Stack of computer parts
Hummingbird for QubesOS
Has anyone had any luck getting hummingbird to work as a vpn vm for Qubes 4 yet? It seems the way network lock operates also does not jive well with the way Qubes operates.
I have tried running it directly in sys-net, which is obviously not ideal for many situations, as well as directly on an ethernet port clients connect to(routing towards sys-net), in addition to being a regular sys-vpn with no luck so far. Im sure I am not the only one to have tried this, perhaps someone else has had some luck
