darrenn
Asus RT-N12, DD-WRT, and OpenVPN
Followed the settings from the tutorial on the site. Double chcked them with the conf file. Can't seem to figure out wahts going wrong here. I am not getting a connection though. Here is my status for OpenVPN in DD-WRT. I am running build 18777.
State
Server: : Local Address: Remote Address: Client: CONNECTED: SUCCESS Local Address: 10.4.14.166 Remote Address:
Status
Log
Serverlog Clientlog 20120601 00:16:06 I LZO compression initialized
20120601 00:16:06 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
20120601 00:16:06 Socket Buffers: R=[114688->131072] S=[114688->131072]
20120601 00:16:06 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
20120601 00:16:06 Local Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-client'
20120601 00:16:06 Expected Remote Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-server'
20120601 00:16:06 Local Options hash (VER=V4): '22188c5b'
20120601 00:16:06 Expected Remote Options hash (VER=V4): 'a8f55717'
20120601 00:16:06 I UDPv4 link local: [undef]
20120601 00:16:06 I UDPv4 link remote: 95.211.169.3:443
20120601 00:16:06 TLS: Initial packet from 95.211.169.3:443 sid=bc9f7e8f f346dae3
20120601 00:16:07 VERIFY OK: depth=1 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
20120601 00:16:07 VERIFY OK: nsCertType=SERVER
20120601 00:16:07 VERIFY OK: depth=0 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
20120601 00:16:10 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
20120601 00:16:10 NOTE: --mute triggered...
20120601 00:16:17 4 variation(s) on previous 5 message(s) suppressed by --mute
20120601 00:16:17 I [server] Peer Connection Initiated with 95.211.169.3:443
20120601 00:16:19 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
20120601 00:16:19 PUSH: Received control message: 'PUSH_REPLY redirect-gateway def1 dhcp-option DNS 10.4.0.1 comp-lzo no route 10.4.0.1 topology net30 ping 10 ping-restart 120 ifconfig 10.4.14.166 10.4.14.165'
20120601 00:16:19 OPTIONS IMPORT: timers and/or timeouts modified
20120601 00:16:19 OPTIONS IMPORT: LZO parms modified
20120601 00:16:19 OPTIONS IMPORT: --ifconfig/up options modified
20120601 00:16:19 NOTE: --mute triggered...
20120601 00:16:19 2 variation(s) on previous 5 message(s) suppressed by --mute
20120601 00:16:19 I Preserving previous TUN/TAP instance: tun1
20120601 00:16:19 I Initialization Sequence Completed
20120601 00:17:06 MANAGEMENT: Client connected from 127.0.0.1:5001
20120601 00:17:06 D MANAGEMENT: CMD 'state'
20120601 00:17:06 MANAGEMENT: Client disconnected
20120601 00:17:06 D MANAGEMENT: CMD 'log 500'
20120601 00:17:10 MANAGEMENT: Client connected from 127.0.0.1:5001
20120601 00:17:10 D MANAGEMENT: CMD 'state'
20120601 00:17:10 MANAGEMENT: Client disconnected
20120601 00:17:11 MANAGEMENT: Client connected from 127.0.0.1:5001
20120601 00:17:11 D MANAGEMENT: CMD 'log 500'
19700101 00:00:00
@darrenn
I had trouble with builds in the range you are using and reverted to earlier builds which worked more reliably ... that being said the builds back in the 14xxx did not have the 'advanced' portion of the OpenVpn client screen and thus cannot be used. Also look at this note ........
http://svn.dd-wrt.com:8000/ticket/1868
altho that has not been a problem for me ... Cheers
