Not connected, Your IP: 216.73.216.32
SpinGiggles
Can't connect with IPv6, IPv4 has no speed, Network lock disables internet.
Hey all,
    I'm excited to start using AirVPN.  I'm running into a couple of issues.  When I try connecting with IPv6 enabled it gets stuck and never connects.  When I try connecting with just IPv4, it works!  However the download and upload are both 0 bits.  When I try using network lock with the IPv4 connection, it worsens even further by disabling even web browser connection.  I can connect to the web when using only IPv4, but not when network lock is activated.  (I'm activating network lock and then connecting to the VPN)   Is the speed supposed to read only how much is being used currently?   If so that's not a problem.  I still would like to be able to use network lock.   I noticed NordVPN in my network adapters could that interfere?  Log files included.
Edit:  Hey sorry everyone seems to be working now!  Thanks.
Edit2:  Well IPv4, still no dice on IPv6.   Will this be a detriment?
ipv4 network lock.txt ipv4 no lock.txt ipv6 no lock.txt ipv6 lock.txt
Edited ... by SpinGiggles
