barrabbas 0 Posted ... i have just cancelled my home broadband internet and started to tether my android phone to pc for internet. unfortunately i cant get air vpn to connect when tethering. it keeps trying to connect to server then gives a bootstrap failed pop up. do i need to alter settings in eddie? it always ran fine when using broadband. Quote Share this post Link to post
barrabbas 0 Posted ... i have installed eddie on my phone and it masks my ip address when using the phone to browse. unfortunately when i tether to my pc it is still showing my ip address. pc is running windows 7. is any one able to help? Quote Share this post Link to post
Tech Jedi Alex 1584 Posted ... Tethered devices will not be routed through a VPN connection which got established using Android's VPNService API (which pretty much every VPN app on the store is using). You need root privileges to force its cooperation. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
barrabbas 0 Posted ... thank you for letting me know. any idea how i get the vpn to start working on my pc whilst tethering? Quote Share this post Link to post
Tech Jedi Alex 1584 Posted ... Simply connect with Eddie. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
barrabbas 0 Posted ... 3 minutes ago, giganerd said: Simply connect with Eddie. as per my first post, unfortunately eddie wont connect when im tethering. Quote Share this post Link to post
Tech Jedi Alex 1584 Posted ... Oh, right. Then I misunderstood you. You don't connect with Android, you do with your PC. Then things get more complicated. Can you try a connection with vanilla OpenVPN? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
barrabbas 0 Posted ... 41 minutes ago, giganerd said: Simply connect with Eddie. i have just installed open vpn using this sites guide. its saying im connected to netherlands and have been assigned an ip address, but when i check my phones ip is still showing. Quote Share this post Link to post
Tech Jedi Alex 1584 Posted ... Would you kindly paste OpenVPN/Eddie logs? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
barrabbas 0 Posted ... open vpn log- Mon May 13 22:40:14 2019 OpenVPN 2.4.7 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 25 2019 Mon May 13 22:40:14 2019 Windows version 6.1 (Windows 7) 64bit Mon May 13 22:40:14 2019 library versions: OpenSSL 1.1.0j 20 Nov 2018, LZO 2.10 Enter Management Password: Mon May 13 22:40:14 2019 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25341 Mon May 13 22:40:14 2019 Need hold release from management interface, waiting... Mon May 13 22:40:15 2019 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25341 Mon May 13 22:40:15 2019 MANAGEMENT: CMD 'state on' Mon May 13 22:40:15 2019 MANAGEMENT: CMD 'log all on' Mon May 13 22:40:15 2019 MANAGEMENT: CMD 'echo all on' Mon May 13 22:40:15 2019 MANAGEMENT: CMD 'bytecount 5' Mon May 13 22:40:15 2019 MANAGEMENT: CMD 'hold off' Mon May 13 22:40:15 2019 MANAGEMENT: CMD 'hold release' Mon May 13 22:40:15 2019 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication Mon May 13 22:40:15 2019 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication Mon May 13 22:40:15 2019 MANAGEMENT: >STATE:1557783615,RESOLVE,,,,,, Mon May 13 22:40:16 2019 TCP/UDP: Preserving recently used remote address: [AF_INET6]64:ff9b::d598:a2a9:443 Mon May 13 22:40:16 2019 Socket Buffers: R=[8192->262144] S=[8192->262144] Mon May 13 22:40:16 2019 UDP link local: (not bound) Mon May 13 22:40:16 2019 UDP link remote: [AF_INET6]64:ff9b::d598:a2a9:443 Mon May 13 22:40:16 2019 MANAGEMENT: >STATE:1557783616,WAIT,,,,,, Mon May 13 22:40:16 2019 MANAGEMENT: >STATE:1557783616,AUTH,,,,,, Mon May 13 22:40:16 2019 TLS: Initial packet from [AF_INET6]64:ff9b::d598:a2a9:443, sid=6aef02e4 f4f03a6f Mon May 13 22:40:16 2019 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org Mon May 13 22:40:16 2019 VERIFY KU OK Mon May 13 22:40:16 2019 Validating certificate extended key usage Mon May 13 22:40:16 2019 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication Mon May 13 22:40:16 2019 VERIFY EKU OK Mon May 13 22:40:16 2019 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Caph, emailAddress=info@airvpn.org Mon May 13 22:40:16 2019 Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA Mon May 13 22:40:16 2019 [Caph] Peer Connection Initiated with [AF_INET6]64:ff9b::d598:a2a9:443 Mon May 13 22:40:17 2019 MANAGEMENT: >STATE:1557783617,GET_CONFIG,,,,,, Mon May 13 22:40:17 2019 SENT CONTROL [Caph]: 'PUSH_REQUEST' (status=1) Mon May 13 22:40:17 2019 PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.12.132.1,route-gateway 10.12.132.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.12.132.243 255.255.255.0,peer-id 5,cipher AES-256-GCM' Mon May 13 22:40:17 2019 OPTIONS IMPORT: timers and/or timeouts modified Mon May 13 22:40:17 2019 OPTIONS IMPORT: compression parms modified Mon May 13 22:40:17 2019 OPTIONS IMPORT: --ifconfig/up options modified Mon May 13 22:40:17 2019 OPTIONS IMPORT: route options modified Mon May 13 22:40:17 2019 OPTIONS IMPORT: route-related options modified Mon May 13 22:40:17 2019 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified Mon May 13 22:40:17 2019 OPTIONS IMPORT: peer-id set Mon May 13 22:40:17 2019 OPTIONS IMPORT: adjusting link_mtu to 1625 Mon May 13 22:40:17 2019 OPTIONS IMPORT: data channel crypto options modified Mon May 13 22:40:17 2019 Data Channel: using negotiated cipher 'AES-256-GCM' Mon May 13 22:40:17 2019 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key Mon May 13 22:40:17 2019 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key Mon May 13 22:40:17 2019 interactive service msg_channel=0 Mon May 13 22:40:17 2019 ROUTE_GATEWAY 192.168.42.129/255.255.255.0 I=21 HWADDR=ae:62:95:09:11:49 Mon May 13 22:40:17 2019 open_tun Mon May 13 22:40:17 2019 TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{24B96585-D520-455A-9231-1B22178F6353}.tap Mon May 13 22:40:17 2019 TAP-Windows Driver Version 9.23 Mon May 13 22:40:17 2019 Set TAP-Windows TUN subnet mode network/local/netmask = 10.12.132.0/10.12.132.243/255.255.255.0 [SUCCEEDED] Mon May 13 22:40:17 2019 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.12.132.243/255.255.255.0 on interface {24B96585-D520-455A-9231-1B22178F6353} [DHCP-serv: 10.12.132.254, lease-time: 31536000] Mon May 13 22:40:17 2019 Successful ARP Flush on interface [14] {24B96585-D520-455A-9231-1B22178F6353} Mon May 13 22:40:17 2019 MANAGEMENT: >STATE:1557783617,ASSIGN_IP,,10.12.132.243,,,, Mon May 13 22:40:22 2019 TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up Mon May 13 22:40:22 2019 ROUTE remote_host protocol differs from tunneled Mon May 13 22:40:22 2019 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.12.132.1 Mon May 13 22:40:22 2019 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4 Mon May 13 22:40:22 2019 Route addition via IPAPI succeeded [adaptive] Mon May 13 22:40:22 2019 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.12.132.1 Mon May 13 22:40:22 2019 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4 Mon May 13 22:40:22 2019 Route addition via IPAPI succeeded [adaptive] Mon May 13 22:40:22 2019 Initialization Sequence Completed Mon May 13 22:40:22 2019 MANAGEMENT: >STATE:1557783622,CONNECTED,SUCCESS,10.12.132.243,64:ff9b::d598:a2a9,443,, Quote Share this post Link to post
