twelvesky
ANSWERED [Solved] Cant connect to AirVPN anymore
So I was connected to AirVPN and wanted to start a program in OFFLINE MODE.
In order to be offline I did this
deactivate Ethernet.
Then i turned it back on and now it wont reconnect anymore to any server in AirVPN and it keeps LOOPING with the message
"Couldnt connect, because the targeted Computer is refusing the connection 127.0.0.1:3100"
. i already tried reinstalling everything but nothing worked. restarted pc aswell
. 2020.01.10 11:11:56 - Eddie version: 2.16.3 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.18363.0, Mono/.Net: v4.0.30319
. 2020.01.10 11:11:56 - Reading options from C:\Users\deniz\AppData\Local\AirVPN\default.xml
. 2020.01.10 11:11:56 - Command line arguments (1): path="home"
. 2020.01.10 11:11:56 - Profile path: C:\Users\deniz\AppData\Local\AirVPN\default.xml
. 2020.01.10 11:11:57 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
. 2020.01.10 11:11:57 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2020.01.10 11:11:57 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2020.01.10 11:11:57 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2020.01.10 11:11:57 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe)
. 2020.01.10 11:11:57 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem
W 2020.01.10 11:11:58 - Recovery. Unexpected crash?
. 2020.01.10 11:11:58 - Routes, remove 213.152.161.181 for gateway 10.5.158.1 failed: Network interface no more available.
. 2020.01.10 11:11:58 - Updating systems & servers data ...
I 2020.01.10 11:11:58 - Session starting.
I 2020.01.10 11:11:58 - Checking authorization ...
. 2020.01.10 11:11:58 - Systems & servers data update completed
! 2020.01.10 11:11:58 - Connecting to Alchiba (Netherlands, Alblasserdam)
. 2020.01.10 11:11:58 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2020.01.10 11:11:58 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.01.10 11:11:58 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2020.01.10 11:11:58 - Connection to OpenVPN Management Interface
W 2020.01.10 11:12:00 - Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte 127.0.0.1:3100
. 2020.01.10 11:12:00 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.01.10 11:12:00 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.01.10 11:12:00 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.01.10 11:12:00 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.01.10 11:12:00 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.183:443
. 2020.01.10 11:12:00 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.01.10 11:12:00 - OpenVPN > TCP/UDP: Socket bind failed: Addr to bind has no AF_INET record
. 2020.01.10 11:12:00 - OpenVPN > Exiting due to fatal error
! 2020.01.10 11:12:00 - Disconnecting
. 2020.01.10 11:12:00 - Connection terminated.
I 2020.01.10 11:12:07 - Checking authorization ...
! 2020.01.10 11:12:08 - Connecting to Matar (Netherlands, Alblasserdam)
. 2020.01.10 11:12:08 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2020.01.10 11:12:08 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.01.10 11:12:08 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2020.01.10 11:12:08 - Connection to OpenVPN Management Interface
W 2020.01.10 11:12:10 - Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte 127.0.0.1:3100
. 2020.01.10 11:12:10 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.01.10 11:12:10 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.01.10 11:12:10 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.01.10 11:12:10 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.01.10 11:12:10 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]109.232.227.140:443
. 2020.01.10 11:12:10 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.01.10 11:12:10 - OpenVPN > TCP/UDP: Socket bind failed: Addr to bind has no AF_INET record
. 2020.01.10 11:12:10 - OpenVPN > Exiting due to fatal error
! 2020.01.10 11:12:10 - Disconnecting
. 2020.01.10 11:12:10 - Connection terminated.
I 2020.01.10 11:12:13 - Cancel requested.
! 2020.01.10 11:12:13 - Session terminated.
