Not connected, Your IP: 216.73.216.169
dumbo9696
Connection failing
I have never had any issues with my connection until today. I would be a newbie in VPN speak,, But I just notice when the VPN tries to check route . It send a sigterm command to kill the connection.. I have full subs and maybe someone can help identify the issue in my logs? I am sorry if this is in the incorrect location to post this in advance..
Any help would be great..
I 2019.10.19 08:08:22 - AirVPN client version: 2.9.2, System: OSX, Name: 10.10.5, Architecture: x64
. 2019.10.19 08:08:22 - Reading options from /Users/homepc/.airvpn/AirVPN.xml
. 2019.10.19 08:08:22 - Data Path: /Users/homepc/.airvpn
. 2019.10.19 08:08:22 - App Path: /Users/homepc/Downloads/AirVPN.app/Contents/MacOS
. 2019.10.19 08:08:22 - Executable Path: /Users/homepc/Downloads/AirVPN.app/Contents/MacOS/AirVPN
. 2019.10.19 08:08:22 - Command line arguments (0):
. 2019.10.19 08:08:22 - Operating System: Unix 14.5.0.0 - Darwin Homes-Mac-mini 14.5.0 Darwin Kernel Version 14.5.0: Sun Jun  4 21:40:08 PDT 2017; root:xnu-2782.70.3~1/RELEASE_X86_64 x86_64
. 2019.10.19 08:08:22 - Updating systems & servers data ...
I 2019.10.19 08:08:23 - OpenVPN Driver - Expected
I 2019.10.19 08:08:23 - OpenVPN - Version: OpenVPN 2.3.6 (/Users/homepc/Downloads/AirVPN.app/Contents/MacOS/openvpn)
I 2019.10.19 08:08:23 - SSH - Version: OpenSSH_6.2p2, OSSLShim 0.9.8r 8 Dec 2011 (/usr/bin/ssh)
I 2019.10.19 08:08:23 - SSL - Version: stunnel 5.09 (/Users/homepc/Downloads/AirVPN.app/Contents/MacOS/stunnel)
I 2019.10.19 08:08:23 - Session starting.
I 2019.10.19 08:08:23 - IPv6 disabled on network adapter (Bluetooth DUN)
I 2019.10.19 08:08:23 - IPv6 disabled on network adapter (Ethernet)
I 2019.10.19 08:08:23 - IPv6 disabled on network adapter (Wi-Fi)
I 2019.10.19 08:08:23 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.10.19 08:08:23 - Systems & servers data update completed
I 2019.10.19 08:08:23 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2019.10.19 08:08:31 - Checking authorization ...
! 2019.10.19 08:08:31 - Connecting to Alpheratz (Netherlands, Alblasserdam)
. 2019.10.19 08:08:31 - OpenVPN > OpenVPN 2.3.6 x86_64-apple-darwin14.0.0 [SSL (OpenSSL)] [LZO] [MH] [IPv6] built on Jan 12 2015
. 2019.10.19 08:08:31 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2019.10.19 08:08:31 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.10.19 08:08:31 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2019.10.19 08:08:31 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2019.10.19 08:08:31 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2019.10.19 08:08:31 - OpenVPN > Socket Buffers: R=[196724->65536] S=[9216->65536]
. 2019.10.19 08:08:31 - OpenVPN > UDPv4 link local: [undef]
. 2019.10.19 08:08:31 - OpenVPN > UDPv4 link remote: [AF_INET]134.19.179.242:443
. 2019.10.19 08:08:31 - OpenVPN > TLS: Initial packet from [AF_INET]134.19.179.242:443, sid=6a004914 19ba2336
. 2019.10.19 08:08:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.10.19 08:08:31 - OpenVPN > Validating certificate key usage
. 2019.10.19 08:08:31 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2019.10.19 08:08:31 - OpenVPN > VERIFY KU OK
. 2019.10.19 08:08:31 - OpenVPN > Validating certificate extended key usage
. 2019.10.19 08:08:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.10.19 08:08:31 - OpenVPN > VERIFY EKU OK
. 2019.10.19 08:08:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alpheratz, emailAddress=info@airvpn.org
. 2019.10.19 08:08:32 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2019.10.19 08:08:32 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2019.10.19 08:08:32 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2019.10.19 08:08:32 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2019.10.19 08:08:32 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2019.10.19 08:08:32 - OpenVPN > [Alpheratz] Peer Connection Initiated with [AF_INET]134.19.179.242:443
. 2019.10.19 08:08:34 - OpenVPN > SENT CONTROL [Alpheratz]: 'PUSH_REQUEST' (status=1)
. 2019.10.19 08:08:34 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.32.196.1,route-gateway 10.32.196.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.32.196.187 255.255.255.0,peer-id 21'
. 2019.10.19 08:08:34 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.10.19 08:08:34 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2019.10.19 08:08:34 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.10.19 08:08:34 - OpenVPN > OPTIONS IMPORT: route options modified
. 2019.10.19 08:08:34 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.10.19 08:08:34 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.10.19 08:08:34 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.10.19 08:08:34 - OpenVPN > Opened utun device utun0
. 2019.10.19 08:08:34 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2019.10.19 08:08:34 - OpenVPN > /sbin/ifconfig utun0 delete
. 2019.10.19 08:08:34 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.10.19 08:08:34 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.10.19 08:08:34 - OpenVPN > /sbin/ifconfig utun0 10.32.196.187 10.32.196.187 netmask 255.255.255.0 mtu 1500 up
. 2019.10.19 08:08:34 - OpenVPN > /sbin/route add -net 10.32.196.0 10.32.196.187 255.255.255.0
. 2019.10.19 08:08:34 - OpenVPN > add net 10.32.196.0: gateway 10.32.196.187
. 2019.10.19 08:08:34 - OpenVPN > /sbin/route add -net 134.19.179.242 192.168.1.1 255.255.255.255
. 2019.10.19 08:08:34 - OpenVPN > add net 134.19.179.242: gateway 192.168.1.1
. 2019.10.19 08:08:34 - OpenVPN > /sbin/route add -net 0.0.0.0 10.32.196.1 128.0.0.0
. 2019.10.19 08:08:34 - OpenVPN > add net 0.0.0.0: gateway 10.32.196.1
. 2019.10.19 08:08:34 - OpenVPN > /sbin/route add -net 128.0.0.0 10.32.196.1 128.0.0.0
. 2019.10.19 08:08:34 - OpenVPN > add net 128.0.0.0: gateway 10.32.196.1
. 2019.10.19 08:08:34 - Starting Management Interface
. 2019.10.19 08:08:34 - OpenVPN > Initialization Sequence Completed
I 2019.10.19 08:08:34 - DNS of a network adapter forced (Bluetooth DUN)
I 2019.10.19 08:08:34 - DNS of a network adapter forced (Ethernet)
I 2019.10.19 08:08:34 - DNS of a network adapter forced (Wi-Fi)
I 2019.10.19 08:08:34 - DNS of a network adapter forced (Bluetooth PAN)
I 2019.10.19 08:08:34 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2019.10.19 08:08:34 - Flushing DNS
I 2019.10.19 08:08:35 - Checking route
W 2019.10.19 08:09:05 - The request timed out
! 2019.10.19 08:09:05 - Disconnecting
. 2019.10.19 08:09:05 - Management - Send 'signal SIGTERM'
. 2019.10.19 08:09:05 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.10.19 08:09:05 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2019.10.19 08:09:05 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2019.10.19 08:09:05 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.10.19 08:09:09 - OpenVPN > TLS: new session incoming connection from [AF_INET]134.19.179.242:443
. 2019.10.19 08:09:10 - OpenVPN > /sbin/route delete -net 134.19.179.242 192.168.1.1 255.255.255.255
. 2019.10.19 08:09:10 - OpenVPN > delete net 134.19.179.242: gateway 192.168.1.1
. 2019.10.19 08:09:11 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.32.196.1 128.0.0.0
. 2019.10.19 08:09:11 - OpenVPN > delete net 0.0.0.0: gateway 10.32.196.1
. 2019.10.19 08:09:11 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.32.196.1 128.0.0.0
. 2019.10.19 08:09:11 - OpenVPN > delete net 128.0.0.0: gateway 10.32.196.1
. 2019.10.19 08:09:11 - OpenVPN > Closing TUN/TAP interface
. 2019.10.19 08:09:11 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.10.19 08:09:11 - Connection terminated.
I 2019.10.19 08:09:11 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2019.10.19 08:09:11 - DNS of a network adapter restored to original settings (Ethernet)
I 2019.10.19 08:09:11 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2019.10.19 08:09:11 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2019.10.19 08:09:11 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2019.10.19 08:09:14 - Checking authorization ...
! 2019.10.19 08:09:14 - Connecting to Alpheratz (Netherlands, Alblasserdam)
. 2019.10.19 08:09:14 - OpenVPN > OpenVPN 2.3.6 x86_64-apple-darwin14.0.0 [SSL (OpenSSL)] [LZO] [MH] [IPv6] built on Jan 12 2015
. 2019.10.19 08:09:14 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2019.10.19 08:09:14 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.10.19 08:09:14 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2019.10.19 08:09:14 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2019.10.19 08:09:14 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2019.10.19 08:09:14 - OpenVPN > Socket Buffers: R=[196724->65536] S=[9216->65536]
. 2019.10.19 08:09:14 - OpenVPN > UDPv4 link local: [undef]
. 2019.10.19 08:09:14 - OpenVPN > UDPv4 link remote: [AF_INET]134.19.179.242:443
. 2019.10.19 08:09:14 - OpenVPN > TLS: Initial packet from [AF_INET]134.19.179.242:443, sid=47fed691 e207e817
. 2019.10.19 08:09:14 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.10.19 08:09:14 - OpenVPN > Validating certificate key usage
. 2019.10.19 08:09:15 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2019.10.19 08:09:15 - OpenVPN > VERIFY KU OK
. 2019.10.19 08:09:15 - OpenVPN > Validating certificate extended key usage
. 2019.10.19 08:09:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.10.19 08:09:15 - OpenVPN > VERIFY EKU OK
. 2019.10.19 08:09:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alpheratz, emailAddress=info@airvpn.org
. 2019.10.19 08:09:15 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2019.10.19 08:09:15 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2019.10.19 08:09:15 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2019.10.19 08:09:15 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2019.10.19 08:09:15 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2019.10.19 08:09:15 - OpenVPN > [Alpheratz] Peer Connection Initiated with [AF_INET]134.19.179.242:443
. 2019.10.19 08:09:17 - OpenVPN > SENT CONTROL [Alpheratz]: 'PUSH_REQUEST' (status=1)
. 2019.10.19 08:09:17 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.32.196.1,route-gateway 10.32.196.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.32.196.187 255.255.255.0,peer-id 31'
. 2019.10.19 08:09:17 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.10.19 08:09:17 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.10.19 08:09:17 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2019.10.19 08:09:17 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.10.19 08:09:17 - OpenVPN > OPTIONS IMPORT: route options modified
. 2019.10.19 08:09:17 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.10.19 08:09:17 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.10.19 08:09:17 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.10.19 08:09:17 - OpenVPN > Opened utun device utun0
. 2019.10.19 08:09:18 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2019.10.19 08:09:18 - OpenVPN > /sbin/ifconfig utun0 delete
. 2019.10.19 08:09:18 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.10.19 08:09:18 - OpenVPN > /sbin/ifconfig utun0 10.32.196.187 10.32.196.187 netmask 255.255.255.0 mtu 1500 up
. 2019.10.19 08:09:18 - OpenVPN > /sbin/route add -net 10.32.196.0 10.32.196.187 255.255.255.0
. 2019.10.19 08:09:18 - OpenVPN > add net 10.32.196.0: gateway 10.32.196.187
. 2019.10.19 08:09:18 - OpenVPN > /sbin/route add -net 134.19.179.242 192.168.1.1 255.255.255.255
. 2019.10.19 08:09:18 - OpenVPN > add net 134.19.179.242: gateway 192.168.1.1
. 2019.10.19 08:09:18 - OpenVPN > /sbin/route add -net 0.0.0.0 10.32.196.1 128.0.0.0
. 2019.10.19 08:09:18 - OpenVPN > add net 0.0.0.0: gateway 10.32.196.1
. 2019.10.19 08:09:18 - OpenVPN > /sbin/route add -net 128.0.0.0 10.32.196.1 128.0.0.0
. 2019.10.19 08:09:18 - OpenVPN > add net 128.0.0.0: gateway 10.32.196.1
. 2019.10.19 08:09:18 - Starting Management Interface
. 2019.10.19 08:09:18 - OpenVPN > Initialization Sequence Completed
I 2019.10.19 08:09:19 - DNS of a network adapter forced (Bluetooth DUN)
I 2019.10.19 08:09:19 - DNS of a network adapter forced (Ethernet)
I 2019.10.19 08:09:19 - DNS of a network adapter forced (Wi-Fi)
I 2019.10.19 08:09:19 - DNS of a network adapter forced (Bluetooth PAN)
I 2019.10.19 08:09:19 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2019.10.19 08:09:19 - Flushing DNS
I 2019.10.19 08:09:19 - Checking route
W 2019.10.19 08:10:09 - The request timed out
! 2019.10.19 08:10:09 - Disconnecting
. 2019.10.19 08:10:09 - Management - Send 'signal SIGTERM'
. 2019.10.19 08:10:09 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2019.10.19 08:10:09 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.10.19 08:10:09 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.10.19 08:10:14 - OpenVPN > /sbin/route delete -net 134.19.179.242 192.168.1.1 255.255.255.255
. 2019.10.19 08:10:14 - OpenVPN > delete net 134.19.179.242: gateway 192.168.1.1
. 2019.10.19 08:10:14 - Connection terminated.
I 2019.10.19 08:10:14 - DNS of a network adapter restored to original settings (Bluetooth DUN)
. 2019.10.19 08:10:14 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.32.196.1 128.0.0.0
. 2019.10.19 08:10:14 - OpenVPN > delete net 0.0.0.0: gateway 10.32.196.1
I 2019.10.19 08:10:14 - DNS of a network adapter restored to original settings (Ethernet)
. 2019.10.19 08:10:14 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.32.196.1 128.0.0.0
I 2019.10.19 08:10:14 - DNS of a network adapter restored to original settings (Wi-Fi)
. 2019.10.19 08:10:15 - OpenVPN > delete net 128.0.0.0: gateway 10.32.196.1
I 2019.10.19 08:10:15 - DNS of a network adapter restored to original settings (Bluetooth PAN)
. 2019.10.19 08:10:15 - OpenVPN > Closing TUN/TAP interface
I 2019.10.19 08:10:15 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
. 2019.10.19 08:10:15 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
I 2019.10.19 08:10:15 - Cancel requested.
I 2019.10.19 08:10:15 - IPv6 restored on network adapter (Bluetooth DUN)
I 2019.10.19 08:10:15 - IPv6 restored on network adapter (Ethernet)
I 2019.10.19 08:10:15 - IPv6 restored on network adapter (Wi-Fi)
I 2019.10.19 08:10:16 - IPv6 restored on network adapter (Bluetooth PAN)
I 2019.10.19 08:10:16 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2019.10.19 08:10:16 - Session terminated.
@ Flx
I was able to connect using tunnelblick and creating an AirVPN configuration file. Would that confirm your thought on port forward issue?
Great.
Do/Can you see the Connected Server/Session in Profile/Overview?
As said before Im a newbie..sorry. At the minute I have a client and a tunnelblick open.. The client doesn't connected and I sent the log. Do you want the log from the tunnickblick?
14 minutes ago, Flx said:
Great.
 i can see same server in the client and when i try to connect it fails using client ,but works using tunnelblick..
FLX .. It is fixed now I just reinstalled the eddie client  and it works 100% .. (Schoolboy error) . I had the older version. It must of stop working..
Thanks for making the time and helping me.. !!!
Is port forwarding working as well?
not sure- where do i check that?
see log I 2019.10.19 10:50:08 - Session starting.
I 2019.10.19 10:50:08 - Checking authorization ...
! 2019.10.19 10:50:09 - Connecting to Alchiba (Netherlands, Alblasserdam)
. 2019.10.19 10:50:09 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.10.19 10:50:09 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.10.19 10:50:09 - Connection to OpenVPN Management Interface
. 2019.10.19 10:50:09 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.10.19 10:50:09 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.10.19 10:50:09 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.10.19 10:50:09 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.10.19 10:50:09 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.10.19 10:50:09 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.183:443
. 2019.10.19 10:50:09 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2019.10.19 10:50:09 - OpenVPN > UDP link local: (not bound)
. 2019.10.19 10:50:09 - OpenVPN > UDP link remote: [AF_INET]213.152.161.183:443
. 2019.10.19 10:50:09 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.10.19 10:50:09 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.183:443, sid=9912d22d 5e2ff042
. 2019.10.19 10:50:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.10.19 10:50:09 - OpenVPN > VERIFY KU OK
. 2019.10.19 10:50:09 - OpenVPN > Validating certificate extended key usage
. 2019.10.19 10:50:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.10.19 10:50:09 - OpenVPN > VERIFY EKU OK
. 2019.10.19 10:50:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.10.19 10:50:10 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.10.19 10:50:10 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.183:443
. 2019.10.19 10:50:11 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.10.19 10:50:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.5.134.1,dhcp-option DNS6 fde6:7a:7d20:186::1,tun-ipv6,route-gateway 10.5.134.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:186::108e/64 fde6:7a:7d20:186::1,ifconfig 10.5.134.144 255.255.255.0,peer-id 8,cipher AES-256-GCM'
. 2019.10.19 10:50:11 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.10.19 10:50:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.10.19 10:50:11 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.10.19 10:50:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.10.19 10:50:11 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.10.19 10:50:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.10.19 10:50:11 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.10.19 10:50:11 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.10.19 10:50:11 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.10.19 10:50:11 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.10.19 10:50:11 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.10.19 10:50:11 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.10.19 10:50:11 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=ac:87:a3:07:c6:68
. 2019.10.19 10:50:11 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2019.10.19 10:50:11 - OpenVPN > GDG6: problem writing to routing socket
. 2019.10.19 10:50:11 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2019.10.19 10:50:11 - OpenVPN > Opened utun device utun0
. 2019.10.19 10:50:11 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2019.10.19 10:50:11 - OpenVPN > /sbin/ifconfig utun0 delete
. 2019.10.19 10:50:11 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.10.19 10:50:11 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.10.19 10:50:11 - OpenVPN > /sbin/ifconfig utun0 10.5.134.144 10.5.134.144 netmask 255.255.255.0 mtu 1500 up
. 2019.10.19 10:50:11 - OpenVPN > /sbin/route add -net 10.5.134.0 10.5.134.144 255.255.255.0
. 2019.10.19 10:50:11 - OpenVPN > add net 10.5.134.0: gateway 10.5.134.144
. 2019.10.19 10:50:11 - OpenVPN > /sbin/ifconfig utun0 inet6 fde6:7a:7d20:186::108e/64
. 2019.10.19 10:50:11 - OpenVPN > add_route_ipv6(fde6:7a:7d20:186::/64 -> fde6:7a:7d20:186::108e metric 0) dev utun0
. 2019.10.19 10:50:11 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:186:: -prefixlen 64 -iface utun0
. 2019.10.19 10:50:11 - OpenVPN > add net fde6:7a:7d20:186::: gateway utun0: File exists
. 2019.10.19 10:50:11 - OpenVPN > route: writing to routing socket: File exists
. 2019.10.19 10:50:11 - OpenVPN > /sbin/route add -net 213.152.161.183 192.168.1.1 255.255.255.255
. 2019.10.19 10:50:11 - OpenVPN > add net 213.152.161.183: gateway 192.168.1.1
. 2019.10.19 10:50:11 - OpenVPN > /sbin/route add -net 0.0.0.0 10.5.134.1 128.0.0.0
. 2019.10.19 10:50:11 - OpenVPN > add net 0.0.0.0: gateway 10.5.134.1
. 2019.10.19 10:50:11 - OpenVPN > /sbin/route add -net 128.0.0.0 10.5.134.1 128.0.0.0
. 2019.10.19 10:50:11 - OpenVPN > add net 128.0.0.0: gateway 10.5.134.1
. 2019.10.19 10:50:11 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:186::1 metric -1) dev utun0
. 2019.10.19 10:50:11 - OpenVPN > /sbin/route add -inet6 :: -prefixlen 3 -iface utun0
. 2019.10.19 10:50:11 - OpenVPN > add net ::: gateway utun0
. 2019.10.19 10:50:11 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:186::1 metric -1) dev utun0
. 2019.10.19 10:50:11 - OpenVPN > /sbin/route add -inet6 2000:: -prefixlen 4 -iface utun0
. 2019.10.19 10:50:11 - OpenVPN > add net 2000::: gateway utun0
. 2019.10.19 10:50:11 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:186::1 metric -1) dev utun0
. 2019.10.19 10:50:11 - OpenVPN > /sbin/route add -inet6 3000:: -prefixlen 4 -iface utun0
. 2019.10.19 10:50:11 - OpenVPN > add net 3000::: gateway utun0
. 2019.10.19 10:50:11 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:186::1 metric -1) dev utun0
. 2019.10.19 10:50:11 - OpenVPN > /sbin/route add -inet6 fc00:: -prefixlen 7 -iface utun0
. 2019.10.19 10:50:11 - OpenVPN > add net fc00::: gateway utun0
. 2019.10.19 10:50:11 - DNS of a network adapter forced (Bluetooth DUN, from Automatic to 10.5.134.1, fde6:7a:7d20:186::1)
. 2019.10.19 10:50:11 - DNS of a network adapter forced (Ethernet, from Automatic to 10.5.134.1, fde6:7a:7d20:186::1)
. 2019.10.19 10:50:12 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.5.134.1, fde6:7a:7d20:186::1)
. 2019.10.19 10:50:12 - DNS of a network adapter forced (Bluetooth PAN, from Automatic to 10.5.134.1, fde6:7a:7d20:186::1)
. 2019.10.19 10:50:12 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.5.134.1, fde6:7a:7d20:186::1)
. 2019.10.19 10:50:12 - Routes, added a new route, 213.152.161.181 for gateway 10.5.134.1
. 2019.10.19 10:50:12 - Routes, added a new route, 2a00:1678:2470:19:9016:df76:43b5:703e for gateway fde6:7a:7d20:186::1
. 2019.10.19 10:50:12 - Flushing DNS
I 2019.10.19 10:50:12 - Checking route IPv4
I 2019.10.19 10:50:12 - Checking route IPv6
I 2019.10.19 10:50:13 - Checking DNS
! 2019.10.19 10:50:13 - Connected.
. 2019.10.19 10:50:14 - OpenVPN > Initialization Sequence Completed
! 2019.10.19 10:50:18 - Disconnecting
. 2019.10.19 10:50:19 - Routes, removed a route previously added, 213.152.161.181 for gateway 10.5.134.1
. 2019.10.19 10:50:19 - Routes, removed a route previously added, 2a00:1678:2470:19:9016:df76:43b5:703e for gateway fde6:7a:7d20:186::1
. 2019.10.19 10:50:19 - Sending management termination signal
. 2019.10.19 10:50:19 - Management - Send 'signal SIGTERM'
. 2019.10.19 10:50:19 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.10.19 10:50:19 - OpenVPN > SIGTERM received, sending exit notification to peer
