCAA0ED9}", "gateway": "link", "metric": "301" }, { "address": "255.255.255.255", "interface": "{BFD88B57-0500-11EA-B93B-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "255.255.255.255", "interface": "{E2ADDAA2-5A58-4AF2-AB60-4D65DCAA0ED9}", "gateway": "link", "metric": "301" }, { "address": "::1", "interface": "{BFD88B57-0500-11EA-B93B-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "fe80::\/64", "interface": "{E2ADDAA2-5A58-4AF2-AB60-4D65DCAA0ED9}", "gateway": "link", "metric": "301" }, { "address": "fe80::f4cb:84fe:b2fb:818b", "interface": "{E2ADDAA2-5A58-4AF2-AB60-4D65DCAA0ED9}", "gateway": "link", "metric": "301" }, { "address": "ff00::\/8", "interface": "{BFD88B57-0500-11EA-B93B-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "ff00::\/8", "interface": "{E2ADDAA2-5A58-4AF2-AB60-4D65DCAA0ED9}", "gateway": "link", "metric": "301" } ], "interfaces": [ { "friendly": "Ethernet", "id": "{70D791C4-6012-4B1C-A08A-53FF3CD92902}", "name": "Ethernet", "description": "Intel(R) Ethernet Connection I217-LM", "type": "Ethernet", "status": "Down", "bytes_received": "13981883", "bytes_sent": "2922892", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::908f:3dd9:f52f:bcb1", "169.254.188.177" ], "gateways": [], "bind": true, "dns4": "8.8.8.8,8.8.4.4", "dns6": null }, { "friendly": "Ethernet 2", "id": "{209ED911-75CC-4C59-AE4A-A32E0C832A9D}", "name": "Ethernet 2", "description": "TAP-ProtonVPN Windows Adapter V9", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::912e:76c6:6f6a:e112", "169.254.225.18" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Ethernet 3", "id": "{FF8307EB-79CD-4B9F-9CAB-E8EFF1F83569}", "name": "Ethernet 3", "description": "Speedify Virtual Adapter", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::c0a5:c6d6:a7a5:621e", "169.254.98.30" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection", "id": "{62805BFF-95FF-43B6-B2FB-A9E894257090}", "name": "Local Area Connection", "description": "TAP-Windows Adapter V9", "type": "53", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::bdbc:19fe:33fc:2b33", "169.254.43.51" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection* 1", "id": "{4FB962E7-4FD5-43C1-B9F4-281AEBFCB2EB}", "name": "Local Area Connection* 1", "description": "Microsoft Wi-Fi Direct Virtual Adapter", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::458b:d100:206:56b8", "169.254.86.184" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection* 2", "id": "{431D1BBF-CBAE-41B3-81DB-8904F75FA9A6}", "name": "Local Area Connection* 2", "description": "Microsoft Wi-Fi Direct Virtual Adapter #2", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::6de2:5bb5:d38d:6334", "169.254.99.52" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Wi-Fi", "id": "{E2ADDAA2-5A58-4AF2-AB60-4D65DCAA0ED9}", "name": "Wi-Fi", "description": "Intel(R) Dual Band Wireless-N 7260", "type": "Wireless80211", "status": "Up", "bytes_received": "887975030", "bytes_sent": "43214995", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::f4cb:84fe:b2fb:818b", "192.168.0.101" ], "gateways": [ "192.168.0.1" ], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Loopback Pseudo-Interface 1", "id": "{BFD88B57-0500-11EA-B93B-806E6F6E6963}", "name": "Loopback Pseudo-Interface 1", "description": "Software Loopback Interface 1", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "::1", "127.0.0.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null } ], "ipv4-default-gateway": "192.168.0.1", "ipv4-default-interface": "{E2ADDAA2-5A58-4AF2-AB60-4D65DCAA0ED9}" } ---------------------------- ipconfig /all: Windows IP Configuration Host Name . . . . . . . . . . . . : DESKTOP-37QTO5M Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Ethernet adapter Ethernet: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) Ethernet Connection I217-LM Physical Address. . . . . . . . . : 68-F7-28-7F-1F-37 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Ethernet adapter Ethernet 2: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : TAP-ProtonVPN Windows Adapter V9 Physical Address. . . . . . . . . : 00-FF-20-9E-D9-11 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Ethernet adapter Ethernet 3: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Speedify Virtual Adapter Physical Address. . . . . . . . . : 00-FF-FF-83-07-EB DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Unknown adapter Local Area Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : TAP-Windows Adapter V9 Physical Address. . . . . . . . . : 00-FF-62-80-5B-FF DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Local Area Connection* 1: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter Physical Address. . . . . . . . . : CC-3D-82-8A-55-85 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Local Area Connection* 2: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2 Physical Address. . . . . . . . . : CE-3D-82-8A-55-84 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Wi-Fi: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-N 7260 Physical Address. . . . . . . . . : CC-3D-82-8A-55-84 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::f4cb:84fe:b2fb:818b%19(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.0.101(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : 21 March 2020 12:24:34 Lease Expires . . . . . . . . . . : 21 March 2020 20:21:05 Default Gateway . . . . . . . . . : 192.168.0.1 DHCP Server . . . . . . . . . . . : 192.168.0.1 DHCPv6 IAID . . . . . . . . . . . : 164380034 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-25-5C-05-93-68-F7-28-7F-1F-37 DNS Servers . . . . . . . . . . . : 8.8.8.8 8.8.4.4 NetBIOS over Tcpip. . . . . . . . : Enabled Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... 21 minutes ago, deffonotsean said: Detected DNS: 8.8.4.4, 8.8.8.8 Be advised that Google saves what you resolve via their DNS servers. Consider using AirDNS only, or maybe with the secondary server from OpenNIC as a fallback. 25 minutes ago, deffonotsean said: Test HTTP IPv6: Error:curl: (6) Could not resolve host: ipv6.eddie.website In Eddie's preferences > Networking, set Layer IPv6 to Block. Even on your WLAN interface you don't seem to have support for IPv6, so we should block it. 27 minutes ago, deffonotsean said: openvpn.directives: client Any specific reason you are using your own directives (which are identical to what Eddie would use, anyway)? 28 minutes ago, deffonotsean said: Eddie version: 2.16.3 Your problem is a common error with Eddie 2.16.3. There's Eddie 2.18.x which fixes many issues, including yours. Consider updating if using a cable connection is out of the question. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Madflave 0 Posted ... I fixed this but cant remember how just searching on here but now I have a new problem it connects but pages wont load. Doh! lol Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... Why post it, then? It doesn't help at all. If you have problems of your own, open your own thread, please. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
