sableslayer 1 Posted ... Hello , I'm using eddie-cli armhf portable on one of my SBCs and been trying to whitelist internal traffic with -netlock. Is there some option to force tunneling and still whitelist my internal ip range so i can reach ssh?? Thank you! Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... It's already normal behavior that local traffic is not routed through the VPN. The --netlock.allow_private option is used to control that, but it defaults to true already, so it should work. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
sableslayer 1 Posted ... $ sudo /home/rock64/.eddie-cli_2.16.3_linux_armhf_portable/eddie-cli -login=**** -password=**** --netlock.allow_private -connect exception inside UnhandledException handler: Object reference not set to an instance of an object [ERROR] FATAL UNHANDLED EXCEPTION: System.DllNotFoundException: Lib.Platform.Linux.Native.so at (wrapper managed-to-native) Eddie.Platform.Linux.NativeMethods:eddie_signal (int,Eddie.Platform.Linux.NativeMethods/eddie_sighandler) at Eddie.Platform.Linux.NativeMethods.Signal (System.Int32 signum, Eddie.Platform.Linux.NativeMethods+eddie_sighandler handler) [0x00000] in <1a3bcbd9ff4c4d73ad6d40616d94b558>:0 at Eddie.Platform.Linux.Platform.OnInit (System.Boolean cli) [0x0020e] in <1a3bcbd9ff4c4d73ad6d40616d94b558>:0 at Eddie.Core.Engine.Initialization (System.Boolean cli) [0x00000] in <3be0437ef3624232adf6091382fd1690>:0 at Eddie.CLI.Linux.MainClass.Main (System.String[] args) [0x00030] in <7501db3f6411483fbe2e6a08141919e4>:0 $ sudo /home/rock64/.eddie-cli_2.16.3_linux_armhf_portable/eddie-cli -login=**** -password=**** -netlock.allow_private -connect exception inside UnhandledException handler: Object reference not set to an instance of an object [ERROR] FATAL UNHANDLED EXCEPTION: System.DllNotFoundException: Lib.Platform.Linux.Native.so at (wrapper managed-to-native) Eddie.Platform.Linux.NativeMethods:eddie_signal (int,Eddie.Platform.Linux.NativeMethods/eddie_sighandler) at Eddie.Platform.Linux.NativeMethods.Signal (System.Int32 signum, Eddie.Platform.Linux.NativeMethods+eddie_sighandler handler) [0x00000] in <1a3bcbd9ff4c4d73ad6d40616d94b558>:0 at Eddie.Platform.Linux.Platform.OnInit (System.Boolean cli) [0x0020e] in <1a3bcbd9ff4c4d73ad6d40616d94b558>:0 at Eddie.Core.Engine.Initialization (System.Boolean cli) [0x00000] in <3be0437ef3624232adf6091382fd1690>:0 at Eddie.CLI.Linux.MainClass.Main (System.String[] args) [0x00030] in <7501db3f6411483fbe2e6a08141919e4>:0 Couldnt get it to run with that option. Any suggestion? I know it works without netlock but im trying to force tunnelling so that my nodes dont leak data but i can still connect to ssh locally. Seems like i need to setup some iptable rules if theirs no option like their is in the gui for whitelisting ip ranges. Quote Share this post Link to post
sableslayer 1 Posted ... --Use vpn for all traffic except local. sudo ufw default deny incoming sudo ufw default deny outgoing sudo ufw allow out on tun0 sudo ufw allow in on tun0 sudo ufw allow from 192.168.1.1/24 ##edit to your own subnet. sudo ufw allow out ip port ##change the ip and port to the vpn's - Quote Share this post Link to post
