Shadow101
Linux Mint - AirVPN 2.16.3 - IvP6 Stuck
Dear All,
I am trying to switch over to Linux (due to Windows being an absolutely nightmare). I have been using an older AirVPN version without problem on Linux Mint. I updated to version 2.16.3 yesterday. However since doing this Eddie now connects to a server - Displays "Connecting to [server]". Then "Checking IvP4 Route". Then "Checking IvP6 Route" and gets stuck on this. It attempts to re-try this 3 times and then attempts to restart and try another server.
I have noticed that I can use certain servers (that presumably don't use IvP6) such as the UK's Algedi server. This is obviously limiting the servers I can use. If someone could help it would be much appreciated.
I have previously seen mentioned installing Eddie including the XML file. I however cannot find this on Linux Mint (found it on my Windows computer but this isn't really helpful). Also, I am not sure if this is relevant. But when I installed the new version of Eddie it did not update the old version and instead installed it on top. The old version was listed as "AirVPN" in Linux and the new as "Eddie - OpenVPN GUI". I have since uninstalled the old AirVPN but again could not find the XML file and it seems the user data from this file remains as I have not had to re-enter login information on the newly installed 2.16.3 version.
Logs are below:
Eddie System/Environment Report - 24/08/2018 14:47 UTC
Eddie version: 2.16.3
Eddie OS build: linux_x64
Eddie architecture: x64
OS type: Linux
OS name: Linux Mint 18.3 Sylvia \n \l
OS version: Linux HP-Wave 4.10.0-38-generic #42~16.04.1-Ubuntu SMP Tue Oct 10 16:32:20 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
OS architecture: x64
Mono /.Net Framework: 4.2.1 (Debian 4.2.1.102+dfsg2-7ubuntu4); Framework: v4.0.30319
OpenVPN driver: Found, /dev/net/tun
OpenVPN: 2.3.10 - OpenSSL 1.0.2g 1 Mar 2016, LZO 2.08 (/usr/sbin/openvpn)
SSH: OpenSSH_7.2p2 Ubuntu-4ubuntu2.4, OpenSSL 1.0.2g 1 Mar 2016 (/usr/bin/ssh)
SSL: stunnel 5.30 (/usr/bin/stunnel4)
curl: 7.47.0 (/usr/bin/curl)
Profile path: /home/home/.airvpn/default.xml
Data path: /home/home/.airvpn
Application path: /usr/lib/eddie-ui
Executable path: /usr/lib/eddie-ui/Eddie-UI.exe
Command line arguments: (5 args) path="/home/home/.airvpn" path.resources="/usr/share/eddie-ui" path.exec="/usr/bin/eddie-ui" console.mode="none" linux.dbus="unix:abstract=/tmp/dbus-xCWFND5D6f,guid=992464337c6be550e8793a895b802788"
Network Lock Active: Yes, Linux iptables
Connected to VPN: No
Detected DNS: 127.0.1.1
Test DNS IPv4: Ok
Test DNS IPv6: Ok
Test Ping IPv4: -1 ms
Test Ping IPv6: 102 ms
Test HTTP IPv4: Error:curl: (28) Connection timed out after 20000 milliseconds
Test HTTP IPv6: Error:curl: (28) Connection timed out after 20001 milliseconds
Test HTTPS: Error:curl: (7) Failed to connect to eddie.website port 443: Connection timed out
login: (omissis)
password: (omissis)
remember: True
key: (omissis)
connect: True
netlock: True
ipv6.mode: none
network.entry.iplayer: ipv6-ipv4
Logs:
. 2018.08.24 16:43:25 - Eddie version: 2.16.3 / linux_x64, System: Linux, Name: Linux Mint 18.3 Sylvia \n \l, Version: Linux HP-Wave 4.10.0-38-generic #42~16.04.1-Ubuntu SMP Tue Oct 10 16:32:20 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux, Mono/.Net: 4.2.1 (Debian 4.2.1.102+dfsg2-7ubuntu4); Framework: v4.0.30319
. 2018.08.24 16:43:25 - Reading options from /home/home/.airvpn/default.xml
. 2018.08.24 16:43:26 - Command line arguments (5): path="/home/home/.airvpn" path.resources="/usr/share/eddie-ui" path.exec="/usr/bin/eddie-ui" console.mode="none" linux.dbus="unix:abstract=/tmp/dbus-xCWFND5D6f,guid=992464337c6be550e8793a895b802788"
. 2018.08.24 16:43:26 - Profile path: /home/home/.airvpn/default.xml
. 2018.08.24 16:43:27 - OpenVPN Driver - Found, /dev/net/tun
. 2018.08.24 16:43:27 - OpenVPN - Version: 2.3.10 - OpenSSL 1.0.2g 1 Mar 2016, LZO 2.08 (/usr/sbin/openvpn)
. 2018.08.24 16:43:27 - SSH - Version: OpenSSH_7.2p2 Ubuntu-4ubuntu2.4, OpenSSL 1.0.2g 1 Mar 2016 (/usr/bin/ssh)
. 2018.08.24 16:43:27 - SSL - Version: stunnel 5.30 (/usr/bin/stunnel4)
. 2018.08.24 16:43:27 - curl - Version: 7.47.0 (/usr/bin/curl)
. 2018.08.24 16:43:27 - Certification Authorities: /usr/share/eddie-ui/cacert.pem
W 2018.08.24 16:43:27 - Recovery. Unexpected crash?
. 2018.08.24 16:43:27 - Routes, removed a route previously added, 217.151.98.163 for gateway 10.4.0.1
. 2018.08.24 16:43:27 - DNS of the system restored to original settings (Rename method)
! 2018.08.24 16:43:27 - Deactivation of Network Lock
! 2018.08.24 16:43:27 - Activation of Network Lock - Linux iptables
. 2018.08.24 16:43:27 - Updating systems & servers data ...
I 2018.08.24 16:43:37 - Session starting.
I 2018.08.24 16:43:37 - Checking authorization ...
! 2018.08.24 16:43:37 - Connecting to Alderamin (Austria, Vienna)
. 2018.08.24 16:43:38 - OpenVPN > OpenVPN 2.3.10 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [iPv6] built on Jun 22 2017
. 2018.08.24 16:43:38 - OpenVPN > library versions: OpenSSL 1.0.2g 1 Mar 2016, LZO 2.08
. 2018.08.24 16:43:38 - Connection to OpenVPN Management Interface
. 2018.08.24 16:43:38 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.08.24 16:43:38 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2018.08.24 16:43:38 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.08.24 16:43:38 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.08.24 16:43:38 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2018.08.24 16:43:38 - OpenVPN > UDPv6 link local: [undef]
. 2018.08.24 16:43:38 - OpenVPN > UDPv6 link remote: [AF_INET6]2001:ac8:29:5:2a4b:7bb6:475d:f0f4:443
. 2018.08.24 16:43:38 - OpenVPN > TLS: Initial packet from [AF_INET6]2001:ac8:29:5:2a4b:7bb6:475d:f0f4:443, sid=b9015ea5 1de2dce7
. 2018.08.24 16:43:38 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.08.24 16:43:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.08.24 16:43:38 - OpenVPN > Validating certificate key usage
. 2018.08.24 16:43:38 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2018.08.24 16:43:38 - OpenVPN > VERIFY KU OK
. 2018.08.24 16:43:38 - OpenVPN > Validating certificate extended key usage
. 2018.08.24 16:43:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.08.24 16:43:38 - OpenVPN > VERIFY EKU OK
. 2018.08.24 16:43:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alderamin, emailAddress=info@airvpn.org
. 2018.08.24 16:43:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2018.08.24 16:43:38 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.08.24 16:43:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2018.08.24 16:43:38 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.08.24 16:43:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.08.24 16:43:38 - OpenVPN > [Alderamin] Peer Connection Initiated with [AF_INET6]2001:ac8:29:5:2a4b:7bb6:475d:f0f4:443
. 2018.08.24 16:43:40 - OpenVPN > SENT CONTROL [Alderamin]: 'PUSH_REQUEST' (status=1)
. 2018.08.24 16:43:40 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.5.244.1,route-gateway 10.5.244.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.5.244.250 255.255.255.0,peer-id 1'
. 2018.08.24 16:43:40 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.08.24 16:43:40 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2018.08.24 16:43:40 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.08.24 16:43:40 - OpenVPN > OPTIONS IMPORT: route options modified
. 2018.08.24 16:43:40 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.08.24 16:43:40 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.08.24 16:43:40 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.08.24 16:43:40 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561
. 2018.08.24 16:43:40 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=wlp2s0 HWADDR=10:f0:05:04:ef:d4
. 2018.08.24 16:43:40 - OpenVPN > TUN/TAP device tun0 opened
. 2018.08.24 16:43:40 - OpenVPN > TUN/TAP TX queue length set to 100
. 2018.08.24 16:43:40 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2018.08.24 16:43:40 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500
. 2018.08.24 16:43:40 - OpenVPN > /sbin/ip addr add dev tun0 10.5.244.250/24 broadcast 10.5.244.255
. 2018.08.24 16:43:44 - Systems & servers data update completed
. 2018.08.24 16:43:45 - OpenVPN > ROUTE remote_host protocol differs from tunneled
. 2018.08.24 16:43:45 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.5.244.1
. 2018.08.24 16:43:45 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.5.244.1
. 2018.08.24 16:43:45 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup
. 2018.08.24 16:43:45 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
. 2018.08.24 16:43:45 - Routes, added a new route, 185.9.19.107 for gateway 10.5.244.1
. 2018.08.24 16:43:45 - Unable to compute route for 2001:ac8:29:5:b8b5:994b:e1ff:20e9: IPv6 VPN gateway not available.
. 2018.08.24 16:43:45 - Flushing DNS
I 2018.08.24 16:43:46 - Checking route IPv4
I 2018.08.24 16:43:46 - Checking route IPv6
. 2018.08.24 15:44:09 - curl: (28) Connection timed out after 20001 milliseconds
. 2018.08.24 15:44:09 - Checking route (2° try)
. 2018.08.24 15:44:30 - curl: (28) Connection timed out after 20001 milliseconds
. 2018.08.24 15:44:30 - Checking route (3° try)
. 2018.08.24 15:44:52 - curl: (28) Connection timed out after 20001 milliseconds
E 2018.08.24 15:44:52 - Checking route IPv6 failed.
. 2018.08.24 15:44:52 - OpenVPN > Initialization Sequence Completed
! 2018.08.24 15:44:52 - Disconnecting
. 2018.08.24 15:44:52 - Routes, removed a route previously added, 185.9.19.107 for gateway 10.5.244.1
. 2018.08.24 15:44:52 - Sending management termination signal
. 2018.08.24 15:44:52 - Management - Send 'signal SIGTERM'
. 2018.08.24 15:44:53 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2018.08.24 15:44:53 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.08.24 15:44:53 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.08.24 15:44:57 - OpenVPN > /sbin/ip route del 0.0.0.0/1
. 2018.08.24 15:44:57 - OpenVPN > /sbin/ip route del 128.0.0.0/1
. 2018.08.24 15:44:57 - OpenVPN > Closing TUN/TAP interface
. 2018.08.24 15:44:57 - OpenVPN > /sbin/ip addr del dev tun0 10.5.244.250/24
. 2018.08.24 15:44:57 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2018.08.24 15:44:57 - Connection terminated.
. 2018.08.24 15:44:57 - DNS of the system restored to original settings (Rename method)
I 2018.08.24 15:45:00 - Checking authorization ...
! 2018.08.24 15:45:00 - Connecting to Alderamin (Austria, Vienna)
. 2018.08.24 15:45:00 - OpenVPN > OpenVPN 2.3.10 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [iPv6] built on Jun 22 2017
. 2018.08.24 15:45:00 - OpenVPN > library versions: OpenSSL 1.0.2g 1 Mar 2016, LZO 2.08
. 2018.08.24 15:45:00 - Connection to OpenVPN Management Interface
. 2018.08.24 15:45:00 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.08.24 15:45:00 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2018.08.24 15:45:00 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.08.24 15:45:00 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.08.24 15:45:00 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2018.08.24 15:45:00 - OpenVPN > UDPv6 link local: [undef]
. 2018.08.24 15:45:00 - OpenVPN > UDPv6 link remote: [AF_INET6]2001:ac8:29:5:2a4b:7bb6:475d:f0f4:443
. 2018.08.24 15:45:00 - OpenVPN > TLS: Initial packet from [AF_INET6]2001:ac8:29:5:2a4b:7bb6:475d:f0f4:443, sid=5b2da4e7 160a3bd0
. 2018.08.24 15:45:00 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.08.24 15:45:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.08.24 15:45:00 - OpenVPN > Validating certificate key usage
. 2018.08.24 15:45:00 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2018.08.24 15:45:00 - OpenVPN > VERIFY KU OK
. 2018.08.24 15:45:00 - OpenVPN > Validating certificate extended key usage
. 2018.08.24 15:45:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.08.24 15:45:00 - OpenVPN > VERIFY EKU OK
. 2018.08.24 15:45:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alderamin, emailAddress=info@airvpn.org
. 2018.08.24 15:45:01 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2018.08.24 15:45:01 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.08.24 15:45:01 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2018.08.24 15:45:01 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.08.24 15:45:01 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.08.24 15:45:01 - OpenVPN > [Alderamin] Peer Connection Initiated with [AF_INET6]2001:ac8:29:5:2a4b:7bb6:475d:f0f4:443
. 2018.08.24 15:45:03 - OpenVPN > SENT CONTROL [Alderamin]: 'PUSH_REQUEST' (status=1)
. 2018.08.24 15:45:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.5.244.1,route-gateway 10.5.244.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.5.244.250 255.255.255.0,peer-id 1'
. 2018.08.24 15:45:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.08.24 15:45:03 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2018.08.24 15:45:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.08.24 15:45:03 - OpenVPN > OPTIONS IMPORT: route options modified
. 2018.08.24 15:45:03 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.08.24 15:45:03 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.08.24 15:45:03 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.08.24 15:45:03 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561
. 2018.08.24 15:45:03 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=wlp2s0 HWADDR=10:f0:05:04:ef:d4
. 2018.08.24 15:45:03 - OpenVPN > TUN/TAP device tun0 opened
. 2018.08.24 15:45:03 - OpenVPN > TUN/TAP TX queue length set to 100
. 2018.08.24 15:45:03 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2018.08.24 15:45:03 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500
. 2018.08.24 15:45:03 - OpenVPN > /sbin/ip addr add dev tun0 10.5.244.250/24 broadcast 10.5.244.255
. 2018.08.24 15:45:08 - OpenVPN > ROUTE remote_host protocol differs from tunneled
. 2018.08.24 15:45:08 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.5.244.1
. 2018.08.24 15:45:08 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.5.244.1
. 2018.08.24 15:45:08 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup
. 2018.08.24 15:45:08 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
. 2018.08.24 15:45:08 - Routes, added a new route, 185.9.19.107 for gateway 10.5.244.1
. 2018.08.24 15:45:08 - Unable to compute route for 2001:ac8:29:5:b8b5:994b:e1ff:20e9: IPv6 VPN gateway not available.
. 2018.08.24 15:45:08 - Flushing DNS
I 2018.08.24 15:45:08 - Checking route IPv4
I 2018.08.24 15:45:09 - Checking route IPv6
. 2018.08.24 15:45:29 - curl: (28) Connection timed out after 20001 milliseconds
. 2018.08.24 15:45:29 - OpenVPN > Initialization Sequence Completed
! 2018.08.24 15:45:29 - Disconnecting
. 2018.08.24 15:45:29 - Routes, removed a route previously added, 185.9.19.107 for gateway 10.5.244.1
. 2018.08.24 15:45:29 - Sending management termination signal
. 2018.08.24 15:45:29 - Management - Send 'signal SIGTERM'
. 2018.08.24 15:45:29 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.08.24 15:45:29 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.08.24 15:45:34 - OpenVPN > /sbin/ip route del 0.0.0.0/1
. 2018.08.24 15:45:34 - OpenVPN > /sbin/ip route del 128.0.0.0/1
. 2018.08.24 15:45:34 - OpenVPN > Closing TUN/TAP interface
. 2018.08.24 15:45:34 - OpenVPN > /sbin/ip addr del dev tun0 10.5.244.250/24
. 2018.08.24 15:45:34 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2018.08.24 15:45:34 - Connection terminated.
. 2018.08.24 15:45:34 - DNS of the system restored to original settings (Rename method)
I 2018.08.24 15:45:34 - Cancel requested.
! 2018.08.24 15:45:34 - Session terminated.
Network Interfaces and Routes:
"support_ipv4": true,
"support_ipv6": true,
"routes": [
"address": "0.0.0.0\/0",
"gateway": "192.168.0.1",
"interface": "wlp2s0",
"metric": "600"
"address": "::\/0",
"gateway": "fe80::9221:6ff:feb2:f504",
"metric": "600"
"interfaces": [
"friendly": "lo",
"id": "lo",
"name": "lo",
"description": "lo",
"type": "Loopback",
"status": "Unknown",
"bytes_received": "290718",
"bytes_sent": "290718",
"ips": [
"127.0.0.1",
"::1"
"gateways": [],
"bind": true
"friendly": "enp3s0",
"id": "enp3s0",
"name": "enp3s0",
"description": "enp3s0",
"type": "Ethernet",
"status": "Down",
"bytes_received": "0",
"bytes_sent": "0",
"ips": [],
"gateways": [],
"bind": false
"friendly": "wlp2s0",
"id": "wlp2s0",
"name": "wlp2s0",
"description": "wlp2s0",
"type": "Wireless80211",
"status": "Up",
"bytes_received": "1102259",
"bytes_sent": "407718",
"ips": [
"192.168.0.35",
"fd17:74a:b2d:0:ade4:fccb:e2d6:aa36",
"fd17:74a:b2d:0:7d9d:96da:a145:aa68",
"2a02:c7f:1e6d:ea00:ade4:fccb:e2d6:aa36",
"2a02:c7f:1e6d:ea00:4671:ac3:5a52:eb1a",
"fe80::275e:3f7f:c7f8:4cf6"
"gateways": [
"192.168.0.1",
"bind": true
"ipv4-default-gateway": "192.168.0.1",
"ipv4-default-interface": "wlp2s0",
"ipv6-default-gateway": "fe80::9221:6ff:feb2:f504",
"ipv6-default-interface": "wlp2s0"
UID: 0
Run as normal user: True; ID:1000; Name:home
ip addr show:
1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp3s0: mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether a0:8c:fd:d1:70:90 brd ff:ff:ff:ff:ff:ff
3: wlp2s0: mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 10:f0:05:04:ef:d4 brd ff:ff:ff:ff:ff:ff
inet 192.168.0.35/24 brd 192.168.0.255 scope global dynamic wlp2s0
valid_lft 86125sec preferred_lft 86125sec
inet6 fd17:74a:b2d:0:ade4:fccb:e2d6:aa36/64 scope global temporary dynamic
valid_lft 604527sec preferred_lft 86063sec
inet6 fd17:74a:b2d:0:7d9d:96da:a145:aa68/64 scope global mngtmpaddr noprefixroute
inet6 2a02:c7f:1e6d:ea00:ade4:fccb:e2d6:aa36/64 scope global temporary dynamic
valid_lft 1972sec preferred_lft 1972sec
inet6 2a02:c7f:1e6d:ea00:4671:ac3:5a52:eb1a/64 scope global mngtmpaddr noprefixroute dynamic
inet6 fe80::275e:3f7f:c7f8:4cf6/64 scope link
ip link show:
1: lo: mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: enp3s0: mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 1000
3: wlp2s0: mtu 1500 qdisc mq state UP mode DORMANT group default qlen 1000
ip -4 route show:
default via 192.168.0.1 dev wlp2s0 proto static metric 600
169.254.0.0/16 dev wlp2s0 scope link metric 1000
192.168.0.0/24 dev wlp2s0 proto kernel scope link src 192.168.0.35 metric 600
ip -6 route show:
2a02:c7f:1e6d:ea00::/64 dev wlp2s0 proto kernel metric 256 expires 1971sec pref medium
fd17:74a:b2d::/64 dev wlp2s0 proto kernel metric 256 expires 604526sec pref medium
fe80::/64 dev wlp2s0 proto kernel metric 256 pref medium
default via fe80::9221:6ff:feb2:f504 dev wlp2s0 proto static metric 600 pref medium
,multicast,up,lower_up>,broadcast,multicast,up>,up,lower_up>,multicast,up,lower_up>,broadcast,multicast,up>,up,lower_up>
Thanks for any help!
I don't really know anything, but have you tried Settings -> Networking and change "Layer IPv6" or other things in there?
EDIT: Or change "Internet Protocol used for connection" to IPv4, IPv6. I think I had some problems if it was other way around.
Dear Keikari,
Thank you for your response.
I tried messing around with all these settings but it has not worked.
It seems that any server that uses IPv6 gets stuck. I am only assuming this from looking at the logs as I try to connect to different servers. Ones that say Flushing DNS" > "Checking IPv4 > Connected" work. Ones that say "Flushing DNS > Checking IvP4 > Checking IPv6" get stuck.
If anyone has any other suggesting it would be much appreciated. I really want to continue to use Linux but this is severely limiting the number of servers I can connect too.
Thank you.
Dear Keikari,
Hello, there was another thread on this some time recently. I had this experience with Eddie for a bit, and I run on Mint as well (atm).  Hope this helps:  https://airvpn.org/topic/28638-wont-connect-at-checking-ipv6/?do=findComment&comment=77248
You may have checked something in Network Manager by accidentas well. This program is a little bit buggy, as I'm sure Airvpn staff can attest to. Make sure "required to connect to internet" settings in NM are not checked. Check syslog to make sure something else isn't going on in real time, for instance, MAC address spoofing not working right. Try deleting the connection in Network Manager and makinga fresh one.
