Thrilling
ANSWERED OpenVPN > write UDPv6: Unknown error (code=10051)
Hi there,
I updated Windows today. Afetwards i couldn't connect to servers anymore. I noticed that error message in my logs. Already tried uninstalling Eddie and installing the current version
Please help
Eddie System/Environment Report - 30/10/2019 20:51 UTC
Eddie version: 2.16.3
Eddie OS build: windows_x64
Eddie architecture: x64
OS type: Windows
OS name: Windows 10 Home
OS version: Microsoft Windows NT 10.0.18362.0
OS architecture: x64
Mono /.Net Framework: v4.0.30319
OpenVPN driver: TAP-Windows Adapter V9, version 9.21.2
OpenVPN: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (C:\NICHT WINDOWS\zzzProgramme\AirVPN\openvpn.exe)
SSH: plink 0.67 (C:\NICHT WINDOWS\zzzProgramme\AirVPN\plink.exe)
SSL: stunnel 5.40 (C:\NICHT WINDOWS\zzzProgramme\AirVPN\stunnel.exe)
curl: 7.54.1 (C:\NICHT WINDOWS\zzzProgramme\AirVPN\curl.exe)
Profile path: C:\NICHT WINDOWS\zzzProgramme\AirVPN\default.xml
Data path: C:\NICHT WINDOWS\zzzProgramme\AirVPN
Application path: C:\NICHT WINDOWS\zzzProgramme\AirVPN
Executable path: C:\NICHT WINDOWS\zzzProgramme\AirVPN\Eddie-UI.exe
Command line arguments: (0 args)
Network Lock Active: Yes, Windows Filtering Platform
Connected to VPN: No
Detected DNS: 192.168.178.1
Test DNS IPv4: Ok
Test DNS IPv6: Failed
Test Ping IPv4: 29 ms
Test Ping IPv6: -1 ms
Test HTTP IPv4: Ok
Test HTTP IPv6: Error:curl: (6) Could not resolve host: ipv6.eddie.website
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
connect: True
netlock: True
network.entry.iplayer: ipv6-ipv4
gui.tray_minimized: False
gui.notifications: False
Logs:
. 2019.10.30 21:51:08 - Eddie version: 2.16.3 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.18362.0, Mono/.Net: v4.0.30319
. 2019.10.30 21:51:08 - Reading options from C:\NICHT WINDOWS\zzzProgramme\AirVPN\default.xml
. 2019.10.30 21:51:08 - Command line arguments (0):
. 2019.10.30 21:51:08 - Profile path: C:\NICHT WINDOWS\zzzProgramme\AirVPN\default.xml
. 2019.10.30 21:51:09 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
. 2019.10.30 21:51:09 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (C:\NICHT WINDOWS\zzzProgramme\AirVPN\openvpn.exe)
. 2019.10.30 21:51:09 - SSH - Version: plink 0.67 (C:\NICHT WINDOWS\zzzProgramme\AirVPN\plink.exe)
. 2019.10.30 21:51:09 - SSL - Version: stunnel 5.40 (C:\NICHT WINDOWS\zzzProgramme\AirVPN\stunnel.exe)
. 2019.10.30 21:51:09 - curl - Version: 7.54.1 (C:\NICHT WINDOWS\zzzProgramme\AirVPN\curl.exe)
. 2019.10.30 21:51:09 - Certification Authorities: C:\NICHT WINDOWS\zzzProgramme\AirVPN\res\cacert.pem
W 2019.10.30 21:51:10 - Recovery. Unexpected crash?
. 2019.10.30 21:51:10 - Routes, remove 213.152.162.109 for gateway 10.19.196.1 failed: The route deletion failed: Element not found
. 2019.10.30 21:51:10 - Routes, remove 213.152.162.89 for gateway 10.24.68.1 failed: The route deletion failed: Element not found
. 2019.10.30 21:51:10 - Routes, remove 213.152.162.74 for gateway 10.17.68.1 failed: The route deletion failed: Element not found
. 2019.10.30 21:51:10 - Routes, remove 213.152.162.79 for gateway 10.7.136.1 failed: The route deletion failed: Element not found
. 2019.10.30 21:51:10 - Routes, remove 109.202.107.5 for gateway 10.7.72.1 failed: The route deletion failed: Element not found
. 2019.10.30 21:51:10 - Routes, remove 213.152.162.89 for gateway 10.24.80.1 failed: The route deletion failed: Element not found
. 2019.10.30 21:51:10 - Routes, remove 213.152.162.165 for gateway 10.8.240.1 failed: The route deletion failed: Element not found
. 2019.10.30 21:51:10 - Routes, remove 213.152.161.74 for gateway 10.30.144.1 failed: The route deletion failed: Element not found
. 2019.10.30 21:51:10 - Routes, remove 213.152.162.10 for gateway 10.19.128.1 failed: The route deletion failed: Element not found
. 2019.10.30 21:51:10 - Routes, remove 213.152.162.94 for gateway 10.17.192.1 failed: The route deletion failed: Element not found
. 2019.10.30 21:51:10 - Above log line repeated 1 times more
. 2019.10.30 21:51:10 - Routes, remove 213.152.162.114 for gateway 10.30.32.1 failed: The route deletion failed: Element not found
. 2019.10.30 21:51:10 - Routes, remove 213.152.162.79 for gateway 10.7.140.1 failed: The route deletion failed: Element not found
. 2019.10.30 21:51:11 - Routes, remove 213.152.161.165 for gateway 10.15.204.1 failed: The route deletion failed: Element not found
. 2019.10.30 21:51:11 - Routes, remove 213.152.161.30 for gateway 10.22.48.1 failed: The route deletion failed: Element not found
. 2019.10.30 21:51:11 - Routes, remove 109.202.107.10 for gateway 10.7.48.1 failed: The route deletion failed: Element not found
. 2019.10.30 21:51:11 - Routes, remove 213.152.161.138 for gateway 10.31.16.1 failed: The route deletion failed: Element not found
. 2019.10.30 21:51:11 - Routes, remove 194.187.251.163 for gateway 10.15.176.1 failed: The route deletion failed: Element not found
! 2019.10.30 21:51:11 - Activation of Network Lock - Windows Filtering Platform
. 2019.10.30 21:51:11 - Updating systems & servers data ...
I 2019.10.30 21:51:11 - Session starting.
. 2019.10.30 21:51:11 - Systems & servers data update completed
I 2019.10.30 21:51:18 - Checking authorization ...
! 2019.10.30 21:51:19 - Connecting to Muscida (Netherlands, Alblasserdam)
. 2019.10.30 21:51:19 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.10.30 21:51:19 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.10.30 21:51:19 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.10.30 21:51:19 - Connection to OpenVPN Management Interface
. 2019.10.30 21:51:19 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.10.30 21:51:19 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.10.30 21:51:19 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.10.30 21:51:19 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.10.30 21:51:19 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.10.30 21:51:19 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET6]2a00:1678:2470:5:c3f2:a35b:10ce:5e53:443
. 2019.10.30 21:51:19 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.10.30 21:51:19 - OpenVPN > UDPv6 link local: (not bound)
. 2019.10.30 21:51:19 - OpenVPN > UDPv6 link remote: [AF_INET6]2a00:1678:2470:5:c3f2:a35b:10ce:5e53:443
. 2019.10.30 21:51:19 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.10.30 21:51:22 - OpenVPN > write UDPv6: Unknown error (code=10051)
Network Interfaces and Routes:
    "support_ipv4": true,
    "support_ipv6": true,
    "routes": [
            "address": "0.0.0.0\/0",
            "interface": "{E59E7DC1-3542-4179-9F54-389D5E35B703}",
            "gateway": "192.168.178.1",
            "metric": "35"
            "address": "127.0.0.0\/8",
            "interface": "{BBF65BF5-7A3A-11E8-B28A-806E6F6E6963}",
            "gateway": "link",
            "metric": "331"
            "address": "127.0.0.1",
            "gateway": "link",
            "metric": "331"
            "address": "127.255.255.255",
            "gateway": "link",
            "metric": "331"
            "address": "192.168.178.0\/24",
            "gateway": "link",
            "metric": "291"
            "address": "192.168.178.24",
            "gateway": "link",
            "metric": "291"
            "address": "192.168.178.255",
            "gateway": "link",
            "metric": "291"
            "address": "224.0.0.0\/4",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "291"
            "address": "255.255.255.255",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "291"
            "address": "::1",
            "gateway": "link",
            "metric": "331"
            "address": "fe80::\/64",
            "gateway": "link",
            "metric": "291"
            "address": "fe80::4c1d:2994:be6d:7bea",
            "gateway": "link",
            "metric": "291"
            "address": "ff00::\/8",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "291"
            "address": "2a0d:5600:24:55:fd29:bb91:4da5:f922",
            "gateway": "fde6:7a:7d20:d18::1",
            "metric": "4294967295"
            "address": "2a00:1678:2470:6:6f0d:8828:9fc4:bbdd",
            "gateway": "fde6:7a:7d20:1b10::1",
    "interfaces": [
            "friendly": "Ethernet",
            "id": "{E59E7DC1-3542-4179-9F54-389D5E35B703}",
            "name": "Ethernet",
            "description": "Realtek PCIe GBE Family Controller",
            "type": "Ethernet",
            "status": "Up",
            "bytes_received": "1837409527",
            "bytes_sent": "37887796",
            "ips": [
                "192.168.178.24"
            "gateways": [
                "192.168.178.1"
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Ethernet 2",
            "id": "{7FDBDECB-98DE-4964-A9DD-C70E616AA3E3}",
            "name": "Ethernet 2",
            "description": "TAP-Windows Adapter V9",
            "type": "Ethernet",
            "status": "Down",
            "bytes_received": "0",
            "bytes_sent": "0",
            "ips": [
                "fe80::a970:a76f:9f65:f6a2",
                "169.254.246.162"
            "gateways": [],
            "bind": true,
            "dns4": "10.31.16.1",
            "dns6": null
            "friendly": "Loopback Pseudo-Interface 1",
            "id": "{BBF65BF5-7A3A-11E8-B28A-806E6F6E6963}",
            "name": "Loopback Pseudo-Interface 1",
            "description": "Software Loopback Interface 1",
            "type": "Loopback",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
    "ipv4-default-gateway": "192.168.178.1",
    "ipv4-default-interface": "{E59E7DC1-3542-4179-9F54-389D5E35B703}"
ipconfig /all:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : DESKTOP-RQM0GS7
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : fritz.box
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . : fritz.box
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . : 30-9C-23-24-9E-F4
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::4c1d:2994:be6d:7bea%15(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.178.24(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Wednesday, 30 October 2019 21:15:12
   Lease Expires . . . . . . . . . . : Saturday, 9 November 2019 21:15:13
   Default Gateway . . . . . . . . . : 192.168.178.1
   DHCP Server . . . . . . . . . . . : 192.168.178.1
   DHCPv6 IAID . . . . . . . . . . . : 103848995
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-22-C5-86-B1-30-9C-23-24-9E-F4
   DNS Servers . . . . . . . . . . . : 192.168.178.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Ethernet 2:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : TAP-Windows Adapter V9
   Physical Address. . . . . . . . . : 00-FF-7F-DB-DE-CB
the airvpn support team helped me out (in a matter of minutes after creating the ticket!). changing network settings to "IPv4, IPv6" solved the problem
