Not connected, Your IP: 216.73.216.85
traver02
Eddie stable repeatedly saying OpenVPN was not found
never happened in the past
OpenVPN not found
removed and reinstalled the client. no way
LAN cable
any idea?????
my log
Eddie System/Environment Report - 06/01/2020 18:23 UTC
Eddie version: 2.16.3
Eddie OS build: windows_x64
Eddie architecture: x64
OS type: Windows
OS name: Windows 10 Pro
OS version: Microsoft Windows NT 10.0.16299.0
OS architecture: x64
Mono /.Net Framework: v4.0.30319
OpenVPN driver: TAP-Windows Adapter V9, version 9.21.2
OpenVPN:  ()
SSH:
plink 0.70
Build platform: 64-bit Windows
Compiler: clang 5.0.0 (http://llvm.org/git/clang.git dba970f4d143480b964f77b363ec23f22cea0390) (http://llvm.org/git/llvm.git 52ebe03cb0a728134e66d04f85281bc5a60d7091), emulating Visual Studio 2013 / MSVC++ 12.0 (_MSC_VER=1800)
Source commit: 3cd10509a51edf5a21cdc80aabf7e6a934522d47 (C:\Program Files\PuTTY\\plink.exe)
SSL:  ()
curl: 7.54.1 (C:\Program Files\AirVPN\curl.exe)
Profile path: C:\Users\luca_z170\AppData\Local\AirVPN\default.xml
Data path: C:\Users\luca_z170\AppData\Local\AirVPN
Application path: C:\Program Files\AirVPN
Executable path: C:\Program Files\AirVPN\Eddie-UI.exe
Command line arguments: (1 args) path="home"
Network Lock Active: No
Connected to VPN: No
Detected DNS: 192.168.1.254
Test DNS IPv4: Ok
Test DNS IPv6: Failed
Test Ping IPv4: 2 ms
Test Ping IPv6: -1 ms
Test HTTP IPv4: Ok
Test HTTP IPv6: Error:curl: (6) Could not resolve host: ipv6.eddie.website
Test HTTPS:
Error:curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: https://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a "bundle"
 of Certificate Authority (CA) public keys (CA certs). If the default
 bundle file isn't adequate, you can specify an alternate file
 using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
 the bundle, the certificate verification probably failed due to a
 problem with the certificate (it might be expired, or the name might
 not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
 the -k (or --insecure) option.
HTTPS-proxy has similar options --proxy-cacert and --proxy-insecure.
login: (omissis)
password: (omissis)
remember: True
servers.whitelist: ddca2f921f1266f076f5352a659ffdb990994463fe0fd871e6a4c268253af298
servers.blacklist: 95d9a07645e79b70f9b7292b4252784a8b12723c3b916cd11721983a214efa76
areas.whitelist: de
gui.tray_minimized: False
Logs:
. 2020.01.06 19:19:41 - Eddie version: 2.16.3 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.16299.0, Mono/.Net: v4.0.30319
. 2020.01.06 19:19:41 - Reading options from C:\Users\luca_z170\AppData\Local\AirVPN\default.xml
. 2020.01.06 19:19:41 - Command line arguments (1): path="home"
. 2020.01.06 19:19:41 - Profile path: C:\Users\luca_z170\AppData\Local\AirVPN\default.xml
. 2020.01.06 19:19:43 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
E 2020.01.06 19:19:43 - OpenVPN - Not available
. 2020.01.06 19:19:43 - SSH - Version: plink 0.70
. 2020.01.06 19:19:43 -     Build platform: 64-bit Windows
. 2020.01.06 19:19:43 -     Compiler: clang 5.0.0 (http://llvm.org/git/clang.git dba970f4d143480b964f77b363ec23f22cea0390) (http://llvm.org/git/llvm.git 52ebe03cb0a728134e66d04f85281bc5a60d7091), emulating Visual Studio 2013 / MSVC++ 12.0 (_MSC_VER=1800)
. 2020.01.06 19:19:43 -     Source commit: 3cd10509a51edf5a21cdc80aabf7e6a934522d47 (C:\Program Files\PuTTY\\plink.exe)
W 2020.01.06 19:19:43 - SSL - Not available
. 2020.01.06 19:19:43 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe)
W 2020.01.06 19:19:43 - Certification Authorities - Not available
W 2020.01.06 19:19:43 - Recovery. Unexpected crash?
. 2020.01.06 19:19:43 - Routes, remove 213.152.161.117 for gateway 10.5.218.1 failed: Impossibile eliminare la route: Impossibile trovare elemento
. 2020.01.06 19:19:43 - Routes, remove 178.162.204.238 for gateway 10.22.222.1 failed: Impossibile eliminare la route: Impossibile trovare elemento
. 2020.01.06 19:19:43 - Updating systems & servers data ...
I 2020.01.06 19:19:43 - Ready
. 2020.01.06 19:19:44 - Systems & servers data update completed
I 2020.01.06 19:19:45 - Session starting.
F 2020.01.06 19:19:45 - OpenVPN Not found
F 2020.01.06 19:20:00 - OpenVPN Not found
F 2020.01.06 19:22:05 - OpenVPN Not found
Network Interfaces and Routes:
    "support_ipv4": true,
    "support_ipv6": true,
    "routes": [
            "address": "0.0.0.0\/0",
            "interface": "{45BEB98F-3966-4B92-93C7-1B2F4BDE30DA}",
            "gateway": "192.168.1.254",
            "metric": "25"
            "address": "127.0.0.0\/8",
            "interface": "{FFAA0AEF-B569-11E7-A310-806E6F6E6963}",
            "gateway": "link",
            "metric": "331"
            "address": "127.0.0.1",
            "gateway": "link",
            "metric": "331"
            "address": "127.255.255.255",
            "gateway": "link",
            "metric": "331"
            "address": "192.168.1.0\/24",
            "gateway": "link",
            "metric": "281"
            "address": "192.168.1.100",
            "gateway": "link",
            "metric": "281"
            "address": "192.168.1.255",
            "gateway": "link",
            "metric": "281"
            "address": "224.0.0.0\/4",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "address": "255.255.255.255",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "address": "::1",
            "gateway": "link",
            "metric": "331"
            "address": "fe80::\/64",
            "gateway": "link",
            "metric": "281"
            "interface": "{C37C5D5D-7B11-4428-B13C-21DC1701730E}",
            "gateway": "link",
            "metric": "331"
            "address": "fe80::1059:3415:3f57:fe9b",
            "gateway": "link",
            "metric": "331"
            "address": "fe80::8842:791e:7dac:a68e",
            "gateway": "link",
            "metric": "281"
            "address": "ff00::\/8",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "331"
    "interfaces": [
            "friendly": "Ethernet",
            "id": "{45BEB98F-3966-4B92-93C7-1B2F4BDE30DA}",
            "name": "Ethernet",
            "description": "Intel(R) Ethernet Connection (2) I219-V",
            "type": "Ethernet",
            "status": "Up",
            "bytes_received": "29089258",
            "bytes_sent": "2920735",
            "ips": [
                "192.168.1.100"
            "gateways": [
                "192.168.1.254"
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Ethernet 2",
            "id": "{214F2A6F-BF26-403D-9A09-A66FBD0E2504}",
            "name": "Ethernet 2",
            "description": "TAP-Windows Adapter V9",
            "type": "Ethernet",
            "status": "Down",
            "bytes_received": "0",
            "bytes_sent": "0",
            "ips": [
                "fe80::c08f:bf0d:2015:4e97",
                "169.254.78.151"
            "gateways": [],
            "bind": true,
            "dns4": "10.4.0.1",
            "dns6": null
            "friendly": "Loopback Pseudo-Interface 1",
            "id": "{FFAA0AEF-B569-11E7-A310-806E6F6E6963}",
            "name": "Loopback Pseudo-Interface 1",
            "description": "Software Loopback Interface 1",
            "type": "Loopback",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Connessione alla rete locale (LAN)* 2",
            "id": "{C37C5D5D-7B11-4428-B13C-21DC1701730E}",
            "name": "Connessione alla rete locale (LAN)* 2",
            "description": "Microsoft Teredo Tunneling Adapter",
            "type": "Tunnel",
            "status": "Up",
            "bytes_received": "456",
            "bytes_sent": "3688",
            "support_ipv4": false,
            "ips": [
            "gateways": [],
            "bind": true,
            "dns4": null,
            "dns6": null
    "ipv4-default-gateway": "192.168.1.254",
    "ipv4-default-interface": "{45BEB98F-3966-4B92-93C7-1B2F4BDE30DA}"
ipconfig /all:
Configurazione IP di Windows
   Nome host . . . . . . . . . . . . . . : DESKTOP-PRSLRFF
   Suffisso DNS primario . . . . . . . . :
   Tipo nodo . . . . . . . . . . . . . . : Ibrido
   Routing IP abilitato . . . . . . . .  : S
   Proxy WINS abilitato . . . . . . . .  : No
   Elenco di ricerca suffissi DNS. . . . : lan
Scheda Ethernet Ethernet:
   Suffisso DNS specifico per connessione: lan
   Descrizione . . . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I219-V
   Indirizzo fisico. . . . . . . . . . . : 70-4D-7B-2C-01-A2
   DHCP abilitato. . . . . . . . . . . . : S
   Configurazione automatica abilitata   : S
   Indirizzo IPv6 locale rispetto al collegamento . : fe80::8842:791e:7dac:a68e%6(Preferenziale)
   Indirizzo IPv4. . . . . . . . . . . . : 192.168.1.100(Preferenziale)
   Subnet mask . . . . . . . . . . . . . : 255.255.255.0
   Lease ottenuto. . . . . . . . . . . . : luned 6 gennaio 2020 19:09:01
   Scadenza lease . . . . . . . . . . .  : marted 7 gennaio 2020 07:11:00
   Gateway predefinito . . . . . . . . . : 192.168.1.254
   Server DHCP . . . . . . . . . . . . . : 192.168.1.254
   IAID DHCPv6 . . . . . . . . . . . : 208686459
   DUID Client DHCPv6. . . . . . . . : 00-01-00-01-20-29-77-86-70-4D-7B-2C-01-A2
   Server DNS . . . . . . . . . . . . .  : 192.168.1.254
   NetBIOS su TCP/IP . . . . . . . . . . : Attivato
Scheda Ethernet Ethernet 2:
   Stato supporto. . . . . . . . . . . . : Supporto disconnesso
   Descrizione . . . . . . . . . . . . . : TAP-Windows Adapter V9
   Indirizzo fisico. . . . . . . . . . . : 00-FF-21-4F-2A-6F
Scheda Tunnel Connessione alla rete locale (LAN)* 2:
   Descrizione . . . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
   Indirizzo fisico. . . . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP abilitato. . . . . . . . . . . . : No
   Indirizzo IPv6 locale rispetto al collegamento . : fe80::1059:3415:3f57:fe9b%12(Preferenziale)
   IAID DHCPv6 . . . . . . . . . . . : 201326592
   NetBIOS su TCP/IP . . . . . . . . . . : Disattivato
Edited ... by giganerd
LOG formatting
I split your reply into a new topic as the previous one was not yours.
Apart from the curl HTTPS error, try to disable IPv6 in Eddie settings > Network > Layer IPv6 set to Block.
@pi22a Please open your own thread and give as much info as you can.
