retroschlampe 0 Posted ... My problem is that, I can't connect to any server with Eddie from my account and on all platforms Quote Share this post Link to post
Tech Jedi Alex 1586 Posted ... Then we need more info on your setup, especially network-wise. Do you use WLAN or a cable? Which router are you using? ISP? Which servers, ports and protocols are you trying in the clients? And above all, which clients on which versions? Does it work outside your network? All these things are there in the logs, by the way. If you decide to paste them, use the LOG preformat in the upper left corner of the editor window and paste them in the grey box that appears. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
retroschlampe 0 Posted ... Hi,My ISP is Orange in France. Before it worked very well especially in 4g. Today, it is impossible to connect. He is trying to connect to a recommended server without logging in? Before, I did not need to change ports and protocols. Eddie is trying to connect but does not connect even with a cable RG45 that itself on Windows or Debian? Quote Share this post Link to post
Tech Jedi Alex 1586 Posted ... I'm not sure whether it was my mistake, but you click on the LOG button and a grey box appears. You copy the logs from Eddie (which is under the Logs tab in the client) and you paste it into that box. 2 hours ago, retroschlampe said: He is trying to connect to a recommended server without logging in? I'm quite sure Eddie logs in automatically and follows the preference to autoconnect to the recommended server. Both can be changed. 2 hours ago, retroschlampe said: Eddie is trying to connect but does not connect even with a cable RG45 that itself on Windows or Debian? Hm. I'd say, maybe something changed in your router, automatic update with some added or changed functionality, but if it neither works on mobile nor over "fixed" internet and neither on Windows nor on Linux, the options get extremely thin... Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Kurkul 0 Posted ... Hi, I have the same problem right now that I can't connect to any AirVPN server. It is no problem to use just Internet without connection true Eddie, but when I try to connect to AirVPN server I have that: I 2019.06.21 08:59:40 - Session starting. I 2019.06.21 08:59:40 - Checking authorization ... ! 2019.06.21 08:59:40 - Connecting to Albali (Sweden, Uppsala) . 2019.06.21 08:59:40 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2019.06.21 08:59:40 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2019.06.21 08:59:40 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.06.21 08:59:40 - Connection to OpenVPN Management Interface . 2019.06.21 08:59:40 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.06.21 08:59:40 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.06.21 08:59:40 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.06.21 08:59:40 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.06.21 08:59:40 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.06.21 08:59:40 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]XXX.XXX.XXX.XXX:443 . 2019.06.21 08:59:40 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2019.06.21 08:59:40 - OpenVPN > UDP link local: (not bound) . 2019.06.21 08:59:40 - OpenVPN > UDP link remote: [AF_INET]XXX.XXX.XXX.XXX:443 . 2019.06.21 08:59:40 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2019.06.21 09:00:12 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2019.06.21 09:00:12 - OpenVPN > SIGTERM received, sending exit notification to peer . 2019.06.21 09:00:17 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2019.06.21 09:00:17 - Disconnecting Quote Share this post Link to post
lunkrai213 0 Posted ... Same here 404 Error with new Windows Client and Linux. any help is appreciated fixed: url blocker of my router didn't allow access to IP addresses directly, which seems to be needed for the air vpn client. Quote Share this post Link to post
