Snowplow 2 Posted ... Ever since I updated to IOS 12, and the issue continues in IOS 13, my connections to Air via OpenVPN Connect have consumed excessive battery when the phone is idle. It works great while I maintain a persistent external connection, like streaming music. Today I looked at a log in the OpenVPN Connect app, and it seems to be perpetually waking the phone back up to connect. Again, this didn't seem to be an issue in IOS 11. I am wondering if there are any options I can configure in my OPVN files generated (as of now they're unmodified) that alters the behavior? I have the following selected: Reconnect On Wakeup=ON Seamless Tunnel=ON VPN Protocol=Adaptive IPv6 = IPV4-ONLY Tunnel Connection Timeout=30 sec Allow Compression=NO Minimum TLS version=Default DNS Fallback=ON Connect Via=Any Network Layer 2 Reachability=ON Quote Share this post Link to post
Snowplow 2 Posted ... 2019-10-01 00:00:56 Connecting to [199.249.230.44]:80 (199.249.230.44) via UDPv4 2019-10-01 00:00:56 EVENT: CONNECTING 2019-10-01 00:00:56 Tunnel Options:V4,dev-type tun,link-mtu 1602,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-256-CBC,auth SHA512,keysize 256,key-method 2,tls-client 2019-10-01 00:00:56 Creds: UsernameEmpty/PasswordEmpty 2019-10-01 00:00:56 Peer Info: IV_GUI_VER=net.openvpn.connect.ios 3.0.2-894 IV_VER=3.2 IV_PLAT=ios IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 IV_AUTO_SESS=1 UV_IPV6=yes IV_HWADDR=<redacted by Snowplow> 2019-10-01 00:00:56 VERIFY OK : depth=1 cert. version : 3 serial number : <redacted by Snowplow> issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true 2019-10-01 00:00:56 VERIFY OK : depth=0 cert. version : 3 serial number : 16 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Chamaeleon, emailAddress=info@airvpn.org issued on : 2016-12-02 16:46:10 expires on : 2026-11-30 16:46:10 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication 2019-10-01 00:00:57 OS Event: SLEEP 2019-10-01 00:00:57 EVENT: PAUSE 2019-10-01 00:00:58 OS Event: WAKEUP 2019-10-01 00:01:01 RESUME TEST: Internet:ReachableViaWiFi/-R t------ 2019-10-01 00:01:01 STANDARD RESUME 2019-10-01 00:01:01 EVENT: RESUME 2019-10-01 00:01:01 EVENT: RECONNECTING 2019-10-01 00:01:01 Contacting [199.249.230.44]:80/UDP via UDP 2019-10-01 00:01:01 EVENT: WAIT 2019-10-01 00:01:01 OS Event: SLEEP 2019-10-01 00:01:01 Connecting to [199.249.230.44]:80 (199.249.230.44) via UDPv4 2019-10-01 00:01:01 EVENT: PAUSE 2019-10-01 00:01:04 OS Event: WAKEUP 2019-10-01 00:01:07 RESUME TEST: Internet:ReachableViaWiFi/-R t------ 2019-10-01 00:01:07 STANDARD RESUME 2019-10-01 00:01:07 EVENT: RESUME 2019-10-01 00:01:07 EVENT: RECONNECTING 2019-10-01 00:01:07 Contacting [199.249.230.44]:80/UDP via UDP 2019-10-01 00:01:07 EVENT: WAIT 2019-10-01 00:01:07 OS Event: SLEEP 2019-10-01 00:01:07 Connecting to [199.249.230.44]:80 (199.249.230.44) via UDPv4 2019-10-01 00:01:07 EVENT: PAUSE 2019-10-01 00:01:07 OS Event: WAKEUP 2019-10-01 00:01:10 RESUME TEST: Internet:ReachableViaWiFi/-R t------ 2019-10-01 00:01:10 STANDARD RESUME 2019-10-01 00:01:10 EVENT: RESUME 2019-10-01 00:01:10 EVENT: RECONNECTING 2019-10-01 00:01:10 Contacting [199.249.230.44]:80/UDP via UDP 2019-10-01 00:01:10 EVENT: WAIT 2019-10-01 00:01:10 Connecting to [199.249.230.44]:80 (199.249.230.44) via UDPv4 2019-10-01 00:01:10 OS Event: SLEEP 2019-10-01 00:01:10 EVENT: PAUSE 2019-10-01 00:01:12 OS Event: WAKEUP 2019-10-01 00:01:15 RESUME TEST: Internet:ReachableViaWiFi/-R t------ 2019-10-01 00:01:15 STANDARD RESUME 2019-10-01 00:01:15 EVENT: RESUME 2019-10-01 00:01:15 EVENT: RECONNECTING 2019-10-01 00:01:15 Contacting [199.249.230.44]:80/UDP via UDP 2019-10-01 00:01:15 EVENT: WAIT 2019-10-01 00:01:15 OS Event: SLEEP 2019-10-01 00:01:15 Connecting to [199.249.230.44]:80 (199.249.230.44) via UDPv4 2019-10-01 00:01:15 EVENT: PAUSE 2019-10-01 00:01:17 OS Event: WAKEUP Quote Share this post Link to post
Snowplow 2 Posted ... From the log above, you can see that every few seconds it repeats this cycle while the phone is locked and hypothetically doing very little. Back to my original question, is there something on the user-side that I can do? Is there a server-side configuration that needs to change? Does it look like a bug in OpenVPN Connect? (I will gladly open a bug report with them, but first wanted to find out if it's something that I/we can fix first). Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... I have the same battery drain when using the personal hotspot. I nailed it down to frequent keepalive packets keeping the phone perpetually active. It's not a bug, it really seems to be a feature. And with that in mind the iPhone isn't really that durable as people believe, it's just effective energy saving. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Snowplow 2 Posted ... 20 hours ago, giganerd said: I have the same battery drain when using the personal hotspot. I nailed it down to frequent keepalive packets keeping the phone perpetually active. It's not a bug, it really seems to be a feature. And with that in mind the iPhone isn't really that durable as people believe, it's just effective energy saving. Thank you for your reply and information. Do you know from where the 'keepalive' packets originate...phone, network, app, etc.? Back on iOS11 I had great battery performance with OpenVPN always on. It clearly got worse when I moved to iOS 12. Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... 1 hour ago, Snowplow said: Do you know from where the 'keepalive' packets originate...phone, network, app, etc.? The keepalives are not the problem. The devices are. Keepalives are actually very important. They are sent to verify that the other side of the link is still active and therefore ensure that the connection is still okay. Especially important for home users with their routers which use Network Address Translation (NAT), as NAT devices usually kill inactive connections pretty fast. Mobile devices utilize some form of energy management to dynamically enable and disable modules as they're needed. And a disabled module doesn't require any energy, therefore it reduces energy consumption. This is especially true for the CPU. On Android for example the CPU can be clocked down into a deep sleep state where the CPU is not active at all, therefore it doesn't consume power. I think it's similar on iOS. Now, the CPU is the heart of any computer. To make a device do anything it must be woken up from that deep sleep everytime. The optimization of the CPU clock to find the right balance between doing something and not consuming energy is at the heart of energy optimization. Those keepalives have a certain predictability because they're timer-based, mostly bound to some widely-used standard, therefore standard time windows. A connection is only reset once a timer runs out. So you can plan ahead a bit and leave the CPU in peace for longer periods of time and send out any keepalives and other packets in one shot when you do wake up the CPU. If you have the hotspot opened, you need to send out beacon packets so that your hotspot is visible. You have to listen to connections, and once someone connects you will need to be up at all times to forward packets to the GSM network (which is 2/3/4/5G). This keeps the CPU online at all times. You can clock it down to the slowest clock rate but it will inevitably be active all the time. That's my battery drain. iOS is not optimized for VPN connections. You can optimize a bit, but you will need to send more packets which are, above all, encrypted and decrypted with a high difficulty AES-256 encryption algorithm which was not made for embedded devices, but for security. It doesn't just keep the CPU alive, it also stresses it more, causing it to sometimes clock a bit faster to keep up. And whatever CPU clocks faster consumes more power. I believe that's your battery drain. On the iOS 11 -> 12 problem I can only assume that Apple changed something somewhere in the OS which makes life difficult from an optimization point of view. No way to say for sure as that platform is closed source, so closed it actually violates open source licenses in the app store. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
mith_y2k 6 Posted ... I use openVPN on ios 12 and now 13 and I haven't seen such issues. Yes of course it uses battery, but it's 5-7% per day. I create and manage profiles from the openvpn app, but tend to turn vpn on and off from the settings menu. Would that make a difference? Quote Share this post Link to post
Snowplow 2 Posted ... Thank you both for your replies. On the side I opened a ticket with OpenVPN. Their analysis as of now is there's an issue with my device (which means 2 devices, really) and they do not see the same behavior on their test devices. My battery drain issue is variable. I have times where the log shows a connection with no subsequent activity for long periods of time, such as 30-60 minutes. At those times, I can periodically use the phone and only consume 1% battery in 1 hr. I also have times where the log shows OS wakeup events every 3 seconds, followed by a reconnect. In those scenarios, to put it in perspective I lost 3% battery in 1hr of the phone just sitting on a desk unused. This suggests that sometimes the device is connecting and keeping the connection active, and other times it's allowing the connection to drop then reconnecting. The frequent wakeup->reconnect events correlate to higher power draw. For now I am stopping my VPN-on-demand usage and manually enabling it at times I am more keen to prevent network operator snooping. However I did not have this issue previously and I have little trust in my network operator, so I am very interested in finding a solution to return to full VPN-on-demand functionality. Since OpenVPN suggests my devices are the issue, and one of them being quite new, I will probably do a test of restoring one of them but not loading from my iTunes backup. Perhaps something in my iTunes backup is causing the issue? I originally noticed this issue immediately after updating to iOS 12 on my older device. Quite literally I would see times that the phone would chew through 7% battery in 3 minutes (and get hot) and give me very poor network performance. Quote Share this post Link to post
