El.Presidente
Network Lock - Connecting
Heya,
Network Lock is always enabled but some Hours ago. Eddie wasnt connected to something, just idle, i´d click to Connect the next best Server and switched to Opera and tried to Connect Startpage.com, Eddie was still connecting and i can see the Webpage. How i can stop it. its only some Seconds my Real IP is there but i dont want it.
This is where we need the Eddie log. Go back on Eddie and start normally of what you did. Then click Logs, you will see a list of information in there. On the right side, there is two things you can do. "Save to File" to generate a .txt file for you to attach it in your post or "Copy to Clipboard" to paste your log. Your log will tell us what is going on.
Thanks for your Reply. ;)
. 2020.01.09 05:23:56 - Eddie version: 2.16.3 / windows_x64, System: Windows, Name: Windows 10 Enterprise LTSC 2019, Version: Microsoft Windows NT 10.0.17763.0, Mono/.Net: v4.0.30319
. 2020.01.09 05:23:56 - Reading options from C:\Users\Administrator\AppData\Local\AirVPN\default.xml
. 2020.01.09 05:23:57 - Command line arguments (1): path="home"
. 2020.01.09 05:23:57 - Profile path: C:\Users\Administrator\AppData\Local\AirVPN\default.xml
. 2020.01.09 05:23:58 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
. 2020.01.09 05:23:58 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2020.01.09 05:23:58 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2020.01.09 05:23:58 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2020.01.09 05:23:58 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe)
. 2020.01.09 05:23:58 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem
W 2020.01.09 05:23:59 - Recovery. Unexpected crash?
. 2020.01.09 05:23:59 - Routes, remove 109.202.107.5 for gateway 10.7.82.1 failed: L”schen der Route fehlgeschlagen: Element nicht gefunden
. 2020.01.09 05:23:59 - Routes, remove 134.19.179.171 for gateway 10.29.146.1 failed: L”schen der Route fehlgeschlagen: Element nicht gefunden
. 2020.01.09 05:24:00 - Above log line repeated 1 times more
. 2020.01.09 05:24:00 - Routes, remove 134.19.179.147 for gateway 10.33.194.1 failed: L”schen der Route fehlgeschlagen: Element nicht gefunden
. 2020.01.09 05:24:00 - Routes, remove 2.58.47.203 for gateway 10.15.34.1 failed: L”schen der Route fehlgeschlagen: Element nicht gefunden
. 2020.01.09 05:24:00 - Routes, remove 213.152.161.10 for gateway 10.10.98.1 failed: L”schen der Route fehlgeschlagen: Element nicht gefunden
! 2020.01.09 05:24:00 - Deactivation of Network Lock
! 2020.01.09 05:24:00 - Activation of Network Lock - Windows Filtering Platform
. 2020.01.09 05:24:00 - Updating systems & servers data ...
I 2020.01.09 05:24:00 - Ready
. 2020.01.09 05:24:00 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 63.33.78.166 port 80: Network unreachable)
I 2020.01.09 05:27:55 - Session starting.
I 2020.01.09 05:27:56 - Checking authorization ...
! 2020.01.09 05:27:56 - Connecting to Rukbat (Netherlands, Alblasserdam)
. 2020.01.09 05:27:57 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2020.01.09 05:27:57 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.01.09 05:27:57 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2020.01.09 05:27:57 - Connection to OpenVPN Management Interface
. 2020.01.09 05:27:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2020.01.09 05:27:57 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.01.09 05:27:57 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.01.09 05:27:57 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.01.09 05:27:57 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.01.09 05:27:57 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.86:443
. 2020.01.09 05:27:57 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.01.09 05:27:57 - OpenVPN > UDP link local: (not bound)
. 2020.01.09 05:27:57 - OpenVPN > UDP link remote: [AF_INET]213.152.162.86:443
. 2020.01.09 05:27:57 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.86:443, sid=26a468cb 201c01a9
. 2020.01.09 05:27:57 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2020.01.09 05:27:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.01.09 05:27:57 - OpenVPN > VERIFY KU OK
. 2020.01.09 05:27:57 - OpenVPN > Validating certificate extended key usage
. 2020.01.09 05:27:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.01.09 05:27:57 - OpenVPN > VERIFY EKU OK
. 2020.01.09 05:27:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Rukbat, emailAddress=info@airvpn.org
. 2020.01.09 05:27:57 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.01.09 05:27:57 - OpenVPN > [Rukbat] Peer Connection Initiated with [AF_INET]213.152.162.86:443
. 2020.01.09 05:27:58 - OpenVPN > SENT CONTROL [Rukbat]: 'PUSH_REQUEST' (status=1)
. 2020.01.09 05:27:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.98.1,dhcp-option DNS6 fde6:7a:7d20:1862::1,tun-ipv6,route-gateway 10.28.98.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1862::105d/64 fde6:7a:7d20:1862::1,ifconfig 10.28.98.95 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2020.01.09 05:27:58 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.01.09 05:27:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.01.09 05:27:58 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.01.09 05:27:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.01.09 05:27:58 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.01.09 05:27:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.01.09 05:27:58 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.01.09 05:27:58 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.01.09 05:27:58 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.01.09 05:27:58 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.01.09 05:27:58 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.01.09 05:27:58 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.01.09 05:27:58 - OpenVPN > interactive service msg_channel=0
. 2020.01.09 05:27:58 - OpenVPN > ROUTE_GATEWAY 192.168.2.1/255.255.255.0 I=8 HWADDR=00:d8:61:aa:4a:b3
. 2020.01.09 05:27:58 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.01.09 05:27:58 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element nicht gefunden.   (code=1168)
. 2020.01.09 05:27:58 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2020.01.09 05:27:58 - OpenVPN > open_tun
. 2020.01.09 05:27:58 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{A14203D2-D35E-43F3-98D1-55EA82273867}.tap
. 2020.01.09 05:27:58 - OpenVPN > TAP-Windows Driver Version 9.21
. 2020.01.09 05:27:58 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.28.98.0/10.28.98.95/255.255.255.0 [SUCCEEDED]
. 2020.01.09 05:27:58 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.28.98.95/255.255.255.0 on interface {A14203D2-D35E-43F3-98D1-55EA82273867} [DHCP-serv: 10.28.98.254, lease-time: 31536000]
. 2020.01.09 05:27:58 - OpenVPN > Successful ARP Flush on interface [11] {A14203D2-D35E-43F3-98D1-55EA82273867}
. 2020.01.09 05:27:58 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2020.01.09 05:27:59 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=11 fde6:7a:7d20:1862::105d store=active
. 2020.01.09 05:28:00 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:1862::1 validate=no
. 2020.01.09 05:28:00 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1862::/64 -> fde6:7a:7d20:1862::105d metric 0) dev Ethernet 2
. 2020.01.09 05:28:00 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1862::/64 interface=11 fe80::8 store=active
. 2020.01.09 05:28:00 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.01.09 05:28:05 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2020.01.09 05:28:05 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.162.86 MASK 255.255.255.255 192.168.2.1
. 2020.01.09 05:28:05 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2020.01.09 05:28:05 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2020.01.09 05:28:05 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.28.98.1
. 2020.01.09 05:28:05 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.28.98.1
. 2020.01.09 05:28:05 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1862::1 metric -1) dev Ethernet 2
. 2020.01.09 05:28:05 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=11 fe80::8 store=active
. 2020.01.09 05:28:05 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.01.09 05:28:05 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1862::1 metric -1) dev Ethernet 2
. 2020.01.09 05:28:05 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=11 fe80::8 store=active
. 2020.01.09 05:28:05 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1862::1 metric -1) dev Ethernet 2
. 2020.01.09 05:28:05 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=11 fe80::8 store=active
. 2020.01.09 05:28:05 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1862::1 metric -1) dev Ethernet 2
. 2020.01.09 05:28:05 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=11 fe80::8 store=active
. 2020.01.09 05:28:05 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2020.01.09 05:28:05 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2020.01.09 05:28:05 - DNS leak protection with packet filtering enabled.
. 2020.01.09 05:28:05 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.28.98.1)
. 2020.01.09 05:28:05 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:1862::1)
. 2020.01.09 05:28:05 - Routes, added a new route, 213.152.162.84 for gateway 10.28.98.1
. 2020.01.09 05:28:05 - Routes, added a new route, 2a00:1678:2470:3a:ec14:6a76:7ec2:c48b for gateway fde6:7a:7d20:1862::1
. 2020.01.09 05:28:05 - Flushing DNS
I 2020.01.09 05:28:08 - Checking route IPv4
I 2020.01.09 05:28:08 - Checking route IPv6
I 2020.01.09 05:28:12 - Checking DNS
! 2020.01.09 05:28:23 - Connected.
. 2020.01.09 05:28:23 - OpenVPN > Initialization Sequence Completed
Edited ... by giganerd
Apply LOG formatting to logs
At next Test, Eddie hangs again on Checking xyz, in this Time i visit https://ipleak.net/ and see not my Real IP, i see AirVPN´s IP, thats ok, i was thinking it could be a Leak between Network Lock and a Complete Connection. Ok, i think my Problem is solved.
