Combat 1 Posted ... Recently, when I use torrent with VPN active, Eddie is crashing after some time and it says Disconnecting endlessly. I have tested various torrent clients, always with the same results. When this happens, I can't disable Eddie normally and the only way to do it's from Task Manager. Since I don't know what the cause of the problem is, I would like to disable my anvitirus software for a few hours while torrenting, to take a test. Is it safe to torrenting without antivirus, only with VPN active? To take the test, I need to disable it only during download. Sorry if my English is not good. Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... Make exceptions for Eddie and all binaries in its directory, especially openvpn.exe. But generally, yes, it's safe. 3 hours ago, Combat said: Recently, when I use torrent with VPN active, Eddie is crashing after some time and it says Disconnecting endlessly. But I'd like to look at the logs while this happens. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
zhang888 1067 Posted ... Depends what you download and especially where from. Antiviruses are not a replacement for common sense. Generally, avoid opening any non media file, no matter how much the source seems to be trusted. Avoid cracked Windows apps as well, those has zero confidence and you will never be able to verify that what you actually downloaded is malware free. For everything questionable use virustotal.com, 50 anti-virus engines are better than 1 installed. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
Combat 1 Posted ... 19 hours ago, giganerd said: Make exceptions for Eddie and all binaries in its directory, especially openvpn.exe. But generally, yes, it's safe. But I'd like to look at the logs while this happens. I've already added the entire folder to exceptions, with same results. Logs says "Signal SIGTERM" endlessly. Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... Disable it completely and try again. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
