justrandomperson
Control Eddie Client via scripts
Hi, I am wondering whether is it possible to control Eddie VPN via commands, signals,etc?
I need only a single feature, to change VPN servers via scripts. Currently I am running it on MacOS, but I also have Linux.
Please suggest what are the ways to change VPN from scripts automatically?
Hi
This feature should arrive with Eddie 3. You could try communicating with the OpenVPN deamon via telnet but I didn't have such good experiences with that.
1 minute ago, airnoob said:
Hi
Thank you for the quick reply, currently I am trying to achieve this using automation scripts. Hope Eddie 3 will be released soon
OK. You don't have to control Eddie. Instead try to "control" the actual VPN channel/connection.
For Windows OS(example):
https://airvpn.org/forums/topic/17440-guide-fix-for-tap-adapter-in-windows/?do=findComment&comment=82338
Follow that(the above link) and make your own script.sh for Linux etc.
Otherwise,
wait for the arrival of Eddie 3.
Good Luck,
Flx
