StarFscker
Ubuntu, using OpenVPN, TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Hello, I'm getting TLS handshake failures when trying to connect with OpenVPN. I also cannot connect with the Eddie client. It used to work a couple days ago. Any ideas?
$ openvpn --config AirVPN_America_TCP-443.ovpn
Wed Sep 18 11:29:18 2019 OpenVPN 2.4.4 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on May 14 2019
Wed Sep 18 11:29:18 2019 library versions: OpenSSL 1.1.1  11 Sep 2018, LZO 2.08
Wed Sep 18 11:29:18 2019 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Sep 18 11:29:18 2019 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Sep 18 11:29:20 2019 TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.194:443
Wed Sep 18 11:29:20 2019 Socket Buffers: R=[87380->87380] S=[16384->16384]
Wed Sep 18 11:29:20 2019 Attempting to establish TCP connection with [AF_INET]104.254.90.194:443 [nonblock]
Wed Sep 18 11:29:21 2019 TCP connection established with [AF_INET]104.254.90.194:443
Wed Sep 18 11:29:21 2019 TCP_CLIENT link local: (not bound)
Wed Sep 18 11:29:21 2019 TCP_CLIENT link remote: [AF_INET]104.254.90.194:443
Wed Sep 18 11:30:21 2019 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Sep 18 11:30:21 2019 TLS Error: TLS handshake failed
Wed Sep 18 11:30:21 2019 Fatal TLS error (check_tls_errors_co), restarting
Wed Sep 18 11:30:21 2019 SIGUSR1[soft,tls-error] received, process restarting
Wed Sep 18 11:30:21 2019 Restart pause, 5 second(s)
Wed Sep 18 11:30:26 2019 TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.194:443
Wed Sep 18 11:30:26 2019 Socket Buffers: R=[87380->87380] S=[16384->16384]
Wed Sep 18 11:30:26 2019 Attempting to establish TCP connection with [AF_INET]104.254.90.194:443 [nonblock]
Wed Sep 18 11:30:27 2019 TCP connection established with [AF_INET]104.254.90.194:443
Wed Sep 18 11:30:27 2019 TCP_CLIENT link local: (not bound)
Wed Sep 18 11:30:27 2019 TCP_CLIENT link remote: [AF_INET]104.254.90.194:443
Wed Sep 18 11:31:27 2019 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Sep 18 11:31:27 2019 TLS Error: TLS handshake failed
Wed Sep 18 11:31:27 2019 Fatal TLS error (check_tls_errors_co), restarting
Wed Sep 18 11:31:27 2019 SIGUSR1[soft,tls-error] received, process restarting
Wed Sep 18 11:31:27 2019 Restart pause, 5 second(s)
Wed Sep 18 11:31:32 2019 TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.194:443
Wed Sep 18 11:31:32 2019 Socket Buffers: R=[87380->87380] S=[16384->16384]
Wed Sep 18 11:31:32 2019 Attempting to establish TCP connection with [AF_INET]104.254.90.194:443 [nonblock]
Wed Sep 18 11:31:33 2019 TCP connection established with [AF_INET]104.254.90.194:443
Wed Sep 18 11:31:33 2019 TCP_CLIENT link local: (not bound)
Wed Sep 18 11:31:33 2019 TCP_CLIENT link remote: [AF_INET]104.254.90.194:443
Wed Sep 18 11:32:33 2019 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Sep 18 11:32:33 2019 TLS Error: TLS handshake failed
Wed Sep 18 11:32:33 2019 Fatal TLS error (check_tls_errors_co), restarting
Wed Sep 18 11:32:33 2019 SIGUSR1[soft,tls-error] received, process restarting
Wed Sep 18 11:32:33 2019 Restart pause, 5 second(s)
Wed Sep 18 11:32:38 2019 TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.194:443
Wed Sep 18 11:32:38 2019 Socket Buffers: R=[87380->87380] S=[16384->16384]
Wed Sep 18 11:32:38 2019 Attempting to establish TCP connection with [AF_INET]104.254.90.194:443 [nonblock]
Wed Sep 18 11:32:39 2019 TCP connection established with [AF_INET]104.254.90.194:443
Wed Sep 18 11:32:39 2019 TCP_CLIENT link local: (not bound)
Wed Sep 18 11:32:39 2019 TCP_CLIENT link remote: [AF_INET]104.254.90.194:443
Wed Sep 18 11:33:39 2019 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Sep 18 11:33:39 2019 TLS Error: TLS handshake failed
Wed Sep 18 11:33:39 2019 Fatal TLS error (check_tls_errors_co), restarting
Wed Sep 18 11:33:39 2019 SIGUSR1[soft,tls-error] received, process restarting
Wed Sep 18 11:33:39 2019 Restart pause, 5 second(s)
Wed Sep 18 11:33:44 2019 TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.194:443
Wed Sep 18 11:33:44 2019 Socket Buffers: R=[87380->87380] S=[16384->16384]
Wed Sep 18 11:33:44 2019 Attempting to establish TCP connection with [AF_INET]104.254.90.194:443 [nonblock]
Wed Sep 18 11:33:45 2019 TCP connection established with [AF_INET]104.254.90.194:443
Wed Sep 18 11:33:45 2019 TCP_CLIENT link local: (not bound)
Wed Sep 18 11:33:45 2019 TCP_CLIENT link remote: [AF_INET]104.254.90.194:443
