JSD
Two suggestions about settings of Eddie
Two suggestions:
a) Let Network Lock be enabled by default, at least at systems where it works well without sincere problems.
Why?
1. The vast majority of users do not have any reason NOT to enable it, but want to be protected from any “leaks” and be on the safe side.
2. Those who need to disable Network Lock will – on average – also be the technically more competent people. So it will be no problem for them do disable Network Lock.
b) When Network Lock is enabled, prevent pinging to any Non-Air-Vpn-servers by default.
Why?
1. Most people do not need such a ping, but it might be harmful in some situations (torrenting).
2. Those who need ping together with Network Lock being enabled will also be those who are more technically competent.
The vast majority of Linux users will find themselves locked out of their internet connection by default because the current version does not properly revert back from it automatically. At least on some distributions. It's a temporary thing, of course.
I personally tend to go with the least surprising way of programming. It's called the Principle of Least Astonishment and is regarded as a golden rule of it. Now, a program locking your internet access and restricting it to only when you are connected to AirVPN the minute you open it will tell users "thanks for launching our client, that will be 2€ for three days, please". There is the preference of enabling it when the client is started, of course, but when you tick that box you will, on the contrary, expect it to restrict you to AirVPN servers. :)
a) There was a post from Staff some time ago detailing why they didn't do this by default but I can't find it anymore :(
b) Problem is: Windows version = macOS version = Linux version. If you do this on one you will carry it to the other two.
