Not connected, Your IP: 216.73.216.36
the1lemming
Unable to sign in Work WiFi and Council Free WiFi
Hello
Is there any way that I can use airvpn to sign into my work guest WiFi?
And is there any way to sign into the free WiFi run by the local council while your and about town shopping?
When I try to sign on the OpenVPN just keeps connecting but never does, when I am signed into the WiFi. And when I do connect to OpenVPN first, I can never connect to the WiFi.
I am using android and the OpenVPN app.
I have tried creating a key using port 80 and 443 but no joy.
Some WiFi networks block OpenVPN, you can try different ports/connection methods, but I doubt they'll work.
Go to this page: https://airvpn.org/generator/ and select "Advanced Mode" where you can see all the available options. In theory one should work. Did you try SSL over port 443? That masks your connection as if it was regular HTTPS so that should work.
May I ask how I select SSL when using the configurator from an android phone to create a key?
I can work out how to select a port but the SSL is beyond me.
Cheers
Cheers
Hi - see the following images.
Try various combinations until you find one that works. There are loads of protocols/ports to choose from, so it may be worth making 5-10 configs and going through them 1 by 1 on your device. Please note Android doesn't support SSL, but you can still try the others
