74ccxw8as
Help with my connection chain
Tell me, I have been using airvpn for a long time and I like it.
I have such a task: what would it be on the final VPS in which case it was absolutely impossible to calculate me and where I am connecting from. I adhere to many security measures and of course I do not use my accounts on servers, etc. I am currently using the following connection scheme:
MY PC (win 10) [direct ip] ==> VPS (rent on real data) [tor + airvpn] ==> WORK VPS (rent on fictional data, paid through anonymous wallets purchased) [tor + vpn]
P.S: airvpn purchased anonymously using tor + dash + on both servers is NetworkLock.
Can you please tell me where the weaknesses are here.
In general, I want to use the new improved connection scheme:
On my PC via Kodachi installed on usb [I do NOT use home WIFI, but wifi people who are 500 m + from me] + [my modded VPN + tor + air] ==> tails or whonix VPS [tor + air] ==> WORKING VPS [tor + air vpn]
Tell me the weaknesses that need to be improved so that my actions are completely anonymous, confidential and safe.
In bold:
What I learned is that Microsoft knows every single installation of Windows which accesses Windows Update. You don't get updates without offering some unique IDs.
Possible legal red flags are:
Do they know that you do?
Are they aware of the fact that every move of yours might be linked to them? If you live in a repressive country, are you additionally ready to accept their demise if things go south?
And is 500m not too much of a range for simple 802.11x networks? We have that thing in Germany where the strength of the signal must not exceed a certain value. So if your private network can be used from 500m away in populous areas, you're quite certainly in illegal territory.
Don't be overzealous about all these things. Everyone leaves traces in the digital age. Someone who does everything to not do that is even more suspicious. :)
