philips
curl SSL certificate problem: self signed certificate in the certificate chain
Hi everybody,
Due to DPI (Deep Packet Inspection), I have to use SSL on port 443.
Since some days, I face to an error message with Eddie, and  when I look in the logs of Eddie, I have this line:
E 2018.10.23 23:30:11 - curl: (60) SSL certificate problem: self signed certificate in certificate chain
E 2018.10.23 23:30:11 -     More details here: https://curl.haxx.se/docs/sslcerts.html
E 2018.10.23 23:30:11 -     curl performs SSL certificate verification by default, using a "bundle"
E 2018.10.23 23:30:11 -     of Certificate Authority (CA) public keys (CA certs). If the default
E 2018.10.23 23:30:11 -     bundle file isn't adequate, you can specify an alternate file
E 2018.10.23 23:30:11 -     using the --cacert option.
E 2018.10.23 23:30:11 -     If this HTTPS server uses a certificate signed by a CA represented in
E 2018.10.23 23:30:11 -     the bundle, the certificate verification probably failed due to a
E 2018.10.23 23:30:11 -     problem with the certificate (it might be expired, or the name might
E 2018.10.23 23:30:11 -     not match the domain name in the URL).
E 2018.10.23 23:30:11 -     If you'd like to turn off curl's verification of the certificate, use
E 2018.10.23 23:30:11 -     the -k (or --insecure) option.
E 2018.10.23 23:30:11 -     HTTPS-proxy has similar options --proxy-cacert and --proxy-insecure.
I can still create a VPN connection, but I guess this is not usual.
So, if anyone knows why I get the message and how to solve it
