notgund1
ANSWERED Switching repetetively between servers
I´ve been using eddie client for months now and have had 3 servers that I mostly use without any problems. But now in the past weeks I´ve noticed that the client has been switching between those 3 servers repetetively during my connection. This causes problems with these IP changes. Mostly with torrenting but also having to refresh any activity im doing when this happens.
Hello Notgund1,
I am by no means an expert, but If you want someone to be able to help you, they will need more information.
Like the operating system you are using, and logs from Eddie so they can figure out the reason why it is happening to you.
Have you tried using different ports and connection protocols, to see if it still happens? Just out of curiosity?
