Not connected, Your IP: 216.73.216.248
vpn_usr
AirVPN OS X + Eddie- Login not working
Hi Just wondering if anyone can help with this:
I have successfully setup an account on the airvpn.org website.  If I then try to login using the same credentials, I keep getting a wrong login / password error.  I can logout and in to the website, but the Eddie client throws this error.
The only issue I can think of is that my username has an @ in it.  Is this critical?
thanks,
/me
On one OS X system where I installed Eddie it used the wrong keyboard layout. I have no idea why that happened, but it drove me crazy since the user name which didn't have any of the critical letters in it displayed fine. Try typing your password in the user name field where you can see it and check if everything looks as it should.
