computer-Frezona 0 Posted ... Eddie has a lot of trobble starting up. he is saing. Recovery, unexpected crash? even afther de-installing en re-installing. looking at the logs it keeps saying: routes, remove ....... (numbers change) fore gateway ....... (numbers change) failed: The route deletion failed: kan element niet vinden (= dutch, meens can't find the element) the time that he makes contact (afther 5 minutes of waiting) it automaticaly shot down the vpn and gave the message in the log boek: Sending management termination signal Management - Send 'signal SIGTERM' over and over again.... see file fout eddie 1 feb.txt Quote Share this post Link to post
Tech Jedi Alex 1492 Posted ... Hm. TAP is not set correctly to the right address, it seems. "ips": [ "fe80::a582:1989:a059:dfb1", "169.254.223.177" The disconnects may emerge from continuous replays, maybe something meddles with the traffic. . 2020.02.01 19:43:12 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #267611 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2020.02.01 19:46:34 - Above log line repeated 372 times more . 2020.02.01 19:46:34 - OpenVPN > [Alphard] Inactivity timeout (--ping-restart), restarting Eddie version: 2.16.3 Can you try 2.18.x, please? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
