ethanb79 1 Posted ... (edited) I got AirVPN a couple of days ago and up until now I was extremely satisfied with it. However, today (and also yesterday) my download speeds have been spiking constantly, going from 4 kbit/s to 2 mbit/s and back down to 0, so on and so forth. I seem unable to maintain a constant download speed. I just bought 3 months of AirVPN and this really just seems unacceptable to me but I'm sure it's something wrong on my side. I'm really not great with this kind of stuff (technology more advanced than Google Drive) and would really appreciate some help. I'm hoping to use the VPN for torrenting. I've tried different protocols and none of them seem to fix this issue. I've also applied mssfix and have tried port forwarding as well. My ISP is TDS if that means anything. I also tried changing the buffer sizes but it has no effect. Here are some logs: Eddie System/Environment Report - 9/13/2019 2:06 AM UTC Eddie version: 2.16.3 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Home OS version: Microsoft Windows NT 10.0.18362.0 OS architecture: x64 Mono /.Net Framework: v4.0.30319 OpenVPN driver: TAP-Windows Adapter V9 #2, version 9.21.2 OpenVPN: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe) SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) curl: 7.54.1 (C:\Program Files\AirVPN\curl.exe) Profile path: C:\Users\tropi\AppData\Local\AirVPN\default.xml Data path: C:\Users\tropi\AppData\Local\AirVPN Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (1 args) path="home" Network Lock Active: No Connected to VPN: Yes, Anser Detected DNS: 10.9.90.1, 192.168.0.1, 216.170.153.146, fde6:7a:7d20:55a::1 Test DNS IPv4: Ok Test DNS IPv6: Ok Test Ping IPv4: 257 ms Test Ping IPv6: 253 ms Test HTTP IPv4: Ok Test HTTP IPv6: Ok Test HTTPS: Ok ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True servers.blacklist: 9c6476c8458f559686cd084a78d622e6ae7ccd26d1fbeb8cd50b8c6350146291 mode.protocol: UDP mode.alt: 3 openvpn.custom: mssfix 1442 openvpn.sndbuf: -1 openvpn.rcvbuf: -1 ---------------------------- Logs: . 2019.09.12 20:12:54 - Eddie version: 2.16.3 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.18362.0, Mono/.Net: v4.0.30319 . 2019.09.12 20:12:54 - Reading options from C:\Users\tropi\AppData\Local\AirVPN\default.xml . 2019.09.12 20:12:55 - Command line arguments (1): path="home" . 2019.09.12 20:12:55 - Profile path: C:\Users\tropi\AppData\Local\AirVPN\default.xml . 2019.09.12 20:12:58 - OpenVPN Driver - TAP-Windows Adapter V9 #2, version 9.21.2 . 2019.09.12 20:12:58 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2019.09.12 20:12:58 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe) . 2019.09.12 20:12:58 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) . 2019.09.12 20:12:58 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe) . 2019.09.12 20:12:58 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem . 2019.09.12 20:12:58 - Updating systems & servers data ... I 2019.09.12 20:12:58 - Ready . 2019.09.12 20:12:59 - Systems & servers data update completed I 2019.09.12 20:13:42 - Session starting. I 2019.09.12 20:13:42 - Checking authorization ... ! 2019.09.12 20:13:43 - Connecting to Alwaid (Canada, Toronto, Ontario) . 2019.09.12 20:13:43 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2019.09.12 20:13:43 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2019.09.12 20:13:43 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.09.12 20:13:43 - Connection to OpenVPN Management Interface . 2019.09.12 20:13:43 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.09.12 20:13:43 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.09.12 20:13:43 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.09.12 20:13:43 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.09.12 20:13:43 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.09.12 20:13:43 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.117:1194 . 2019.09.12 20:13:43 - OpenVPN > Socket Buffers: R=[65536->524288] S=[65536->524288] . 2019.09.12 20:13:43 - OpenVPN > Attempting to establish TCP connection with [AF_INET]184.75.221.117:1194 [nonblock] . 2019.09.12 20:13:43 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2019.09.12 20:13:44 - OpenVPN > TCP connection established with [AF_INET]184.75.221.117:1194 . 2019.09.12 20:13:44 - OpenVPN > TCP_CLIENT link local: (not bound) . 2019.09.12 20:13:44 - OpenVPN > TCP_CLIENT link remote: [AF_INET]184.75.221.117:1194 . 2019.09.12 20:13:44 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.117:1194, sid=60f0ff1e 8d313054 . 2019.09.12 20:13:44 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2019.09.12 20:13:44 - OpenVPN > VERIFY KU OK . 2019.09.12 20:13:44 - OpenVPN > Validating certificate extended key usage . 2019.09.12 20:13:44 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2019.09.12 20:13:44 - OpenVPN > VERIFY EKU OK . 2019.09.12 20:13:44 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2019.09.12 20:13:44 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2019.09.12 20:13:44 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.117:1194 . 2019.09.12 20:13:45 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2019.09.12 20:13:45 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.8.155.1,dhcp-option DNS6 fde6:7a:7d20:49b::1,tun-ipv6,route-gateway 10.8.155.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:49b::1034/64 fde6:7a:7d20:49b::1,ifconfig 10.8.155.54 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2019.09.12 20:13:45 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2019.09.12 20:13:45 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2019.09.12 20:13:45 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2019.09.12 20:13:45 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2019.09.12 20:13:45 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2019.09.12 20:13:45 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2019.09.12 20:13:45 - OpenVPN > OPTIONS IMPORT: peer-id set . 2019.09.12 20:13:45 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627 . 2019.09.12 20:13:45 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2019.09.12 20:13:45 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2019.09.12 20:13:45 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.09.12 20:13:45 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.09.12 20:13:45 - OpenVPN > interactive service msg_channel=0 . 2019.09.12 20:13:45 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=10:02:b5:86:59:5c . 2019.09.12 20:13:45 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2019.09.12 20:13:45 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2019.09.12 20:13:45 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2019.09.12 20:13:45 - OpenVPN > open_tun . 2019.09.12 20:13:46 - OpenVPN > TAP-WIN32 device [Ethernet 4] opened: \\.\Global\{EC5D0326-55CA-4233-B026-CDC459606FF8}.tap . 2019.09.12 20:13:46 - OpenVPN > TAP-Windows Driver Version 9.21 . 2019.09.12 20:13:46 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.8.155.0/10.8.155.54/255.255.255.0 [SUCCEEDED] . 2019.09.12 20:13:46 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.8.155.54/255.255.255.0 on interface {EC5D0326-55CA-4233-B026-CDC459606FF8} [DHCP-serv: 10.8.155.254, lease-time: 31536000] . 2019.09.12 20:13:46 - OpenVPN > Successful ARP Flush on interface [23] {EC5D0326-55CA-4233-B026-CDC459606FF8} . 2019.09.12 20:13:46 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2019.09.12 20:13:47 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=23 fde6:7a:7d20:49b::1034 store=active . 2019.09.12 20:13:48 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Ethernet 4 static fde6:7a:7d20:49b::1 validate=no . 2019.09.12 20:13:48 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2019.09.12 20:13:48 - OpenVPN > add_route_ipv6(fde6:7a:7d20:49b::/64 -> fde6:7a:7d20:49b::1034 metric 0) dev Ethernet 4 . 2019.09.12 20:13:48 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:49b::/64 interface=23 fe80::8 store=active . 2019.09.12 20:13:48 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:13:53 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2019.09.12 20:13:53 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.221.117 MASK 255.255.255.255 192.168.0.1 . 2019.09.12 20:13:53 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4 . 2019.09.12 20:13:53 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:13:53 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.8.155.1 . 2019.09.12 20:13:53 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.09.12 20:13:53 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:13:53 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.8.155.1 . 2019.09.12 20:13:53 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.09.12 20:13:53 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:13:53 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:49b::1 metric -1) dev Ethernet 4 . 2019.09.12 20:13:53 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=23 fe80::8 store=active . 2019.09.12 20:13:53 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:13:53 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:49b::1 metric -1) dev Ethernet 4 . 2019.09.12 20:13:53 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:13:53 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:13:53 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:49b::1 metric -1) dev Ethernet 4 . 2019.09.12 20:13:53 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:13:53 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:13:53 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:49b::1 metric -1) dev Ethernet 4 . 2019.09.12 20:13:53 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=23 fe80::8 store=active . 2019.09.12 20:13:53 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:13:53 - Interface Ethernet 4 metric changed from Automatic to 3, layer IPv4 . 2019.09.12 20:13:53 - Interface Ethernet 4 metric changed from Automatic to 3, layer IPv6 . 2019.09.12 20:13:53 - DNS leak protection with packet filtering enabled. . 2019.09.12 20:13:54 - DNS IPv4 of a network adapter forced (Ethernet 4, from automatic to 10.8.155.1) . 2019.09.12 20:13:54 - DNS IPv6 of a network adapter forced (Ethernet 4, from automatic to fde6:7a:7d20:49b::1) . 2019.09.12 20:13:54 - Routes, added a new route, 184.75.221.115 for gateway 10.8.155.1 . 2019.09.12 20:13:54 - Routes, added a new route, 2606:6080:1001:11:60bc:461c:1305:bb4b for gateway fde6:7a:7d20:49b::1 . 2019.09.12 20:13:54 - Flushing DNS I 2019.09.12 20:13:58 - Checking route IPv4 I 2019.09.12 20:13:58 - Checking route IPv6 I 2019.09.12 20:14:02 - Checking DNS ! 2019.09.12 20:14:02 - Connected. . 2019.09.12 20:14:02 - OpenVPN > Initialization Sequence Completed . 2019.09.12 20:23:03 - Updating systems & servers data ... . 2019.09.12 20:23:04 - Systems & servers data update completed . 2019.09.12 20:33:08 - Updating systems & servers data ... . 2019.09.12 20:33:09 - Systems & servers data update completed ! 2019.09.12 20:34:58 - Disconnecting . 2019.09.12 20:34:59 - Routes, removed a route previously added, 184.75.221.115 for gateway 10.8.155.1 . 2019.09.12 20:34:59 - Routes, removed a route previously added, 2606:6080:1001:11:60bc:461c:1305:bb4b for gateway fde6:7a:7d20:49b::1 . 2019.09.12 20:34:59 - Sending management termination signal . 2019.09.12 20:34:59 - Management - Send 'signal SIGTERM' . 2019.09.12 20:34:59 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2019.09.12 20:34:59 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 184.75.221.117 MASK 255.255.255.255 192.168.0.1 . 2019.09.12 20:34:59 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:34:59 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.8.155.1 . 2019.09.12 20:34:59 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:34:59 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.8.155.1 . 2019.09.12 20:34:59 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:34:59 - OpenVPN > delete_route_ipv6(::/3) . 2019.09.12 20:34:59 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 interface=23 fe80::8 store=active . 2019.09.12 20:34:59 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:34:59 - OpenVPN > delete_route_ipv6(2000::/4) . 2019.09.12 20:34:59 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:34:59 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:34:59 - OpenVPN > delete_route_ipv6(3000::/4) . 2019.09.12 20:34:59 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:34:59 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:34:59 - OpenVPN > delete_route_ipv6(fc00::/7) . 2019.09.12 20:34:59 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=23 fe80::8 store=active . 2019.09.12 20:34:59 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:35:00 - OpenVPN > Closing TUN/TAP interface . 2019.09.12 20:35:00 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:49b::/64) . 2019.09.12 20:35:00 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:49b::/64 interface=23 fe80::8 store=active . 2019.09.12 20:35:00 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address Ethernet 4 fde6:7a:7d20:49b::1034 store=active . 2019.09.12 20:35:00 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns Ethernet 4 all . 2019.09.12 20:35:00 - OpenVPN > TAP: DHCP address released . 2019.09.12 20:35:00 - OpenVPN > SIGTERM[hard,] received, process exiting . 2019.09.12 20:35:00 - Connection terminated. . 2019.09.12 20:35:00 - DNS IPv4 of a network adapter restored to original settings (Ethernet 4, to automatic) . 2019.09.12 20:35:01 - DNS IPv6 of a network adapter restored to original settings (Ethernet 4, to automatic) . 2019.09.12 20:35:01 - DNS leak protection with packet filtering disabled. . 2019.09.12 20:35:01 - Interface Ethernet 4 metric restored from 3 to Automatic, layer IPv4 . 2019.09.12 20:35:01 - Interface Ethernet 4 metric restored from 3 to Automatic, layer IPv6 . 2019.09.12 20:35:01 - Flushing DNS ! 2019.09.12 20:35:04 - Session terminated. I 2019.09.12 20:35:34 - Session starting. I 2019.09.12 20:35:34 - Checking authorization ... ! 2019.09.12 20:35:35 - Connecting to Enif (Canada, Toronto, Ontario) . 2019.09.12 20:35:35 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2019.09.12 20:35:35 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2019.09.12 20:35:35 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.09.12 20:35:35 - Connection to OpenVPN Management Interface . 2019.09.12 20:35:35 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.09.12 20:35:35 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.09.12 20:35:35 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.09.12 20:35:35 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.09.12 20:35:35 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.09.12 20:35:35 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.245:2018 . 2019.09.12 20:35:35 - OpenVPN > Socket Buffers: R=[65536->524288] S=[65536->524288] . 2019.09.12 20:35:35 - OpenVPN > Attempting to establish TCP connection with [AF_INET]104.254.90.245:2018 [nonblock] . 2019.09.12 20:35:35 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2019.09.12 20:35:36 - OpenVPN > TCP connection established with [AF_INET]104.254.90.245:2018 . 2019.09.12 20:35:36 - OpenVPN > TCP_CLIENT link local: (not bound) . 2019.09.12 20:35:36 - OpenVPN > TCP_CLIENT link remote: [AF_INET]104.254.90.245:2018 . 2019.09.12 20:35:36 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.245:2018, sid=154320cf 5e27c918 . 2019.09.12 20:35:36 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2019.09.12 20:35:36 - OpenVPN > VERIFY KU OK . 2019.09.12 20:35:36 - OpenVPN > Validating certificate extended key usage . 2019.09.12 20:35:36 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2019.09.12 20:35:36 - OpenVPN > VERIFY EKU OK . 2019.09.12 20:35:36 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2019.09.12 20:35:36 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2019.09.12 20:35:36 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.254.90.245:2018 . 2019.09.12 20:35:37 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2019.09.12 20:35:38 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.16.91.1,dhcp-option DNS6 fde6:7a:7d20:c5b::1,tun-ipv6,route-gateway 10.16.91.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:c5b::102f/64 fde6:7a:7d20:c5b::1,ifconfig 10.16.91.49 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2019.09.12 20:35:38 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2019.09.12 20:35:38 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2019.09.12 20:35:38 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2019.09.12 20:35:38 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2019.09.12 20:35:38 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2019.09.12 20:35:38 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2019.09.12 20:35:38 - OpenVPN > OPTIONS IMPORT: peer-id set . 2019.09.12 20:35:38 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627 . 2019.09.12 20:35:38 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2019.09.12 20:35:38 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2019.09.12 20:35:38 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.09.12 20:35:38 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.09.12 20:35:38 - OpenVPN > interactive service msg_channel=0 . 2019.09.12 20:35:38 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=10:02:b5:86:59:5c . 2019.09.12 20:35:38 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2019.09.12 20:35:38 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2019.09.12 20:35:38 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2019.09.12 20:35:38 - OpenVPN > open_tun . 2019.09.12 20:35:38 - OpenVPN > TAP-WIN32 device [Ethernet 4] opened: \\.\Global\{EC5D0326-55CA-4233-B026-CDC459606FF8}.tap . 2019.09.12 20:35:38 - OpenVPN > TAP-Windows Driver Version 9.21 . 2019.09.12 20:35:38 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.16.91.0/10.16.91.49/255.255.255.0 [SUCCEEDED] . 2019.09.12 20:35:38 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.16.91.49/255.255.255.0 on interface {EC5D0326-55CA-4233-B026-CDC459606FF8} [DHCP-serv: 10.16.91.254, lease-time: 31536000] . 2019.09.12 20:35:38 - OpenVPN > Successful ARP Flush on interface [23] {EC5D0326-55CA-4233-B026-CDC459606FF8} . 2019.09.12 20:35:38 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2019.09.12 20:35:39 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=23 fde6:7a:7d20:c5b::102f store=active . 2019.09.12 20:35:40 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Ethernet 4 static fde6:7a:7d20:c5b::1 validate=no . 2019.09.12 20:35:40 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2019.09.12 20:35:40 - OpenVPN > add_route_ipv6(fde6:7a:7d20:c5b::/64 -> fde6:7a:7d20:c5b::102f metric 0) dev Ethernet 4 . 2019.09.12 20:35:40 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:c5b::/64 interface=23 fe80::8 store=active . 2019.09.12 20:35:40 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:35:45 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2019.09.12 20:35:45 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 104.254.90.245 MASK 255.255.255.255 192.168.0.1 . 2019.09.12 20:35:45 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4 . 2019.09.12 20:35:45 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:35:45 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.16.91.1 . 2019.09.12 20:35:45 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.09.12 20:35:45 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:35:45 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.16.91.1 . 2019.09.12 20:35:45 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.09.12 20:35:45 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:35:45 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:c5b::1 metric -1) dev Ethernet 4 . 2019.09.12 20:35:45 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=23 fe80::8 store=active . 2019.09.12 20:35:45 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:35:45 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:c5b::1 metric -1) dev Ethernet 4 . 2019.09.12 20:35:45 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:35:45 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:35:45 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:c5b::1 metric -1) dev Ethernet 4 . 2019.09.12 20:35:45 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:35:45 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:35:45 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:c5b::1 metric -1) dev Ethernet 4 . 2019.09.12 20:35:45 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=23 fe80::8 store=active . 2019.09.12 20:35:45 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:35:45 - Interface Ethernet 4 metric changed from Automatic to 3, layer IPv4 . 2019.09.12 20:35:45 - Interface Ethernet 4 metric changed from Automatic to 3, layer IPv6 . 2019.09.12 20:35:45 - DNS leak protection with packet filtering enabled. . 2019.09.12 20:35:46 - DNS IPv4 of a network adapter forced (Ethernet 4, from automatic to 10.16.91.1) . 2019.09.12 20:35:46 - DNS IPv6 of a network adapter forced (Ethernet 4, from automatic to fde6:7a:7d20:c5b::1) . 2019.09.12 20:35:46 - Routes, added a new route, 104.254.90.243 for gateway 10.16.91.1 . 2019.09.12 20:35:47 - Routes, added a new route, 2606:6080:2001:9:2679:addd:655:8142 for gateway fde6:7a:7d20:c5b::1 . 2019.09.12 20:35:47 - Flushing DNS I 2019.09.12 20:35:50 - Checking route IPv4 I 2019.09.12 20:35:50 - Checking route IPv6 I 2019.09.12 20:35:54 - Checking DNS ! 2019.09.12 20:35:54 - Connected. . 2019.09.12 20:35:54 - OpenVPN > Initialization Sequence Completed ! 2019.09.12 20:37:51 - Disconnecting . 2019.09.12 20:37:51 - Routes, removed a route previously added, 104.254.90.243 for gateway 10.16.91.1 . 2019.09.12 20:37:51 - Routes, removed a route previously added, 2606:6080:2001:9:2679:addd:655:8142 for gateway fde6:7a:7d20:c5b::1 . 2019.09.12 20:37:51 - Sending management termination signal . 2019.09.12 20:37:51 - Management - Send 'signal SIGTERM' . 2019.09.12 20:37:51 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2019.09.12 20:37:51 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 104.254.90.245 MASK 255.255.255.255 192.168.0.1 . 2019.09.12 20:37:51 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:37:51 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.16.91.1 . 2019.09.12 20:37:51 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:37:51 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.16.91.1 . 2019.09.12 20:37:51 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:37:51 - OpenVPN > delete_route_ipv6(::/3) . 2019.09.12 20:37:51 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 interface=23 fe80::8 store=active . 2019.09.12 20:37:51 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:37:51 - OpenVPN > delete_route_ipv6(2000::/4) . 2019.09.12 20:37:51 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:37:51 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:37:51 - OpenVPN > delete_route_ipv6(3000::/4) . 2019.09.12 20:37:51 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:37:51 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:37:51 - OpenVPN > delete_route_ipv6(fc00::/7) . 2019.09.12 20:37:51 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=23 fe80::8 store=active . 2019.09.12 20:37:51 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:37:52 - OpenVPN > Closing TUN/TAP interface . 2019.09.12 20:37:52 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:c5b::/64) . 2019.09.12 20:37:52 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:c5b::/64 interface=23 fe80::8 store=active . 2019.09.12 20:37:52 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address Ethernet 4 fde6:7a:7d20:c5b::102f store=active . 2019.09.12 20:37:52 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns Ethernet 4 all . 2019.09.12 20:37:52 - OpenVPN > TAP: DHCP address released . 2019.09.12 20:37:52 - OpenVPN > SIGTERM[hard,] received, process exiting . 2019.09.12 20:37:52 - Connection terminated. . 2019.09.12 20:37:52 - DNS IPv4 of a network adapter restored to original settings (Ethernet 4, to automatic) . 2019.09.12 20:37:53 - DNS IPv6 of a network adapter restored to original settings (Ethernet 4, to automatic) . 2019.09.12 20:37:53 - DNS leak protection with packet filtering disabled. . 2019.09.12 20:37:53 - Interface Ethernet 4 metric restored from 3 to Automatic, layer IPv4 . 2019.09.12 20:37:53 - Interface Ethernet 4 metric restored from 3 to Automatic, layer IPv6 I 2019.09.12 20:37:53 - Checking authorization ... ! 2019.09.12 20:37:53 - Connecting to Alphirk (Netherlands, Alblasserdam) . 2019.09.12 20:37:53 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2019.09.12 20:37:53 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2019.09.12 20:37:53 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.09.12 20:37:53 - Connection to OpenVPN Management Interface . 2019.09.12 20:37:53 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.09.12 20:37:53 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.09.12 20:37:53 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.09.12 20:37:53 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.09.12 20:37:53 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.09.12 20:37:53 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]109.202.107.149:2018 . 2019.09.12 20:37:53 - OpenVPN > Socket Buffers: R=[65536->524288] S=[65536->524288] . 2019.09.12 20:37:53 - OpenVPN > Attempting to establish TCP connection with [AF_INET]109.202.107.149:2018 [nonblock] . 2019.09.12 20:37:54 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2019.09.12 20:37:54 - OpenVPN > TCP connection established with [AF_INET]109.202.107.149:2018 . 2019.09.12 20:37:54 - OpenVPN > TCP_CLIENT link local: (not bound) . 2019.09.12 20:37:54 - OpenVPN > TCP_CLIENT link remote: [AF_INET]109.202.107.149:2018 . 2019.09.12 20:37:55 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.149:2018, sid=5a982d1a 1fd2edc9 . 2019.09.12 20:37:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2019.09.12 20:37:55 - OpenVPN > VERIFY KU OK . 2019.09.12 20:37:55 - OpenVPN > Validating certificate extended key usage . 2019.09.12 20:37:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2019.09.12 20:37:55 - OpenVPN > VERIFY EKU OK . 2019.09.12 20:37:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alphirk, emailAddress=info@airvpn.org . 2019.09.12 20:37:55 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2019.09.12 20:37:55 - OpenVPN > [Alphirk] Peer Connection Initiated with [AF_INET]109.202.107.149:2018 . 2019.09.12 20:37:56 - OpenVPN > SENT CONTROL [Alphirk]: 'PUSH_REQUEST' (status=1) . 2019.09.12 20:37:57 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.7.123.1,dhcp-option DNS6 fde6:7a:7d20:37b::1,tun-ipv6,route-gateway 10.7.123.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:37b::10a9/64 fde6:7a:7d20:37b::1,ifconfig 10.7.123.171 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2019.09.12 20:37:57 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2019.09.12 20:37:57 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2019.09.12 20:37:57 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2019.09.12 20:37:57 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2019.09.12 20:37:57 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2019.09.12 20:37:57 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2019.09.12 20:37:57 - OpenVPN > OPTIONS IMPORT: peer-id set . 2019.09.12 20:37:57 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627 . 2019.09.12 20:37:57 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2019.09.12 20:37:57 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2019.09.12 20:37:57 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.09.12 20:37:57 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.09.12 20:37:57 - OpenVPN > interactive service msg_channel=0 . 2019.09.12 20:37:57 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=10:02:b5:86:59:5c . 2019.09.12 20:37:57 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2019.09.12 20:37:57 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2019.09.12 20:37:57 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2019.09.12 20:37:57 - OpenVPN > open_tun . 2019.09.12 20:37:57 - OpenVPN > TAP-WIN32 device [Ethernet 4] opened: \\.\Global\{EC5D0326-55CA-4233-B026-CDC459606FF8}.tap . 2019.09.12 20:37:57 - OpenVPN > TAP-Windows Driver Version 9.21 . 2019.09.12 20:37:57 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.7.123.0/10.7.123.171/255.255.255.0 [SUCCEEDED] . 2019.09.12 20:37:57 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.7.123.171/255.255.255.0 on interface {EC5D0326-55CA-4233-B026-CDC459606FF8} [DHCP-serv: 10.7.123.254, lease-time: 31536000] . 2019.09.12 20:37:57 - OpenVPN > Successful ARP Flush on interface [23] {EC5D0326-55CA-4233-B026-CDC459606FF8} . 2019.09.12 20:37:57 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2019.09.12 20:37:58 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=23 fde6:7a:7d20:37b::10a9 store=active . 2019.09.12 20:37:59 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Ethernet 4 static fde6:7a:7d20:37b::1 validate=no . 2019.09.12 20:37:59 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2019.09.12 20:37:59 - OpenVPN > add_route_ipv6(fde6:7a:7d20:37b::/64 -> fde6:7a:7d20:37b::10a9 metric 0) dev Ethernet 4 . 2019.09.12 20:37:59 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:37b::/64 interface=23 fe80::8 store=active . 2019.09.12 20:37:59 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:38:04 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2019.09.12 20:38:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 109.202.107.149 MASK 255.255.255.255 192.168.0.1 . 2019.09.12 20:38:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4 . 2019.09.12 20:38:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:38:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.7.123.1 . 2019.09.12 20:38:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.09.12 20:38:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:38:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.7.123.1 . 2019.09.12 20:38:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.09.12 20:38:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:38:04 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:37b::1 metric -1) dev Ethernet 4 . 2019.09.12 20:38:04 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=23 fe80::8 store=active . 2019.09.12 20:38:04 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:38:04 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:37b::1 metric -1) dev Ethernet 4 . 2019.09.12 20:38:04 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:38:04 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:38:04 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:37b::1 metric -1) dev Ethernet 4 . 2019.09.12 20:38:04 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:38:04 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:38:04 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:37b::1 metric -1) dev Ethernet 4 . 2019.09.12 20:38:04 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=23 fe80::8 store=active . 2019.09.12 20:38:04 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:38:04 - Interface Ethernet 4 metric changed from Automatic to 3, layer IPv4 . 2019.09.12 20:38:04 - Interface Ethernet 4 metric changed from Automatic to 3, layer IPv6 . 2019.09.12 20:38:04 - DNS leak protection with packet filtering enabled. . 2019.09.12 20:38:05 - DNS IPv4 of a network adapter forced (Ethernet 4, from automatic to 10.7.123.1) . 2019.09.12 20:38:05 - DNS IPv6 of a network adapter forced (Ethernet 4, from automatic to fde6:7a:7d20:37b::1) . 2019.09.12 20:38:05 - Routes, added a new route, 109.202.107.147 for gateway 10.7.123.1 . 2019.09.12 20:38:06 - Routes, added a new route, 2a00:1678:2470:22:d8a1:dc22:34fb:d6c4 for gateway fde6:7a:7d20:37b::1 . 2019.09.12 20:38:06 - Flushing DNS I 2019.09.12 20:38:09 - Checking route IPv4 I 2019.09.12 20:38:10 - Checking route IPv6 I 2019.09.12 20:38:14 - Checking DNS ! 2019.09.12 20:38:15 - Connected. . 2019.09.12 20:38:15 - OpenVPN > Initialization Sequence Completed ! 2019.09.12 20:42:27 - Disconnecting . 2019.09.12 20:42:27 - Routes, removed a route previously added, 109.202.107.147 for gateway 10.7.123.1 . 2019.09.12 20:42:28 - Routes, removed a route previously added, 2a00:1678:2470:22:d8a1:dc22:34fb:d6c4 for gateway fde6:7a:7d20:37b::1 . 2019.09.12 20:42:28 - Sending management termination signal . 2019.09.12 20:42:28 - Management - Send 'signal SIGTERM' . 2019.09.12 20:42:28 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2019.09.12 20:42:28 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 109.202.107.149 MASK 255.255.255.255 192.168.0.1 . 2019.09.12 20:42:28 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:42:28 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.7.123.1 . 2019.09.12 20:42:28 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:42:28 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.7.123.1 . 2019.09.12 20:42:28 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:42:28 - OpenVPN > delete_route_ipv6(::/3) . 2019.09.12 20:42:28 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 interface=23 fe80::8 store=active . 2019.09.12 20:42:28 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:42:28 - OpenVPN > delete_route_ipv6(2000::/4) . 2019.09.12 20:42:28 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:42:28 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:42:28 - OpenVPN > delete_route_ipv6(3000::/4) . 2019.09.12 20:42:28 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:42:28 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:42:28 - OpenVPN > delete_route_ipv6(fc00::/7) . 2019.09.12 20:42:28 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=23 fe80::8 store=active . 2019.09.12 20:42:28 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:42:28 - OpenVPN > Closing TUN/TAP interface . 2019.09.12 20:42:28 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:37b::/64) . 2019.09.12 20:42:28 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:37b::/64 interface=23 fe80::8 store=active . 2019.09.12 20:42:28 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address Ethernet 4 fde6:7a:7d20:37b::10a9 store=active . 2019.09.12 20:42:28 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns Ethernet 4 all . 2019.09.12 20:42:29 - OpenVPN > TAP: DHCP address released . 2019.09.12 20:42:29 - OpenVPN > SIGTERM[hard,] received, process exiting . 2019.09.12 20:42:29 - Connection terminated. . 2019.09.12 20:42:29 - DNS IPv4 of a network adapter restored to original settings (Ethernet 4, to automatic) . 2019.09.12 20:42:29 - DNS IPv6 of a network adapter restored to original settings (Ethernet 4, to automatic) . 2019.09.12 20:42:29 - DNS leak protection with packet filtering disabled. . 2019.09.12 20:42:29 - Interface Ethernet 4 metric restored from 3 to Automatic, layer IPv4 . 2019.09.12 20:42:29 - Interface Ethernet 4 metric restored from 3 to Automatic, layer IPv6 . 2019.09.12 20:42:29 - Flushing DNS ! 2019.09.12 20:42:33 - Session terminated. I 2019.09.12 20:42:34 - Session starting. I 2019.09.12 20:42:34 - Checking authorization ... ! 2019.09.12 20:42:35 - Connecting to Enif (Canada, Toronto, Ontario) . 2019.09.12 20:42:35 - Routes, added a new route, 104.254.90.246 for gateway 192.168.0.1 . 2019.09.12 20:42:35 - SSL > 2019.09.12 20:42:35 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform . 2019.09.12 20:42:35 - SSL > 2019.09.12 20:42:35 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k 26 Jan 2017 . 2019.09.12 20:42:35 - SSL > 2019.09.12 20:42:35 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI . 2019.09.12 20:42:35 - SSL > 2019.09.12 20:42:35 LOG5[ui]: Reading configuration from file C:\Users\tropi\AppData\Local\AirVPN\f41768b8c1e01ce755e542dbc63cc77f3c25fd055f69ff14bf191cbcc780e632.tmp.ssl . 2019.09.12 20:42:35 - SSL > 2019.09.12 20:42:35 LOG5[ui]: UTF-8 byte order mark detected . 2019.09.12 20:42:35 - SSL > 2019.09.12 20:42:35 LOG6[ui]: Initializing service [openvpn] . 2019.09.12 20:42:35 - SSL > 2019.09.12 20:42:35 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks . 2019.09.12 20:42:35 - SSL > 2019.09.12 20:42:35 LOG5[ui]: Configuration successful . 2019.09.12 20:42:35 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2019.09.12 20:42:35 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2019.09.12 20:42:35 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.09.12 20:42:35 - Connection to OpenVPN Management Interface . 2019.09.12 20:42:35 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.09.12 20:42:35 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.09.12 20:42:35 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.09.12 20:42:35 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.09.12 20:42:35 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.09.12 20:42:35 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:53409 . 2019.09.12 20:42:35 - OpenVPN > Socket Buffers: R=[65536->524288] S=[65536->524288] . 2019.09.12 20:42:35 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:53409 [nonblock] . 2019.09.12 20:42:35 - SSL > 2019.09.12 20:42:35 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:54270 . 2019.09.12 20:42:35 - SSL > 2019.09.12 20:42:35 LOG6[0]: s_connect: connecting 104.254.90.246:443 . 2019.09.12 20:42:35 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:53409 . 2019.09.12 20:42:35 - OpenVPN > TCP_CLIENT link local: (not bound) . 2019.09.12 20:42:35 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:53409 . 2019.09.12 20:42:35 - SSL > 2019.09.12 20:42:35 LOG5[0]: s_connect: connected 104.254.90.246:443 . 2019.09.12 20:42:35 - SSL > 2019.09.12 20:42:35 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.23:54271 . 2019.09.12 20:42:36 - SSL > 2019.09.12 20:42:35 LOG6[0]: SNI: sending servername: 104.254.90.246 . 2019.09.12 20:42:36 - SSL > 2019.09.12 20:42:35 LOG6[0]: Peer certificate not required . 2019.09.12 20:42:36 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2019.09.12 20:42:36 - SSL > 2019.09.12 20:42:36 LOG6[0]: Certificate verification disabled . 2019.09.12 20:42:36 - SSL > 2019.09.12 20:42:36 LOG6[0]: Client certificate not requested . 2019.09.12 20:42:36 - SSL > 2019.09.12 20:42:36 LOG6[0]: TLS connected: new session negotiated . 2019.09.12 20:42:36 - SSL > 2019.09.12 20:42:36 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption) . 2019.09.12 20:42:36 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:53409, sid=93b6dc8b baa033b3 . 2019.09.12 20:42:36 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2019.09.12 20:42:36 - OpenVPN > VERIFY KU OK . 2019.09.12 20:42:36 - OpenVPN > Validating certificate extended key usage . 2019.09.12 20:42:36 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2019.09.12 20:42:36 - OpenVPN > VERIFY EKU OK . 2019.09.12 20:42:36 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2019.09.12 20:42:36 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2019.09.12 20:42:36 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:53409 . 2019.09.12 20:42:37 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2019.09.12 20:42:37 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.16.91.1,dhcp-option DNS6 fde6:7a:7d20:c5b::1,tun-ipv6,route-gateway 10.16.91.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:c5b::102f/64 fde6:7a:7d20:c5b::1,ifconfig 10.16.91.49 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2019.09.12 20:42:37 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2019.09.12 20:42:37 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2019.09.12 20:42:37 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2019.09.12 20:42:37 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2019.09.12 20:42:37 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2019.09.12 20:42:37 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2019.09.12 20:42:37 - OpenVPN > OPTIONS IMPORT: peer-id set . 2019.09.12 20:42:37 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627 . 2019.09.12 20:42:37 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2019.09.12 20:42:37 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2019.09.12 20:42:37 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.09.12 20:42:37 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.09.12 20:42:37 - OpenVPN > interactive service msg_channel=0 . 2019.09.12 20:42:37 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=10:02:b5:86:59:5c . 2019.09.12 20:42:37 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2019.09.12 20:42:37 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2019.09.12 20:42:37 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2019.09.12 20:42:37 - OpenVPN > open_tun . 2019.09.12 20:42:37 - OpenVPN > TAP-WIN32 device [Ethernet 4] opened: \\.\Global\{EC5D0326-55CA-4233-B026-CDC459606FF8}.tap . 2019.09.12 20:42:37 - OpenVPN > TAP-Windows Driver Version 9.21 . 2019.09.12 20:42:37 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.16.91.0/10.16.91.49/255.255.255.0 [SUCCEEDED] . 2019.09.12 20:42:37 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.16.91.49/255.255.255.0 on interface {EC5D0326-55CA-4233-B026-CDC459606FF8} [DHCP-serv: 10.16.91.254, lease-time: 31536000] . 2019.09.12 20:42:37 - OpenVPN > Successful ARP Flush on interface [23] {EC5D0326-55CA-4233-B026-CDC459606FF8} . 2019.09.12 20:42:37 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2019.09.12 20:42:38 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=23 fde6:7a:7d20:c5b::102f store=active . 2019.09.12 20:42:39 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Ethernet 4 static fde6:7a:7d20:c5b::1 validate=no . 2019.09.12 20:42:40 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2019.09.12 20:42:40 - OpenVPN > add_route_ipv6(fde6:7a:7d20:c5b::/64 -> fde6:7a:7d20:c5b::102f metric 0) dev Ethernet 4 . 2019.09.12 20:42:40 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:c5b::/64 interface=23 fe80::8 store=active . 2019.09.12 20:42:40 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:42:45 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2019.09.12 20:42:45 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1 . 2019.09.12 20:42:45 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4 . 2019.09.12 20:42:45 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:42:45 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.16.91.1 . 2019.09.12 20:42:45 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.09.12 20:42:45 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:42:45 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.16.91.1 . 2019.09.12 20:42:45 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.09.12 20:42:45 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:42:45 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:c5b::1 metric -1) dev Ethernet 4 . 2019.09.12 20:42:45 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=23 fe80::8 store=active . 2019.09.12 20:42:45 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:42:45 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:c5b::1 metric -1) dev Ethernet 4 . 2019.09.12 20:42:45 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:42:45 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:42:45 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:c5b::1 metric -1) dev Ethernet 4 . 2019.09.12 20:42:45 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:42:45 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:42:45 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:c5b::1 metric -1) dev Ethernet 4 . 2019.09.12 20:42:45 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=23 fe80::8 store=active . 2019.09.12 20:42:45 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:42:45 - Interface Ethernet 4 metric changed from Automatic to 3, layer IPv4 . 2019.09.12 20:42:45 - Interface Ethernet 4 metric changed from Automatic to 3, layer IPv6 . 2019.09.12 20:42:45 - DNS leak protection with packet filtering enabled. . 2019.09.12 20:42:46 - DNS IPv4 of a network adapter forced (Ethernet 4, from automatic to 10.16.91.1) . 2019.09.12 20:42:46 - DNS IPv6 of a network adapter forced (Ethernet 4, from automatic to fde6:7a:7d20:c5b::1) . 2019.09.12 20:42:46 - Routes, added a new route, 104.254.90.243 for gateway 10.16.91.1 . 2019.09.12 20:42:47 - Routes, added a new route, 2606:6080:2001:9:2679:addd:655:8142 for gateway fde6:7a:7d20:c5b::1 . 2019.09.12 20:42:47 - Flushing DNS I 2019.09.12 20:42:50 - Checking route IPv4 I 2019.09.12 20:42:50 - Checking route IPv6 I 2019.09.12 20:42:54 - Checking DNS ! 2019.09.12 20:42:54 - Connected. . 2019.09.12 20:42:54 - OpenVPN > Initialization Sequence Completed . 2019.09.12 20:43:13 - Updating systems & servers data ... . 2019.09.12 20:43:15 - Systems & servers data update completed . 2019.09.12 20:43:35 - SSL > 2019.09.12 20:43:35 LOG6[cron]: Executing cron jobs . 2019.09.12 20:43:35 - SSL > 2019.09.12 20:43:35 LOG6[cron]: Cron jobs completed in 0 seconds ! 2019.09.12 20:48:29 - Disconnecting . 2019.09.12 20:48:29 - Routes, removed a route previously added, 104.254.90.246 for gateway 192.168.0.1 . 2019.09.12 20:48:29 - Routes, removed a route previously added, 104.254.90.243 for gateway 10.16.91.1 . 2019.09.12 20:48:29 - Routes, removed a route previously added, 2606:6080:2001:9:2679:addd:655:8142 for gateway fde6:7a:7d20:c5b::1 . 2019.09.12 20:48:29 - Sending management termination signal . 2019.09.12 20:48:29 - Management - Send 'signal SIGTERM' . 2019.09.12 20:48:30 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2019.09.12 20:48:30 - SSL > 2019.09.12 20:48:29 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054) . 2019.09.12 20:48:30 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.0.1 . 2019.09.12 20:48:30 - SSL > 2019.09.12 20:48:29 LOG5[0]: Connection reset: 1536249 byte(s) sent to TLS, 49740501 byte(s) sent to socket . 2019.09.12 20:48:30 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:48:30 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.16.91.1 . 2019.09.12 20:48:30 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:48:30 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.16.91.1 . 2019.09.12 20:48:30 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:48:30 - OpenVPN > delete_route_ipv6(::/3) . 2019.09.12 20:48:30 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 interface=23 fe80::8 store=active . 2019.09.12 20:48:30 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:48:30 - OpenVPN > delete_route_ipv6(2000::/4) . 2019.09.12 20:48:30 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:48:30 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:48:30 - OpenVPN > delete_route_ipv6(3000::/4) . 2019.09.12 20:48:30 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:48:30 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:48:30 - OpenVPN > delete_route_ipv6(fc00::/7) . 2019.09.12 20:48:30 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=23 fe80::8 store=active . 2019.09.12 20:48:30 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:48:30 - OpenVPN > Closing TUN/TAP interface . 2019.09.12 20:48:30 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:c5b::/64) . 2019.09.12 20:48:30 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:c5b::/64 interface=23 fe80::8 store=active . 2019.09.12 20:48:30 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address Ethernet 4 fde6:7a:7d20:c5b::102f store=active . 2019.09.12 20:48:30 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns Ethernet 4 all . 2019.09.12 20:48:31 - OpenVPN > TAP: DHCP address released . 2019.09.12 20:48:31 - OpenVPN > SIGTERM[hard,] received, process exiting . 2019.09.12 20:48:39 - Sending soft termination signal . 2019.09.12 20:48:49 - Sending hard termination signal . 2019.09.12 20:48:49 - Connection terminated. . 2019.09.12 20:48:49 - DNS IPv4 of a network adapter restored to original settings (Ethernet 4, to automatic) . 2019.09.12 20:48:49 - DNS IPv6 of a network adapter restored to original settings (Ethernet 4, to automatic) . 2019.09.12 20:48:49 - DNS leak protection with packet filtering disabled. . 2019.09.12 20:48:49 - Interface Ethernet 4 metric restored from 3 to Automatic, layer IPv4 . 2019.09.12 20:48:49 - Interface Ethernet 4 metric restored from 3 to Automatic, layer IPv6 . 2019.09.12 20:48:49 - Flushing DNS ! 2019.09.12 20:48:53 - Session terminated. I 2019.09.12 20:49:28 - Session starting. I 2019.09.12 20:49:29 - Checking authorization ... ! 2019.09.12 20:49:29 - Connecting to Lesath (Canada, Toronto, Ontario) . 2019.09.12 20:49:30 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2019.09.12 20:49:30 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2019.09.12 20:49:30 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.09.12 20:49:30 - Connection to OpenVPN Management Interface . 2019.09.12 20:49:30 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.09.12 20:49:30 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.09.12 20:49:30 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.09.12 20:49:30 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.09.12 20:49:30 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.09.12 20:49:30 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.5:443 . 2019.09.12 20:49:30 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536] . 2019.09.12 20:49:30 - OpenVPN > UDP link local: (not bound) . 2019.09.12 20:49:30 - OpenVPN > UDP link remote: [AF_INET]184.75.221.5:443 . 2019.09.12 20:49:30 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.5:443, sid=bc0d976b 5dc80327 . 2019.09.12 20:49:30 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2019.09.12 20:49:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2019.09.12 20:49:30 - OpenVPN > VERIFY KU OK . 2019.09.12 20:49:30 - OpenVPN > Validating certificate extended key usage . 2019.09.12 20:49:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2019.09.12 20:49:30 - OpenVPN > VERIFY EKU OK . 2019.09.12 20:49:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Lesath, emailAddress=info@airvpn.org . 2019.09.12 20:49:30 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2019.09.12 20:49:30 - OpenVPN > [Lesath] Peer Connection Initiated with [AF_INET]184.75.221.5:443 . 2019.09.12 20:49:31 - OpenVPN > SENT CONTROL [Lesath]: 'PUSH_REQUEST' (status=1) . 2019.09.12 20:49:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.20.250.1,dhcp-option DNS6 fde6:7a:7d20:10fa::1,tun-ipv6,route-gateway 10.20.250.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:10fa::1046/64 fde6:7a:7d20:10fa::1,ifconfig 10.20.250.72 255.255.255.0,peer-id 3,cipher AES-256-GCM' . 2019.09.12 20:49:31 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2019.09.12 20:49:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2019.09.12 20:49:31 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2019.09.12 20:49:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2019.09.12 20:49:31 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2019.09.12 20:49:31 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2019.09.12 20:49:31 - OpenVPN > OPTIONS IMPORT: peer-id set . 2019.09.12 20:49:31 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2019.09.12 20:49:31 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2019.09.12 20:49:31 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2019.09.12 20:49:31 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.09.12 20:49:31 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.09.12 20:49:31 - OpenVPN > interactive service msg_channel=0 . 2019.09.12 20:49:31 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=10:02:b5:86:59:5c . 2019.09.12 20:49:31 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2019.09.12 20:49:31 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2019.09.12 20:49:31 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2019.09.12 20:49:31 - OpenVPN > open_tun . 2019.09.12 20:49:31 - OpenVPN > TAP-WIN32 device [Ethernet 4] opened: \\.\Global\{EC5D0326-55CA-4233-B026-CDC459606FF8}.tap . 2019.09.12 20:49:31 - OpenVPN > TAP-Windows Driver Version 9.21 . 2019.09.12 20:49:31 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.20.250.0/10.20.250.72/255.255.255.0 [SUCCEEDED] . 2019.09.12 20:49:31 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.20.250.72/255.255.255.0 on interface {EC5D0326-55CA-4233-B026-CDC459606FF8} [DHCP-serv: 10.20.250.254, lease-time: 31536000] . 2019.09.12 20:49:31 - OpenVPN > Successful ARP Flush on interface [23] {EC5D0326-55CA-4233-B026-CDC459606FF8} . 2019.09.12 20:49:31 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2019.09.12 20:49:32 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=23 fde6:7a:7d20:10fa::1046 store=active . 2019.09.12 20:49:33 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Ethernet 4 static fde6:7a:7d20:10fa::1 validate=no . 2019.09.12 20:49:33 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2019.09.12 20:49:34 - OpenVPN > add_route_ipv6(fde6:7a:7d20:10fa::/64 -> fde6:7a:7d20:10fa::1046 metric 0) dev Ethernet 4 . 2019.09.12 20:49:34 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:10fa::/64 interface=23 fe80::8 store=active . 2019.09.12 20:49:34 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:49:38 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2019.09.12 20:49:38 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.221.5 MASK 255.255.255.255 192.168.0.1 . 2019.09.12 20:49:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4 . 2019.09.12 20:49:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:49:38 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.20.250.1 . 2019.09.12 20:49:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.09.12 20:49:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:49:38 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.20.250.1 . 2019.09.12 20:49:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.09.12 20:49:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:49:38 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:10fa::1 metric -1) dev Ethernet 4 . 2019.09.12 20:49:38 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=23 fe80::8 store=active . 2019.09.12 20:49:38 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:49:38 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:10fa::1 metric -1) dev Ethernet 4 . 2019.09.12 20:49:38 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:49:38 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:49:38 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:10fa::1 metric -1) dev Ethernet 4 . 2019.09.12 20:49:38 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:49:38 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:49:38 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:10fa::1 metric -1) dev Ethernet 4 . 2019.09.12 20:49:38 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=23 fe80::8 store=active . 2019.09.12 20:49:38 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:49:38 - Interface Ethernet 4 metric changed from Automatic to 3, layer IPv4 . 2019.09.12 20:49:38 - Interface Ethernet 4 metric changed from Automatic to 3, layer IPv6 . 2019.09.12 20:49:38 - DNS leak protection with packet filtering enabled. . 2019.09.12 20:49:39 - DNS IPv4 of a network adapter forced (Ethernet 4, from automatic to 10.20.250.1) . 2019.09.12 20:49:39 - DNS IPv6 of a network adapter forced (Ethernet 4, from automatic to fde6:7a:7d20:10fa::1) . 2019.09.12 20:49:39 - Routes, added a new route, 184.75.221.3 for gateway 10.20.250.1 . 2019.09.12 20:49:39 - Routes, added a new route, 2606:6080:1001:d:c59c:6e9a:3115:6f2f for gateway fde6:7a:7d20:10fa::1 . 2019.09.12 20:49:39 - Flushing DNS I 2019.09.12 20:49:43 - Checking route IPv4 I 2019.09.12 20:49:43 - Checking route IPv6 I 2019.09.12 20:49:47 - Checking DNS ! 2019.09.12 20:49:47 - Connected. . 2019.09.12 20:49:47 - OpenVPN > Initialization Sequence Completed . 2019.09.12 20:53:19 - Updating systems & servers data ... . 2019.09.12 20:53:20 - Systems & servers data update completed ! 2019.09.12 20:55:13 - Disconnecting . 2019.09.12 20:55:13 - Routes, removed a route previously added, 184.75.221.3 for gateway 10.20.250.1 . 2019.09.12 20:55:13 - Routes, removed a route previously added, 2606:6080:1001:d:c59c:6e9a:3115:6f2f for gateway fde6:7a:7d20:10fa::1 . 2019.09.12 20:55:13 - Sending management termination signal . 2019.09.12 20:55:13 - Management - Send 'signal SIGTERM' . 2019.09.12 20:55:13 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2019.09.12 20:55:13 - OpenVPN > SIGTERM received, sending exit notification to peer . 2019.09.12 20:55:18 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 184.75.221.5 MASK 255.255.255.255 192.168.0.1 . 2019.09.12 20:55:18 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:55:18 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.20.250.1 . 2019.09.12 20:55:18 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:55:18 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.20.250.1 . 2019.09.12 20:55:18 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:55:18 - OpenVPN > delete_route_ipv6(::/3) . 2019.09.12 20:55:18 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 interface=23 fe80::8 store=active . 2019.09.12 20:55:18 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:55:18 - OpenVPN > delete_route_ipv6(2000::/4) . 2019.09.12 20:55:18 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:55:18 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:55:19 - OpenVPN > delete_route_ipv6(3000::/4) . 2019.09.12 20:55:19 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:55:19 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:55:19 - OpenVPN > delete_route_ipv6(fc00::/7) . 2019.09.12 20:55:19 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=23 fe80::8 store=active . 2019.09.12 20:55:19 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:55:19 - OpenVPN > Closing TUN/TAP interface . 2019.09.12 20:55:19 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:10fa::/64) . 2019.09.12 20:55:19 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:10fa::/64 interface=23 fe80::8 store=active . 2019.09.12 20:55:19 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address Ethernet 4 fde6:7a:7d20:10fa::1046 store=active . 2019.09.12 20:55:19 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns Ethernet 4 all . 2019.09.12 20:55:19 - OpenVPN > TAP: DHCP address released . 2019.09.12 20:55:19 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2019.09.12 20:55:19 - Connection terminated. . 2019.09.12 20:55:20 - DNS IPv4 of a network adapter restored to original settings (Ethernet 4, to automatic) . 2019.09.12 20:55:20 - DNS IPv6 of a network adapter restored to original settings (Ethernet 4, to automatic) . 2019.09.12 20:55:20 - DNS leak protection with packet filtering disabled. . 2019.09.12 20:55:20 - Interface Ethernet 4 metric restored from 3 to Automatic, layer IPv4 . 2019.09.12 20:55:20 - Interface Ethernet 4 metric restored from 3 to Automatic, layer IPv6 . 2019.09.12 20:55:20 - Flushing DNS ! 2019.09.12 20:55:23 - Session terminated. I 2019.09.12 20:55:44 - Session starting. I 2019.09.12 20:55:44 - Checking authorization ... ! 2019.09.12 20:55:45 - Connecting to Arkab (Canada, Toronto, Ontario) . 2019.09.12 20:55:45 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2019.09.12 20:55:45 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2019.09.12 20:55:45 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.09.12 20:55:45 - Connection to OpenVPN Management Interface . 2019.09.12 20:55:45 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.09.12 20:55:45 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.09.12 20:55:45 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.09.12 20:55:45 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.09.12 20:55:45 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.09.12 20:55:45 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.214:443 . 2019.09.12 20:55:45 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536] . 2019.09.12 20:55:45 - OpenVPN > UDP link local: (not bound) . 2019.09.12 20:55:45 - OpenVPN > UDP link remote: [AF_INET]184.75.221.214:443 . 2019.09.12 20:55:45 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.214:443, sid=c53ab2d8 f7624394 . 2019.09.12 20:55:45 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2019.09.12 20:55:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2019.09.12 20:55:45 - OpenVPN > VERIFY KU OK . 2019.09.12 20:55:45 - OpenVPN > Validating certificate extended key usage . 2019.09.12 20:55:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2019.09.12 20:55:45 - OpenVPN > VERIFY EKU OK . 2019.09.12 20:55:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2019.09.12 20:55:45 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2019.09.12 20:55:45 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.214:443 . 2019.09.12 20:55:46 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2019.09.12 20:55:46 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.9.250.1,dhcp-option DNS6 fde6:7a:7d20:5fa::1,tun-ipv6,route-gateway 10.9.250.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:5fa::10b9/64 fde6:7a:7d20:5fa::1,ifconfig 10.9.250.187 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2019.09.12 20:55:46 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2019.09.12 20:55:46 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2019.09.12 20:55:46 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2019.09.12 20:55:46 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2019.09.12 20:55:46 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2019.09.12 20:55:46 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2019.09.12 20:55:46 - OpenVPN > OPTIONS IMPORT: peer-id set . 2019.09.12 20:55:46 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2019.09.12 20:55:46 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2019.09.12 20:55:46 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2019.09.12 20:55:46 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.09.12 20:55:46 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.09.12 20:55:46 - OpenVPN > interactive service msg_channel=0 . 2019.09.12 20:55:46 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=10:02:b5:86:59:5c . 2019.09.12 20:55:46 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2019.09.12 20:55:46 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2019.09.12 20:55:46 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2019.09.12 20:55:46 - OpenVPN > open_tun . 2019.09.12 20:55:46 - OpenVPN > TAP-WIN32 device [Ethernet 4] opened: \\.\Global\{EC5D0326-55CA-4233-B026-CDC459606FF8}.tap . 2019.09.12 20:55:46 - OpenVPN > TAP-Windows Driver Version 9.21 . 2019.09.12 20:55:46 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.9.250.0/10.9.250.187/255.255.255.0 [SUCCEEDED] . 2019.09.12 20:55:46 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.9.250.187/255.255.255.0 on interface {EC5D0326-55CA-4233-B026-CDC459606FF8} [DHCP-serv: 10.9.250.254, lease-time: 31536000] . 2019.09.12 20:55:46 - OpenVPN > Successful ARP Flush on interface [23] {EC5D0326-55CA-4233-B026-CDC459606FF8} . 2019.09.12 20:55:46 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2019.09.12 20:55:47 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=23 fde6:7a:7d20:5fa::10b9 store=active . 2019.09.12 20:55:48 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Ethernet 4 static fde6:7a:7d20:5fa::1 validate=no . 2019.09.12 20:55:49 - OpenVPN > add_route_ipv6(fde6:7a:7d20:5fa::/64 -> fde6:7a:7d20:5fa::10b9 metric 0) dev Ethernet 4 . 2019.09.12 20:55:49 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:5fa::/64 interface=23 fe80::8 store=active . 2019.09.12 20:55:49 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:55:54 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2019.09.12 20:55:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.221.214 MASK 255.255.255.255 192.168.0.1 . 2019.09.12 20:55:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4 . 2019.09.12 20:55:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:55:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.9.250.1 . 2019.09.12 20:55:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.09.12 20:55:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:55:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.9.250.1 . 2019.09.12 20:55:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.09.12 20:55:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 20:55:54 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:5fa::1 metric -1) dev Ethernet 4 . 2019.09.12 20:55:54 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=23 fe80::8 store=active . 2019.09.12 20:55:54 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:55:54 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:5fa::1 metric -1) dev Ethernet 4 . 2019.09.12 20:55:54 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:55:54 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:55:54 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:5fa::1 metric -1) dev Ethernet 4 . 2019.09.12 20:55:54 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:55:54 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:55:54 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:5fa::1 metric -1) dev Ethernet 4 . 2019.09.12 20:55:54 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=23 fe80::8 store=active . 2019.09.12 20:55:54 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:55:54 - Interface Ethernet 4 metric changed from Automatic to 3, layer IPv4 . 2019.09.12 20:55:54 - Interface Ethernet 4 metric changed from Automatic to 3, layer IPv6 . 2019.09.12 20:55:54 - DNS leak protection with packet filtering enabled. . 2019.09.12 20:55:55 - DNS IPv4 of a network adapter forced (Ethernet 4, from automatic to 10.9.250.1) . 2019.09.12 20:55:55 - DNS IPv6 of a network adapter forced (Ethernet 4, from automatic to fde6:7a:7d20:5fa::1) . 2019.09.12 20:55:55 - Routes, added a new route, 184.75.221.211 for gateway 10.9.250.1 . 2019.09.12 20:55:55 - Routes, added a new route, 2606:6080:1001:17:9ea4:71f9:d294:d7b7 for gateway fde6:7a:7d20:5fa::1 . 2019.09.12 20:55:55 - Flushing DNS I 2019.09.12 20:55:59 - Checking route IPv4 I 2019.09.12 20:55:59 - Checking route IPv6 I 2019.09.12 20:56:02 - Checking DNS ! 2019.09.12 20:56:03 - Connected. . 2019.09.12 20:56:03 - OpenVPN > Initialization Sequence Completed ! 2019.09.12 20:58:55 - Disconnecting . 2019.09.12 20:58:55 - Routes, removed a route previously added, 184.75.221.211 for gateway 10.9.250.1 . 2019.09.12 20:58:56 - Routes, removed a route previously added, 2606:6080:1001:17:9ea4:71f9:d294:d7b7 for gateway fde6:7a:7d20:5fa::1 . 2019.09.12 20:58:56 - Sending management termination signal . 2019.09.12 20:58:56 - Management - Send 'signal SIGTERM' . 2019.09.12 20:58:56 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2019.09.12 20:58:56 - OpenVPN > SIGTERM received, sending exit notification to peer . 2019.09.12 20:59:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 184.75.221.214 MASK 255.255.255.255 192.168.0.1 . 2019.09.12 20:59:02 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:59:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.9.250.1 . 2019.09.12 20:59:02 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:59:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.9.250.1 . 2019.09.12 20:59:02 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.09.12 20:59:02 - OpenVPN > delete_route_ipv6(::/3) . 2019.09.12 20:59:02 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 interface=23 fe80::8 store=active . 2019.09.12 20:59:02 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:59:02 - OpenVPN > delete_route_ipv6(2000::/4) . 2019.09.12 20:59:02 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:59:02 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:59:02 - OpenVPN > delete_route_ipv6(3000::/4) . 2019.09.12 20:59:02 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=23 fe80::8 store=active . 2019.09.12 20:59:02 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:59:02 - OpenVPN > delete_route_ipv6(fc00::/7) . 2019.09.12 20:59:02 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=23 fe80::8 store=active . 2019.09.12 20:59:02 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 20:59:02 - OpenVPN > Closing TUN/TAP interface . 2019.09.12 20:59:02 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:5fa::/64) . 2019.09.12 20:59:02 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:5fa::/64 interface=23 fe80::8 store=active . 2019.09.12 20:59:02 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address Ethernet 4 fde6:7a:7d20:5fa::10b9 store=active . 2019.09.12 20:59:03 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns Ethernet 4 all . 2019.09.12 20:59:03 - OpenVPN > TAP: DHCP address released . 2019.09.12 20:59:03 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2019.09.12 20:59:03 - Connection terminated. . 2019.09.12 20:59:03 - DNS IPv4 of a network adapter restored to original settings (Ethernet 4, to automatic) . 2019.09.12 20:59:03 - DNS IPv6 of a network adapter restored to original settings (Ethernet 4, to automatic) . 2019.09.12 20:59:03 - DNS leak protection with packet filtering disabled. . 2019.09.12 20:59:03 - Interface Ethernet 4 metric restored from 3 to Automatic, layer IPv4 . 2019.09.12 20:59:03 - Interface Ethernet 4 metric restored from 3 to Automatic, layer IPv6 . 2019.09.12 20:59:03 - Flushing DNS ! 2019.09.12 20:59:07 - Session terminated. I 2019.09.12 21:01:21 - Session starting. I 2019.09.12 21:01:21 - Checking authorization ... ! 2019.09.12 21:01:22 - Connecting to Anser (Netherlands, Alblasserdam) . 2019.09.12 21:01:22 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2019.09.12 21:01:22 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2019.09.12 21:01:22 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.09.12 21:01:22 - Connection to OpenVPN Management Interface . 2019.09.12 21:01:22 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.09.12 21:01:22 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.09.12 21:01:22 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.09.12 21:01:22 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.09.12 21:01:22 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.09.12 21:01:22 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]109.202.103.173:443 . 2019.09.12 21:01:22 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536] . 2019.09.12 21:01:22 - OpenVPN > UDP link local: (not bound) . 2019.09.12 21:01:22 - OpenVPN > UDP link remote: [AF_INET]109.202.103.173:443 . 2019.09.12 21:01:22 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2019.09.12 21:01:22 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.103.173:443, sid=b056651b dbe2b52c . 2019.09.12 21:01:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2019.09.12 21:01:22 - OpenVPN > VERIFY KU OK . 2019.09.12 21:01:22 - OpenVPN > Validating certificate extended key usage . 2019.09.12 21:01:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2019.09.12 21:01:22 - OpenVPN > VERIFY EKU OK . 2019.09.12 21:01:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2019.09.12 21:01:23 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2019.09.12 21:01:23 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.103.173:443 . 2019.09.12 21:01:24 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2019.09.12 21:01:24 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.9.90.1,dhcp-option DNS6 fde6:7a:7d20:55a::1,tun-ipv6,route-gateway 10.9.90.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:55a::10e1/64 fde6:7a:7d20:55a::1,ifconfig 10.9.90.227 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2019.09.12 21:01:24 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2019.09.12 21:01:24 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2019.09.12 21:01:24 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2019.09.12 21:01:24 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2019.09.12 21:01:24 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2019.09.12 21:01:24 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2019.09.12 21:01:24 - OpenVPN > OPTIONS IMPORT: peer-id set . 2019.09.12 21:01:24 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2019.09.12 21:01:24 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2019.09.12 21:01:24 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2019.09.12 21:01:24 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.09.12 21:01:24 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.09.12 21:01:24 - OpenVPN > interactive service msg_channel=0 . 2019.09.12 21:01:24 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=10:02:b5:86:59:5c . 2019.09.12 21:01:24 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2019.09.12 21:01:24 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2019.09.12 21:01:24 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2019.09.12 21:01:24 - OpenVPN > open_tun . 2019.09.12 21:01:24 - OpenVPN > TAP-WIN32 device [Ethernet 4] opened: \\.\Global\{EC5D0326-55CA-4233-B026-CDC459606FF8}.tap . 2019.09.12 21:01:24 - OpenVPN > TAP-Windows Driver Version 9.21 . 2019.09.12 21:01:24 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.9.90.0/10.9.90.227/255.255.255.0 [SUCCEEDED] . 2019.09.12 21:01:24 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.9.90.227/255.255.255.0 on interface {EC5D0326-55CA-4233-B026-CDC459606FF8} [DHCP-serv: 10.9.90.254, lease-time: 31536000] . 2019.09.12 21:01:24 - OpenVPN > Successful ARP Flush on interface [23] {EC5D0326-55CA-4233-B026-CDC459606FF8} . 2019.09.12 21:01:24 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2019.09.12 21:01:25 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=23 fde6:7a:7d20:55a::10e1 store=active . 2019.09.12 21:01:26 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Ethernet 4 static fde6:7a:7d20:55a::1 validate=no . 2019.09.12 21:01:27 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2019.09.12 21:01:27 - OpenVPN > add_route_ipv6(fde6:7a:7d20:55a::/64 -> fde6:7a:7d20:55a::10e1 metric 0) dev Ethernet 4 . 2019.09.12 21:01:27 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:55a::/64 interface=23 fe80::8 store=active . 2019.09.12 21:01:27 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 21:01:31 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2019.09.12 21:01:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 109.202.103.173 MASK 255.255.255.255 192.168.0.1 . 2019.09.12 21:01:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4 . 2019.09.12 21:01:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 21:01:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.9.90.1 . 2019.09.12 21:01:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.09.12 21:01:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 21:01:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.9.90.1 . 2019.09.12 21:01:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.09.12 21:01:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.09.12 21:01:31 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:55a::1 metric -1) dev Ethernet 4 . 2019.09.12 21:01:31 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=23 fe80::8 store=active . 2019.09.12 21:01:31 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 21:01:31 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:55a::1 metric -1) dev Ethernet 4 . 2019.09.12 21:01:31 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=23 fe80::8 store=active . 2019.09.12 21:01:31 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 21:01:31 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:55a::1 metric -1) dev Ethernet 4 . 2019.09.12 21:01:31 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=23 fe80::8 store=active . 2019.09.12 21:01:31 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 21:01:31 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:55a::1 metric -1) dev Ethernet 4 . 2019.09.12 21:01:31 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=23 fe80::8 store=active . 2019.09.12 21:01:31 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2019.09.12 21:01:31 - Interface Ethernet 4 metric changed from Automatic to 3, layer IPv4 . 2019.09.12 21:01:31 - Interface Ethernet 4 metric changed from Automatic to 3, layer IPv6 . 2019.09.12 21:01:31 - DNS leak protection with packet filtering enabled. . 2019.09.12 21:01:32 - DNS IPv4 of a network adapter forced (Ethernet 4, from automatic to 10.9.90.1) . 2019.09.12 21:01:32 - DNS IPv6 of a network adapter forced (Ethernet 4, from automatic to fde6:7a:7d20:55a::1) . 2019.09.12 21:01:32 - Routes, added a new route, 109.202.103.170 for gateway 10.9.90.1 . 2019.09.12 21:01:33 - Routes, added a new route, 2a00:1678:2470:7:7265:24fc:ff33:113b for gateway fde6:7a:7d20:55a::1 . 2019.09.12 21:01:33 - Flushing DNS I 2019.09.12 21:01:36 - Checking route IPv4 I 2019.09.12 21:01:37 - Checking route IPv6 I 2019.09.12 21:01:41 - Checking DNS ! 2019.09.12 21:01:41 - Connected. . 2019.09.12 21:01:41 - OpenVPN > Initialization Sequence Completed . 2019.09.12 21:03:24 - Updating systems & servers data ... . 2019.09.12 21:03:26 - Systems & servers data update completed ---------------------------- Network Interfaces and Routes: { "support_ipv4": true, "support_ipv6": true, "routes": [ { "address": "0.0.0.0\/0", "interface": "{96F37CCE-DE3E-467F-A916-558F37FF4D42}", "gateway": "192.168.0.1", "metric": "55" }, { "address": "0.0.0.0\/1", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "10.9.90.1", "metric": "3" }, { "address": "10.9.90.0\/24", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "link", "metric": "259" }, { "address": "10.9.90.227", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "link", "metric": "259" }, { "address": "10.9.90.255", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "link", "metric": "259" }, { "address": "109.202.103.170", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "10.9.90.1", "metric": "4" }, { "address": "109.202.103.173", "interface": "{96F37CCE-DE3E-467F-A916-558F37FF4D42}", "gateway": "192.168.0.1", "metric": "55" }, { "address": "127.0.0.0\/8", "interface": "{B62F1F46-D65B-11E7-B89A-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.0.0.1", "interface": "{B62F1F46-D65B-11E7-B89A-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.255.255.255", "interface": "{B62F1F46-D65B-11E7-B89A-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "128.0.0.0\/1", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "10.9.90.1", "metric": "3" }, { "address": "192.168.0.0\/24", "interface": "{96F37CCE-DE3E-467F-A916-558F37FF4D42}", "gateway": "link", "metric": "311" }, { "address": "192.168.0.23", "interface": "{96F37CCE-DE3E-467F-A916-558F37FF4D42}", "gateway": "link", "metric": "311" }, { "address": "192.168.0.255", "interface": "{96F37CCE-DE3E-467F-A916-558F37FF4D42}", "gateway": "link", "metric": "311" }, { "address": "224.0.0.0\/4", "interface": "{B62F1F46-D65B-11E7-B89A-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "224.0.0.0\/4", "interface": "{96F37CCE-DE3E-467F-A916-558F37FF4D42}", "gateway": "link", "metric": "311" }, { "address": "224.0.0.0\/4", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "link", "metric": "259" }, { "address": "255.255.255.255", "interface": "{B62F1F46-D65B-11E7-B89A-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "255.255.255.255", "interface": "{96F37CCE-DE3E-467F-A916-558F37FF4D42}", "gateway": "link", "metric": "311" }, { "address": "255.255.255.255", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "link", "metric": "259" }, { "address": "::\/3", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "fe80::8", "metric": "259" }, { "address": "::1", "interface": "{B62F1F46-D65B-11E7-B89A-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "2000::\/4", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "fe80::8", "metric": "259" }, { "address": "2a00:1678:2470:7:7265:24fc:ff33:113b", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "fde6:7a:7d20:55a::1", "metric": "259" }, { "address": "3000::\/4", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "fe80::8", "metric": "259" }, { "address": "fc00::\/7", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "fe80::8", "metric": "259" }, { "address": "fde6:7a:7d20:55a::\/64", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "fe80::8", "metric": "259" }, { "address": "fde6:7a:7d20:55a::10e1", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "link", "metric": "259" }, { "address": "fe80::\/64", "interface": "{96F37CCE-DE3E-467F-A916-558F37FF4D42}", "gateway": "link", "metric": "311" }, { "address": "fe80::\/64", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "link", "metric": "259" }, { "address": "fe80::863:3369:2876:7ccd", "interface": "{96F37CCE-DE3E-467F-A916-558F37FF4D42}", "gateway": "link", "metric": "311" }, { "address": "fe80::148c:f372:cd1a:408b", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "link", "metric": "259" }, { "address": "ff00::\/8", "interface": "{B62F1F46-D65B-11E7-B89A-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "ff00::\/8", "interface": "{96F37CCE-DE3E-467F-A916-558F37FF4D42}", "gateway": "link", "metric": "311" }, { "address": "ff00::\/8", "interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "gateway": "link", "metric": "259" }, { "address": "2a00:1678:2470:7:7265:24fc:ff33:113b", "gateway": "fde6:7a:7d20:55a::1", "metric": "4294967295" } ], "interfaces": [ { "friendly": "Ethernet 4", "id": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "name": "Ethernet 4", "description": "TAP-Windows Adapter V9 #2", "type": "Ethernet", "status": "Up", "bytes_received": "391059743", "bytes_sent": "47517729", "support_ipv4": true, "support_ipv6": true, "ips": [ "fde6:7a:7d20:55a::10e1", "fe80::148c:f372:cd1a:408b", "10.9.90.227" ], "gateways": [ "10.9.90.1", "fe80::8", "fde6:7a:7d20:55a::1" ], "bind": true, "dns4": "10.9.90.1", "dns6": null }, { "friendly": "Ethernet", "id": "{9F9254C8-24A3-451D-BCFB-21FFE65B2695}", "name": "Ethernet", "description": "Realtek PCIe GBE Family Controller", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::9dc1:da73:2551:773e", "169.254.119.62" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection* 4", "id": "{5CD26EBB-CB31-4B69-AECF-A8F1F941C8E2}", "name": "Local Area Connection* 4", "description": "Microsoft Wi-Fi Direct Virtual Adapter #3", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::8ccc:8efc:1f66:3ee9", "169.254.62.233" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection* 5", "id": "{1E942638-C857-448D-956B-C5CDDF087D60}", "name": "Local Area Connection* 5", "description": "Microsoft Wi-Fi Direct Virtual Adapter #4", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::844c:ae3e:52b8:fa79", "169.254.250.121" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Wi-Fi", "id": "{96F37CCE-DE3E-467F-A916-558F37FF4D42}", "name": "Wi-Fi", "description": "Intel(R) Dual Band Wireless-AC 7265", "type": "Wireless80211", "status": "Up", "bytes_received": "5224550681", "bytes_sent": "2627593684", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::863:3369:2876:7ccd", "192.168.0.23" ], "gateways": [ "192.168.0.1" ], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Bluetooth Network Connection", "id": "{C54D0E32-B84A-401F-A3AF-A634C4F59CE6}", "name": "Bluetooth Network Connection", "description": "Bluetooth PAN HelpText", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::eda9:c5e5:5465:1210", "169.254.18.16" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Loopback Pseudo-Interface 1", "id": "{B62F1F46-D65B-11E7-B89A-806E6F6E6963}", "name": "Loopback Pseudo-Interface 1", "description": "Software Loopback Interface 1", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "::1", "127.0.0.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null } ], "ipv4-default-gateway": "10.9.90.1", "ipv4-default-interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}", "ipv6-default-gateway": "fe80::8", "ipv6-default-interface": "{EC5D0326-55CA-4233-B026-CDC459606FF8}" } ---------------------------- ipconfig /all: Windows IP Configuration Host Name . . . . . . . . . . . . : DESKTOP-V5L4NQO Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : tds Ethernet adapter Ethernet 4: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : TAP-Windows Adapter V9 #2 Physical Address. . . . . . . . . : 00-FF-EC-5D-03-26 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : fde6:7a:7d20:55a::10e1(Preferred) Link-local IPv6 Address . . . . . : fe80::148c:f372:cd1a:408b%23(Preferred) IPv4 Address. . . . . . . . . . . : 10.9.90.227(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Thursday, September 12, 2019 9:01:24 PM Lease Expires . . . . . . . . . . : Friday, September 11, 2020 9:01:24 PM Default Gateway . . . . . . . . . : DHCP Server . . . . . . . . . . . : 10.9.90.254 DHCPv6 IAID . . . . . . . . . . . : 755040236 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1E-55-A9-6D-9C-5C-8E-37-17-9C DNS Servers . . . . . . . . . . . : fde6:7a:7d20:55a::1 10.9.90.1 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Ethernet: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller Physical Address. . . . . . . . . : 9C-5C-8E-37-17-9C DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Local Area Connection* 4: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #3 Physical Address. . . . . . . . . : 10-02-B5-86-59-5D DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Local Area Connection* 5: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #4 Physical Address. . . . . . . . . : 12-02-B5-86-59-5C DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Wi-Fi: Connection-specific DNS Suffix . : tds Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 7265 Physical Address. . . . . . . . . : 10-02-B5-86-59-5C DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::863:3369:2876:7ccd%15(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.0.23(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Wednesday, September 11, 2019 8:57:31 PM Lease Expires . . . . . . . . . . : Friday, September 13, 2019 7:14:45 PM Default Gateway . . . . . . . . . : 192.168.0.1 DHCP Server . . . . . . . . . . . : 192.168.0.1 DHCPv6 IAID . . . . . . . . . . . : 84935349 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1E-55-A9-6D-9C-5C-8E-37-17-9C DNS Servers . . . . . . . . . . . : 192.168.0.1 216.170.153.146 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Bluetooth Network Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Bluetooth PAN HelpText Physical Address. . . . . . . . . : 10-02-B5-86-59-60 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Sorry if that's way too many logs, I don't really know what to include specifically Edited ... by giganerd Formatting for logs Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... Can you try disabling IPv6? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
BlueBanana 39 Posted ... I remember there has been an issue with the TAP - Driver on Windows a couple of years ago, also speed related: https://airvpn.org/forums/topic/16573-tap-driver-9210-causing-a-myriad-of-issues/ You can try downgrading to TAP - Windows 9.9.2, but i don't know if it makes sense to use such an old software with Windows 10. When i had my Windows machine, i also had some speed issues, and replacing the TAP-Driver fixed it. But i don't know if it is still the way to go. Since i don't run Windows anymore, i am not able to test it. Regards BB Quote Hide BlueBanana's signature Hide all signatures AMD Ryzen 3950X @ 105W PPL Gigabyte X570 Aorus Elite Nvidia RTX 4070 Ti Super Corsair DDR4-3200 32GB Share this post Link to post
Flx 77 Posted ... On 9/12/2019 at 10:09 PM, ethanb79 said: OpenVPN driver: TAP-Windows Adapter V9 #2, version 9.21.2 See if you can update your TAP adapter to the latest.tap-windows-9.23.3-I601-Win10.exe.zip Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
ethanb79 1 Posted ... updating my TAP adapter did the trick. thanks so much guys 1 Flx reacted to this Quote Share this post Link to post
