dullaxpress 0 Posted ... Hey, i got AirVPN yesterday and i cannot connected [Eddie UI, OpenVPN, ...] wont connect to any server from AirVPN its just stuck at connecting then just disconnecting and so on.. i tried every solution possible. i had before nVPN with openvpn gui and it worked fine.. i deleted it then got AirVPN but it wont connect tried every solution possible if this not gonna work for me i want a refund asap Quote Share this post Link to post
Tech Jedi Alex 1585 Posted ... Let's calm down a bit. Can you please first post the Eddie log here? Use the LOG button in the top left corner of the editor and paste them in the box that appears. Edit: Okay, you found a workaround. But let's still try to get down to the bottom of all. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
vv52 0 Posted ... Hello, Same situation here. Since yesterday i can't connect to any server. No new software was intstalled etc, even windows patches. Log with TCP (udp doesnt work either): I 2019.06.27 17:45:38 - Session starting. I 2019.06.27 17:45:38 - Checking authorization ... ! 2019.06.27 17:45:38 - Connecting to Cervantes (Germany, Frankfurt) . 2019.06.27 17:45:38 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2019.06.27 17:45:38 - OpenVPN > Windows version 6.1 (Windows 7) 64bit . 2019.06.27 17:45:38 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.06.27 17:45:38 - Connection to OpenVPN Management Interface . 2019.06.27 17:45:38 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.06.27 17:45:38 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.06.27 17:45:38 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.06.27 17:45:38 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.06.27 17:45:38 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.06.27 17:45:38 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET6]2001:ac8:20:2c:8efe:ed7:7e97:6f97:443 . 2019.06.27 17:45:38 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144] . 2019.06.27 17:45:38 - OpenVPN > Attempting to establish TCP connection with [AF_INET6]2001:ac8:20:2c:8efe:ed7:7e97:6f97:443 [nonblock] . 2019.06.27 17:45:38 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 Quote Share this post Link to post
Tech Jedi Alex 1585 Posted ... Open your own threads, please, your setups are NOT the same and helping two people at the same time never works. Besides, by posting in threads of others you are actually hijacking. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
vv52 0 Posted ... Ok no prob, i can also raise a ticket but i think our problems match. Quote Share this post Link to post
