Moat
Howto: Setup airvpn on DD-WRT, refreshed guide.
On 12/14/2025 at 1:25 AM, Ziutek131 said:
Good morning, I have a Linksys 1200 and since yesterday I haven't been able to connect and I haven't changed anything, I also downloaded the configuration files again and still nothing, something must have changed?
I am in the same boat, I have a TP-Link C9 v1 that was working fine until last week. It stays Re-connecting, I have tiried multiple changes in the configuration and cannot make it work.
Could anyone be so kind and share a working configuration, please?
The picture in the step 3 of the first post is not showing, maybe is just me.
December 23 2025 this "Re-connecting..." dance started on tomato routers. Now I see it also affected dd-wrt.
Dec 23 18:51:30 unknown daemon.notice openvpn[9066]: TCP/UDP: Closing socket
Dec 23 18:51:30 unknown daemon.notice openvpn[9066]: SIGUSR1[soft,tls-error] received, process restarting
Dec 23 18:51:30 unknown daemon.notice openvpn[9066]: Restart pause, 2 second(s)
Be advised that the servers started pushing IPv6 recently (in the PUSH_REPLY there now is redirect-gateway ipv6). The guide references v4 only, so if v6 is disabled in the system OpenVPN will fail to connect. You must explicitly filter out all pushed IPv6 options, see:
Or adapt the guide to include v6.
Hi All,
I have an Asus Router with custom Merlin software, I have been using the generator to create wireguard servers to mostly Europe. This setup has been working well up to 2026. No matter what wireguard server I use I just get Stopped when having this setup as enabled.
