gl7
how to define main Gateway for route outside tunnel problem with ZeroTier One
Hi, I am using routes > outside VPN tunnel feature, but i have problem recently after install ZeroTier One, which works like hamachi that create virtual local lan across internet. The eddie client seem to see the ZeroTier as gateway (ip as 25.255.255.254) instead of the actual gateway (192.168.0.1). As log:
With ZeroTier network adapter enabled:
. 2019.02.01 18:18:13 - Routes, remove 192.168.8.0/24 for gateway 25.255.255.254
After disable the ZeroTier network adapter, example of one of the ip that route outside VPN tunnel:
. 2019.02.01 18:18:20 - Routes, added a new route, 192.168.8.0/24 for gateway 192.168.0.1
As it route to the ZeroTier, which causes the IP not working as ZeroTier does not have internet connectivity.
I would like to know is there a way to define main gateway?
I tried manually choosing the "networking" > "interface used for connection" that linked to 192.168.0.1, but the route gateway still assign to 25.255.255.254. Which causing all the route outside ips not working.
