rickyroshan
Eddie UI refuses to open!!
I recently got AirVPN and have used it successfully a few times before, but I've run into an issue where the UI version of Eddie won't open. When I run the .exe on Windows, the gray icon shows up on my taskbar, but vanishes after ~45 seconds (or immediately if I try to click on it). There's still an instance of the "Eddie - Windows UI" background task running, but no window ever opens, and I don't seem to actually connect to one of AirVPN's servers.
I dont have the answer to your problem, but tinker with the following:
Uninstall current non-working Eddie version, then
install a higher or lower version
If you look here , i remember seeing a thread about windows 10 tap problems. If nothing helps,can you setup a router to use AirVPN?
