Arceon
ANSWERED Linux firewall with Eddie & Network Lock
Yesterday I found out ufw wouldn't stay active after a reboot because of the Eddie Network Lock. When the VPN isn't active, that's all right, for then I don't want incoming or outgoing traffic, anyway.
However, how do I block incoming traffic when the VPN is active? I couldn't find an option for that in Eddie.
I did remember having to use port forwarding for P2P programs. Does that have to do with this?
Thank you
If there's nothing listening on your forwarded port on your computer, like a torrent client, there won't be any incoming traffic. The other incoming traffic works only after you initiate some kind of outgoing request, so essentially, if you block outgoing, you also block incoming passively.
I take it this is what happens when using Network Lock, then?
If so, how would I block incoming when connected to my VPN apart from my forwarded ports?
It places firewall rules to block all that is outgoing and not directed towards AirVPN server IPs.
You're behind NAT routers both with your ISP and AirVPN. Anything you didn't explicitly forward does not pass through to your computer. There's nothing to block. You only need to worry about the outgoing connections because NAT routers typically forward the source ports of these connections dynamically and close them when the connection is closed.
Thank you for the clarification. I remember I have disabled UPnP and NAT-PMP on my router, is this what you are referring to?
Universal Plug and Play and the NAT-Port Mapping Protocol are protocol stacks with which a torrent client for example can forward a port it needs on your router explicitly. Means, when you check in your router's web interface or so, you can see them being open. These are separate technologies from the basic functionality of NAT: Those ports are implicit and usually only survive one short connection, sometimes a session (FTP or SSH for example). You normally don't see them in the web UI and are only opened when you initiate the connection ("no incoming without outgoing traffic").
UPnP and NAT-PMP are a bit problematic because they can easily open that torrent port on your ISP router explicitly without you being notified of it. Therefore, it usually is a better idea to disable them behind a VPN, as you did.
Thank you for the clarifications! It is clear to me now
