Tamarrano
no connection to any server ......please fix it
I cannot connect to any server ,,,,
this is the first time since I have this vpn that does not work ......
here my log
Serverlog Clientlog 20120915 08:05:28 Expected Remote Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-server'
20120915 08:05:28 Local Options hash (VER=V4): '22188c5b'
20120915 08:05:28 Expected Remote Options hash (VER=V4): 'a8f55717'
20120915 08:05:28 I UDPv4 link local: [undef]
20120915 08:05:28 I UDPv4 link remote: 46.165.208.65:443
20120915 08:06:28 N TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
20120915 08:06:28 N TLS Error: TLS handshake failed
20120915 08:06:28 TCP/UDP: Closing socket
20120915 08:06:28 I SIGUSR1[soft tls-error] received process restarting
20120915 08:06:28 Restart pause 2 second(s)
20120915 08:06:30 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20120915 08:06:30 I Re-using SSL/TLS context
20120915 08:06:30 I LZO compression initialized
20120915 08:06:30 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
20120915 08:06:30 Socket Buffers: R=[163840->131072] S=[163840->131072]
20120915 08:06:30 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
20120915 08:06:30 Local Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-client'
20120915 08:06:30 Expected Remote Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-server'
20120915 08:06:30 Local Options hash (VER=V4): '22188c5b'
20120915 08:06:30 Expected Remote Options hash (VER=V4): 'a8f55717'
20120915 08:06:30 I UDPv4 link local: [undef]
20120915 08:06:30 I UDPv4 link remote: 46.165.208.65:443
20120915 08:07:30 N TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
20120915 08:07:30 N TLS Error: TLS handshake failed
20120915 08:07:30 TCP/UDP: Closing socket
20120915 08:07:30 I SIGUSR1[soft tls-error] received process restarting
20120915 08:07:30 Restart pause 2 second(s)
20120915 08:07:32 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20120915 08:07:32 I Re-using SSL/TLS context
20120915 08:07:32 I LZO compression initialized
20120915 08:07:32 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
20120915 08:07:32 Socket Buffers: R=[163840->131072] S=[163840->131072]
20120915 08:07:32 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
20120915 08:07:32 Local Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-client'
20120915 08:07:32 Expected Remote Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-server'
20120915 08:07:32 Local Options hash (VER=V4): '22188c5b'
20120915 08:07:32 Expected Remote Options hash (VER=V4): 'a8f55717'
20120915 08:07:32 I UDPv4 link local: [undef]
20120915 08:07:32 I UDPv4 link remote: 46.165.208.65:443
20120915 08:07:46 MANAGEMENT: Client connected from 127.0.0.1:5001
20120915 08:07:46 D MANAGEMENT: CMD 'state'
20120915 08:07:46 MANAGEMENT: Client disconnected
20120915 08:07:46 D MANAGEMENT: CMD 'log 500'
19700101 00:00:00
I am having the same problem please help.I have tried ever server using TCP and UDP with the client and without.
9/15/2012 - 1:49 AM AirVPN client version: 1.7
9/15/2012 - 1:49 AM Reading options from C:\Users\mypc\AppData\Roaming
\AirVPN\Air\1.0.0.0\AirVPN.xml
9/15/2012 - 1:49 AM OpenVPN bundle version: OpenVPN 2.2.2
9/15/2012 - 1:49 AM OpenVPN current version: OpenVPN 2.2.2
9/15/2012 - 1:49 AM Ready.
9/15/2012 - 1:49 AM Login...
9/15/2012 - 1:49 AM Login success.
9/15/2012 - 1:49 AM Contacting service...
9/15/2012 - 1:49 AM Connecting...
9/15/2012 - 1:49 AM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built
on Dec 15 2011
9/15/2012 - 1:49 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or
higher to call user-defined scripts or executables
9/15/2012 - 1:49 AM LZO compression initialized
9/15/2012 - 1:49 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0
ET:0 EL:0 ]
9/15/2012 - 1:49 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
9/15/2012 - 1:49 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135
ET:0 EL:0 AF:3/1 ]
9/15/2012 - 1:49 AM Local Options hash (VER=V4): '22188c5b'
9/15/2012 - 1:49 AM Expected Remote Options hash (VER=V4): 'a8f55717'
9/15/2012 - 1:49 AM UDPv4 link local: [undef]
9/15/2012 - 1:49 AM UDPv4 link remote: 31.193.12.74:80
9/15/2012 - 1:50 AM TLS Error: TLS key negotiation failed to occur within
9/15/2012 - 1:50 AM TLS Error: TLS handshake failed
9/15/2012 - 1:50 AM TCP/UDP: Closing socket
9/15/2012 - 1:50 AM SIGUSR1[soft,tls-error] received, process restarting
9/15/2012 - 1:50 AM Restart pause, 2 second(s)
9/15/2012 - 1:50 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or
9/15/2012 - 1:50 AM LZO compression initialized
9/15/2012 - 1:50 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0
ET:0 EL:0 ]
9/15/2012 - 1:50 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
9/15/2012 - 1:50 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135
ET:0 EL:0 AF:3/1 ]
9/15/2012 - 1:50 AM Local Options hash (VER=V4): '22188c5b'
9/15/2012 - 1:50 AM Expected Remote Options hash (VER=V4): 'a8f55717'
9/15/2012 - 1:50 AM UDPv4 link local: [undef]
9/15/2012 - 1:50 AM UDPv4 link remote: 31.193.12.74:80
9/15/2012 - 1:51 AM TLS: Initial packet from 31.193.12.74:80, sid=fd92d513
9fa6fda5
9/15/2012 - 1:51 AM VERIFY OK: depth=1,
/C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.o
rg
9/15/2012 - 1:51 AM VERIFY OK: nsCertType=SERVER
9/15/2012 - 1:51 AM VERIFY OK: depth=0,
/C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
9/15/2012 - 1:51 AM TLS Error: TLS key negotiation failed to occur within
9/15/2012 - 1:51 AM TLS Error: TLS handshake failed
9/15/2012 - 1:51 AM TCP/UDP: Closing socket
9/15/2012 - 1:51 AM SIGUSR1[soft,tls-error] received, process restarting
9/15/2012 - 1:51 AM Restart pause, 2 second(s)
9/15/2012 - 1:51 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or
9/15/2012 - 1:51 AM LZO compression initialized
9/15/2012 - 1:51 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0
ET:0 EL:0 ]
9/15/2012 - 1:51 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
9/15/2012 - 1:51 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135
ET:0 EL:0 AF:3/1 ]
9/15/2012 - 1:51 AM Local Options hash (VER=V4): '22188c5b'
9/15/2012 - 1:51 AM Expected Remote Options hash (VER=V4): 'a8f55717'
9/15/2012 - 1:51 AM UDPv4 link local: [undef]
9/15/2012 - 1:51 AM UDPv4 link remote: 31.193.12.74:80
9/15/2012 - 1:52 AM Disconnecting...
9/15/2012 - 1:52 AM Disconnected.
9/15/2012 - 1:52 AM Login...
9/15/2012 - 1:52 AM Login success.
9/15/2012 - 1:53 AM Contacting service...
9/15/2012 - 1:53 AM Connecting...
9/15/2012 - 1:53 AM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built
on Dec 15 2011
9/15/2012 - 1:53 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or
9/15/2012 - 1:53 AM LZO compression initialized
9/15/2012 - 1:53 AM Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0
ET:0 EL:0 ]
9/15/2012 - 1:53 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
9/15/2012 - 1:53 AM Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135
ET:0 EL:0 AF:3/1 ]
9/15/2012 - 1:53 AM Local Options hash (VER=V4): '958c5492'
9/15/2012 - 1:53 AM Expected Remote Options hash (VER=V4): '79ef4284'
9/15/2012 - 1:53 AM Attempting to establish TCP connection with
31.193.12.98:80
9/15/2012 - 1:53 AM TCP connection established with 31.193.12.98:80
9/15/2012 - 1:53 AM TCPv4_CLIENT link local: [undef]
9/15/2012 - 1:53 AM TCPv4_CLIENT link remote: 31.193.12.98:80
9/15/2012 - 1:54 AM TLS Error: TLS key negotiation failed to occur within
9/15/2012 - 1:54 AM TLS Error: TLS handshake failed
9/15/2012 - 1:54 AM Fatal TLS error (check_tls_errors_co), restarting
9/15/2012 - 1:54 AM TCP/UDP: Closing socket
9/15/2012 - 1:54 AM SIGUSR1[soft,tls-error] received, process restarting
9/15/2012 - 1:54 AM Restart pause, 5 second(s)
9/15/2012 - 1:54 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or
9/15/2012 - 1:54 AM LZO compression initialized
9/15/2012 - 1:54 AM Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0
ET:0 EL:0 ]
9/15/2012 - 1:54 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
9/15/2012 - 1:54 AM Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135
ET:0 EL:0 AF:3/1 ]
9/15/2012 - 1:54 AM Local Options hash (VER=V4): '958c5492'
9/15/2012 - 1:54 AM Expected Remote Options hash (VER=V4): '79ef4284'
9/15/2012 - 1:54 AM Attempting to establish TCP connection with
31.193.12.98:80
9/15/2012 - 1:54 AM TCP connection established with 31.193.12.98:80
9/15/2012 - 1:54 AM TCPv4_CLIENT link local: [undef]
9/15/2012 - 1:54 AM TCPv4_CLIENT link remote: 31.193.12.98:80
9/15/2012 - 1:54 AM TLS: Initial packet from 31.193.12.98:80, sid=d4f208bc
631e6da4
9/15/2012 - 1:54 AM VERIFY OK: depth=1,
rg
9/15/2012 - 1:54 AM VERIFY OK: nsCertType=SERVER
9/15/2012 - 1:54 AM VERIFY OK: depth=0,
9/15/2012 - 1:54 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized
with 256 bit key
9/15/2012 - 1:54 AM Data Channel Encrypt: Using 160 bit message hash
'SHA1' for HMAC authentication
9/15/2012 - 1:54 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized
with 256 bit key
9/15/2012 - 1:54 AM Data Channel Decrypt: Using 160 bit message hash
9/15/2012 - 1:54 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-
AES256-SHA, 2048 bit RSA
9/15/2012 - 1:54 AM [server] Peer Connection Initiated with
31.193.12.98:80
9/15/2012 - 1:54 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
9/15/2012 - 1:55 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Same problem here as well... I cannot connect to any server.
2012-09-14 23:33:19 *Tunnelblick: OS X 10.6.8; Tunnelblick 3.2.8 (build 2891.3099)
2012-09-14 23:33:19 *Tunnelblick: Attempting connection with London using shadow copy; Set nameserver = 1; monitoring connection
2012-09-14 23:33:19 *Tunnelblick: /Applications/Tunnelblick.app/Contents/Resources/openvpnstart start London.tblk 1337 1 0 1 0 49 -atDASNGWrdasngw
2012-09-14 23:33:19 *Tunnelblick: openvpnstart message: Loading tun.kext
2012-09-14 23:33:19 *Tunnelblick: Established communication with OpenVPN
2012-09-14 23:33:19 OpenVPN 2.2.1 i386-apple-darwin10.8.0 [sSL] [LZO2] [PKCS11] [eurephia] built on Aug 10 2012
2012-09-14 23:33:19 MANAGEMENT: TCP Socket listening on 127.0.0.1:1337
2012-09-14 23:33:19 Need hold release from management interface, waiting...
2012-09-14 23:33:19 MANAGEMENT: Client connected from 127.0.0.1:1337
2012-09-14 23:33:19 MANAGEMENT: CMD 'pid'
2012-09-14 23:33:19 MANAGEMENT: CMD 'state on'
2012-09-14 23:33:19 MANAGEMENT: CMD 'state'
2012-09-14 23:33:19 MANAGEMENT: CMD 'hold release'
2012-09-14 23:33:19 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2012-09-14 23:33:19 WARNING: file 'user.key' is group or others accessible
2012-09-14 23:33:19 LZO compression initialized
2012-09-14 23:33:19 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2012-09-14 23:33:19 Socket Buffers: R=[42080->65536] S=[9216->65536]
2012-09-14 23:33:19 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2012-09-14 23:33:19 Local Options hash (VER=V4): '22188c5b'
2012-09-14 23:33:19 Expected Remote Options hash (VER=V4): 'a8f55717'
2012-09-14 23:33:19 UDPv4 link local: [undef]
2012-09-14 23:33:19 UDPv4 link remote: 146.185.25.170:443
2012-09-14 23:33:19 MANAGEMENT: >STATE:1347690799,WAIT,,,
2012-09-14 23:33:19 *Tunnelblick: openvpnstart: /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Library/Application Support/Tunnelblick/Users/MPower/London.tblk/Contents/Resources --daemon --management 127.0.0.1 1337 --config /Library/Application Support/Tunnelblick/Users/MPower/London.tblk/Contents/Resources/config.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-SMPower-SLibrary-SApplication Support-STunnelblick-SConfigurations-SLondon.tblk-SContents-SResources-Sconfig.ovpn.1_0_1_0_49.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw --up-restart
2012-09-14 23:34:19 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2012-09-14 23:34:19 TLS Error: TLS handshake failed
2012-09-14 23:34:19 TCP/UDP: Closing socket
2012-09-14 23:34:19 SIGUSR1[soft,tls-error] received, process restarting
2012-09-14 23:34:19 MANAGEMENT: >STATE:1347690859,RECONNECTING,tls-error,,
2012-09-14 23:34:19 MANAGEMENT: CMD 'hold release'
2012-09-14 23:34:19 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2012-09-14 23:34:19 WARNING: file 'user.key' is group or others accessible
2012-09-14 23:34:19 LZO compression initialized
2012-09-14 23:34:19 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2012-09-14 23:34:19 Socket Buffers: R=[42080->65536] S=[9216->65536]
2012-09-14 23:34:19 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2012-09-14 23:34:19 Local Options hash (VER=V4): '22188c5b'
2012-09-14 23:34:19 Expected Remote Options hash (VER=V4): 'a8f55717'
2012-09-14 23:34:19 UDPv4 link local: [undef]
2012-09-14 23:34:19 UDPv4 link remote: 146.185.25.170:443
2012-09-14 23:34:19 MANAGEMENT: >STATE:1347690859,WAIT,,,
2012-09-14 23:35:20 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2012-09-14 23:35:20 TLS Error: TLS handshake failed
2012-09-14 23:35:20 TCP/UDP: Closing socket
2012-09-14 23:35:20 SIGUSR1[soft,tls-error] received, process restarting
2012-09-14 23:35:20 MANAGEMENT: >STATE:1347690920,RECONNECTING,tls-error,,
2012-09-14 23:35:20 MANAGEMENT: CMD 'hold release'
2012-09-14 23:35:20 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2012-09-14 23:35:20 WARNING: file 'user.key' is group or others accessible
2012-09-14 23:35:20 LZO compression initialized
2012-09-14 23:35:20 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2012-09-14 23:35:20 Socket Buffers: R=[42080->65536] S=[9216->65536]
2012-09-14 23:35:20 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2012-09-14 23:35:20 Local Options hash (VER=V4): '22188c5b'
2012-09-14 23:35:20 Expected Remote Options hash (VER=V4): 'a8f55717'
2012-09-14 23:35:20 UDPv4 link local: [undef]
2012-09-14 23:35:20 UDPv4 link remote: 146.185.25.170:443
2012-09-14 23:35:20 MANAGEMENT: >STATE:1347690920,WAIT,,,
Same problem here
2012-09-15 09:26:27 *Tunnelblick: OS X 10.7.3; Tunnelblick 3.2.8 (build 2891.3099)
2012-09-15 09:26:27 *Tunnelblick: Attempting connection with AirVPN NL Leporis - UDP 443; Set nameserver = 1; monitoring connection
2012-09-15 09:26:27 *Tunnelblick: /Applications/Tunnelblick.app/Contents/Resources/openvpnstart start AirVPN\ NL\ Leporis\ -\ UDP\ 443.tblk 1337 1 0 0 0 49 -atDASNGWrdasngw
2012-09-15 09:26:28 *Tunnelblick: openvpnstart message: Loading tun.kext
2012-09-15 09:26:28 *Tunnelblick: Established communication with OpenVPN
2012-09-15 09:26:28 OpenVPN 2.2.1 i386-apple-darwin10.8.0 [sSL] [LZO2] [PKCS11] [eurephia] built on Aug 10 2012
2012-09-15 09:26:28 MANAGEMENT: TCP Socket listening on 127.0.0.1:1337
2012-09-15 09:26:28 Need hold release from management interface, waiting...
2012-09-15 09:26:28 MANAGEMENT: Client connected from 127.0.0.1:1337
2012-09-15 09:26:28 MANAGEMENT: CMD 'pid'
2012-09-15 09:26:28 MANAGEMENT: CMD 'state on'
2012-09-15 09:26:28 MANAGEMENT: CMD 'state'
2012-09-15 09:26:28 MANAGEMENT: CMD 'hold release'
2012-09-15 09:26:28 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2012-09-15 09:26:28 LZO compression initialized
2012-09-15 09:26:28 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2012-09-15 09:26:28 Socket Buffers: R=[42080->65536] S=[9216->65536]
2012-09-15 09:26:28 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2012-09-15 09:26:28 Local Options hash (VER=V4): '22188c5b'
2012-09-15 09:26:28 Expected Remote Options hash (VER=V4): 'a8f55717'
2012-09-15 09:26:28 UDPv4 link local: [undef]
2012-09-15 09:26:28 UDPv4 link remote: 95.211.191.33:443
2012-09-15 09:26:28 MANAGEMENT: >STATE:1347693988,WAIT,,,
2012-09-15 09:26:28 *Tunnelblick: openvpnstart: /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Users/Russell/Library/Application Support/Tunnelblick/Configurations/AirVPN NL Leporis - UDP 443.tblk/Contents/Resources --daemon --management 127.0.0.1 1337 --config /Users/Russell/Library/Application Support/Tunnelblick/Configurations/AirVPN NL Leporis - UDP 443.tblk/Contents/Resources/config.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-SRussell-SLibrary-SApplication Support-STunnelblick-SConfigurations-SAirVPN NL Leporis -- UDP 443.tblk-SContents-SResources-Sconfig.ovpn.1_0_0_0_49.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw --up-restart
2012-09-15 09:27:28 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2012-09-15 09:27:28 TLS Error: TLS handshake failed
2012-09-15 09:27:28 TCP/UDP: Closing socket
2012-09-15 09:27:28 SIGUSR1[soft,tls-error] received, process restarting
2012-09-15 09:27:28 MANAGEMENT: >STATE:1347694048,RECONNECTING,tls-error,,
2012-09-15 09:27:28 MANAGEMENT: CMD 'hold release'
2012-09-15 09:27:28 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2012-09-15 09:27:28 LZO compression initialized
2012-09-15 09:27:28 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2012-09-15 09:27:28 Socket Buffers: R=[42080->65536] S=[9216->65536]
2012-09-15 09:27:28 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2012-09-15 09:27:28 Local Options hash (VER=V4): '22188c5b'
2012-09-15 09:27:28 Expected Remote Options hash (VER=V4): 'a8f55717'
2012-09-15 09:27:28 UDPv4 link local: [undef]
2012-09-15 09:27:28 UDPv4 link remote: 95.211.191.33:443
2012-09-15 09:27:28 MANAGEMENT: >STATE:1347694048,WAIT,,,
