problem_debian
Eddie on debian = deb: command not found
Maby im retarded but I go here https://airvpn.org/linux/
Download the Linux>64bit>debian>graphical ui file
Open terminal copu/paste
user@host:~$ wget -qO - https://eddie.website/repository/keys/eddie_maintainer_gpg.key|sudo apt-key add -
[sudo] password for user:
OK
user@host:~$ deb http://eddie.website/repository/apt stable main
Could not find the database of available applications, run update-command-not-found as root to fix this
I tryed going su -
root@host:~# deb: command not found
deb:: command not found
but same thing happened  Any suggestions on what i do wrong?
This is not a terminal command, it's the syntax of apt.
What is retarted is that debian maintainers didn't make it a command, which could take the arguments
as input and place them it /etc/apt/sources.list.
So you will have to do it manually.
echo "deb http://eddie.website/repository/apt stable main" >> /etc/apt/sources.list
apt update
