mwm
Possible iPlayer Workaround
I have been searching for a solution to unblock iPlayer for a while now and I have found a way to watch it while still being connected to a VPN through Eddie.
I recently found out that Eddie supports third party OVPN files. I already run my own VPN server for personal use on a cheap VPS so I added the OVPN file from my server to Eddie and connected and iPlayer worked!
I know this isn't the easiest solution but it's still a solution. It also might unblock things like Netflix and Prime Video.
Hope this helps someone
Script for OpenVPN server: https://github.com/Nyr/openvpn-install
VPS Provider: https://www.vmhaus.com/
Edit: If you're going to give this ago, you want to choose a lesser known VPS service as theres a lesser chance of the IP getting blocked as soon
