Redtexta
Continuous disconnects and loss of Browser after wake from sleep (inactivity timeout)
Ready to throw Eddie and change providers after 3 years of pretty much faultless use.
Only threads that have some similar issues have no answers.
I have unchecked what advised tried multiple combinations of TCPs,UDPs Ports & IPs but problem persists in similar circumstances - nothing had changed when this started last week out of the blue.
I have blocked IPv6 (my provider doesn't support) just in case and turned on & off just about every checkbox.
Rebooted Router etc etc etc
Currently logs off due to 'inactivity timeout' regardless of wether inactive or not.
Get notification of disconnect, and reconnects (previously before unchecking tunnel & AirVPN dns would require connecting to new server before working) and previous server would not work until Mac rebooted, but Safari doesn't work even after disconnecting Eddie and turning off Network Lock (torrents work though) and I must reconnect to Eddie to get internet to work.
Repeat Ad Nauseum.
Logs before 17:30 are unattended in sleep mode.
I hope someone can please help, if no one can make sense of the logs I will try a service ticket - otherwise will have to look elsewhere for VPN.
. 2019.03.25 09:56:27 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 09:56:27 - Flushing DNS
I 2019.03.25 09:56:28 - Checking route IPv4
. 2019.03.25 09:56:48 - curl: (28) Connection timed out after 20009 milliseconds
. 2019.03.25 09:56:48 - Checking route (2° try)
. 2019.03.25 09:57:09 - curl: (28) Connection timed out after 20001 milliseconds
. 2019.03.25 09:57:09 - Checking route (3° try)
. 2019.03.25 09:57:36 - curl: (28) Connection timed out after 20005 milliseconds
E 2019.03.25 09:57:36 - Checking route IPv4 failed.
. 2019.03.25 09:57:36 - OpenVPN > Initialization Sequence Completed
! 2019.03.25 09:57:36 - Disconnecting
. 2019.03.25 09:57:36 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 09:57:36 - Sending management termination signal
. 2019.03.25 09:57:36 - Management - Send 'signal SIGTERM'
. 2019.03.25 09:57:36 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 09:57:36 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.25 09:57:41 - OpenVPN > /sbin/route delete -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 09:57:41 - OpenVPN > delete net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 09:57:41 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 09:57:41 - OpenVPN > delete net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 09:57:41 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 09:57:41 - OpenVPN > delete net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 09:57:41 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 09:57:41 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.25 09:57:41 - Connection terminated.
. 2019.03.25 09:57:41 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 09:57:41 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 09:57:41 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 09:57:41 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 09:57:42 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 09:57:42 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 09:57:42 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 09:57:42 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 09:57:42 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 09:57:42 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 09:57:45 - Checking authorization ...
. 2019.03.25 09:57:46 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 09:57:47 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 09:57:47 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 09:57:47 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 09:57:47 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 09:57:47 - Connecting to Sabik (United States, Los Angeles)
. 2019.03.25 09:57:47 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 09:57:47 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 09:57:47 - Connection to OpenVPN Management Interface
. 2019.03.25 09:57:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 09:57:47 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 09:57:47 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 09:57:47 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 09:57:47 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 09:57:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 09:57:47 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 09:57:47 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 09:57:47 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 09:57:47 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 09:57:47 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=2ecede14 0e86ab32
. 2019.03.25 09:57:47 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 09:57:47 - OpenVPN > VERIFY KU OK
. 2019.03.25 09:57:47 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 09:57:47 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 09:57:47 - OpenVPN > VERIFY EKU OK
. 2019.03.25 09:57:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 09:57:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 09:57:48 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 09:57:49 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 09:57:49 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.25 09:57:49 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 09:57:49 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 09:57:49 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 09:57:49 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 09:57:49 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 09:57:49 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 09:57:49 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 09:57:49 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 09:57:49 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 09:57:49 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 09:57:49 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 09:57:49 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 09:57:49 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 09:57:49 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 09:57:49 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 09:57:49 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 09:57:49 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 09:57:49 - Above log line repeated 1 times more
. 2019.03.25 09:57:49 - OpenVPN > Opened utun device utun2
. 2019.03.25 09:57:49 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 09:57:49 - OpenVPN > /sbin/ifconfig utun2 delete
. 2019.03.25 09:57:49 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 09:57:49 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 09:57:49 - OpenVPN > /sbin/ifconfig utun2 10.28.158.45 10.28.158.45 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 09:57:49 - OpenVPN > /sbin/route add -net 10.28.158.0 10.28.158.45 255.255.255.0
. 2019.03.25 09:57:49 - OpenVPN > add net 10.28.158.0: gateway 10.28.158.45
. 2019.03.25 09:57:49 - OpenVPN > /sbin/route add -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 09:57:49 - OpenVPN > add net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 09:57:49 - OpenVPN > /sbin/route add -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 09:57:49 - OpenVPN > add net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 09:57:49 - OpenVPN > /sbin/route add -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 09:57:49 - OpenVPN > add net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 09:57:50 - DNS of a network adapter forced (Ethernet, from Automatic to 10.28.158.1)
. 2019.03.25 09:57:50 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 09:57:50 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 09:57:50 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 09:57:50 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 09:57:51 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 09:57:51 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 09:57:51 - Flushing DNS
I 2019.03.25 09:57:51 - Checking route IPv4
. 2019.03.25 09:58:11 - curl: (28) Connection timed out after 20003 milliseconds
. 2019.03.25 09:58:11 - Checking route (2° try)
. 2019.03.25 10:30:00 - curl: (28) Connection timed out after 1907063 milliseconds
. 2019.03.25 10:30:00 - Checking route (3° try)
. 2019.03.25 10:30:22 - curl: (28) Connection timed out after 20003 milliseconds
E 2019.03.25 10:30:22 - Checking route IPv4 failed.
. 2019.03.25 10:30:22 - OpenVPN > Initialization Sequence Completed
! 2019.03.25 10:30:22 - Disconnecting
. 2019.03.25 10:30:22 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 10:30:22 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2019.03.25 10:30:22 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.25 10:30:22 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.25 10:30:22 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 10:30:22 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 10:30:22 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 10:30:22 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 10:30:22 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=3ec87a05 7825c1a1
. 2019.03.25 10:30:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 10:30:22 - OpenVPN > VERIFY KU OK
. 2019.03.25 10:30:22 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 10:30:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 10:30:22 - OpenVPN > VERIFY EKU OK
. 2019.03.25 10:30:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 10:30:22 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 10:30:22 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 10:30:22 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 10:30:22 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2019.03.25 10:30:22 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 10:30:22 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 10:30:22 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 10:30:22 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 10:30:22 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 10:30:22 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 10:30:22 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 10:30:22 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 10:30:22 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 10:30:22 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 10:30:22 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 10:30:22 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 10:30:22 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 10:30:22 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 10:30:22 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 10:30:22 - OpenVPN > Preserving previous TUN/TAP instance: utun2
. 2019.03.25 10:30:22 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 10:30:22 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 10:30:22 - Flushing DNS
. 2019.03.25 10:30:23 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 10:30:23 - Sending management termination signal
. 2019.03.25 10:30:23 - Management - Send 'signal SIGTERM'
. 2019.03.25 10:30:23 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 10:30:23 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.25 10:30:23 - Updating systems & servers data ...
. 2019.03.25 10:30:28 - OpenVPN > /sbin/route delete -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 10:30:28 - OpenVPN > delete net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 10:30:28 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 10:30:28 - OpenVPN > delete net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 10:30:28 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 10:30:28 - OpenVPN > delete net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 10:30:28 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 10:30:28 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.25 10:30:28 - Connection terminated.
. 2019.03.25 10:30:28 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 10:30:28 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 10:30:28 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 10:30:28 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 10:30:28 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 10:30:28 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 10:30:29 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 10:30:30 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 10:30:30 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 10:30:30 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 10:30:38 - Checking authorization ...
. 2019.03.25 10:30:39 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 10:30:39 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 10:30:40 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 10:30:40 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 10:30:40 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 10:30:40 - Connecting to Sabik (United States, Los Angeles)
. 2019.03.25 10:30:40 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 10:30:40 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 10:30:40 - Connection to OpenVPN Management Interface
. 2019.03.25 10:30:40 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 10:30:40 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 10:30:40 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 10:30:40 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 10:30:40 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 10:30:40 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 10:30:40 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 10:30:40 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 10:30:40 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 10:30:40 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 10:30:58 - macOS - PF rules updated, reloading
. 2019.03.25 10:30:59 - Systems & servers data update completed
. 2019.03.25 10:31:10 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=2f68ca10 9db8d6ec
. 2019.03.25 10:31:10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 10:31:10 - OpenVPN > VERIFY KU OK
. 2019.03.25 10:31:10 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 10:31:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 10:31:10 - OpenVPN > VERIFY EKU OK
. 2019.03.25 10:31:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 10:31:31 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 10:31:31 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 10:31:31 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 10:31:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2019.03.25 10:31:31 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 10:31:31 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 10:31:31 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 10:31:31 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 10:31:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 10:31:31 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 10:31:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 10:31:31 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 10:31:31 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 10:31:31 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 10:31:31 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 10:31:31 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 10:31:31 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 10:31:31 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 10:31:31 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 10:31:31 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 10:31:31 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 10:31:31 - Above log line repeated 1 times more
. 2019.03.25 10:31:31 - OpenVPN > Opened utun device utun2
. 2019.03.25 10:31:31 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 10:31:31 - OpenVPN > /sbin/ifconfig utun2 delete
. 2019.03.25 10:31:31 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 10:31:31 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 10:31:31 - OpenVPN > /sbin/ifconfig utun2 10.28.158.45 10.28.158.45 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 10:31:31 - OpenVPN > /sbin/route add -net 10.28.158.0 10.28.158.45 255.255.255.0
. 2019.03.25 10:31:31 - OpenVPN > add net 10.28.158.0: gateway 10.28.158.45
. 2019.03.25 10:31:31 - OpenVPN > /sbin/route add -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 10:31:31 - OpenVPN > add net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 10:31:31 - OpenVPN > /sbin/route add -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 10:31:31 - OpenVPN > add net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 10:31:31 - OpenVPN > /sbin/route add -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 10:31:31 - OpenVPN > add net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 10:32:14 - DNS of a network adapter forced (Ethernet, from Automatic to 10.28.158.1)
. 2019.03.25 10:32:54 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 10:33:28 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 10:34:08 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 10:34:36 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 10:34:56 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 10:34:56 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 10:34:56 - Flushing DNS
. 2019.03.25 10:34:56 - macOS - PF rules updated, reloading
I 2019.03.25 10:34:57 - Checking route IPv4
I 2019.03.25 10:34:59 - Checking DNS
! 2019.03.25 10:35:00 - Connected.
. 2019.03.25 10:35:01 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 10:54:21 - Updating systems & servers data ...
. 2019.03.25 10:55:16 - Systems & servers data update completed
. 2019.03.25 12:08:36 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2019.03.25 12:08:36 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.25 12:08:36 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.25 14:09:29 - macOS - PF rules updated, reloading
! 2019.03.25 14:09:30 - Disconnecting
. 2019.03.25 14:09:30 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 14:09:30 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 14:09:30 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 14:09:30 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 14:09:30 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 14:09:30 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=a49560ce 4d6d761f
. 2019.03.25 14:09:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 14:09:30 - OpenVPN > VERIFY KU OK
. 2019.03.25 14:09:30 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 14:09:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 14:09:30 - OpenVPN > VERIFY EKU OK
. 2019.03.25 14:09:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 14:09:30 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 14:09:30 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 14:09:30 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 14:09:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.25 14:09:30 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 14:09:30 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 14:09:30 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 14:09:30 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 14:09:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 14:09:30 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 14:09:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 14:09:30 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 14:09:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 14:09:30 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 14:09:30 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 14:09:30 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 14:09:30 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 14:09:30 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 14:09:30 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 14:09:30 - OpenVPN > Preserving previous TUN/TAP instance: utun2
. 2019.03.25 14:09:31 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 14:09:31 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 14:09:31 - Flushing DNS
. 2019.03.25 14:09:32 - macOS - PF rules updated, reloading
. 2019.03.25 14:09:32 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 14:09:32 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2019.03.25 14:09:32 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.25 14:09:32 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.25 14:09:32 - Sending management termination signal
. 2019.03.25 14:09:32 - Management - Send 'signal SIGTERM'
. 2019.03.25 14:09:32 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 14:09:32 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 14:09:32 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 14:09:32 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 14:09:32 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=7c2fb8bd 4af443d5
. 2019.03.25 14:09:32 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 14:09:32 - OpenVPN > VERIFY KU OK
. 2019.03.25 14:09:32 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 14:09:32 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 14:09:32 - OpenVPN > VERIFY EKU OK
. 2019.03.25 14:09:32 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 14:09:32 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 14:09:32 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 14:09:32 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 14:09:32 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.25 14:09:33 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 14:09:33 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2019.03.25 14:09:33 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 14:09:33 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 14:09:33 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 14:09:33 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 14:09:33 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 14:09:33 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 14:09:33 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 14:09:33 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 14:09:33 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 14:09:33 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 14:09:33 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 14:09:33 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 14:09:33 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 14:09:33 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 14:09:33 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 14:09:33 - OpenVPN > Preserving previous TUN/TAP instance: utun2
W 2019.03.25 14:09:33 - Routes, add 199.241.147.35 for gateway 10.28.158.1 failed: route: writing to routing socket: File exists
. 2019.03.25 14:09:33 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 14:09:33 - Flushing DNS
. 2019.03.25 14:09:34 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 14:09:37 - OpenVPN > /sbin/route delete -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 14:09:37 - OpenVPN > delete net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 14:09:37 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 14:09:37 - OpenVPN > delete net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 14:09:37 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 14:09:37 - OpenVPN > delete net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 14:09:37 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 14:09:37 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.25 14:09:37 - Connection terminated.
. 2019.03.25 14:09:37 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 14:09:37 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 14:09:37 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 14:09:37 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 14:09:37 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 14:09:37 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 14:09:38 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 14:09:39 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 14:09:39 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 14:09:39 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 14:09:42 - Checking authorization ...
. 2019.03.25 14:09:43 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 14:09:43 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 14:09:43 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 14:09:43 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 14:09:43 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 14:09:43 - Connecting to Sabik (United States, Los Angeles)
. 2019.03.25 14:09:44 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 14:09:44 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 14:09:44 - Connection to OpenVPN Management Interface
. 2019.03.25 14:09:44 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 14:09:44 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 14:09:44 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 14:09:44 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 14:09:44 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 14:09:44 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 14:09:44 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 14:09:44 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 14:09:44 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 14:09:44 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 14:10:04 - Updating systems & servers data ...
. 2019.03.25 14:10:13 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=c1cc854e 65386009
. 2019.03.25 14:10:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 14:10:34 - OpenVPN > VERIFY KU OK
. 2019.03.25 14:10:34 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 14:10:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 14:10:34 - OpenVPN > VERIFY EKU OK
. 2019.03.25 14:10:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 14:10:34 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 14:10:34 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 14:10:34 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 14:10:34 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2019.03.25 14:10:34 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 14:10:34 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 14:10:34 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 14:10:34 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 14:10:34 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 14:10:34 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 14:10:34 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 14:10:34 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 14:10:34 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 14:10:34 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 14:10:34 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 14:10:34 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 14:10:34 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 14:10:34 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 14:10:34 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 14:10:34 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 14:10:34 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 14:10:34 - Above log line repeated 1 times more
. 2019.03.25 14:10:34 - OpenVPN > Opened utun device utun2
. 2019.03.25 14:10:34 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 14:10:34 - OpenVPN > /sbin/ifconfig utun2 delete
. 2019.03.25 14:10:34 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 14:10:34 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 14:10:34 - OpenVPN > /sbin/ifconfig utun2 10.28.158.45 10.28.158.45 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 14:10:34 - OpenVPN > /sbin/route add -net 10.28.158.0 10.28.158.45 255.255.255.0
. 2019.03.25 14:10:34 - OpenVPN > add net 10.28.158.0: gateway 10.28.158.45
. 2019.03.25 14:10:34 - OpenVPN > /sbin/route add -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 14:10:34 - OpenVPN > add net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 14:10:34 - OpenVPN > /sbin/route add -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 14:10:34 - OpenVPN > add net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 14:10:34 - OpenVPN > /sbin/route add -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 14:10:34 - OpenVPN > add net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 14:11:16 - DNS of a network adapter forced (Ethernet, from Automatic to 10.28.158.1)
. 2019.03.25 14:11:16 - macOS - PF rules updated, reloading
. 2019.03.25 14:11:17 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 14:11:17 - Systems & servers data update completed
. 2019.03.25 14:11:57 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 14:12:19 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 14:12:19 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 14:12:19 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 14:12:19 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 14:12:19 - Flushing DNS
. 2019.03.25 14:12:20 - macOS - PF rules updated, reloading
I 2019.03.25 14:12:21 - Checking route IPv4
I 2019.03.25 14:12:23 - Checking DNS
! 2019.03.25 14:12:24 - Connected.
. 2019.03.25 14:12:24 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 15:40:49 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2019.03.25 15:40:49 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.25 15:40:49 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.25 15:40:52 - macOS - PF rules updated, reloading
! 2019.03.25 15:40:53 - Disconnecting
. 2019.03.25 15:40:53 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 15:40:53 - Sending management termination signal
. 2019.03.25 15:40:53 - Management - Send 'signal SIGTERM'
. 2019.03.25 15:40:53 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 15:40:53 - OpenVPN > /sbin/route delete -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 15:40:53 - OpenVPN > delete net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 15:40:53 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 15:40:53 - OpenVPN > delete net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 15:40:53 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 15:40:53 - OpenVPN > delete net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 15:40:53 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 15:40:53 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2019.03.25 15:40:53 - Connection terminated.
. 2019.03.25 15:40:54 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 15:40:54 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 15:40:54 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 15:40:54 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 15:40:54 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 15:40:54 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 15:40:55 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 15:40:56 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 15:40:56 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 15:40:56 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 15:40:59 - Checking authorization ...
. 2019.03.25 15:41:00 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 15:41:00 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 15:41:00 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 15:41:00 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 15:41:01 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 15:41:01 - Connecting to Sabik (United States, Los Angeles)
. 2019.03.25 15:41:01 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 15:41:01 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 15:41:01 - Connection to OpenVPN Management Interface
. 2019.03.25 15:41:01 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 15:41:01 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 15:41:01 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 15:41:01 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 15:41:01 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 15:41:01 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 15:41:01 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 15:41:01 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 15:41:01 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 15:41:01 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 15:41:31 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=edecbbde 9bf73d3d
. 2019.03.25 15:41:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 15:41:31 - OpenVPN > VERIFY KU OK
. 2019.03.25 15:41:31 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 15:41:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 15:41:31 - OpenVPN > VERIFY EKU OK
. 2019.03.25 15:41:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 15:41:32 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 15:41:32 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 15:41:52 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 15:41:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.25 15:41:52 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 15:41:52 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 15:41:52 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 15:41:52 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 15:41:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 15:41:52 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 15:41:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 15:41:52 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 15:41:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 15:41:52 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 15:41:52 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 15:41:52 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 15:41:52 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 15:41:52 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 15:41:52 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 15:41:52 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 15:41:52 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 15:41:52 - Above log line repeated 1 times more
. 2019.03.25 15:41:52 - OpenVPN > Opened utun device utun2
. 2019.03.25 15:41:52 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 15:41:52 - OpenVPN > /sbin/ifconfig utun2 delete
. 2019.03.25 15:41:52 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 15:41:52 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 15:41:52 - OpenVPN > /sbin/ifconfig utun2 10.28.158.45 10.28.158.45 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 15:41:52 - OpenVPN > /sbin/route add -net 10.28.158.0 10.28.158.45 255.255.255.0
. 2019.03.25 15:41:52 - OpenVPN > add net 10.28.158.0: gateway 10.28.158.45
. 2019.03.25 15:41:52 - OpenVPN > /sbin/route add -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 15:41:52 - OpenVPN > add net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 15:41:52 - OpenVPN > /sbin/route add -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 15:41:52 - OpenVPN > add net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 15:41:52 - OpenVPN > /sbin/route add -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 15:41:52 - OpenVPN > add net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 15:41:55 - DNS of a network adapter forced (Ethernet, from Automatic to 10.28.158.1)
. 2019.03.25 15:41:55 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 15:41:55 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 15:41:55 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 15:41:55 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 15:41:56 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 15:41:56 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 15:41:56 - Flushing DNS
. 2019.03.25 15:41:56 - macOS - PF rules updated, reloading
I 2019.03.25 15:41:57 - Checking route IPv4
I 2019.03.25 15:41:59 - Checking DNS
! 2019.03.25 15:42:01 - Connected.
. 2019.03.25 15:42:01 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 15:49:47 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2019.03.25 15:49:47 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.25 15:49:47 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.25 15:49:49 - Updating systems & servers data ...
. 2019.03.25 15:49:50 - macOS - PF rules updated, reloading
! 2019.03.25 15:49:51 - Disconnecting
. 2019.03.25 15:49:51 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 15:49:51 - Sending management termination signal
. 2019.03.25 15:49:51 - Management - Send 'signal SIGTERM'
. 2019.03.25 15:49:51 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 15:49:51 - OpenVPN > /sbin/route delete -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 15:49:51 - OpenVPN > delete net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 15:49:51 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 15:49:51 - OpenVPN > delete net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 15:49:51 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 15:49:51 - OpenVPN > delete net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 15:49:51 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 15:49:51 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2019.03.25 15:49:51 - Connection terminated.
. 2019.03.25 15:49:51 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 15:49:52 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 15:49:52 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 15:49:52 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 15:49:52 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 15:49:52 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 15:49:52 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 15:49:53 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 15:49:53 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 15:49:53 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 15:49:56 - Checking authorization ...
. 2019.03.25 15:49:57 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 15:49:57 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 15:49:58 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 15:49:58 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 15:49:58 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 15:49:58 - Connecting to Sabik (United States, Los Angeles)
. 2019.03.25 15:49:58 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 15:49:58 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 15:49:58 - Connection to OpenVPN Management Interface
. 2019.03.25 15:49:58 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 15:49:58 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 15:49:58 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 15:49:58 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 15:49:58 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 15:49:58 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 15:49:58 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 15:49:58 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 15:49:58 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 15:49:58 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 15:50:24 - macOS - PF rules updated, reloading
. 2019.03.25 15:50:25 - Systems & servers data update completed
. 2019.03.25 15:50:28 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=1da7ae1f 542042af
. 2019.03.25 15:50:28 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 15:50:28 - OpenVPN > VERIFY KU OK
. 2019.03.25 15:50:28 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 15:50:28 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 15:50:28 - OpenVPN > VERIFY EKU OK
. 2019.03.25 15:50:28 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 15:50:29 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 15:50:29 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 15:50:30 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 15:50:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.25 15:50:30 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 15:50:30 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 15:50:30 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 15:50:30 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 15:50:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 15:50:30 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 15:50:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 15:50:30 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 15:50:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 15:50:30 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 15:50:30 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 15:50:30 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 15:50:30 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 15:50:30 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 15:50:30 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 15:50:30 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 15:50:30 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 15:50:30 - Above log line repeated 1 times more
. 2019.03.25 15:50:30 - OpenVPN > Opened utun device utun2
. 2019.03.25 15:50:30 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 15:50:30 - OpenVPN > /sbin/ifconfig utun2 delete
. 2019.03.25 15:50:30 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 15:50:30 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 15:50:30 - OpenVPN > /sbin/ifconfig utun2 10.28.158.45 10.28.158.45 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 15:50:30 - OpenVPN > /sbin/route add -net 10.28.158.0 10.28.158.45 255.255.255.0
. 2019.03.25 15:50:30 - OpenVPN > add net 10.28.158.0: gateway 10.28.158.45
. 2019.03.25 15:50:30 - OpenVPN > /sbin/route add -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 15:50:30 - OpenVPN > add net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 15:50:30 - OpenVPN > /sbin/route add -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 15:50:30 - OpenVPN > add net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 15:50:30 - OpenVPN > /sbin/route add -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 15:50:30 - OpenVPN > add net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 15:50:57 - DNS of a network adapter forced (Ethernet, from Automatic to 10.28.158.1)
. 2019.03.25 15:50:57 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 15:50:57 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 15:50:57 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 15:50:57 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 15:50:57 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 15:50:57 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 15:50:57 - Flushing DNS
. 2019.03.25 15:50:58 - macOS - PF rules updated, reloading
I 2019.03.25 15:50:59 - Checking route IPv4
I 2019.03.25 15:51:01 - Checking DNS
! 2019.03.25 15:51:02 - Connected.
. 2019.03.25 15:51:02 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 17:30:23 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2019.03.25 17:30:23 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.25 17:30:23 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.25 17:30:27 - macOS - PF rules updated, reloading
! 2019.03.25 17:30:28 - Disconnecting
. 2019.03.25 17:30:29 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 17:30:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 17:30:29 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 17:30:29 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 17:30:29 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 17:30:29 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=831d3c4d 4d1ebacf
. 2019.03.25 17:30:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 17:30:29 - OpenVPN > VERIFY KU OK
. 2019.03.25 17:30:29 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 17:30:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 17:30:29 - OpenVPN > VERIFY EKU OK
. 2019.03.25 17:30:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 17:30:29 - Sending management termination signal
. 2019.03.25 17:30:29 - Management - Send 'signal SIGTERM'
. 2019.03.25 17:30:29 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 17:30:29 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.25 17:30:29 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 17:30:29 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 17:30:30 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 17:30:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2019.03.25 17:30:30 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 17:30:30 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 17:30:30 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 17:30:30 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 17:30:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 17:30:30 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 17:30:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 17:30:30 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 17:30:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 17:30:30 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 17:30:30 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 17:30:30 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 17:30:30 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 17:30:30 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:30:30 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:30:30 - OpenVPN > Preserving previous TUN/TAP instance: utun2
. 2019.03.25 17:30:30 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 17:30:30 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 17:30:30 - Flushing DNS
. 2019.03.25 17:30:31 - macOS - PF rules updated, reloading
. 2019.03.25 17:30:32 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 17:30:34 - OpenVPN > /sbin/route delete -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 17:30:34 - OpenVPN > delete net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 17:30:34 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:30:34 - OpenVPN > delete net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:30:34 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:30:34 - OpenVPN > delete net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:30:34 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 17:30:34 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.25 17:30:34 - Connection terminated.
. 2019.03.25 17:30:34 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 17:30:34 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 17:30:34 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 17:30:34 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 17:30:34 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 17:30:34 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 17:30:35 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:30:36 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:30:36 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:30:36 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 17:30:39 - Checking authorization ...
. 2019.03.25 17:30:40 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 17:30:40 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 17:30:40 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 17:30:40 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 17:30:40 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 17:30:40 - Connecting to Sabik (United States, Los Angeles)
. 2019.03.25 17:30:41 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 17:30:41 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 17:30:41 - Connection to OpenVPN Management Interface
. 2019.03.25 17:30:41 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 17:30:41 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 17:30:41 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 17:30:41 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 17:30:41 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 17:30:41 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 17:30:41 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 17:30:41 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 17:30:41 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 17:30:41 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 17:31:10 - OpenVPN > TLS Error: Unroutable control packet received from [AF_INET]199.241.147.37:53 (si=3 op=P_ACK_V1)
. 2019.03.25 17:31:12 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=5fed8b80 cdb8b468
. 2019.03.25 17:31:12 - Updating systems & servers data ...
. 2019.03.25 17:31:12 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 17:31:12 - OpenVPN > VERIFY KU OK
. 2019.03.25 17:31:12 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 17:31:12 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 17:31:12 - OpenVPN > VERIFY EKU OK
. 2019.03.25 17:31:12 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 17:31:13 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 17:31:13 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 17:31:14 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 17:31:14 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2019.03.25 17:31:14 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 17:31:14 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 17:31:14 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 17:31:14 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 17:31:14 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 17:31:14 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 17:31:14 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 17:31:14 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 17:31:14 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 17:31:14 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 17:31:14 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 17:31:14 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 17:31:14 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 17:31:14 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:31:14 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:31:14 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 17:31:14 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 17:31:14 - Above log line repeated 1 times more
. 2019.03.25 17:31:14 - OpenVPN > Opened utun device utun2
. 2019.03.25 17:31:14 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 17:31:14 - OpenVPN > /sbin/ifconfig utun2 delete
. 2019.03.25 17:31:14 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 17:31:14 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 17:31:14 - OpenVPN > /sbin/ifconfig utun2 10.28.158.45 10.28.158.45 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 17:31:14 - OpenVPN > /sbin/route add -net 10.28.158.0 10.28.158.45 255.255.255.0
. 2019.03.25 17:31:14 - OpenVPN > add net 10.28.158.0: gateway 10.28.158.45
. 2019.03.25 17:31:14 - OpenVPN > /sbin/route add -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 17:31:14 - OpenVPN > add net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 17:31:14 - OpenVPN > /sbin/route add -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:31:14 - OpenVPN > add net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:31:14 - OpenVPN > /sbin/route add -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:31:14 - OpenVPN > add net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:31:14 - DNS of a network adapter forced (Ethernet, from Automatic to 10.28.158.1)
. 2019.03.25 17:31:15 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 17:31:15 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 17:31:15 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 17:31:15 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 17:31:15 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 17:31:15 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 17:31:15 - Flushing DNS
I 2019.03.25 17:31:16 - Checking route IPv4
. 2019.03.25 17:31:27 - Systems & servers data update completed
. 2019.03.25 17:31:36 - curl: (28) Connection timed out after 20005 milliseconds
. 2019.03.25 17:31:36 - Checking route (2° try)
. 2019.03.25 17:31:57 - curl: (28) Connection timed out after 20003 milliseconds
. 2019.03.25 17:31:57 - Checking route (3° try)
. 2019.03.25 17:32:19 - curl: (28) Connection timed out after 20005 milliseconds
E 2019.03.25 17:32:19 - Checking route IPv4 failed.
. 2019.03.25 17:32:20 - OpenVPN > Initialization Sequence Completed
! 2019.03.25 17:32:20 - Disconnecting
. 2019.03.25 17:32:20 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 17:32:20 - Sending management termination signal
. 2019.03.25 17:32:20 - Management - Send 'signal SIGTERM'
. 2019.03.25 17:32:20 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 17:32:20 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.25 17:32:25 - OpenVPN > /sbin/route delete -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 17:32:25 - OpenVPN > delete net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 17:32:25 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:32:25 - OpenVPN > delete net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:32:25 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:32:25 - OpenVPN > delete net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:32:25 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 17:32:25 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.25 17:32:25 - Connection terminated.
. 2019.03.25 17:32:25 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 17:32:25 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 17:32:25 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 17:32:25 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 17:32:25 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 17:32:25 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 17:32:25 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:32:26 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:32:26 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:32:26 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 17:32:29 - Checking authorization ...
. 2019.03.25 17:32:30 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 17:32:31 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 17:32:31 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 17:32:31 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 17:32:31 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 17:32:31 - Connecting to Sabik (United States, Los Angeles)
. 2019.03.25 17:32:31 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 17:32:31 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 17:32:31 - Connection to OpenVPN Management Interface
. 2019.03.25 17:32:31 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 17:32:31 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 17:32:31 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 17:32:31 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 17:32:31 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 17:32:31 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 17:32:31 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 17:32:31 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 17:32:31 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 17:32:31 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 17:33:01 - OpenVPN > TLS Error: Unroutable control packet received from [AF_INET]199.241.147.37:53 (si=3 op=P_ACK_V1)
. 2019.03.25 17:33:01 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=f6666299 9ed9f903
. 2019.03.25 17:33:02 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 17:33:02 - OpenVPN > VERIFY KU OK
. 2019.03.25 17:33:02 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 17:33:02 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 17:33:02 - OpenVPN > VERIFY EKU OK
. 2019.03.25 17:33:02 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
! 2019.03.25 17:33:02 - Disconnecting
. 2019.03.25 17:33:02 - Sending management termination signal
. 2019.03.25 17:33:02 - Management - Send 'signal SIGTERM'
. 2019.03.25 17:33:02 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 17:33:02 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.25 17:33:02 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 17:33:02 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 17:33:04 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 17:33:04 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2019.03.25 17:33:04 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 17:33:04 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 17:33:04 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 17:33:04 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 17:33:04 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 17:33:04 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 17:33:04 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 17:33:04 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 17:33:04 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 17:33:04 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 17:33:04 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 17:33:04 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 17:33:04 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 17:33:04 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:33:04 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:33:04 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 17:33:04 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 17:33:04 - Above log line repeated 1 times more
. 2019.03.25 17:33:04 - OpenVPN > Opened utun device utun2
. 2019.03.25 17:33:04 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 17:33:04 - OpenVPN > /sbin/ifconfig utun2 delete
. 2019.03.25 17:33:04 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 17:33:04 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 17:33:04 - OpenVPN > /sbin/ifconfig utun2 10.28.158.45 10.28.158.45 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 17:33:04 - OpenVPN > /sbin/route add -net 10.28.158.0 10.28.158.45 255.255.255.0
. 2019.03.25 17:33:04 - OpenVPN > add net 10.28.158.0: gateway 10.28.158.45
. 2019.03.25 17:33:04 - OpenVPN > /sbin/route add -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 17:33:04 - OpenVPN > add net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 17:33:04 - OpenVPN > /sbin/route add -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:33:04 - OpenVPN > add net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:33:04 - OpenVPN > /sbin/route add -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:33:04 - OpenVPN > add net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:33:04 - DNS of a network adapter forced (Ethernet, from Automatic to 10.28.158.1)
. 2019.03.25 17:33:04 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 17:33:04 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 17:33:05 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 17:33:05 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 17:33:05 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 17:33:05 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 17:33:05 - Flushing DNS
. 2019.03.25 17:33:06 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 17:33:07 - OpenVPN > /sbin/route delete -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 17:33:07 - OpenVPN > delete net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 17:33:07 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:33:07 - OpenVPN > delete net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:33:07 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:33:07 - OpenVPN > delete net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:33:07 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 17:33:07 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.25 17:33:07 - Connection terminated.
. 2019.03.25 17:33:07 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 17:33:07 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 17:33:07 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 17:33:07 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 17:33:07 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 17:33:07 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 17:33:08 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:33:08 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:33:08 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:33:08 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:33:08 - Flushing DNS
! 2019.03.25 17:33:08 - Session terminated.
I 2019.03.25 17:33:23 - Session starting.
I 2019.03.25 17:33:23 - Checking authorization ...
. 2019.03.25 17:33:24 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 17:33:24 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 17:33:24 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 17:33:25 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 17:33:25 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 17:33:25 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.25 17:33:25 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 17:33:25 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 17:33:25 - Connection to OpenVPN Management Interface
. 2019.03.25 17:33:25 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 17:33:25 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 17:33:25 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 17:33:25 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 17:33:25 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 17:33:25 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:53
. 2019.03.25 17:33:25 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 17:33:25 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 17:33:25 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:53
. 2019.03.25 17:33:25 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 17:33:55 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:53, sid=51bb0b1e 4e5a3c31
. 2019.03.25 17:33:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 17:33:55 - OpenVPN > VERIFY KU OK
. 2019.03.25 17:33:55 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 17:33:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 17:33:55 - OpenVPN > VERIFY EKU OK
. 2019.03.25 17:33:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.25 17:33:56 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 17:33:56 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:53
. 2019.03.25 17:33:57 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 17:33:57 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2019.03.25 17:33:57 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 17:33:57 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.25 17:33:57 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 17:33:57 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.25 17:33:57 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 17:33:57 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 17:33:57 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 17:33:57 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 17:33:57 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 17:33:57 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 17:33:57 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 17:33:57 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 17:33:57 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 17:33:57 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:33:57 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:33:57 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 17:33:57 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 17:33:57 - Above log line repeated 1 times more
. 2019.03.25 17:33:57 - OpenVPN > Opened utun device utun2
. 2019.03.25 17:33:57 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 17:33:57 - OpenVPN > /sbin/ifconfig utun2 delete
. 2019.03.25 17:33:57 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 17:33:57 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 17:33:57 - OpenVPN > /sbin/ifconfig utun2 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 17:33:57 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.25 17:33:57 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.25 17:33:57 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.25 17:33:57 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.25 17:33:57 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 17:33:57 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.25 17:33:57 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 17:33:57 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.25 17:33:57 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.25 17:33:58 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 17:33:58 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 17:33:58 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 17:33:58 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 17:33:58 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 17:33:58 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.25 17:33:58 - Flushing DNS
. 2019.03.25 17:33:59 - macOS - PF rules updated, reloading
I 2019.03.25 17:34:00 - Checking route IPv4
I 2019.03.25 17:34:02 - Checking DNS
! 2019.03.25 17:34:04 - Connected.
. 2019.03.25 17:34:04 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 17:47:54 - Eddie version: 2.16.3 / macos_x64, System: MacOS, Name: 10.14.3, Version: Darwin Neils-Mac-mini.local 18.2.0 Darwin Kernel Version 18.2.0: Thu Dec 20 20:46:53 PST 2018; root:xnu-4903.241.1~1/RELEASE_X86_64 x86_64, Mono/.Net: v4.0.30319
. 2019.03.25 17:47:54 - Reading options from /Users/neilmclellan/.airvpn/default.xml
. 2019.03.25 17:47:56 - Command line arguments (1): gui.osx.style="dark"
. 2019.03.25 17:47:56 - Profile path: /Users/neilmclellan/.airvpn/default.xml
. 2019.03.25 17:48:00 - OpenVPN Driver - Expected
. 2019.03.25 17:48:00 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
. 2019.03.25 17:48:00 - SSH - Version: OpenSSH_7.9p1, LibreSSL 2.7.3 (/usr/bin/ssh)
. 2019.03.25 17:48:00 - SSL - Version: stunnel 5.48 (/Applications/Eddie.app/Contents/MacOS/stunnel)
. 2019.03.25 17:48:00 - curl - Version: 7.54.0 (/usr/bin/curl)
. 2019.03.25 17:48:00 - Certification Authorities: /Applications/Eddie.app/Contents/MacOS/../Resources/cacert.pem
W 2019.03.25 17:48:00 - Recovery. Unexpected crash?
. 2019.03.25 17:48:00 - Routes, removed a route previously added, 184.75.221.171 for gateway 10.8.190.1
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 184.75.223.195 for gateway 10.29.62.1
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 184.75.221.43 for gateway 10.30.222.1
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 184.75.223.219 for gateway 10.24.30.1
. 2019.03.25 17:48:01 - Above log line repeated 1 times more
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 137.63.71.51 for gateway 10.31.94.1
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 162.219.176.3 for gateway 10.6.126.1
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 199.21.149.49 for gateway 10.15.142.1
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 184.75.221.35 for gateway 10.28.30.1
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 104.254.90.251 for gateway 10.18.30.1
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 104.254.90.187 for gateway 10.28.94.1
. 2019.03.25 17:48:02 - Routes, removed a route previously added, 184.75.221.3 for gateway 10.20.254.1
. 2019.03.25 17:48:02 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 17:48:02 - Above log line repeated 4 times more
! 2019.03.25 17:48:02 - Activation of Network Lock - macOS - PF
. 2019.03.25 17:48:03 - macOS - PF rules updated, reloading
. 2019.03.25 17:48:04 - Updating systems & servers data ...
. 2019.03.25 17:48:17 - macOS - PF rules updated, reloading
I 2019.03.25 17:48:18 - Session starting.
I 2019.03.25 17:48:18 - Checking authorization ...
. 2019.03.25 17:48:19 - Systems & servers data update completed
. 2019.03.25 17:48:19 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 17:48:20 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 17:48:20 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 17:48:20 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 17:48:20 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 17:48:20 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.25 17:48:21 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 17:48:21 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 17:48:21 - Connection to OpenVPN Management Interface
. 2019.03.25 17:48:21 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 17:48:21 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 17:48:21 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 17:48:21 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 17:48:21 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 17:48:21 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:53
. 2019.03.25 17:48:21 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 17:48:21 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 17:48:21 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:53
. 2019.03.25 17:48:21 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:53, sid=cd4addf9 2135e76e
. 2019.03.25 17:48:21 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 17:48:21 - OpenVPN > VERIFY KU OK
. 2019.03.25 17:48:21 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 17:48:21 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 17:48:21 - OpenVPN > VERIFY EKU OK
. 2019.03.25 17:48:21 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.25 17:48:21 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 17:48:22 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 17:48:22 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:53
. 2019.03.25 17:48:23 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 17:48:23 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2019.03.25 17:48:23 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 17:48:23 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.25 17:48:23 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 17:48:23 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.25 17:48:23 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 17:48:23 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 17:48:23 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 17:48:23 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 17:48:23 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 17:48:23 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 17:48:23 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 17:48:23 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 17:48:23 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 17:48:23 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:48:23 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:48:23 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 17:48:23 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 17:48:23 - OpenVPN > Opened utun device utun1
. 2019.03.25 17:48:23 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 17:48:23 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.25 17:48:23 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 17:48:23 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 17:48:23 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 17:48:23 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.25 17:48:23 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.25 17:48:23 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.25 17:48:23 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.25 17:48:23 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 17:48:23 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.25 17:48:23 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 17:48:23 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.25 17:48:23 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.25 17:48:24 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 17:48:24 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 17:48:24 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 17:48:25 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 17:48:25 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 17:48:25 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.25 17:48:25 - Flushing DNS
. 2019.03.25 17:48:25 - macOS - PF rules updated, reloading
I 2019.03.25 17:48:26 - Checking route IPv4
I 2019.03.25 17:48:29 - Checking DNS
! 2019.03.25 17:48:31 - Connected.
. 2019.03.25 17:48:31 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 17:58:24 - Updating systems & servers data ...
. 2019.03.25 17:58:29 - Systems & servers data update completed
. 2019.03.25 18:29:57 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.25 18:29:57 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.25 18:29:57 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.25 18:29:58 - macOS - PF rules updated, reloading
! 2019.03.25 18:29:59 - Disconnecting
. 2019.03.25 18:29:59 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 18:29:59 - Sending management termination signal
. 2019.03.25 18:29:59 - Management - Send 'signal SIGTERM'
. 2019.03.25 18:29:59 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 18:29:59 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.25 18:29:59 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.25 18:29:59 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:29:59 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:29:59 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:29:59 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:29:59 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 18:29:59 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2019.03.25 18:29:59 - Connection terminated.
. 2019.03.25 18:29:59 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 18:29:59 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 18:30:00 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 18:30:00 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 18:30:00 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 18:30:00 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 18:30:00 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:30:00 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:30:00 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:30:00 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 18:30:03 - Checking authorization ...
. 2019.03.25 18:30:05 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 18:30:05 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 18:30:05 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 18:30:05 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 18:30:05 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 18:30:05 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.25 18:30:05 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 18:30:05 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 18:30:05 - Connection to OpenVPN Management Interface
. 2019.03.25 18:30:05 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 18:30:05 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 18:30:05 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 18:30:05 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 18:30:05 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 18:30:05 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:53
. 2019.03.25 18:30:05 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 18:30:05 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 18:30:05 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:53
. 2019.03.25 18:30:05 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 18:30:05 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:53, sid=cbafc4f0 199786c2
. 2019.03.25 18:30:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 18:30:06 - OpenVPN > VERIFY KU OK
. 2019.03.25 18:30:06 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 18:30:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 18:30:06 - OpenVPN > VERIFY EKU OK
. 2019.03.25 18:30:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.25 18:30:06 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 18:30:06 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:53
. 2019.03.25 18:30:07 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 18:30:08 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2019.03.25 18:30:08 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 18:30:08 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.25 18:30:08 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 18:30:08 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.25 18:30:08 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 18:30:08 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 18:30:08 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 18:30:08 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 18:30:08 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 18:30:08 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 18:30:08 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 18:30:08 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 18:30:08 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 18:30:08 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 18:30:08 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 18:30:08 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 18:30:08 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 18:30:08 - OpenVPN > Opened utun device utun1
. 2019.03.25 18:30:08 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 18:30:08 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.25 18:30:08 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 18:30:08 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 18:30:08 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 18:30:08 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.25 18:30:08 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.25 18:30:08 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.25 18:30:08 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.25 18:30:08 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:30:08 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:30:08 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:30:08 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:30:09 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.25 18:30:09 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:30:10 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:30:10 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:30:11 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:30:12 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 18:30:12 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.25 18:30:12 - Flushing DNS
. 2019.03.25 18:30:12 - macOS - PF rules updated, reloading
I 2019.03.25 18:30:13 - Checking route IPv4
I 2019.03.25 18:30:16 - Checking DNS
! 2019.03.25 18:30:17 - Connected.
. 2019.03.25 18:30:17 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 18:47:55 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.25 18:47:55 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.25 18:47:55 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.25 18:47:56 - Updating systems & servers data ...
. 2019.03.25 18:47:56 - macOS - PF rules updated, reloading
! 2019.03.25 18:47:57 - Disconnecting
. 2019.03.25 18:47:58 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 18:47:58 - Sending management termination signal
. 2019.03.25 18:47:58 - Management - Send 'signal SIGTERM'
. 2019.03.25 18:47:58 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:53
. 2019.03.25 18:47:58 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 18:47:58 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 18:47:58 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:53
. 2019.03.25 18:47:58 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 18:47:58 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.25 18:47:58 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:53, sid=0868cc19 a2cca0cf
. 2019.03.25 18:47:58 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 18:47:58 - OpenVPN > VERIFY KU OK
. 2019.03.25 18:47:58 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 18:47:58 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 18:47:58 - OpenVPN > VERIFY EKU OK
. 2019.03.25 18:47:58 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.25 18:47:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 18:47:59 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:53
. 2019.03.25 18:48:00 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 18:48:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2019.03.25 18:48:00 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 18:48:00 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.25 18:48:00 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 18:48:00 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.25 18:48:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 18:48:00 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 18:48:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 18:48:00 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 18:48:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 18:48:00 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 18:48:00 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 18:48:00 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 18:48:00 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 18:48:00 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 18:48:00 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 18:48:00 - OpenVPN > Preserving previous TUN/TAP instance: utun1
. 2019.03.25 18:48:00 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 18:48:00 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.25 18:48:00 - Flushing DNS
. 2019.03.25 18:48:01 - macOS - PF rules updated, reloading
. 2019.03.25 18:48:02 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 18:48:03 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.25 18:48:03 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.25 18:48:03 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:48:03 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:48:03 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:48:03 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:48:03 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 18:48:03 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.25 18:48:03 - Connection terminated.
. 2019.03.25 18:48:03 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 18:48:03 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 18:48:04 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 18:48:04 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 18:48:04 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 18:48:04 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 18:48:05 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:48:05 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:48:06 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:48:06 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 18:48:09 - Checking authorization ...
. 2019.03.25 18:48:11 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 18:48:11 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 18:48:11 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 18:48:11 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 18:48:11 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 18:48:11 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.25 18:48:11 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 18:48:11 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 18:48:11 - Connection to OpenVPN Management Interface
. 2019.03.25 18:48:11 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 18:48:11 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 18:48:11 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 18:48:11 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 18:48:11 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 18:48:11 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:53
. 2019.03.25 18:48:11 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 18:48:11 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 18:48:11 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:53
. 2019.03.25 18:48:11 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 18:48:11 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:53, sid=3ae5b991 fe57ff55
. 2019.03.25 18:48:12 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 18:48:12 - OpenVPN > VERIFY KU OK
. 2019.03.25 18:48:12 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 18:48:12 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 18:48:12 - OpenVPN > VERIFY EKU OK
. 2019.03.25 18:48:12 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.25 18:48:12 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 18:48:12 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:53
. 2019.03.25 18:48:13 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 18:48:13 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2019.03.25 18:48:13 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 18:48:13 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.25 18:48:13 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 18:48:13 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.25 18:48:13 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 18:48:13 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 18:48:13 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 18:48:13 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 18:48:13 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 18:48:13 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 18:48:13 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 18:48:13 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 18:48:13 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 18:48:13 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 18:48:13 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 18:48:13 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 18:48:13 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 18:48:13 - OpenVPN > Opened utun device utun1
. 2019.03.25 18:48:13 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 18:48:13 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.25 18:48:13 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 18:48:13 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 18:48:13 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 18:48:13 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.25 18:48:13 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.25 18:48:13 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.25 18:48:13 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.25 18:48:13 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:48:13 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:48:13 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:48:13 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:48:14 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.25 18:48:14 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:48:14 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:48:15 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:48:16 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:48:16 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 18:48:16 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.25 18:48:16 - Flushing DNS
I 2019.03.25 18:48:17 - Checking route IPv4
. 2019.03.25 18:48:19 - Systems & servers data update completed
. 2019.03.25 18:48:37 - curl: (28) Connection timed out after 20002 milliseconds
. 2019.03.25 18:48:37 - Checking route (2° try)
. 2019.03.25 18:48:58 - curl: (28) Connection timed out after 20004 milliseconds
. 2019.03.25 18:48:58 - OpenVPN > Initialization Sequence Completed
! 2019.03.25 18:48:58 - Disconnecting
. 2019.03.25 18:48:58 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 18:48:58 - Sending management termination signal
. 2019.03.25 18:48:58 - Management - Send 'signal SIGTERM'
. 2019.03.25 18:48:58 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 18:48:58 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.25 18:49:03 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.25 18:49:03 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.25 18:49:03 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:49:03 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:49:03 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:49:03 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:49:03 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 18:49:03 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.25 18:49:03 - Connection terminated.
. 2019.03.25 18:49:03 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 18:49:03 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 18:49:03 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 18:49:03 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 18:49:03 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 18:49:03 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 18:49:04 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:49:04 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:49:04 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:49:04 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:49:04 - Flushing DNS
! 2019.03.25 18:49:04 - Session terminated.
! 2019.03.25 18:49:08 - Deactivation of Network Lock
I 2019.03.25 18:49:26 - Session starting.
I 2019.03.25 18:49:26 - Checking authorization ...
. 2019.03.25 18:49:27 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 18:49:27 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 18:49:27 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 18:49:27 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 18:49:27 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 18:49:27 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.25 18:49:27 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 18:49:27 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 18:49:27 - Connection to OpenVPN Management Interface
. 2019.03.25 18:49:27 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 18:49:27 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 18:49:27 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 18:49:27 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 18:49:27 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 18:49:27 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:53
. 2019.03.25 18:49:27 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 18:49:27 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 18:49:27 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:53
. 2019.03.25 18:49:28 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 18:49:28 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:53, sid=4a0ff817 f5c58a09
. 2019.03.25 18:49:28 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 18:49:28 - OpenVPN > VERIFY KU OK
. 2019.03.25 18:49:28 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 18:49:28 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 18:49:28 - OpenVPN > VERIFY EKU OK
. 2019.03.25 18:49:28 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.25 18:49:28 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 18:49:28 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:53
. 2019.03.25 18:49:29 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 18:49:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2019.03.25 18:49:30 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 18:49:30 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.25 18:49:30 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 18:49:30 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.25 18:49:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 18:49:30 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 18:49:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 18:49:30 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 18:49:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 18:49:30 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 18:49:30 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 18:49:30 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 18:49:30 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 18:49:30 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 18:49:30 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 18:49:30 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 18:49:30 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 18:49:30 - OpenVPN > Opened utun device utun1
. 2019.03.25 18:49:30 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 18:49:30 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.25 18:49:30 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 18:49:30 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 18:49:30 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 18:49:30 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.25 18:49:30 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.25 18:49:30 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.25 18:49:30 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.25 18:49:30 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:49:30 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:49:30 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:49:30 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:49:30 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.25 18:49:30 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:49:31 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:49:31 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:49:31 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:49:31 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 18:49:31 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.25 18:49:31 - Flushing DNS
I 2019.03.25 18:49:31 - Checking route IPv4
I 2019.03.25 18:49:33 - Checking DNS
! 2019.03.25 18:49:35 - Connected.
. 2019.03.25 18:49:35 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 14:36:33 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 14:36:33 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 14:36:33 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 14:36:33 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 14:36:33 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 14:36:33 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 14:36:33 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 14:36:33 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=3dab12db 027ceea7
. 2019.03.26 14:36:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 14:36:34 - OpenVPN > VERIFY KU OK
. 2019.03.26 14:36:34 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 14:36:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 14:36:34 - OpenVPN > VERIFY EKU OK
. 2019.03.26 14:36:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 14:36:34 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 14:36:34 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 14:36:35 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 14:36:35 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 14:36:35 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 14:36:35 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 14:36:35 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 14:36:35 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 14:36:35 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 14:36:35 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 14:36:35 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 14:36:35 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 14:36:35 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 14:36:35 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 14:36:35 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 14:36:35 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 14:36:35 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 14:36:35 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 14:36:35 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 14:36:35 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 14:36:35 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 14:36:35 - OpenVPN > Opened utun device utun1
. 2019.03.26 14:36:35 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 14:36:35 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 14:36:35 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 14:36:35 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 14:36:35 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 14:36:35 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 14:36:35 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 14:36:35 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 14:36:35 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 14:36:35 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 14:36:35 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 14:36:35 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 14:36:35 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 14:36:36 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 14:36:37 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 14:36:37 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 14:36:37 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 14:36:37 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 14:36:37 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 14:36:37 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 14:36:37 - Flushing DNS
. 2019.03.26 14:36:38 - macOS - PF rules updated, reloading
! 2019.03.26 14:36:39 - Connected.
. 2019.03.26 14:36:39 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 14:36:42 - macOS - PF rules updated, reloading
. 2019.03.26 14:36:43 - Systems & servers data update completed
. 2019.03.26 15:01:58 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.26 15:01:58 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.26 15:01:58 - OpenVPN > Restart pause, 5 second(s)
! 2019.03.26 15:01:59 - Disconnecting
. 2019.03.26 15:01:59 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 15:01:59 - Sending management termination signal
. 2019.03.26 15:01:59 - Management - Send 'signal SIGTERM'
. 2019.03.26 15:02:00 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.26 15:02:00 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 15:02:00 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 15:02:00 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 15:02:00 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 15:02:00 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 15:02:00 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 15:02:00 - OpenVPN > Closing TUN/TAP interface
. 2019.03.26 15:02:00 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2019.03.26 15:02:00 - Connection terminated.
. 2019.03.26 15:02:00 - IPv6 restored on network adapter (Ethernet)
. 2019.03.26 15:02:00 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.26 15:02:00 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.26 15:02:00 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.26 15:02:00 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.26 15:02:00 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.26 15:02:01 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 15:02:02 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 15:02:02 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 15:02:02 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.26 15:02:05 - Checking authorization ...
. 2019.03.26 15:02:07 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.26 15:02:07 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.26 15:02:07 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.26 15:02:07 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.26 15:02:07 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.26 15:02:07 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.26 15:02:07 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.26 15:02:07 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.26 15:02:07 - Connection to OpenVPN Management Interface
. 2019.03.26 15:02:07 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.26 15:02:07 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 15:02:07 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 15:02:07 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 15:02:07 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 15:02:07 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 15:02:07 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 15:02:07 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 15:02:07 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 15:02:07 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 15:02:07 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=1a675a4a 5e22e76b
. 2019.03.26 15:02:08 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 15:02:08 - OpenVPN > VERIFY KU OK
. 2019.03.26 15:02:08 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 15:02:08 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 15:02:08 - OpenVPN > VERIFY EKU OK
. 2019.03.26 15:02:08 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 15:02:08 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 15:02:08 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 15:02:09 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 15:02:09 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 15:02:09 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 15:02:09 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 15:02:09 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 15:02:09 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 15:02:09 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 15:02:09 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 15:02:09 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 15:02:09 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 15:02:09 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 15:02:09 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 15:02:09 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 15:02:09 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 15:02:09 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 15:02:09 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 15:02:09 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 15:02:09 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 15:02:09 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 15:02:09 - OpenVPN > Opened utun device utun1
. 2019.03.26 15:02:09 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 15:02:09 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 15:02:09 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 15:02:09 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 15:02:09 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 15:02:09 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 15:02:09 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 15:02:09 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 15:02:09 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 15:02:09 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 15:02:09 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 15:02:09 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 15:02:09 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 15:02:10 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 15:02:10 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 15:02:11 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 15:02:11 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 15:02:11 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 15:02:11 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 15:02:11 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 15:02:11 - Flushing DNS
. 2019.03.26 15:02:12 - macOS - PF rules updated, reloading
! 2019.03.26 15:02:13 - Connected.
. 2019.03.26 15:02:13 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 15:02:32 - Updating systems & servers data ...
. 2019.03.26 15:02:36 - Systems & servers data update completed
. 2019.03.26 15:30:18 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.26 15:30:18 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.26 15:30:18 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.26 15:30:21 - macOS - PF rules updated, reloading
! 2019.03.26 15:30:22 - Disconnecting
. 2019.03.26 15:30:22 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 15:30:22 - Sending management termination signal
. 2019.03.26 15:30:22 - Management - Send 'signal SIGTERM'
. 2019.03.26 15:30:22 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.26 15:30:22 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 15:30:22 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 15:30:22 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 15:30:22 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 15:30:22 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 15:30:22 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 15:30:22 - OpenVPN > Closing TUN/TAP interface
. 2019.03.26 15:30:22 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2019.03.26 15:30:22 - Connection terminated.
. 2019.03.26 15:30:22 - IPv6 restored on network adapter (Ethernet)
. 2019.03.26 15:30:23 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.26 15:30:23 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.26 15:30:23 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.26 15:30:23 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.26 15:30:23 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.26 15:30:23 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 15:30:24 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 15:30:24 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 15:30:24 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.26 15:30:27 - Checking authorization ...
. 2019.03.26 15:30:28 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.26 15:30:29 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.26 15:30:29 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.26 15:30:29 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.26 15:30:29 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.26 15:30:29 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.26 15:30:29 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.26 15:30:29 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.26 15:30:29 - Connection to OpenVPN Management Interface
. 2019.03.26 15:30:29 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.26 15:30:29 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 15:30:29 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 15:30:29 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 15:30:29 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 15:30:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 15:30:29 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 15:30:29 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 15:30:29 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 15:30:29 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 15:30:29 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=cc3a5046 1e4d22c2
. 2019.03.26 15:30:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 15:30:30 - OpenVPN > VERIFY KU OK
. 2019.03.26 15:30:30 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 15:30:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 15:30:30 - OpenVPN > VERIFY EKU OK
. 2019.03.26 15:30:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 15:30:30 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 15:30:30 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 15:30:31 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 15:30:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 15:30:31 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 15:30:31 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 15:30:31 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 15:30:31 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 15:30:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 15:30:31 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 15:30:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 15:30:31 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 15:30:31 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 15:30:31 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 15:30:31 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 15:30:31 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 15:30:31 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 15:30:31 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 15:30:31 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 15:30:31 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 15:30:31 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 15:30:31 - OpenVPN > Opened utun device utun1
. 2019.03.26 15:30:31 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 15:30:31 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 15:30:31 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 15:30:31 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 15:30:31 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 15:30:31 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 15:30:31 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 15:30:31 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 15:30:31 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 15:30:31 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 15:30:31 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 15:30:31 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 15:30:31 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 15:30:32 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 15:30:32 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 15:30:32 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 15:30:32 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 15:30:32 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 15:30:32 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 15:30:32 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 15:30:32 - Flushing DNS
. 2019.03.26 15:30:34 - macOS - PF rules updated, reloading
! 2019.03.26 15:30:35 - Connected.
. 2019.03.26 15:30:35 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 16:02:42 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.26 16:02:42 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.26 16:02:42 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.26 16:03:33 - macOS - PF rules updated, reloading
! 2019.03.26 16:04:02 - Disconnecting
. 2019.03.26 16:04:02 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 16:04:02 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 16:04:02 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 16:04:02 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 16:04:02 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 16:04:02 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=23199345 86f9af64
. 2019.03.26 16:04:02 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 16:04:02 - OpenVPN > VERIFY KU OK
. 2019.03.26 16:04:02 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 16:04:02 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 16:04:02 - OpenVPN > VERIFY EKU OK
. 2019.03.26 16:04:02 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 16:04:02 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 16:04:02 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 16:04:02 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 16:04:02 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 16:04:02 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 16:04:02 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 16:04:02 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 16:04:02 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 16:04:02 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 16:04:02 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 16:04:02 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 16:04:02 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 16:04:02 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 16:04:02 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 16:04:02 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 16:04:02 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 16:04:02 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 16:04:02 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 16:04:02 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 16:04:02 - OpenVPN > Preserving previous TUN/TAP instance: utun1
. 2019.03.26 16:04:02 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 16:04:02 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 16:04:02 - Flushing DNS
. 2019.03.26 16:04:03 - macOS - PF rules updated, reloading
. 2019.03.26 16:04:04 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 16:04:04 - OpenVPN > write UDP: Network is down (code=50)
. 2019.03.26 16:04:04 - Above log line repeated 1 times more
. 2019.03.26 16:04:04 - Sending management termination signal
. 2019.03.26 16:04:04 - Management - Send 'signal SIGTERM'
. 2019.03.26 16:04:04 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.26 16:04:04 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.26 16:04:05 - Updating systems & servers data ...
. 2019.03.26 16:04:09 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 16:04:09 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 16:04:09 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 16:04:09 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 16:04:09 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 16:04:09 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 16:04:09 - OpenVPN > Closing TUN/TAP interface
. 2019.03.26 16:04:09 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.26 16:04:09 - Connection terminated.
. 2019.03.26 16:04:09 - IPv6 restored on network adapter (Ethernet)
. 2019.03.26 16:04:09 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.26 16:04:09 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.26 16:04:09 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.26 16:04:09 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.26 16:04:09 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.26 16:04:09 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 16:04:09 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 16:04:09 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 16:04:09 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.26 16:04:12 - Checking authorization ...
. 2019.03.26 16:04:13 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.26 16:04:13 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.26 16:04:14 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.26 16:04:14 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.26 16:04:14 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.26 16:04:14 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.26 16:04:14 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.26 16:04:14 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.26 16:04:14 - Connection to OpenVPN Management Interface
. 2019.03.26 16:04:14 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.26 16:04:14 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 16:04:14 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 16:04:14 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 16:04:14 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 16:04:14 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 16:04:14 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 16:04:14 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 16:04:14 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 16:04:14 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 16:04:14 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=a6914e54 5fb42c20
. 2019.03.26 16:04:15 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 16:04:15 - OpenVPN > VERIFY KU OK
. 2019.03.26 16:04:15 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 16:04:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 16:04:15 - OpenVPN > VERIFY EKU OK
. 2019.03.26 16:04:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 16:04:15 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 16:04:15 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 16:04:16 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 16:04:16 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 16:04:16 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 16:04:16 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 16:04:16 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 16:04:16 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 16:04:16 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 16:04:16 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 16:04:16 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 16:04:16 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 16:04:16 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 16:04:16 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 16:04:16 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 16:04:16 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 16:04:16 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 16:04:16 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 16:04:16 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 16:04:16 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 16:04:16 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 16:04:16 - OpenVPN > Opened utun device utun1
. 2019.03.26 16:04:16 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 16:04:16 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 16:04:16 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 16:04:16 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 16:04:16 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 16:04:16 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 16:04:16 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 16:04:16 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 16:04:16 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 16:04:16 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 16:04:16 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 16:04:16 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 16:04:16 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 16:04:17 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 16:04:18 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 16:04:18 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 16:04:18 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 16:04:18 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 16:04:18 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 16:04:18 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 16:04:18 - Flushing DNS
! 2019.03.26 16:04:19 - Connected.
. 2019.03.26 16:04:19 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 16:04:28 - Systems & servers data update completed
. 2019.03.26 17:34:06 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.26 17:34:06 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.26 17:34:06 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.26 17:34:08 - macOS - PF rules updated, reloading
! 2019.03.26 17:34:09 - Disconnecting
. 2019.03.26 17:34:09 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 17:34:09 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 17:34:09 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 17:34:09 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 17:34:09 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 17:34:09 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=bb5f801e 4b859d10
. 2019.03.26 17:34:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 17:34:09 - OpenVPN > VERIFY KU OK
. 2019.03.26 17:34:09 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 17:34:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 17:34:09 - OpenVPN > VERIFY EKU OK
. 2019.03.26 17:34:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 17:34:09 - Sending management termination signal
. 2019.03.26 17:34:09 - Management - Send 'signal SIGTERM'
. 2019.03.26 17:34:09 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.26 17:34:09 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.26 17:34:10 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 17:34:10 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 17:34:11 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 17:34:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 17:34:11 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 17:34:11 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 17:34:11 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 17:34:11 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 17:34:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 17:34:11 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 17:34:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 17:34:11 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 17:34:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 17:34:11 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 17:34:11 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 17:34:11 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 17:34:11 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 17:34:11 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 17:34:11 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 17:34:11 - OpenVPN > Preserving previous TUN/TAP instance: utun1
. 2019.03.26 17:34:11 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 17:34:11 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 17:34:11 - Flushing DNS
. 2019.03.26 17:34:12 - macOS - PF rules updated, reloading
. 2019.03.26 17:34:13 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 17:34:14 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 17:34:14 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 17:34:14 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 17:34:14 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 17:34:14 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 17:34:14 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 17:34:14 - OpenVPN > Closing TUN/TAP interface
. 2019.03.26 17:34:14 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.26 17:34:14 - Connection terminated.
. 2019.03.26 17:34:14 - IPv6 restored on network adapter (Ethernet)
. 2019.03.26 17:34:14 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.26 17:34:14 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.26 17:34:14 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.26 17:34:14 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.26 17:34:14 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.26 17:34:15 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 17:34:16 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 17:34:16 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 17:34:16 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.26 17:34:19 - Checking authorization ...
. 2019.03.26 17:34:20 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.26 17:34:20 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.26 17:34:20 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.26 17:34:20 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.26 17:34:21 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.26 17:34:21 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.26 17:34:21 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.26 17:34:21 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.26 17:34:21 - Connection to OpenVPN Management Interface
. 2019.03.26 17:34:21 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.26 17:34:21 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 17:34:21 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 17:34:21 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 17:34:21 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 17:34:21 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 17:34:21 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 17:34:21 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 17:34:21 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 17:34:21 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 17:34:21 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=8714e7a6 3785c85c
. 2019.03.26 17:34:21 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 17:34:21 - OpenVPN > VERIFY KU OK
. 2019.03.26 17:34:21 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 17:34:21 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 17:34:21 - OpenVPN > VERIFY EKU OK
. 2019.03.26 17:34:21 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 17:34:22 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 17:34:22 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 17:34:23 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 17:34:23 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 17:34:23 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 17:34:23 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 17:34:23 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 17:34:23 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 17:34:23 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 17:34:23 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 17:34:23 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 17:34:23 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 17:34:23 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 17:34:23 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 17:34:23 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 17:34:23 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 17:34:23 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 17:34:23 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 17:34:23 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 17:34:23 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 17:34:23 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 17:34:23 - OpenVPN > Opened utun device utun1
. 2019.03.26 17:34:23 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 17:34:23 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 17:34:23 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 17:34:23 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 17:34:23 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 17:34:23 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 17:34:23 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 17:34:23 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 17:34:23 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 17:34:23 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 17:34:23 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 17:34:23 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 17:34:23 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 17:34:24 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 17:34:25 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 17:34:25 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 17:34:25 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 17:34:25 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 17:34:25 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 17:34:25 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 17:34:25 - Flushing DNS
! 2019.03.26 17:34:26 - Connected.
. 2019.03.26 17:34:26 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 17:34:44 - Updating systems & servers data ...
. 2019.03.26 17:34:49 - Systems & servers data update completed
. 2019.03.26 17:42:26 - macOS - PF rules updated, reloading
! 2019.03.26 17:42:27 - Disconnecting
. 2019.03.26 17:42:27 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 17:42:27 - Sending management termination signal
. 2019.03.26 17:42:27 - Management - Send 'signal SIGTERM'
. 2019.03.26 17:42:27 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.26 17:42:27 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.26 17:42:32 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 17:42:32 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 17:42:32 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 17:42:32 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 17:42:32 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 17:42:32 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 17:42:32 - OpenVPN > Closing TUN/TAP interface
. 2019.03.26 17:42:32 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.26 17:42:32 - Connection terminated.
. 2019.03.26 17:42:32 - IPv6 restored on network adapter (Ethernet)
. 2019.03.26 17:42:32 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.26 17:42:32 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.26 17:42:32 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.26 17:42:32 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.26 17:42:32 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.26 17:42:32 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 17:42:32 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 17:42:32 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 17:42:32 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 17:42:32 - Flushing DNS
! 2019.03.26 17:42:33 - Session terminated.
! 2019.03.26 17:42:34 - Deactivation of Network Lock
! 2019.03.26 17:43:41 - Activation of Network Lock - macOS - PF
. 2019.03.26 17:43:43 - macOS - PF rules updated, reloading
I 2019.03.26 17:43:46 - Session starting.
I 2019.03.26 17:43:46 - Checking authorization ...
. 2019.03.26 17:43:47 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.26 17:43:47 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.26 17:43:47 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.26 17:43:47 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.26 17:43:47 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.26 17:43:47 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.26 17:43:47 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.26 17:43:47 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.26 17:43:47 - Connection to OpenVPN Management Interface
. 2019.03.26 17:43:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.26 17:43:47 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 17:43:47 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 17:43:47 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 17:43:47 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 17:43:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 17:43:47 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 17:43:47 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 17:43:47 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 17:43:48 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 17:43:48 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=2435b175 800d3b7e
. 2019.03.26 17:43:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 17:43:48 - OpenVPN > VERIFY KU OK
. 2019.03.26 17:43:48 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 17:43:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 17:43:48 - OpenVPN > VERIFY EKU OK
. 2019.03.26 17:43:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 17:43:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 17:43:48 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 17:43:50 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 17:43:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 17:43:50 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 17:43:50 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 17:43:50 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 17:43:50 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 17:43:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 17:43:50 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 17:43:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 17:43:50 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 17:43:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 17:43:50 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 17:43:50 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 17:43:50 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 17:43:50 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 17:43:50 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 17:43:50 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 17:43:50 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 17:43:50 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 17:43:50 - OpenVPN > Opened utun device utun1
. 2019.03.26 17:43:50 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 17:43:50 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 17:43:50 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 17:43:50 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 17:43:50 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 17:43:50 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 17:43:50 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 17:43:50 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 17:43:50 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 17:43:50 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 17:43:50 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 17:43:50 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 17:43:50 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 17:43:50 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 17:43:50 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 17:43:50 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 17:43:50 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 17:43:51 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 17:43:51 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 17:43:51 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 17:43:51 - Flushing DNS
. 2019.03.26 17:43:52 - macOS - PF rules updated, reloading
! 2019.03.26 17:43:53 - Connected.
. 2019.03.26 17:43:53 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 17:45:13 - Updating systems & servers data ...
. 2019.03.26 17:45:18 - Systems & servers data update completed
. 2019.03.26 17:55:25 - Updating systems & servers data ...
. 2019.03.26 17:55:30 - Systems & servers data update completed
. 2019.03.26 18:05:36 - Updating systems & servers data ...
. 2019.03.26 18:05:41 - Systems & servers data update completed
. 2019.03.26 18:16:33 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.26 18:16:33 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.26 18:16:33 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.26 18:16:35 - Updating systems & servers data ...
. 2019.03.26 18:16:36 - macOS - PF rules updated, reloading
! 2019.03.26 18:16:37 - Disconnecting
. 2019.03.26 18:16:38 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 18:16:38 - Sending management termination signal
. 2019.03.26 18:16:38 - Management - Send 'signal SIGTERM'
. 2019.03.26 18:16:38 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.26 18:16:38 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 18:16:38 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 18:16:38 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:16:38 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:16:38 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:16:38 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:16:38 - OpenVPN > Closing TUN/TAP interface
. 2019.03.26 18:16:38 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2019.03.26 18:16:38 - Connection terminated.
. 2019.03.26 18:16:38 - IPv6 restored on network adapter (Ethernet)
. 2019.03.26 18:16:38 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.26 18:16:38 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.26 18:16:38 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.26 18:16:38 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.26 18:16:38 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.26 18:16:38 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:16:38 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:16:38 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:16:38 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.26 18:16:42 - Checking authorization ...
. 2019.03.26 18:16:43 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.26 18:16:43 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.26 18:16:43 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.26 18:16:43 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.26 18:16:43 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.26 18:16:43 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.26 18:16:43 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.26 18:16:43 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.26 18:16:43 - Connection to OpenVPN Management Interface
. 2019.03.26 18:16:43 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.26 18:16:43 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 18:16:43 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 18:16:43 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 18:16:43 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 18:16:43 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 18:16:43 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 18:16:43 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 18:16:43 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 18:16:44 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 18:16:44 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=816cdd23 322acab5
. 2019.03.26 18:16:44 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 18:16:44 - OpenVPN > VERIFY KU OK
. 2019.03.26 18:16:44 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 18:16:44 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 18:16:44 - OpenVPN > VERIFY EKU OK
. 2019.03.26 18:16:44 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 18:16:44 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 18:16:44 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 18:16:45 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 18:16:46 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 18:16:46 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 18:16:46 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 18:16:46 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 18:16:46 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 18:16:46 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 18:16:46 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 18:16:46 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 18:16:46 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 18:16:46 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 18:16:46 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 18:16:46 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 18:16:46 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 18:16:46 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 18:16:46 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 18:16:46 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 18:16:46 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 18:16:46 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 18:16:46 - OpenVPN > Opened utun device utun1
. 2019.03.26 18:16:46 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 18:16:46 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 18:16:46 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 18:16:46 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 18:16:46 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 18:16:46 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 18:16:46 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 18:16:46 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 18:16:46 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 18:16:46 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:16:46 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:16:46 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:16:46 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:16:46 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 18:16:48 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:16:48 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:16:48 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:16:48 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:16:48 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 18:16:48 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 18:16:48 - Flushing DNS
. 2019.03.26 18:16:49 - macOS - PF rules updated, reloading
! 2019.03.26 18:16:50 - Connected.
. 2019.03.26 18:16:50 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 18:16:51 - Systems & servers data update completed
. 2019.03.26 18:47:57 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.26 18:47:57 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.26 18:47:57 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.26 18:47:58 - macOS - PF rules updated, reloading
! 2019.03.26 18:47:59 - Disconnecting
. 2019.03.26 18:47:59 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 18:47:59 - Sending management termination signal
. 2019.03.26 18:47:59 - Management - Send 'signal SIGTERM'
. 2019.03.26 18:47:59 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.26 18:47:59 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 18:47:59 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 18:47:59 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:47:59 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:47:59 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:47:59 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:47:59 - OpenVPN > Closing TUN/TAP interface
. 2019.03.26 18:47:59 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2019.03.26 18:47:59 - Connection terminated.
. 2019.03.26 18:47:59 - IPv6 restored on network adapter (Ethernet)
. 2019.03.26 18:47:59 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.26 18:48:00 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.26 18:48:00 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.26 18:48:00 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.26 18:48:00 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.26 18:48:00 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:48:01 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:48:01 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:48:01 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.26 18:48:04 - Checking authorization ...
. 2019.03.26 18:48:05 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.26 18:48:06 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.26 18:48:06 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.26 18:48:06 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.26 18:48:06 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.26 18:48:06 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.26 18:48:06 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.26 18:48:06 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.26 18:48:06 - Connection to OpenVPN Management Interface
. 2019.03.26 18:48:06 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.26 18:48:06 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 18:48:06 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 18:48:06 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 18:48:06 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 18:48:06 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 18:48:06 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 18:48:06 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 18:48:06 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 18:48:06 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 18:48:06 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=be1e93d8 dc247f5a
. 2019.03.26 18:48:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 18:48:06 - OpenVPN > VERIFY KU OK
. 2019.03.26 18:48:06 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 18:48:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 18:48:06 - OpenVPN > VERIFY EKU OK
. 2019.03.26 18:48:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 18:48:07 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 18:48:07 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 18:48:08 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 18:48:08 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 18:48:08 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 18:48:08 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 18:48:08 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 18:48:08 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 18:48:08 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 18:48:08 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 18:48:08 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 18:48:08 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 18:48:08 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 18:48:08 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 18:48:08 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 18:48:08 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 18:48:08 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 18:48:08 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 18:48:08 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 18:48:08 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 18:48:08 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 18:48:08 - OpenVPN > Opened utun device utun1
. 2019.03.26 18:48:08 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 18:48:08 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 18:48:08 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 18:48:08 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 18:48:08 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 18:48:08 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 18:48:08 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 18:48:08 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 18:48:08 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 18:48:08 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:48:08 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:48:08 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:48:08 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:48:09 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 18:48:10 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:48:10 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:48:10 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:48:10 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:48:10 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 18:48:10 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 18:48:10 - Flushing DNS
. 2019.03.26 18:48:11 - macOS - PF rules updated, reloading
! 2019.03.26 18:48:13 - Connected.
. 2019.03.26 18:48:13 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 18:48:29 - Updating systems & servers data ...
. 2019.03.26 18:48:33 - Systems & servers data update completed
. 2019.03.26 18:51:35 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.26 18:51:35 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.26 18:51:35 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.26 18:51:36 - macOS - PF rules updated, reloading
! 2019.03.26 18:51:37 - Disconnecting
. 2019.03.26 18:51:37 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 18:51:37 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 18:51:37 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 18:51:37 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 18:51:37 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 18:51:37 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=97300180 382cb41b
. 2019.03.26 18:51:37 - Sending management termination signal
. 2019.03.26 18:51:37 - Management - Send 'signal SIGTERM'
. 2019.03.26 18:51:37 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.26 18:51:37 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.26 18:51:37 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 18:51:37 - OpenVPN > VERIFY KU OK
. 2019.03.26 18:51:37 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 18:51:37 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 18:51:37 - OpenVPN > VERIFY EKU OK
. 2019.03.26 18:51:37 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 18:51:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 18:51:38 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 18:51:39 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 18:51:39 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 18:51:39 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 18:51:39 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 18:51:39 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 18:51:39 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 18:51:39 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 18:51:39 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 18:51:39 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 18:51:39 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 18:51:39 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 18:51:39 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 18:51:39 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 18:51:39 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 18:51:39 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 18:51:39 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 18:51:39 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 18:51:39 - OpenVPN > Preserving previous TUN/TAP instance: utun1
. 2019.03.26 18:51:39 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 18:51:39 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 18:51:39 - Flushing DNS
. 2019.03.26 18:51:40 - macOS - PF rules updated, reloading
. 2019.03.26 18:51:41 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 18:51:42 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 18:51:42 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 18:51:42 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:51:42 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:51:42 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:51:42 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:51:42 - OpenVPN > Closing TUN/TAP interface
. 2019.03.26 18:51:42 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.26 18:51:42 - Connection terminated.
. 2019.03.26 18:51:42 - IPv6 restored on network adapter (Ethernet)
. 2019.03.26 18:51:42 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.26 18:51:42 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.26 18:51:42 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.26 18:51:42 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.26 18:51:42 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.26 18:51:42 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:51:43 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:51:43 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:51:43 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.26 18:51:47 - Checking authorization ...
. 2019.03.26 18:51:48 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.26 18:51:49 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.26 18:51:49 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.26 18:51:49 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.26 18:51:49 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.26 18:51:49 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.26 18:51:49 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.26 18:51:49 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.26 18:51:49 - Connection to OpenVPN Management Interface
. 2019.03.26 18:51:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.26 18:51:49 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 18:51:49 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 18:51:49 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 18:51:49 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 18:51:49 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 18:51:49 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 18:51:49 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 18:51:49 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 18:51:49 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 18:51:49 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=ca937bda e9a16345
. 2019.03.26 18:51:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 18:51:50 - OpenVPN > VERIFY KU OK
. 2019.03.26 18:51:50 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 18:51:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 18:51:50 - OpenVPN > VERIFY EKU OK
. 2019.03.26 18:51:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 18:51:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 18:51:50 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 18:51:51 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 18:51:51 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 18:51:51 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 18:51:51 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 18:51:51 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 18:51:51 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 18:51:51 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 18:51:51 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 18:51:51 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 18:51:51 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 18:51:51 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 18:51:51 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 18:51:51 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 18:51:51 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 18:51:51 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 18:51:51 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 18:51:51 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 18:51:51 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 18:51:51 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 18:51:51 - OpenVPN > Opened utun device utun1
. 2019.03.26 18:51:51 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 18:51:51 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 18:51:51 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 18:51:51 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 18:51:51 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 18:51:51 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 18:51:51 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 18:51:51 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 18:51:51 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 18:51:51 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:51:51 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:51:51 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:51:51 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:51:52 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 18:51:53 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:51:54 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:51:56 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:51:57 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:51:57 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 18:51:57 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 18:51:57 - Flushing DNS
! 2019.03.26 18:51:58 - Connected.
. 2019.03.26 18:51:58 - OpenVPN > Initialization Sequence Completed
Edited ... by giganerd
LOG formatting
On 3/26/2019 at 9:25 AM, neilson.cameron said:
Ready to throw Eddie and change providers after 3 years of pretty much faultless use.
Only threads that have some similar issues have no answers.
I have unchecked what advised tried multiple combinations of TCPs,UDPs Ports & IPs but problem persists in similar circumstances - nothing had changed when this started last week out of the blue.
I have blocked IPv6 (my provider doesn't support) just in case and turned on & off just about every checkbox.
Rebooted Router etc etc etc
Currently logs off due to 'inactivity timeout' regardless of wether inactive or not.
Get notification of disconnect, and reconnects (previously before unchecking tunnel & AirVPN dns would require connecting to new server before working) and previous server would not work until Mac rebooted, but Safari doesn't work even after disconnecting Eddie and turning off Network Lock (torrents work though) and I must reconnect to Eddie to get internet to work.
Repeat Ad Nauseum.
Logs before 17:30 are unattended in sleep mode.
I hope someone can please help, if no one can make sense of the logs I will try a service ticket - otherwise will have to look elsewhere for VPN.
. 2019.03.25 09:56:27 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 09:56:27 - Flushing DNS
I 2019.03.25 09:56:28 - Checking route IPv4
. 2019.03.25 09:56:48 - curl: (28) Connection timed out after 20009 milliseconds
. 2019.03.25 09:56:48 - Checking route (2° try)
. 2019.03.25 09:57:09 - curl: (28) Connection timed out after 20001 milliseconds
. 2019.03.25 09:57:09 - Checking route (3° try)
. 2019.03.25 09:57:36 - curl: (28) Connection timed out after 20005 milliseconds
E 2019.03.25 09:57:36 - Checking route IPv4 failed.
. 2019.03.25 09:57:36 - OpenVPN > Initialization Sequence Completed
! 2019.03.25 09:57:36 - Disconnecting
. 2019.03.25 09:57:36 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 09:57:36 - Sending management termination signal
. 2019.03.25 09:57:36 - Management - Send 'signal SIGTERM'
. 2019.03.25 09:57:36 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 09:57:36 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.25 09:57:41 - OpenVPN > /sbin/route delete -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 09:57:41 - OpenVPN > delete net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 09:57:41 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 09:57:41 - OpenVPN > delete net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 09:57:41 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 09:57:41 - OpenVPN > delete net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 09:57:41 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 09:57:41 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.25 09:57:41 - Connection terminated.
. 2019.03.25 09:57:41 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 09:57:41 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 09:57:41 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 09:57:41 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 09:57:42 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 09:57:42 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 09:57:42 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 09:57:42 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 09:57:42 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 09:57:42 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 09:57:45 - Checking authorization ...
. 2019.03.25 09:57:46 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 09:57:47 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 09:57:47 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 09:57:47 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 09:57:47 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 09:57:47 - Connecting to Sabik (United States, Los Angeles)
. 2019.03.25 09:57:47 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 09:57:47 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 09:57:47 - Connection to OpenVPN Management Interface
. 2019.03.25 09:57:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 09:57:47 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 09:57:47 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 09:57:47 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 09:57:47 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 09:57:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 09:57:47 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 09:57:47 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 09:57:47 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 09:57:47 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 09:57:47 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=2ecede14 0e86ab32
. 2019.03.25 09:57:47 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 09:57:47 - OpenVPN > VERIFY KU OK
. 2019.03.25 09:57:47 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 09:57:47 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 09:57:47 - OpenVPN > VERIFY EKU OK
. 2019.03.25 09:57:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 09:57:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 09:57:48 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 09:57:49 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 09:57:49 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.25 09:57:49 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 09:57:49 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 09:57:49 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 09:57:49 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 09:57:49 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 09:57:49 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 09:57:49 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 09:57:49 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 09:57:49 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 09:57:49 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 09:57:49 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 09:57:49 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 09:57:49 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 09:57:49 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 09:57:49 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 09:57:49 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 09:57:49 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 09:57:49 - Above log line repeated 1 times more
. 2019.03.25 09:57:49 - OpenVPN > Opened utun device utun2
. 2019.03.25 09:57:49 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 09:57:49 - OpenVPN > /sbin/ifconfig utun2 delete
. 2019.03.25 09:57:49 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 09:57:49 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 09:57:49 - OpenVPN > /sbin/ifconfig utun2 10.28.158.45 10.28.158.45 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 09:57:49 - OpenVPN > /sbin/route add -net 10.28.158.0 10.28.158.45 255.255.255.0
. 2019.03.25 09:57:49 - OpenVPN > add net 10.28.158.0: gateway 10.28.158.45
. 2019.03.25 09:57:49 - OpenVPN > /sbin/route add -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 09:57:49 - OpenVPN > add net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 09:57:49 - OpenVPN > /sbin/route add -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 09:57:49 - OpenVPN > add net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 09:57:49 - OpenVPN > /sbin/route add -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 09:57:49 - OpenVPN > add net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 09:57:50 - DNS of a network adapter forced (Ethernet, from Automatic to 10.28.158.1)
. 2019.03.25 09:57:50 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 09:57:50 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 09:57:50 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 09:57:50 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 09:57:51 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 09:57:51 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 09:57:51 - Flushing DNS
I 2019.03.25 09:57:51 - Checking route IPv4
. 2019.03.25 09:58:11 - curl: (28) Connection timed out after 20003 milliseconds
. 2019.03.25 09:58:11 - Checking route (2° try)
. 2019.03.25 10:30:00 - curl: (28) Connection timed out after 1907063 milliseconds
. 2019.03.25 10:30:00 - Checking route (3° try)
. 2019.03.25 10:30:22 - curl: (28) Connection timed out after 20003 milliseconds
E 2019.03.25 10:30:22 - Checking route IPv4 failed.
. 2019.03.25 10:30:22 - OpenVPN > Initialization Sequence Completed
! 2019.03.25 10:30:22 - Disconnecting
. 2019.03.25 10:30:22 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 10:30:22 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2019.03.25 10:30:22 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.25 10:30:22 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.25 10:30:22 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 10:30:22 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 10:30:22 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 10:30:22 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 10:30:22 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=3ec87a05 7825c1a1
. 2019.03.25 10:30:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 10:30:22 - OpenVPN > VERIFY KU OK
. 2019.03.25 10:30:22 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 10:30:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 10:30:22 - OpenVPN > VERIFY EKU OK
. 2019.03.25 10:30:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 10:30:22 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 10:30:22 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 10:30:22 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 10:30:22 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2019.03.25 10:30:22 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 10:30:22 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 10:30:22 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 10:30:22 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 10:30:22 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 10:30:22 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 10:30:22 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 10:30:22 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 10:30:22 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 10:30:22 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 10:30:22 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 10:30:22 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 10:30:22 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 10:30:22 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 10:30:22 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 10:30:22 - OpenVPN > Preserving previous TUN/TAP instance: utun2
. 2019.03.25 10:30:22 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 10:30:22 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 10:30:22 - Flushing DNS
. 2019.03.25 10:30:23 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 10:30:23 - Sending management termination signal
. 2019.03.25 10:30:23 - Management - Send 'signal SIGTERM'
. 2019.03.25 10:30:23 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 10:30:23 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.25 10:30:23 - Updating systems & servers data ...
. 2019.03.25 10:30:28 - OpenVPN > /sbin/route delete -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 10:30:28 - OpenVPN > delete net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 10:30:28 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 10:30:28 - OpenVPN > delete net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 10:30:28 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 10:30:28 - OpenVPN > delete net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 10:30:28 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 10:30:28 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.25 10:30:28 - Connection terminated.
. 2019.03.25 10:30:28 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 10:30:28 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 10:30:28 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 10:30:28 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 10:30:28 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 10:30:28 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 10:30:29 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 10:30:30 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 10:30:30 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 10:30:30 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 10:30:38 - Checking authorization ...
. 2019.03.25 10:30:39 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 10:30:39 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 10:30:40 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 10:30:40 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 10:30:40 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 10:30:40 - Connecting to Sabik (United States, Los Angeles)
. 2019.03.25 10:30:40 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 10:30:40 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 10:30:40 - Connection to OpenVPN Management Interface
. 2019.03.25 10:30:40 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 10:30:40 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 10:30:40 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 10:30:40 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 10:30:40 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 10:30:40 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 10:30:40 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 10:30:40 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 10:30:40 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 10:30:40 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 10:30:58 - macOS - PF rules updated, reloading
. 2019.03.25 10:30:59 - Systems & servers data update completed
. 2019.03.25 10:31:10 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=2f68ca10 9db8d6ec
. 2019.03.25 10:31:10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 10:31:10 - OpenVPN > VERIFY KU OK
. 2019.03.25 10:31:10 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 10:31:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 10:31:10 - OpenVPN > VERIFY EKU OK
. 2019.03.25 10:31:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 10:31:31 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 10:31:31 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 10:31:31 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 10:31:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2019.03.25 10:31:31 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 10:31:31 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 10:31:31 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 10:31:31 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 10:31:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 10:31:31 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 10:31:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 10:31:31 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 10:31:31 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 10:31:31 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 10:31:31 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 10:31:31 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 10:31:31 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 10:31:31 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 10:31:31 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 10:31:31 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 10:31:31 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 10:31:31 - Above log line repeated 1 times more
. 2019.03.25 10:31:31 - OpenVPN > Opened utun device utun2
. 2019.03.25 10:31:31 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 10:31:31 - OpenVPN > /sbin/ifconfig utun2 delete
. 2019.03.25 10:31:31 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 10:31:31 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 10:31:31 - OpenVPN > /sbin/ifconfig utun2 10.28.158.45 10.28.158.45 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 10:31:31 - OpenVPN > /sbin/route add -net 10.28.158.0 10.28.158.45 255.255.255.0
. 2019.03.25 10:31:31 - OpenVPN > add net 10.28.158.0: gateway 10.28.158.45
. 2019.03.25 10:31:31 - OpenVPN > /sbin/route add -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 10:31:31 - OpenVPN > add net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 10:31:31 - OpenVPN > /sbin/route add -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 10:31:31 - OpenVPN > add net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 10:31:31 - OpenVPN > /sbin/route add -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 10:31:31 - OpenVPN > add net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 10:32:14 - DNS of a network adapter forced (Ethernet, from Automatic to 10.28.158.1)
. 2019.03.25 10:32:54 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 10:33:28 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 10:34:08 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 10:34:36 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 10:34:56 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 10:34:56 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 10:34:56 - Flushing DNS
. 2019.03.25 10:34:56 - macOS - PF rules updated, reloading
I 2019.03.25 10:34:57 - Checking route IPv4
I 2019.03.25 10:34:59 - Checking DNS
! 2019.03.25 10:35:00 - Connected.
. 2019.03.25 10:35:01 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 10:54:21 - Updating systems & servers data ...
. 2019.03.25 10:55:16 - Systems & servers data update completed
. 2019.03.25 12:08:36 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2019.03.25 12:08:36 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.25 12:08:36 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.25 14:09:29 - macOS - PF rules updated, reloading
! 2019.03.25 14:09:30 - Disconnecting
. 2019.03.25 14:09:30 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 14:09:30 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 14:09:30 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 14:09:30 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 14:09:30 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 14:09:30 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=a49560ce 4d6d761f
. 2019.03.25 14:09:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 14:09:30 - OpenVPN > VERIFY KU OK
. 2019.03.25 14:09:30 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 14:09:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 14:09:30 - OpenVPN > VERIFY EKU OK
. 2019.03.25 14:09:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 14:09:30 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 14:09:30 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 14:09:30 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 14:09:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.25 14:09:30 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 14:09:30 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 14:09:30 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 14:09:30 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 14:09:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 14:09:30 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 14:09:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 14:09:30 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 14:09:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 14:09:30 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 14:09:30 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 14:09:30 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 14:09:30 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 14:09:30 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 14:09:30 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 14:09:30 - OpenVPN > Preserving previous TUN/TAP instance: utun2
. 2019.03.25 14:09:31 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 14:09:31 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 14:09:31 - Flushing DNS
. 2019.03.25 14:09:32 - macOS - PF rules updated, reloading
. 2019.03.25 14:09:32 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 14:09:32 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2019.03.25 14:09:32 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.25 14:09:32 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.25 14:09:32 - Sending management termination signal
. 2019.03.25 14:09:32 - Management - Send 'signal SIGTERM'
. 2019.03.25 14:09:32 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 14:09:32 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 14:09:32 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 14:09:32 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 14:09:32 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=7c2fb8bd 4af443d5
. 2019.03.25 14:09:32 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 14:09:32 - OpenVPN > VERIFY KU OK
. 2019.03.25 14:09:32 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 14:09:32 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 14:09:32 - OpenVPN > VERIFY EKU OK
. 2019.03.25 14:09:32 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 14:09:32 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 14:09:32 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 14:09:32 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 14:09:32 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.25 14:09:33 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 14:09:33 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2019.03.25 14:09:33 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 14:09:33 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 14:09:33 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 14:09:33 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 14:09:33 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 14:09:33 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 14:09:33 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 14:09:33 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 14:09:33 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 14:09:33 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 14:09:33 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 14:09:33 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 14:09:33 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 14:09:33 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 14:09:33 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 14:09:33 - OpenVPN > Preserving previous TUN/TAP instance: utun2
W 2019.03.25 14:09:33 - Routes, add 199.241.147.35 for gateway 10.28.158.1 failed: route: writing to routing socket: File exists
. 2019.03.25 14:09:33 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 14:09:33 - Flushing DNS
. 2019.03.25 14:09:34 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 14:09:37 - OpenVPN > /sbin/route delete -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 14:09:37 - OpenVPN > delete net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 14:09:37 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 14:09:37 - OpenVPN > delete net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 14:09:37 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 14:09:37 - OpenVPN > delete net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 14:09:37 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 14:09:37 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.25 14:09:37 - Connection terminated.
. 2019.03.25 14:09:37 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 14:09:37 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 14:09:37 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 14:09:37 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 14:09:37 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 14:09:37 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 14:09:38 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 14:09:39 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 14:09:39 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 14:09:39 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 14:09:42 - Checking authorization ...
. 2019.03.25 14:09:43 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 14:09:43 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 14:09:43 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 14:09:43 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 14:09:43 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 14:09:43 - Connecting to Sabik (United States, Los Angeles)
. 2019.03.25 14:09:44 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 14:09:44 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 14:09:44 - Connection to OpenVPN Management Interface
. 2019.03.25 14:09:44 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 14:09:44 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 14:09:44 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 14:09:44 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 14:09:44 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 14:09:44 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 14:09:44 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 14:09:44 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 14:09:44 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 14:09:44 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 14:10:04 - Updating systems & servers data ...
. 2019.03.25 14:10:13 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=c1cc854e 65386009
. 2019.03.25 14:10:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 14:10:34 - OpenVPN > VERIFY KU OK
. 2019.03.25 14:10:34 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 14:10:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 14:10:34 - OpenVPN > VERIFY EKU OK
. 2019.03.25 14:10:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 14:10:34 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 14:10:34 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 14:10:34 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 14:10:34 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2019.03.25 14:10:34 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 14:10:34 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 14:10:34 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 14:10:34 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 14:10:34 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 14:10:34 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 14:10:34 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 14:10:34 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 14:10:34 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 14:10:34 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 14:10:34 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 14:10:34 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 14:10:34 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 14:10:34 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 14:10:34 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 14:10:34 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 14:10:34 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 14:10:34 - Above log line repeated 1 times more
. 2019.03.25 14:10:34 - OpenVPN > Opened utun device utun2
. 2019.03.25 14:10:34 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 14:10:34 - OpenVPN > /sbin/ifconfig utun2 delete
. 2019.03.25 14:10:34 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 14:10:34 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 14:10:34 - OpenVPN > /sbin/ifconfig utun2 10.28.158.45 10.28.158.45 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 14:10:34 - OpenVPN > /sbin/route add -net 10.28.158.0 10.28.158.45 255.255.255.0
. 2019.03.25 14:10:34 - OpenVPN > add net 10.28.158.0: gateway 10.28.158.45
. 2019.03.25 14:10:34 - OpenVPN > /sbin/route add -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 14:10:34 - OpenVPN > add net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 14:10:34 - OpenVPN > /sbin/route add -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 14:10:34 - OpenVPN > add net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 14:10:34 - OpenVPN > /sbin/route add -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 14:10:34 - OpenVPN > add net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 14:11:16 - DNS of a network adapter forced (Ethernet, from Automatic to 10.28.158.1)
. 2019.03.25 14:11:16 - macOS - PF rules updated, reloading
. 2019.03.25 14:11:17 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 14:11:17 - Systems & servers data update completed
. 2019.03.25 14:11:57 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 14:12:19 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 14:12:19 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 14:12:19 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 14:12:19 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 14:12:19 - Flushing DNS
. 2019.03.25 14:12:20 - macOS - PF rules updated, reloading
I 2019.03.25 14:12:21 - Checking route IPv4
I 2019.03.25 14:12:23 - Checking DNS
! 2019.03.25 14:12:24 - Connected.
. 2019.03.25 14:12:24 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 15:40:49 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2019.03.25 15:40:49 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.25 15:40:49 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.25 15:40:52 - macOS - PF rules updated, reloading
! 2019.03.25 15:40:53 - Disconnecting
. 2019.03.25 15:40:53 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 15:40:53 - Sending management termination signal
. 2019.03.25 15:40:53 - Management - Send 'signal SIGTERM'
. 2019.03.25 15:40:53 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 15:40:53 - OpenVPN > /sbin/route delete -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 15:40:53 - OpenVPN > delete net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 15:40:53 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 15:40:53 - OpenVPN > delete net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 15:40:53 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 15:40:53 - OpenVPN > delete net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 15:40:53 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 15:40:53 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2019.03.25 15:40:53 - Connection terminated.
. 2019.03.25 15:40:54 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 15:40:54 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 15:40:54 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 15:40:54 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 15:40:54 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 15:40:54 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 15:40:55 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 15:40:56 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 15:40:56 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 15:40:56 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 15:40:59 - Checking authorization ...
. 2019.03.25 15:41:00 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 15:41:00 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 15:41:00 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 15:41:00 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 15:41:01 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 15:41:01 - Connecting to Sabik (United States, Los Angeles)
. 2019.03.25 15:41:01 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 15:41:01 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 15:41:01 - Connection to OpenVPN Management Interface
. 2019.03.25 15:41:01 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 15:41:01 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 15:41:01 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 15:41:01 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 15:41:01 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 15:41:01 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 15:41:01 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 15:41:01 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 15:41:01 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 15:41:01 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 15:41:31 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=edecbbde 9bf73d3d
. 2019.03.25 15:41:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 15:41:31 - OpenVPN > VERIFY KU OK
. 2019.03.25 15:41:31 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 15:41:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 15:41:31 - OpenVPN > VERIFY EKU OK
. 2019.03.25 15:41:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 15:41:32 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 15:41:32 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 15:41:52 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 15:41:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.25 15:41:52 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 15:41:52 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 15:41:52 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 15:41:52 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 15:41:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 15:41:52 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 15:41:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 15:41:52 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 15:41:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 15:41:52 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 15:41:52 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 15:41:52 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 15:41:52 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 15:41:52 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 15:41:52 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 15:41:52 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 15:41:52 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 15:41:52 - Above log line repeated 1 times more
. 2019.03.25 15:41:52 - OpenVPN > Opened utun device utun2
. 2019.03.25 15:41:52 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 15:41:52 - OpenVPN > /sbin/ifconfig utun2 delete
. 2019.03.25 15:41:52 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 15:41:52 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 15:41:52 - OpenVPN > /sbin/ifconfig utun2 10.28.158.45 10.28.158.45 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 15:41:52 - OpenVPN > /sbin/route add -net 10.28.158.0 10.28.158.45 255.255.255.0
. 2019.03.25 15:41:52 - OpenVPN > add net 10.28.158.0: gateway 10.28.158.45
. 2019.03.25 15:41:52 - OpenVPN > /sbin/route add -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 15:41:52 - OpenVPN > add net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 15:41:52 - OpenVPN > /sbin/route add -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 15:41:52 - OpenVPN > add net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 15:41:52 - OpenVPN > /sbin/route add -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 15:41:52 - OpenVPN > add net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 15:41:55 - DNS of a network adapter forced (Ethernet, from Automatic to 10.28.158.1)
. 2019.03.25 15:41:55 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 15:41:55 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 15:41:55 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 15:41:55 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 15:41:56 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 15:41:56 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 15:41:56 - Flushing DNS
. 2019.03.25 15:41:56 - macOS - PF rules updated, reloading
I 2019.03.25 15:41:57 - Checking route IPv4
I 2019.03.25 15:41:59 - Checking DNS
! 2019.03.25 15:42:01 - Connected.
. 2019.03.25 15:42:01 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 15:49:47 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2019.03.25 15:49:47 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.25 15:49:47 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.25 15:49:49 - Updating systems & servers data ...
. 2019.03.25 15:49:50 - macOS - PF rules updated, reloading
! 2019.03.25 15:49:51 - Disconnecting
. 2019.03.25 15:49:51 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 15:49:51 - Sending management termination signal
. 2019.03.25 15:49:51 - Management - Send 'signal SIGTERM'
. 2019.03.25 15:49:51 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 15:49:51 - OpenVPN > /sbin/route delete -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 15:49:51 - OpenVPN > delete net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 15:49:51 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 15:49:51 - OpenVPN > delete net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 15:49:51 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 15:49:51 - OpenVPN > delete net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 15:49:51 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 15:49:51 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2019.03.25 15:49:51 - Connection terminated.
. 2019.03.25 15:49:51 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 15:49:52 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 15:49:52 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 15:49:52 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 15:49:52 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 15:49:52 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 15:49:52 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 15:49:53 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 15:49:53 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 15:49:53 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 15:49:56 - Checking authorization ...
. 2019.03.25 15:49:57 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 15:49:57 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 15:49:58 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 15:49:58 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 15:49:58 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 15:49:58 - Connecting to Sabik (United States, Los Angeles)
. 2019.03.25 15:49:58 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 15:49:58 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 15:49:58 - Connection to OpenVPN Management Interface
. 2019.03.25 15:49:58 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 15:49:58 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 15:49:58 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 15:49:58 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 15:49:58 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 15:49:58 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 15:49:58 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 15:49:58 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 15:49:58 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 15:49:58 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 15:50:24 - macOS - PF rules updated, reloading
. 2019.03.25 15:50:25 - Systems & servers data update completed
. 2019.03.25 15:50:28 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=1da7ae1f 542042af
. 2019.03.25 15:50:28 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 15:50:28 - OpenVPN > VERIFY KU OK
. 2019.03.25 15:50:28 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 15:50:28 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 15:50:28 - OpenVPN > VERIFY EKU OK
. 2019.03.25 15:50:28 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 15:50:29 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 15:50:29 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 15:50:30 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 15:50:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.25 15:50:30 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 15:50:30 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 15:50:30 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 15:50:30 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 15:50:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 15:50:30 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 15:50:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 15:50:30 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 15:50:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 15:50:30 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 15:50:30 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 15:50:30 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 15:50:30 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 15:50:30 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 15:50:30 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 15:50:30 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 15:50:30 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 15:50:30 - Above log line repeated 1 times more
. 2019.03.25 15:50:30 - OpenVPN > Opened utun device utun2
. 2019.03.25 15:50:30 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 15:50:30 - OpenVPN > /sbin/ifconfig utun2 delete
. 2019.03.25 15:50:30 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 15:50:30 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 15:50:30 - OpenVPN > /sbin/ifconfig utun2 10.28.158.45 10.28.158.45 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 15:50:30 - OpenVPN > /sbin/route add -net 10.28.158.0 10.28.158.45 255.255.255.0
. 2019.03.25 15:50:30 - OpenVPN > add net 10.28.158.0: gateway 10.28.158.45
. 2019.03.25 15:50:30 - OpenVPN > /sbin/route add -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 15:50:30 - OpenVPN > add net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 15:50:30 - OpenVPN > /sbin/route add -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 15:50:30 - OpenVPN > add net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 15:50:30 - OpenVPN > /sbin/route add -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 15:50:30 - OpenVPN > add net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 15:50:57 - DNS of a network adapter forced (Ethernet, from Automatic to 10.28.158.1)
. 2019.03.25 15:50:57 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 15:50:57 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 15:50:57 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 15:50:57 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 15:50:57 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 15:50:57 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 15:50:57 - Flushing DNS
. 2019.03.25 15:50:58 - macOS - PF rules updated, reloading
I 2019.03.25 15:50:59 - Checking route IPv4
I 2019.03.25 15:51:01 - Checking DNS
! 2019.03.25 15:51:02 - Connected.
. 2019.03.25 15:51:02 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 17:30:23 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2019.03.25 17:30:23 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.25 17:30:23 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.25 17:30:27 - macOS - PF rules updated, reloading
! 2019.03.25 17:30:28 - Disconnecting
. 2019.03.25 17:30:29 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 17:30:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 17:30:29 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 17:30:29 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 17:30:29 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 17:30:29 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=831d3c4d 4d1ebacf
. 2019.03.25 17:30:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 17:30:29 - OpenVPN > VERIFY KU OK
. 2019.03.25 17:30:29 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 17:30:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 17:30:29 - OpenVPN > VERIFY EKU OK
. 2019.03.25 17:30:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 17:30:29 - Sending management termination signal
. 2019.03.25 17:30:29 - Management - Send 'signal SIGTERM'
. 2019.03.25 17:30:29 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 17:30:29 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.25 17:30:29 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 17:30:29 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 17:30:30 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 17:30:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2019.03.25 17:30:30 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 17:30:30 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 17:30:30 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 17:30:30 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 17:30:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 17:30:30 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 17:30:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 17:30:30 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 17:30:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 17:30:30 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 17:30:30 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 17:30:30 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 17:30:30 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 17:30:30 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:30:30 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:30:30 - OpenVPN > Preserving previous TUN/TAP instance: utun2
. 2019.03.25 17:30:30 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 17:30:30 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 17:30:30 - Flushing DNS
. 2019.03.25 17:30:31 - macOS - PF rules updated, reloading
. 2019.03.25 17:30:32 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 17:30:34 - OpenVPN > /sbin/route delete -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 17:30:34 - OpenVPN > delete net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 17:30:34 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:30:34 - OpenVPN > delete net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:30:34 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:30:34 - OpenVPN > delete net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:30:34 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 17:30:34 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.25 17:30:34 - Connection terminated.
. 2019.03.25 17:30:34 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 17:30:34 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 17:30:34 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 17:30:34 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 17:30:34 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 17:30:34 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 17:30:35 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:30:36 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:30:36 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:30:36 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 17:30:39 - Checking authorization ...
. 2019.03.25 17:30:40 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 17:30:40 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 17:30:40 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 17:30:40 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 17:30:40 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 17:30:40 - Connecting to Sabik (United States, Los Angeles)
. 2019.03.25 17:30:41 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 17:30:41 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 17:30:41 - Connection to OpenVPN Management Interface
. 2019.03.25 17:30:41 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 17:30:41 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 17:30:41 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 17:30:41 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 17:30:41 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 17:30:41 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 17:30:41 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 17:30:41 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 17:30:41 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 17:30:41 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 17:31:10 - OpenVPN > TLS Error: Unroutable control packet received from [AF_INET]199.241.147.37:53 (si=3 op=P_ACK_V1)
. 2019.03.25 17:31:12 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=5fed8b80 cdb8b468
. 2019.03.25 17:31:12 - Updating systems & servers data ...
. 2019.03.25 17:31:12 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 17:31:12 - OpenVPN > VERIFY KU OK
. 2019.03.25 17:31:12 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 17:31:12 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 17:31:12 - OpenVPN > VERIFY EKU OK
. 2019.03.25 17:31:12 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.03.25 17:31:13 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 17:31:13 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 17:31:14 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 17:31:14 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2019.03.25 17:31:14 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 17:31:14 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 17:31:14 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 17:31:14 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 17:31:14 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 17:31:14 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 17:31:14 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 17:31:14 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 17:31:14 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 17:31:14 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 17:31:14 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 17:31:14 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 17:31:14 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 17:31:14 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:31:14 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:31:14 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 17:31:14 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 17:31:14 - Above log line repeated 1 times more
. 2019.03.25 17:31:14 - OpenVPN > Opened utun device utun2
. 2019.03.25 17:31:14 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 17:31:14 - OpenVPN > /sbin/ifconfig utun2 delete
. 2019.03.25 17:31:14 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 17:31:14 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 17:31:14 - OpenVPN > /sbin/ifconfig utun2 10.28.158.45 10.28.158.45 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 17:31:14 - OpenVPN > /sbin/route add -net 10.28.158.0 10.28.158.45 255.255.255.0
. 2019.03.25 17:31:14 - OpenVPN > add net 10.28.158.0: gateway 10.28.158.45
. 2019.03.25 17:31:14 - OpenVPN > /sbin/route add -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 17:31:14 - OpenVPN > add net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 17:31:14 - OpenVPN > /sbin/route add -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:31:14 - OpenVPN > add net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:31:14 - OpenVPN > /sbin/route add -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:31:14 - OpenVPN > add net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:31:14 - DNS of a network adapter forced (Ethernet, from Automatic to 10.28.158.1)
. 2019.03.25 17:31:15 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 17:31:15 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 17:31:15 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 17:31:15 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 17:31:15 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 17:31:15 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 17:31:15 - Flushing DNS
I 2019.03.25 17:31:16 - Checking route IPv4
. 2019.03.25 17:31:27 - Systems & servers data update completed
. 2019.03.25 17:31:36 - curl: (28) Connection timed out after 20005 milliseconds
. 2019.03.25 17:31:36 - Checking route (2° try)
. 2019.03.25 17:31:57 - curl: (28) Connection timed out after 20003 milliseconds
. 2019.03.25 17:31:57 - Checking route (3° try)
. 2019.03.25 17:32:19 - curl: (28) Connection timed out after 20005 milliseconds
E 2019.03.25 17:32:19 - Checking route IPv4 failed.
. 2019.03.25 17:32:20 - OpenVPN > Initialization Sequence Completed
! 2019.03.25 17:32:20 - Disconnecting
. 2019.03.25 17:32:20 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 17:32:20 - Sending management termination signal
. 2019.03.25 17:32:20 - Management - Send 'signal SIGTERM'
. 2019.03.25 17:32:20 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 17:32:20 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.25 17:32:25 - OpenVPN > /sbin/route delete -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 17:32:25 - OpenVPN > delete net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 17:32:25 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:32:25 - OpenVPN > delete net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:32:25 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:32:25 - OpenVPN > delete net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:32:25 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 17:32:25 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.25 17:32:25 - Connection terminated.
. 2019.03.25 17:32:25 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 17:32:25 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 17:32:25 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 17:32:25 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 17:32:25 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 17:32:25 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 17:32:25 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:32:26 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:32:26 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:32:26 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 17:32:29 - Checking authorization ...
. 2019.03.25 17:32:30 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 17:32:31 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 17:32:31 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 17:32:31 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 17:32:31 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 17:32:31 - Connecting to Sabik (United States, Los Angeles)
. 2019.03.25 17:32:31 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 17:32:31 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 17:32:31 - Connection to OpenVPN Management Interface
. 2019.03.25 17:32:31 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 17:32:31 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 17:32:31 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 17:32:31 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 17:32:31 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 17:32:31 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.37:53
. 2019.03.25 17:32:31 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 17:32:31 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 17:32:31 - OpenVPN > UDP link remote: [AF_INET]199.241.147.37:53
. 2019.03.25 17:32:31 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 17:33:01 - OpenVPN > TLS Error: Unroutable control packet received from [AF_INET]199.241.147.37:53 (si=3 op=P_ACK_V1)
. 2019.03.25 17:33:01 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.37:53, sid=f6666299 9ed9f903
. 2019.03.25 17:33:02 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 17:33:02 - OpenVPN > VERIFY KU OK
. 2019.03.25 17:33:02 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 17:33:02 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 17:33:02 - OpenVPN > VERIFY EKU OK
. 2019.03.25 17:33:02 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
! 2019.03.25 17:33:02 - Disconnecting
. 2019.03.25 17:33:02 - Sending management termination signal
. 2019.03.25 17:33:02 - Management - Send 'signal SIGTERM'
. 2019.03.25 17:33:02 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 17:33:02 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.25 17:33:02 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 17:33:02 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.37:53
. 2019.03.25 17:33:04 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 17:33:04 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.158.1,dhcp-option DNS6 fde6:7a:7d20:189e::1,tun-ipv6,route-gateway 10.28.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1,ifconfig 10.28.158.45 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2019.03.25 17:33:04 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 17:33:04 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:189e::1'
. 2019.03.25 17:33:04 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 17:33:04 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:189e::102b/64 fde6:7a:7d20:189e::1'
. 2019.03.25 17:33:04 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 17:33:04 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 17:33:04 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 17:33:04 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 17:33:04 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 17:33:04 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 17:33:04 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 17:33:04 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 17:33:04 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 17:33:04 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:33:04 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:33:04 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 17:33:04 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 17:33:04 - Above log line repeated 1 times more
. 2019.03.25 17:33:04 - OpenVPN > Opened utun device utun2
. 2019.03.25 17:33:04 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 17:33:04 - OpenVPN > /sbin/ifconfig utun2 delete
. 2019.03.25 17:33:04 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 17:33:04 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 17:33:04 - OpenVPN > /sbin/ifconfig utun2 10.28.158.45 10.28.158.45 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 17:33:04 - OpenVPN > /sbin/route add -net 10.28.158.0 10.28.158.45 255.255.255.0
. 2019.03.25 17:33:04 - OpenVPN > add net 10.28.158.0: gateway 10.28.158.45
. 2019.03.25 17:33:04 - OpenVPN > /sbin/route add -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 17:33:04 - OpenVPN > add net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 17:33:04 - OpenVPN > /sbin/route add -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:33:04 - OpenVPN > add net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:33:04 - OpenVPN > /sbin/route add -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:33:04 - OpenVPN > add net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:33:04 - DNS of a network adapter forced (Ethernet, from Automatic to 10.28.158.1)
. 2019.03.25 17:33:04 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 17:33:04 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 17:33:05 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 17:33:05 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.28.158.1)
. 2019.03.25 17:33:05 - Routes, added a new route, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 17:33:05 - Unable to compute route for 2605:8680:12:5:9a76:3402:3e24:834c: IPv6 VPN gateway not available.
. 2019.03.25 17:33:05 - Flushing DNS
. 2019.03.25 17:33:06 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 17:33:07 - OpenVPN > /sbin/route delete -net 199.241.147.37 192.168.1.1 255.255.255.255
. 2019.03.25 17:33:07 - OpenVPN > delete net 199.241.147.37: gateway 192.168.1.1
. 2019.03.25 17:33:07 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:33:07 - OpenVPN > delete net 0.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:33:07 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.28.158.1 128.0.0.0
. 2019.03.25 17:33:07 - OpenVPN > delete net 128.0.0.0: gateway 10.28.158.1
. 2019.03.25 17:33:07 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 17:33:07 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.25 17:33:07 - Connection terminated.
. 2019.03.25 17:33:07 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 17:33:07 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 17:33:07 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 17:33:07 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 17:33:07 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 17:33:07 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 17:33:08 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:33:08 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:33:08 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:33:08 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 17:33:08 - Flushing DNS
! 2019.03.25 17:33:08 - Session terminated.
I 2019.03.25 17:33:23 - Session starting.
I 2019.03.25 17:33:23 - Checking authorization ...
. 2019.03.25 17:33:24 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 17:33:24 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 17:33:24 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 17:33:25 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 17:33:25 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 17:33:25 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.25 17:33:25 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 17:33:25 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 17:33:25 - Connection to OpenVPN Management Interface
. 2019.03.25 17:33:25 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 17:33:25 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 17:33:25 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 17:33:25 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 17:33:25 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 17:33:25 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:53
. 2019.03.25 17:33:25 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 17:33:25 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 17:33:25 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:53
. 2019.03.25 17:33:25 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 17:33:55 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:53, sid=51bb0b1e 4e5a3c31
. 2019.03.25 17:33:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 17:33:55 - OpenVPN > VERIFY KU OK
. 2019.03.25 17:33:55 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 17:33:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 17:33:55 - OpenVPN > VERIFY EKU OK
. 2019.03.25 17:33:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.25 17:33:56 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 17:33:56 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:53
. 2019.03.25 17:33:57 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 17:33:57 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2019.03.25 17:33:57 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 17:33:57 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.25 17:33:57 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 17:33:57 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.25 17:33:57 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 17:33:57 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 17:33:57 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 17:33:57 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 17:33:57 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 17:33:57 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 17:33:57 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 17:33:57 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 17:33:57 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 17:33:57 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:33:57 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:33:57 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 17:33:57 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 17:33:57 - Above log line repeated 1 times more
. 2019.03.25 17:33:57 - OpenVPN > Opened utun device utun2
. 2019.03.25 17:33:57 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 17:33:57 - OpenVPN > /sbin/ifconfig utun2 delete
. 2019.03.25 17:33:57 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 17:33:57 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 17:33:57 - OpenVPN > /sbin/ifconfig utun2 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 17:33:57 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.25 17:33:57 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.25 17:33:57 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.25 17:33:57 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.25 17:33:57 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 17:33:57 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.25 17:33:57 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 17:33:57 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.25 17:33:57 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.25 17:33:58 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 17:33:58 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 17:33:58 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 17:33:58 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 17:33:58 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 17:33:58 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.25 17:33:58 - Flushing DNS
. 2019.03.25 17:33:59 - macOS - PF rules updated, reloading
I 2019.03.25 17:34:00 - Checking route IPv4
I 2019.03.25 17:34:02 - Checking DNS
! 2019.03.25 17:34:04 - Connected.
. 2019.03.25 17:34:04 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 17:47:54 - Eddie version: 2.16.3 / macos_x64, System: MacOS, Name: 10.14.3, Version: Darwin Neils-Mac-mini.local 18.2.0 Darwin Kernel Version 18.2.0: Thu Dec 20 20:46:53 PST 2018; root:xnu-4903.241.1~1/RELEASE_X86_64 x86_64, Mono/.Net: v4.0.30319
. 2019.03.25 17:47:54 - Reading options from /Users/neilmclellan/.airvpn/default.xml
. 2019.03.25 17:47:56 - Command line arguments (1): gui.osx.style="dark"
. 2019.03.25 17:47:56 - Profile path: /Users/neilmclellan/.airvpn/default.xml
. 2019.03.25 17:48:00 - OpenVPN Driver - Expected
. 2019.03.25 17:48:00 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
. 2019.03.25 17:48:00 - SSH - Version: OpenSSH_7.9p1, LibreSSL 2.7.3 (/usr/bin/ssh)
. 2019.03.25 17:48:00 - SSL - Version: stunnel 5.48 (/Applications/Eddie.app/Contents/MacOS/stunnel)
. 2019.03.25 17:48:00 - curl - Version: 7.54.0 (/usr/bin/curl)
. 2019.03.25 17:48:00 - Certification Authorities: /Applications/Eddie.app/Contents/MacOS/../Resources/cacert.pem
W 2019.03.25 17:48:00 - Recovery. Unexpected crash?
. 2019.03.25 17:48:00 - Routes, removed a route previously added, 184.75.221.171 for gateway 10.8.190.1
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 184.75.223.195 for gateway 10.29.62.1
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 184.75.221.43 for gateway 10.30.222.1
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 184.75.223.219 for gateway 10.24.30.1
. 2019.03.25 17:48:01 - Above log line repeated 1 times more
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 137.63.71.51 for gateway 10.31.94.1
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 162.219.176.3 for gateway 10.6.126.1
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 199.21.149.49 for gateway 10.15.142.1
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 184.75.221.35 for gateway 10.28.30.1
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 104.254.90.251 for gateway 10.18.30.1
. 2019.03.25 17:48:01 - Routes, removed a route previously added, 104.254.90.187 for gateway 10.28.94.1
. 2019.03.25 17:48:02 - Routes, removed a route previously added, 184.75.221.3 for gateway 10.20.254.1
. 2019.03.25 17:48:02 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.158.1
. 2019.03.25 17:48:02 - Above log line repeated 4 times more
! 2019.03.25 17:48:02 - Activation of Network Lock - macOS - PF
. 2019.03.25 17:48:03 - macOS - PF rules updated, reloading
. 2019.03.25 17:48:04 - Updating systems & servers data ...
. 2019.03.25 17:48:17 - macOS - PF rules updated, reloading
I 2019.03.25 17:48:18 - Session starting.
I 2019.03.25 17:48:18 - Checking authorization ...
. 2019.03.25 17:48:19 - Systems & servers data update completed
. 2019.03.25 17:48:19 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 17:48:20 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 17:48:20 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 17:48:20 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 17:48:20 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 17:48:20 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.25 17:48:21 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 17:48:21 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 17:48:21 - Connection to OpenVPN Management Interface
. 2019.03.25 17:48:21 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 17:48:21 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 17:48:21 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 17:48:21 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 17:48:21 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 17:48:21 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:53
. 2019.03.25 17:48:21 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 17:48:21 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 17:48:21 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:53
. 2019.03.25 17:48:21 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:53, sid=cd4addf9 2135e76e
. 2019.03.25 17:48:21 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 17:48:21 - OpenVPN > VERIFY KU OK
. 2019.03.25 17:48:21 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 17:48:21 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 17:48:21 - OpenVPN > VERIFY EKU OK
. 2019.03.25 17:48:21 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.25 17:48:21 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 17:48:22 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 17:48:22 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:53
. 2019.03.25 17:48:23 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 17:48:23 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2019.03.25 17:48:23 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 17:48:23 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.25 17:48:23 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 17:48:23 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.25 17:48:23 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 17:48:23 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 17:48:23 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 17:48:23 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 17:48:23 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 17:48:23 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 17:48:23 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 17:48:23 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 17:48:23 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 17:48:23 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:48:23 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 17:48:23 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 17:48:23 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 17:48:23 - OpenVPN > Opened utun device utun1
. 2019.03.25 17:48:23 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 17:48:23 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.25 17:48:23 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 17:48:23 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 17:48:23 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 17:48:23 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.25 17:48:23 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.25 17:48:23 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.25 17:48:23 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.25 17:48:23 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 17:48:23 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.25 17:48:23 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 17:48:23 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.25 17:48:23 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.25 17:48:24 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 17:48:24 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 17:48:24 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 17:48:25 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 17:48:25 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 17:48:25 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.25 17:48:25 - Flushing DNS
. 2019.03.25 17:48:25 - macOS - PF rules updated, reloading
I 2019.03.25 17:48:26 - Checking route IPv4
I 2019.03.25 17:48:29 - Checking DNS
! 2019.03.25 17:48:31 - Connected.
. 2019.03.25 17:48:31 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 17:58:24 - Updating systems & servers data ...
. 2019.03.25 17:58:29 - Systems & servers data update completed
. 2019.03.25 18:29:57 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.25 18:29:57 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.25 18:29:57 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.25 18:29:58 - macOS - PF rules updated, reloading
! 2019.03.25 18:29:59 - Disconnecting
. 2019.03.25 18:29:59 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 18:29:59 - Sending management termination signal
. 2019.03.25 18:29:59 - Management - Send 'signal SIGTERM'
. 2019.03.25 18:29:59 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 18:29:59 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.25 18:29:59 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.25 18:29:59 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:29:59 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:29:59 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:29:59 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:29:59 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 18:29:59 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2019.03.25 18:29:59 - Connection terminated.
. 2019.03.25 18:29:59 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 18:29:59 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 18:30:00 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 18:30:00 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 18:30:00 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 18:30:00 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 18:30:00 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:30:00 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:30:00 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:30:00 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 18:30:03 - Checking authorization ...
. 2019.03.25 18:30:05 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 18:30:05 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 18:30:05 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 18:30:05 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 18:30:05 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 18:30:05 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.25 18:30:05 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 18:30:05 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 18:30:05 - Connection to OpenVPN Management Interface
. 2019.03.25 18:30:05 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 18:30:05 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 18:30:05 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 18:30:05 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 18:30:05 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 18:30:05 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:53
. 2019.03.25 18:30:05 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 18:30:05 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 18:30:05 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:53
. 2019.03.25 18:30:05 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 18:30:05 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:53, sid=cbafc4f0 199786c2
. 2019.03.25 18:30:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 18:30:06 - OpenVPN > VERIFY KU OK
. 2019.03.25 18:30:06 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 18:30:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 18:30:06 - OpenVPN > VERIFY EKU OK
. 2019.03.25 18:30:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.25 18:30:06 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 18:30:06 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:53
. 2019.03.25 18:30:07 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 18:30:08 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2019.03.25 18:30:08 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 18:30:08 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.25 18:30:08 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 18:30:08 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.25 18:30:08 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 18:30:08 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 18:30:08 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 18:30:08 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 18:30:08 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 18:30:08 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 18:30:08 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 18:30:08 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 18:30:08 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 18:30:08 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 18:30:08 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 18:30:08 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 18:30:08 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 18:30:08 - OpenVPN > Opened utun device utun1
. 2019.03.25 18:30:08 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 18:30:08 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.25 18:30:08 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 18:30:08 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 18:30:08 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 18:30:08 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.25 18:30:08 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.25 18:30:08 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.25 18:30:08 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.25 18:30:08 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:30:08 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:30:08 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:30:08 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:30:09 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.25 18:30:09 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:30:10 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:30:10 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:30:11 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:30:12 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 18:30:12 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.25 18:30:12 - Flushing DNS
. 2019.03.25 18:30:12 - macOS - PF rules updated, reloading
I 2019.03.25 18:30:13 - Checking route IPv4
I 2019.03.25 18:30:16 - Checking DNS
! 2019.03.25 18:30:17 - Connected.
. 2019.03.25 18:30:17 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 18:47:55 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.25 18:47:55 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.25 18:47:55 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.25 18:47:56 - Updating systems & servers data ...
. 2019.03.25 18:47:56 - macOS - PF rules updated, reloading
! 2019.03.25 18:47:57 - Disconnecting
. 2019.03.25 18:47:58 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 18:47:58 - Sending management termination signal
. 2019.03.25 18:47:58 - Management - Send 'signal SIGTERM'
. 2019.03.25 18:47:58 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:53
. 2019.03.25 18:47:58 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 18:47:58 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 18:47:58 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:53
. 2019.03.25 18:47:58 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 18:47:58 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.25 18:47:58 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:53, sid=0868cc19 a2cca0cf
. 2019.03.25 18:47:58 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 18:47:58 - OpenVPN > VERIFY KU OK
. 2019.03.25 18:47:58 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 18:47:58 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 18:47:58 - OpenVPN > VERIFY EKU OK
. 2019.03.25 18:47:58 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.25 18:47:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 18:47:59 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:53
. 2019.03.25 18:48:00 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 18:48:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2019.03.25 18:48:00 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 18:48:00 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.25 18:48:00 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 18:48:00 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.25 18:48:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 18:48:00 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 18:48:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 18:48:00 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 18:48:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 18:48:00 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 18:48:00 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 18:48:00 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 18:48:00 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 18:48:00 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 18:48:00 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 18:48:00 - OpenVPN > Preserving previous TUN/TAP instance: utun1
. 2019.03.25 18:48:00 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 18:48:00 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.25 18:48:00 - Flushing DNS
. 2019.03.25 18:48:01 - macOS - PF rules updated, reloading
. 2019.03.25 18:48:02 - OpenVPN > Initialization Sequence Completed
. 2019.03.25 18:48:03 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.25 18:48:03 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.25 18:48:03 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:48:03 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:48:03 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:48:03 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:48:03 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 18:48:03 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.25 18:48:03 - Connection terminated.
. 2019.03.25 18:48:03 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 18:48:03 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 18:48:04 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 18:48:04 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 18:48:04 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 18:48:04 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 18:48:05 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:48:05 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:48:06 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:48:06 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.25 18:48:09 - Checking authorization ...
. 2019.03.25 18:48:11 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 18:48:11 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 18:48:11 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 18:48:11 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 18:48:11 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 18:48:11 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.25 18:48:11 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 18:48:11 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 18:48:11 - Connection to OpenVPN Management Interface
. 2019.03.25 18:48:11 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 18:48:11 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 18:48:11 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 18:48:11 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 18:48:11 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 18:48:11 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:53
. 2019.03.25 18:48:11 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 18:48:11 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 18:48:11 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:53
. 2019.03.25 18:48:11 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 18:48:11 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:53, sid=3ae5b991 fe57ff55
. 2019.03.25 18:48:12 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 18:48:12 - OpenVPN > VERIFY KU OK
. 2019.03.25 18:48:12 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 18:48:12 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 18:48:12 - OpenVPN > VERIFY EKU OK
. 2019.03.25 18:48:12 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.25 18:48:12 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 18:48:12 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:53
. 2019.03.25 18:48:13 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 18:48:13 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2019.03.25 18:48:13 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 18:48:13 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.25 18:48:13 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 18:48:13 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.25 18:48:13 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 18:48:13 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 18:48:13 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 18:48:13 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 18:48:13 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 18:48:13 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 18:48:13 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 18:48:13 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 18:48:13 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 18:48:13 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 18:48:13 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 18:48:13 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 18:48:13 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 18:48:13 - OpenVPN > Opened utun device utun1
. 2019.03.25 18:48:13 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 18:48:13 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.25 18:48:13 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 18:48:13 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 18:48:13 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 18:48:13 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.25 18:48:13 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.25 18:48:13 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.25 18:48:13 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.25 18:48:13 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:48:13 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:48:13 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:48:13 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:48:14 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.25 18:48:14 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:48:14 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:48:15 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:48:16 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:48:16 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 18:48:16 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.25 18:48:16 - Flushing DNS
I 2019.03.25 18:48:17 - Checking route IPv4
. 2019.03.25 18:48:19 - Systems & servers data update completed
. 2019.03.25 18:48:37 - curl: (28) Connection timed out after 20002 milliseconds
. 2019.03.25 18:48:37 - Checking route (2° try)
. 2019.03.25 18:48:58 - curl: (28) Connection timed out after 20004 milliseconds
. 2019.03.25 18:48:58 - OpenVPN > Initialization Sequence Completed
! 2019.03.25 18:48:58 - Disconnecting
. 2019.03.25 18:48:58 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 18:48:58 - Sending management termination signal
. 2019.03.25 18:48:58 - Management - Send 'signal SIGTERM'
. 2019.03.25 18:48:58 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.25 18:48:58 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.25 18:49:03 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.25 18:49:03 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.25 18:49:03 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:49:03 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:49:03 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:49:03 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:49:03 - OpenVPN > Closing TUN/TAP interface
. 2019.03.25 18:49:03 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.25 18:49:03 - Connection terminated.
. 2019.03.25 18:49:03 - IPv6 restored on network adapter (Ethernet)
. 2019.03.25 18:49:03 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.25 18:49:03 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.25 18:49:03 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.25 18:49:03 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.25 18:49:03 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.25 18:49:04 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:49:04 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:49:04 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:49:04 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.25 18:49:04 - Flushing DNS
! 2019.03.25 18:49:04 - Session terminated.
! 2019.03.25 18:49:08 - Deactivation of Network Lock
I 2019.03.25 18:49:26 - Session starting.
I 2019.03.25 18:49:26 - Checking authorization ...
. 2019.03.25 18:49:27 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.25 18:49:27 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.25 18:49:27 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.25 18:49:27 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.25 18:49:27 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.25 18:49:27 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.25 18:49:27 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.25 18:49:27 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.25 18:49:27 - Connection to OpenVPN Management Interface
. 2019.03.25 18:49:27 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.25 18:49:27 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 18:49:27 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 18:49:27 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.25 18:49:27 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.25 18:49:27 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:53
. 2019.03.25 18:49:27 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.25 18:49:27 - OpenVPN > UDP link local: (not bound)
. 2019.03.25 18:49:27 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:53
. 2019.03.25 18:49:28 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.25 18:49:28 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:53, sid=4a0ff817 f5c58a09
. 2019.03.25 18:49:28 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.25 18:49:28 - OpenVPN > VERIFY KU OK
. 2019.03.25 18:49:28 - OpenVPN > Validating certificate extended key usage
. 2019.03.25 18:49:28 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.25 18:49:28 - OpenVPN > VERIFY EKU OK
. 2019.03.25 18:49:28 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.25 18:49:28 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.25 18:49:28 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:53
. 2019.03.25 18:49:29 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.25 18:49:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2019.03.25 18:49:30 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.25 18:49:30 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.25 18:49:30 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.25 18:49:30 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.25 18:49:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.25 18:49:30 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.25 18:49:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.25 18:49:30 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.25 18:49:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.25 18:49:30 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.25 18:49:30 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.25 18:49:30 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.25 18:49:30 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.25 18:49:30 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 18:49:30 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.25 18:49:30 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.25 18:49:30 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.25 18:49:30 - OpenVPN > Opened utun device utun1
. 2019.03.25 18:49:30 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.25 18:49:30 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.25 18:49:30 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.25 18:49:30 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.25 18:49:30 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.25 18:49:30 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.25 18:49:30 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.25 18:49:30 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.25 18:49:30 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.25 18:49:30 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:49:30 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:49:30 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.25 18:49:30 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.25 18:49:30 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.25 18:49:30 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:49:31 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:49:31 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:49:31 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.25 18:49:31 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.25 18:49:31 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.25 18:49:31 - Flushing DNS
I 2019.03.25 18:49:31 - Checking route IPv4
I 2019.03.25 18:49:33 - Checking DNS
! 2019.03.25 18:49:35 - Connected.
. 2019.03.25 18:49:35 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 14:36:33 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 14:36:33 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 14:36:33 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 14:36:33 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 14:36:33 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 14:36:33 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 14:36:33 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 14:36:33 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=3dab12db 027ceea7
. 2019.03.26 14:36:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 14:36:34 - OpenVPN > VERIFY KU OK
. 2019.03.26 14:36:34 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 14:36:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 14:36:34 - OpenVPN > VERIFY EKU OK
. 2019.03.26 14:36:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 14:36:34 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 14:36:34 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 14:36:35 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 14:36:35 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 14:36:35 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 14:36:35 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 14:36:35 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 14:36:35 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 14:36:35 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 14:36:35 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 14:36:35 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 14:36:35 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 14:36:35 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 14:36:35 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 14:36:35 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 14:36:35 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 14:36:35 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 14:36:35 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 14:36:35 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 14:36:35 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 14:36:35 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 14:36:35 - OpenVPN > Opened utun device utun1
. 2019.03.26 14:36:35 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 14:36:35 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 14:36:35 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 14:36:35 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 14:36:35 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 14:36:35 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 14:36:35 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 14:36:35 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 14:36:35 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 14:36:35 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 14:36:35 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 14:36:35 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 14:36:35 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 14:36:36 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 14:36:37 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 14:36:37 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 14:36:37 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 14:36:37 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 14:36:37 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 14:36:37 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 14:36:37 - Flushing DNS
. 2019.03.26 14:36:38 - macOS - PF rules updated, reloading
! 2019.03.26 14:36:39 - Connected.
. 2019.03.26 14:36:39 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 14:36:42 - macOS - PF rules updated, reloading
. 2019.03.26 14:36:43 - Systems & servers data update completed
. 2019.03.26 15:01:58 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.26 15:01:58 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.26 15:01:58 - OpenVPN > Restart pause, 5 second(s)
! 2019.03.26 15:01:59 - Disconnecting
. 2019.03.26 15:01:59 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 15:01:59 - Sending management termination signal
. 2019.03.26 15:01:59 - Management - Send 'signal SIGTERM'
. 2019.03.26 15:02:00 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.26 15:02:00 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 15:02:00 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 15:02:00 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 15:02:00 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 15:02:00 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 15:02:00 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 15:02:00 - OpenVPN > Closing TUN/TAP interface
. 2019.03.26 15:02:00 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2019.03.26 15:02:00 - Connection terminated.
. 2019.03.26 15:02:00 - IPv6 restored on network adapter (Ethernet)
. 2019.03.26 15:02:00 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.26 15:02:00 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.26 15:02:00 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.26 15:02:00 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.26 15:02:00 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.26 15:02:01 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 15:02:02 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 15:02:02 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 15:02:02 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.26 15:02:05 - Checking authorization ...
. 2019.03.26 15:02:07 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.26 15:02:07 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.26 15:02:07 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.26 15:02:07 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.26 15:02:07 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.26 15:02:07 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.26 15:02:07 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.26 15:02:07 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.26 15:02:07 - Connection to OpenVPN Management Interface
. 2019.03.26 15:02:07 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.26 15:02:07 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 15:02:07 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 15:02:07 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 15:02:07 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 15:02:07 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 15:02:07 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 15:02:07 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 15:02:07 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 15:02:07 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 15:02:07 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=1a675a4a 5e22e76b
. 2019.03.26 15:02:08 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 15:02:08 - OpenVPN > VERIFY KU OK
. 2019.03.26 15:02:08 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 15:02:08 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 15:02:08 - OpenVPN > VERIFY EKU OK
. 2019.03.26 15:02:08 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 15:02:08 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 15:02:08 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 15:02:09 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 15:02:09 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 15:02:09 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 15:02:09 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 15:02:09 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 15:02:09 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 15:02:09 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 15:02:09 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 15:02:09 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 15:02:09 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 15:02:09 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 15:02:09 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 15:02:09 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 15:02:09 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 15:02:09 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 15:02:09 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 15:02:09 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 15:02:09 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 15:02:09 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 15:02:09 - OpenVPN > Opened utun device utun1
. 2019.03.26 15:02:09 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 15:02:09 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 15:02:09 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 15:02:09 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 15:02:09 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 15:02:09 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 15:02:09 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 15:02:09 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 15:02:09 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 15:02:09 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 15:02:09 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 15:02:09 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 15:02:09 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 15:02:10 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 15:02:10 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 15:02:11 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 15:02:11 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 15:02:11 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 15:02:11 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 15:02:11 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 15:02:11 - Flushing DNS
. 2019.03.26 15:02:12 - macOS - PF rules updated, reloading
! 2019.03.26 15:02:13 - Connected.
. 2019.03.26 15:02:13 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 15:02:32 - Updating systems & servers data ...
. 2019.03.26 15:02:36 - Systems & servers data update completed
. 2019.03.26 15:30:18 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.26 15:30:18 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.26 15:30:18 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.26 15:30:21 - macOS - PF rules updated, reloading
! 2019.03.26 15:30:22 - Disconnecting
. 2019.03.26 15:30:22 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 15:30:22 - Sending management termination signal
. 2019.03.26 15:30:22 - Management - Send 'signal SIGTERM'
. 2019.03.26 15:30:22 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.26 15:30:22 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 15:30:22 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 15:30:22 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 15:30:22 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 15:30:22 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 15:30:22 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 15:30:22 - OpenVPN > Closing TUN/TAP interface
. 2019.03.26 15:30:22 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2019.03.26 15:30:22 - Connection terminated.
. 2019.03.26 15:30:22 - IPv6 restored on network adapter (Ethernet)
. 2019.03.26 15:30:23 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.26 15:30:23 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.26 15:30:23 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.26 15:30:23 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.26 15:30:23 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.26 15:30:23 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 15:30:24 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 15:30:24 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 15:30:24 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.26 15:30:27 - Checking authorization ...
. 2019.03.26 15:30:28 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.26 15:30:29 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.26 15:30:29 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.26 15:30:29 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.26 15:30:29 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.26 15:30:29 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.26 15:30:29 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.26 15:30:29 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.26 15:30:29 - Connection to OpenVPN Management Interface
. 2019.03.26 15:30:29 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.26 15:30:29 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 15:30:29 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 15:30:29 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 15:30:29 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 15:30:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 15:30:29 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 15:30:29 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 15:30:29 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 15:30:29 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 15:30:29 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=cc3a5046 1e4d22c2
. 2019.03.26 15:30:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 15:30:30 - OpenVPN > VERIFY KU OK
. 2019.03.26 15:30:30 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 15:30:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 15:30:30 - OpenVPN > VERIFY EKU OK
. 2019.03.26 15:30:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 15:30:30 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 15:30:30 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 15:30:31 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 15:30:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 15:30:31 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 15:30:31 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 15:30:31 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 15:30:31 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 15:30:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 15:30:31 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 15:30:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 15:30:31 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 15:30:31 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 15:30:31 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 15:30:31 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 15:30:31 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 15:30:31 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 15:30:31 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 15:30:31 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 15:30:31 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 15:30:31 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 15:30:31 - OpenVPN > Opened utun device utun1
. 2019.03.26 15:30:31 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 15:30:31 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 15:30:31 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 15:30:31 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 15:30:31 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 15:30:31 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 15:30:31 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 15:30:31 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 15:30:31 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 15:30:31 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 15:30:31 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 15:30:31 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 15:30:31 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 15:30:32 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 15:30:32 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 15:30:32 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 15:30:32 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 15:30:32 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 15:30:32 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 15:30:32 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 15:30:32 - Flushing DNS
. 2019.03.26 15:30:34 - macOS - PF rules updated, reloading
! 2019.03.26 15:30:35 - Connected.
. 2019.03.26 15:30:35 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 16:02:42 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.26 16:02:42 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.26 16:02:42 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.26 16:03:33 - macOS - PF rules updated, reloading
! 2019.03.26 16:04:02 - Disconnecting
. 2019.03.26 16:04:02 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 16:04:02 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 16:04:02 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 16:04:02 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 16:04:02 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 16:04:02 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=23199345 86f9af64
. 2019.03.26 16:04:02 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 16:04:02 - OpenVPN > VERIFY KU OK
. 2019.03.26 16:04:02 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 16:04:02 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 16:04:02 - OpenVPN > VERIFY EKU OK
. 2019.03.26 16:04:02 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 16:04:02 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 16:04:02 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 16:04:02 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 16:04:02 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 16:04:02 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 16:04:02 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 16:04:02 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 16:04:02 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 16:04:02 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 16:04:02 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 16:04:02 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 16:04:02 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 16:04:02 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 16:04:02 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 16:04:02 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 16:04:02 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 16:04:02 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 16:04:02 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 16:04:02 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 16:04:02 - OpenVPN > Preserving previous TUN/TAP instance: utun1
. 2019.03.26 16:04:02 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 16:04:02 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 16:04:02 - Flushing DNS
. 2019.03.26 16:04:03 - macOS - PF rules updated, reloading
. 2019.03.26 16:04:04 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 16:04:04 - OpenVPN > write UDP: Network is down (code=50)
. 2019.03.26 16:04:04 - Above log line repeated 1 times more
. 2019.03.26 16:04:04 - Sending management termination signal
. 2019.03.26 16:04:04 - Management - Send 'signal SIGTERM'
. 2019.03.26 16:04:04 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.26 16:04:04 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.26 16:04:05 - Updating systems & servers data ...
. 2019.03.26 16:04:09 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 16:04:09 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 16:04:09 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 16:04:09 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 16:04:09 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 16:04:09 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 16:04:09 - OpenVPN > Closing TUN/TAP interface
. 2019.03.26 16:04:09 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.26 16:04:09 - Connection terminated.
. 2019.03.26 16:04:09 - IPv6 restored on network adapter (Ethernet)
. 2019.03.26 16:04:09 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.26 16:04:09 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.26 16:04:09 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.26 16:04:09 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.26 16:04:09 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.26 16:04:09 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 16:04:09 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 16:04:09 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 16:04:09 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.26 16:04:12 - Checking authorization ...
. 2019.03.26 16:04:13 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.26 16:04:13 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.26 16:04:14 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.26 16:04:14 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.26 16:04:14 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.26 16:04:14 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.26 16:04:14 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.26 16:04:14 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.26 16:04:14 - Connection to OpenVPN Management Interface
. 2019.03.26 16:04:14 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.26 16:04:14 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 16:04:14 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 16:04:14 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 16:04:14 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 16:04:14 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 16:04:14 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 16:04:14 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 16:04:14 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 16:04:14 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 16:04:14 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=a6914e54 5fb42c20
. 2019.03.26 16:04:15 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 16:04:15 - OpenVPN > VERIFY KU OK
. 2019.03.26 16:04:15 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 16:04:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 16:04:15 - OpenVPN > VERIFY EKU OK
. 2019.03.26 16:04:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 16:04:15 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 16:04:15 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 16:04:16 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 16:04:16 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 16:04:16 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 16:04:16 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 16:04:16 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 16:04:16 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 16:04:16 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 16:04:16 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 16:04:16 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 16:04:16 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 16:04:16 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 16:04:16 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 16:04:16 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 16:04:16 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 16:04:16 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 16:04:16 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 16:04:16 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 16:04:16 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 16:04:16 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 16:04:16 - OpenVPN > Opened utun device utun1
. 2019.03.26 16:04:16 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 16:04:16 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 16:04:16 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 16:04:16 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 16:04:16 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 16:04:16 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 16:04:16 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 16:04:16 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 16:04:16 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 16:04:16 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 16:04:16 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 16:04:16 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 16:04:16 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 16:04:17 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 16:04:18 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 16:04:18 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 16:04:18 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 16:04:18 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 16:04:18 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 16:04:18 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 16:04:18 - Flushing DNS
! 2019.03.26 16:04:19 - Connected.
. 2019.03.26 16:04:19 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 16:04:28 - Systems & servers data update completed
. 2019.03.26 17:34:06 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.26 17:34:06 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.26 17:34:06 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.26 17:34:08 - macOS - PF rules updated, reloading
! 2019.03.26 17:34:09 - Disconnecting
. 2019.03.26 17:34:09 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 17:34:09 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 17:34:09 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 17:34:09 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 17:34:09 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 17:34:09 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=bb5f801e 4b859d10
. 2019.03.26 17:34:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 17:34:09 - OpenVPN > VERIFY KU OK
. 2019.03.26 17:34:09 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 17:34:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 17:34:09 - OpenVPN > VERIFY EKU OK
. 2019.03.26 17:34:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 17:34:09 - Sending management termination signal
. 2019.03.26 17:34:09 - Management - Send 'signal SIGTERM'
. 2019.03.26 17:34:09 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.26 17:34:09 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.26 17:34:10 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 17:34:10 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 17:34:11 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 17:34:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 17:34:11 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 17:34:11 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 17:34:11 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 17:34:11 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 17:34:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 17:34:11 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 17:34:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 17:34:11 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 17:34:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 17:34:11 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 17:34:11 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 17:34:11 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 17:34:11 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 17:34:11 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 17:34:11 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 17:34:11 - OpenVPN > Preserving previous TUN/TAP instance: utun1
. 2019.03.26 17:34:11 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 17:34:11 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 17:34:11 - Flushing DNS
. 2019.03.26 17:34:12 - macOS - PF rules updated, reloading
. 2019.03.26 17:34:13 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 17:34:14 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 17:34:14 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 17:34:14 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 17:34:14 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 17:34:14 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 17:34:14 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 17:34:14 - OpenVPN > Closing TUN/TAP interface
. 2019.03.26 17:34:14 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.26 17:34:14 - Connection terminated.
. 2019.03.26 17:34:14 - IPv6 restored on network adapter (Ethernet)
. 2019.03.26 17:34:14 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.26 17:34:14 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.26 17:34:14 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.26 17:34:14 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.26 17:34:14 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.26 17:34:15 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 17:34:16 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 17:34:16 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 17:34:16 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.26 17:34:19 - Checking authorization ...
. 2019.03.26 17:34:20 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.26 17:34:20 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.26 17:34:20 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.26 17:34:20 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.26 17:34:21 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.26 17:34:21 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.26 17:34:21 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.26 17:34:21 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.26 17:34:21 - Connection to OpenVPN Management Interface
. 2019.03.26 17:34:21 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.26 17:34:21 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 17:34:21 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 17:34:21 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 17:34:21 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 17:34:21 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 17:34:21 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 17:34:21 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 17:34:21 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 17:34:21 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 17:34:21 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=8714e7a6 3785c85c
. 2019.03.26 17:34:21 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 17:34:21 - OpenVPN > VERIFY KU OK
. 2019.03.26 17:34:21 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 17:34:21 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 17:34:21 - OpenVPN > VERIFY EKU OK
. 2019.03.26 17:34:21 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 17:34:22 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 17:34:22 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 17:34:23 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 17:34:23 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 17:34:23 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 17:34:23 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 17:34:23 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 17:34:23 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 17:34:23 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 17:34:23 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 17:34:23 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 17:34:23 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 17:34:23 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 17:34:23 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 17:34:23 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 17:34:23 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 17:34:23 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 17:34:23 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 17:34:23 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 17:34:23 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 17:34:23 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 17:34:23 - OpenVPN > Opened utun device utun1
. 2019.03.26 17:34:23 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 17:34:23 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 17:34:23 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 17:34:23 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 17:34:23 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 17:34:23 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 17:34:23 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 17:34:23 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 17:34:23 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 17:34:23 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 17:34:23 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 17:34:23 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 17:34:23 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 17:34:24 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 17:34:25 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 17:34:25 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 17:34:25 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 17:34:25 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 17:34:25 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 17:34:25 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 17:34:25 - Flushing DNS
! 2019.03.26 17:34:26 - Connected.
. 2019.03.26 17:34:26 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 17:34:44 - Updating systems & servers data ...
. 2019.03.26 17:34:49 - Systems & servers data update completed
. 2019.03.26 17:42:26 - macOS - PF rules updated, reloading
! 2019.03.26 17:42:27 - Disconnecting
. 2019.03.26 17:42:27 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 17:42:27 - Sending management termination signal
. 2019.03.26 17:42:27 - Management - Send 'signal SIGTERM'
. 2019.03.26 17:42:27 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.26 17:42:27 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.26 17:42:32 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 17:42:32 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 17:42:32 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 17:42:32 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 17:42:32 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 17:42:32 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 17:42:32 - OpenVPN > Closing TUN/TAP interface
. 2019.03.26 17:42:32 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.26 17:42:32 - Connection terminated.
. 2019.03.26 17:42:32 - IPv6 restored on network adapter (Ethernet)
. 2019.03.26 17:42:32 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.26 17:42:32 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.26 17:42:32 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.26 17:42:32 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.26 17:42:32 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.26 17:42:32 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 17:42:32 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 17:42:32 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 17:42:32 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 17:42:32 - Flushing DNS
! 2019.03.26 17:42:33 - Session terminated.
! 2019.03.26 17:42:34 - Deactivation of Network Lock
! 2019.03.26 17:43:41 - Activation of Network Lock - macOS - PF
. 2019.03.26 17:43:43 - macOS - PF rules updated, reloading
I 2019.03.26 17:43:46 - Session starting.
I 2019.03.26 17:43:46 - Checking authorization ...
. 2019.03.26 17:43:47 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.26 17:43:47 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.26 17:43:47 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.26 17:43:47 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.26 17:43:47 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.26 17:43:47 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.26 17:43:47 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.26 17:43:47 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.26 17:43:47 - Connection to OpenVPN Management Interface
. 2019.03.26 17:43:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.26 17:43:47 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 17:43:47 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 17:43:47 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 17:43:47 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 17:43:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 17:43:47 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 17:43:47 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 17:43:47 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 17:43:48 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 17:43:48 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=2435b175 800d3b7e
. 2019.03.26 17:43:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 17:43:48 - OpenVPN > VERIFY KU OK
. 2019.03.26 17:43:48 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 17:43:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 17:43:48 - OpenVPN > VERIFY EKU OK
. 2019.03.26 17:43:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 17:43:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 17:43:48 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 17:43:50 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 17:43:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 17:43:50 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 17:43:50 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 17:43:50 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 17:43:50 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 17:43:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 17:43:50 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 17:43:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 17:43:50 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 17:43:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 17:43:50 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 17:43:50 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 17:43:50 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 17:43:50 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 17:43:50 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 17:43:50 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 17:43:50 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 17:43:50 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 17:43:50 - OpenVPN > Opened utun device utun1
. 2019.03.26 17:43:50 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 17:43:50 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 17:43:50 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 17:43:50 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 17:43:50 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 17:43:50 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 17:43:50 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 17:43:50 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 17:43:50 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 17:43:50 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 17:43:50 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 17:43:50 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 17:43:50 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 17:43:50 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 17:43:50 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 17:43:50 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 17:43:50 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 17:43:51 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 17:43:51 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 17:43:51 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 17:43:51 - Flushing DNS
. 2019.03.26 17:43:52 - macOS - PF rules updated, reloading
! 2019.03.26 17:43:53 - Connected.
. 2019.03.26 17:43:53 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 17:45:13 - Updating systems & servers data ...
. 2019.03.26 17:45:18 - Systems & servers data update completed
. 2019.03.26 17:55:25 - Updating systems & servers data ...
. 2019.03.26 17:55:30 - Systems & servers data update completed
. 2019.03.26 18:05:36 - Updating systems & servers data ...
. 2019.03.26 18:05:41 - Systems & servers data update completed
. 2019.03.26 18:16:33 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.26 18:16:33 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.26 18:16:33 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.26 18:16:35 - Updating systems & servers data ...
. 2019.03.26 18:16:36 - macOS - PF rules updated, reloading
! 2019.03.26 18:16:37 - Disconnecting
. 2019.03.26 18:16:38 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 18:16:38 - Sending management termination signal
. 2019.03.26 18:16:38 - Management - Send 'signal SIGTERM'
. 2019.03.26 18:16:38 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.26 18:16:38 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 18:16:38 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 18:16:38 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:16:38 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:16:38 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:16:38 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:16:38 - OpenVPN > Closing TUN/TAP interface
. 2019.03.26 18:16:38 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2019.03.26 18:16:38 - Connection terminated.
. 2019.03.26 18:16:38 - IPv6 restored on network adapter (Ethernet)
. 2019.03.26 18:16:38 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.26 18:16:38 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.26 18:16:38 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.26 18:16:38 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.26 18:16:38 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.26 18:16:38 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:16:38 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:16:38 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:16:38 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.26 18:16:42 - Checking authorization ...
. 2019.03.26 18:16:43 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.26 18:16:43 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.26 18:16:43 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.26 18:16:43 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.26 18:16:43 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.26 18:16:43 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.26 18:16:43 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.26 18:16:43 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.26 18:16:43 - Connection to OpenVPN Management Interface
. 2019.03.26 18:16:43 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.26 18:16:43 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 18:16:43 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 18:16:43 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 18:16:43 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 18:16:43 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 18:16:43 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 18:16:43 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 18:16:43 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 18:16:44 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 18:16:44 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=816cdd23 322acab5
. 2019.03.26 18:16:44 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 18:16:44 - OpenVPN > VERIFY KU OK
. 2019.03.26 18:16:44 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 18:16:44 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 18:16:44 - OpenVPN > VERIFY EKU OK
. 2019.03.26 18:16:44 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 18:16:44 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 18:16:44 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 18:16:45 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 18:16:46 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 18:16:46 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 18:16:46 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 18:16:46 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 18:16:46 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 18:16:46 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 18:16:46 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 18:16:46 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 18:16:46 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 18:16:46 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 18:16:46 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 18:16:46 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 18:16:46 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 18:16:46 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 18:16:46 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 18:16:46 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 18:16:46 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 18:16:46 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 18:16:46 - OpenVPN > Opened utun device utun1
. 2019.03.26 18:16:46 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 18:16:46 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 18:16:46 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 18:16:46 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 18:16:46 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 18:16:46 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 18:16:46 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 18:16:46 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 18:16:46 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 18:16:46 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:16:46 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:16:46 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:16:46 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:16:46 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 18:16:48 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:16:48 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:16:48 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:16:48 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:16:48 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 18:16:48 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 18:16:48 - Flushing DNS
. 2019.03.26 18:16:49 - macOS - PF rules updated, reloading
! 2019.03.26 18:16:50 - Connected.
. 2019.03.26 18:16:50 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 18:16:51 - Systems & servers data update completed
. 2019.03.26 18:47:57 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.26 18:47:57 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.26 18:47:57 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.26 18:47:58 - macOS - PF rules updated, reloading
! 2019.03.26 18:47:59 - Disconnecting
. 2019.03.26 18:47:59 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 18:47:59 - Sending management termination signal
. 2019.03.26 18:47:59 - Management - Send 'signal SIGTERM'
. 2019.03.26 18:47:59 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.26 18:47:59 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 18:47:59 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 18:47:59 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:47:59 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:47:59 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:47:59 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:47:59 - OpenVPN > Closing TUN/TAP interface
. 2019.03.26 18:47:59 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2019.03.26 18:47:59 - Connection terminated.
. 2019.03.26 18:47:59 - IPv6 restored on network adapter (Ethernet)
. 2019.03.26 18:47:59 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.26 18:48:00 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.26 18:48:00 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.26 18:48:00 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.26 18:48:00 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.26 18:48:00 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:48:01 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:48:01 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:48:01 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.26 18:48:04 - Checking authorization ...
. 2019.03.26 18:48:05 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.26 18:48:06 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.26 18:48:06 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.26 18:48:06 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.26 18:48:06 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.26 18:48:06 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.26 18:48:06 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.26 18:48:06 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.26 18:48:06 - Connection to OpenVPN Management Interface
. 2019.03.26 18:48:06 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.26 18:48:06 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 18:48:06 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 18:48:06 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 18:48:06 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 18:48:06 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 18:48:06 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 18:48:06 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 18:48:06 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 18:48:06 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 18:48:06 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=be1e93d8 dc247f5a
. 2019.03.26 18:48:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 18:48:06 - OpenVPN > VERIFY KU OK
. 2019.03.26 18:48:06 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 18:48:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 18:48:06 - OpenVPN > VERIFY EKU OK
. 2019.03.26 18:48:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 18:48:07 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 18:48:07 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 18:48:08 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 18:48:08 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 18:48:08 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 18:48:08 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 18:48:08 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 18:48:08 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 18:48:08 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 18:48:08 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 18:48:08 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 18:48:08 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 18:48:08 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 18:48:08 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 18:48:08 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 18:48:08 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 18:48:08 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 18:48:08 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 18:48:08 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 18:48:08 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 18:48:08 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 18:48:08 - OpenVPN > Opened utun device utun1
. 2019.03.26 18:48:08 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 18:48:08 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 18:48:08 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 18:48:08 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 18:48:08 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 18:48:08 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 18:48:08 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 18:48:08 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 18:48:08 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 18:48:08 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:48:08 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:48:08 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:48:08 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:48:09 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 18:48:10 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:48:10 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:48:10 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:48:10 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:48:10 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 18:48:10 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 18:48:10 - Flushing DNS
. 2019.03.26 18:48:11 - macOS - PF rules updated, reloading
! 2019.03.26 18:48:13 - Connected.
. 2019.03.26 18:48:13 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 18:48:29 - Updating systems & servers data ...
. 2019.03.26 18:48:33 - Systems & servers data update completed
. 2019.03.26 18:51:35 - OpenVPN > [bootes] Inactivity timeout (--ping-restart), restarting
. 2019.03.26 18:51:35 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2019.03.26 18:51:35 - OpenVPN > Restart pause, 5 second(s)
. 2019.03.26 18:51:36 - macOS - PF rules updated, reloading
! 2019.03.26 18:51:37 - Disconnecting
. 2019.03.26 18:51:37 - Routes, removed a route previously added, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 18:51:37 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 18:51:37 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 18:51:37 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 18:51:37 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 18:51:37 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=97300180 382cb41b
. 2019.03.26 18:51:37 - Sending management termination signal
. 2019.03.26 18:51:37 - Management - Send 'signal SIGTERM'
. 2019.03.26 18:51:37 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.03.26 18:51:37 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.03.26 18:51:37 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 18:51:37 - OpenVPN > VERIFY KU OK
. 2019.03.26 18:51:37 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 18:51:37 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 18:51:37 - OpenVPN > VERIFY EKU OK
. 2019.03.26 18:51:37 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 18:51:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 18:51:38 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 18:51:39 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 18:51:39 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 18:51:39 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 18:51:39 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 18:51:39 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 18:51:39 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 18:51:39 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 18:51:39 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 18:51:39 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 18:51:39 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 18:51:39 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 18:51:39 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 18:51:39 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 18:51:39 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 18:51:39 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 18:51:39 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 18:51:39 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 18:51:39 - OpenVPN > Preserving previous TUN/TAP instance: utun1
. 2019.03.26 18:51:39 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 18:51:39 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 18:51:39 - Flushing DNS
. 2019.03.26 18:51:40 - macOS - PF rules updated, reloading
. 2019.03.26 18:51:41 - OpenVPN > Initialization Sequence Completed
. 2019.03.26 18:51:42 - OpenVPN > /sbin/route delete -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 18:51:42 - OpenVPN > delete net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 18:51:42 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:51:42 - OpenVPN > delete net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:51:42 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:51:42 - OpenVPN > delete net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:51:42 - OpenVPN > Closing TUN/TAP interface
. 2019.03.26 18:51:42 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.03.26 18:51:42 - Connection terminated.
. 2019.03.26 18:51:42 - IPv6 restored on network adapter (Ethernet)
. 2019.03.26 18:51:42 - IPv6 restored on network adapter (iPhone USB)
. 2019.03.26 18:51:42 - IPv6 restored on network adapter (Wi-Fi)
. 2019.03.26 18:51:42 - IPv6 restored on network adapter (Bluetooth PAN)
. 2019.03.26 18:51:42 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2019.03.26 18:51:42 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2019.03.26 18:51:42 - DNS of a network adapter restored to original settings (iPhone USB, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:51:43 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:51:43 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.29.194.1, fde6:7a:7d20:19c2::1)
. 2019.03.26 18:51:43 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.29.194.1, fde6:7a:7d20:19c2::1)
I 2019.03.26 18:51:47 - Checking authorization ...
. 2019.03.26 18:51:48 - IPv6 disabled on network adapter (Ethernet)
. 2019.03.26 18:51:49 - IPv6 disabled on network adapter (iPhone USB)
. 2019.03.26 18:51:49 - IPv6 disabled on network adapter (Wi-Fi)
. 2019.03.26 18:51:49 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2019.03.26 18:51:49 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2019.03.26 18:51:49 - Connecting to Bootes (United States, Phoenix, Arizona)
. 2019.03.26 18:51:49 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018
. 2019.03.26 18:51:49 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.03.26 18:51:49 - Connection to OpenVPN Management Interface
. 2019.03.26 18:51:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2019.03.26 18:51:49 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 18:51:49 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 18:51:49 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.03.26 18:51:49 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.03.26 18:51:49 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.5:443
. 2019.03.26 18:51:49 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2019.03.26 18:51:49 - OpenVPN > UDP link local: (not bound)
. 2019.03.26 18:51:49 - OpenVPN > UDP link remote: [AF_INET]193.37.254.5:443
. 2019.03.26 18:51:49 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2019.03.26 18:51:49 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.5:443, sid=ca937bda e9a16345
. 2019.03.26 18:51:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.03.26 18:51:50 - OpenVPN > VERIFY KU OK
. 2019.03.26 18:51:50 - OpenVPN > Validating certificate extended key usage
. 2019.03.26 18:51:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.03.26 18:51:50 - OpenVPN > VERIFY EKU OK
. 2019.03.26 18:51:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Bootes, emailAddress=info@airvpn.org
. 2019.03.26 18:51:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.03.26 18:51:50 - OpenVPN > [bootes] Peer Connection Initiated with [AF_INET]193.37.254.5:443
. 2019.03.26 18:51:51 - OpenVPN > SENT CONTROL [bootes]: 'PUSH_REQUEST' (status=1)
. 2019.03.26 18:51:51 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.158.1,dhcp-option DNS6 fde6:7a:7d20:169e::1,tun-ipv6,route-gateway 10.26.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1,ifconfig 10.26.158.223 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2019.03.26 18:51:51 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.03.26 18:51:51 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:169e::1'
. 2019.03.26 18:51:51 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2019.03.26 18:51:51 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:169e::10dd/64 fde6:7a:7d20:169e::1'
. 2019.03.26 18:51:51 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.03.26 18:51:51 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.03.26 18:51:51 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.03.26 18:51:51 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.03.26 18:51:51 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.03.26 18:51:51 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.03.26 18:51:51 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.03.26 18:51:51 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.03.26 18:51:51 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.03.26 18:51:51 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 18:51:51 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.03.26 18:51:51 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=98:5a:eb:cb:f8:c8
. 2019.03.26 18:51:51 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2019.03.26 18:51:51 - OpenVPN > Opened utun device utun1
. 2019.03.26 18:51:51 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2019.03.26 18:51:51 - OpenVPN > /sbin/ifconfig utun1 delete
. 2019.03.26 18:51:51 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2019.03.26 18:51:51 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2019.03.26 18:51:51 - OpenVPN > /sbin/ifconfig utun1 10.26.158.223 10.26.158.223 netmask 255.255.255.0 mtu 1500 up
. 2019.03.26 18:51:51 - OpenVPN > /sbin/route add -net 10.26.158.0 10.26.158.223 255.255.255.0
. 2019.03.26 18:51:51 - OpenVPN > add net 10.26.158.0: gateway 10.26.158.223
. 2019.03.26 18:51:51 - OpenVPN > /sbin/route add -net 193.37.254.5 192.168.1.1 255.255.255.255
. 2019.03.26 18:51:51 - OpenVPN > add net 193.37.254.5: gateway 192.168.1.1
. 2019.03.26 18:51:51 - OpenVPN > /sbin/route add -net 0.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:51:51 - OpenVPN > add net 0.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:51:51 - OpenVPN > /sbin/route add -net 128.0.0.0 10.26.158.1 128.0.0.0
. 2019.03.26 18:51:51 - OpenVPN > add net 128.0.0.0: gateway 10.26.158.1
. 2019.03.26 18:51:52 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.158.1)
. 2019.03.26 18:51:53 - DNS of a network adapter forced (iPhone USB, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:51:54 - DNS of a network adapter forced (Wi-Fi, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:51:56 - DNS of a network adapter forced (Bluetooth PAN, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:51:57 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.29.194.1, fde6:7a:7d20:19c2::1 to 10.26.158.1)
. 2019.03.26 18:51:57 - Routes, added a new route, 193.37.254.3 for gateway 10.26.158.1
. 2019.03.26 18:51:57 - Unable to compute route for 2a0d:5600:2:4:557:907e:7abb:8b73: IPv6 VPN gateway not available.
. 2019.03.26 18:51:57 - Flushing DNS
! 2019.03.26 18:51:58 - Connected.
. 2019.03.26 18:51:58 - OpenVPN > Initialization Sequence Completed
I don't see what version of Eddie you are using (or I missed it). Have you tried using the latest experimental version?
Edited ... by giganerd
Edited the quote to apply LOG format to the logs
don't see how you can blame a VPN provider for something like this.
sleep mode for windows and Mac os is extremely unreliable and then expecting a VPN provider to automatically reconnect is...,
have you tried tunnelblick?
