Not connected, Your IP: 216.73.216.54
Cyssero
Route gateway is not reachable on any active network adapters
Searched these forums and on the internet, cannot find anything to help me solve this issue. Still waiting to hear back from this site's support team, but maybe someone on here knows how to fix this.  I've tried the following, based on what someone posted in another thread: tried with and without network lock, switched to different protocols, and tried different DNS servers based off the link provided.  Here is the log of my most recent attempt:
Eddie System/Environment Report - 12/5/2017 9:18 PM UTC
Eddie version: 2.13.6
Eddie OS build: windows_x64
Eddie architecture: x64
OS type: Windows
OS name: Windows 10 Home
OS version: Microsoft Windows NT 10.0.16299.0
OS architecture: x64
Mono /.Net Framework: v4.0.30319
OpenVPN driver: TAP-Windows Adapter V9, version 9.21.2
OpenVPN: 2.4.3 - OpenSSL 1.0.2l  25 May 2017, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
curl: 7.54.1 (C:\Program Files\AirVPN\curl.exe)
Profile path: C:\Users\frazi\AppData\Local\AirVPN\AirVPN.xml
Data path: C:\Users\frazi\AppData\Local\AirVPN
Application path: C:\Program Files\AirVPN
Executable path: C:\Program Files\AirVPN\AirVPN.exe
Command line arguments: (1 args) path="home"
Network Lock Active: No
Connected to VPN: No
Detected DNS: 192.168.1.1
Test DNS IPv4: Ok
Test DNS IPv6: Failed
Test HTTP: Status: HTTP/1.1 200 OK
 - Headers: server:nginx;date:Tue, 05 Dec 2017 21:18:48 GMT;content-type:text/html; charset=UTF-8;transfer-encoding:chunked;connection:keep-alive;cache-control:no-store, no-cache, must-revalidate, max-age=0;cache-control:post-check=0, pre-check=0;pragma:no-cache;strict-transport-security:max-age=31536000; includeSubdomains; preload;x-frame-options:SAMEORIGIN;x-xss-protection:1; mode=block;x-content-type-options:nosniff;referrer-policy:strict-origin-when-cross-origin;x-filter:limit; - Body (8 bytes): Success.
Test HTTPS: Status: HTTP/2 200
 - Headers: server:nginx;date:Tue, 05 Dec 2017 21:18:49 GMT;content-type:text/html; charset=UTF-8;cache-control:no-store, no-cache, must-revalidate, max-age=0;cache-control:post-check=0, pre-check=0;pragma:no-cache;strict-transport-security:max-age=31536000; includeSubdomains; preload;x-frame-options:SAMEORIGIN;x-xss-protection:1; mode=block;x-content-type-options:nosniff;referrer-policy:strict-origin-when-cross-origin;x-filter:limit; - Body (8 bytes): Success.
login: (omissis)
password: (omissis)
remember: True
dns.servers: 66.70.211.246,69.195.152.204,172.98.193.42,167.160.173.238
Logs:
. 2017.12.05 16:00:38 - OpenVPN > Validating certificate extended key usage
. 2017.12.05 16:00:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.12.05 16:00:38 - OpenVPN > VERIFY EKU OK
. 2017.12.05 16:00:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.12.05 16:00:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.12.05 16:00:38 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.254.90.252:1194
. 2017.12.05 16:00:39 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.12.05 16:00:39 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.8.228 255.255.0.0'
. 2017.12.05 16:00:39 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.12.05 16:00:39 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.12.05 16:00:39 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.12.05 16:00:39 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.12.05 16:00:39 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.12.05 16:00:39 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.12.05 16:00:39 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.12.05 16:00:39 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:00:39 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.12.05 16:00:39 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:00:39 - OpenVPN > interactive service msg_channel=0
. 2017.12.05 16:00:39 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=4 HWADDR=4c:cc:6a:d3:da:67
. 2017.12.05 16:00:39 - OpenVPN > open_tun
. 2017.12.05 16:00:39 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{9B86EF66-5402-4D29-8A41-D0CCC932FA98}.tap
. 2017.12.05 16:00:39 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.12.05 16:00:39 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.8.228/255.255.0.0 [sUCCEEDED]
. 2017.12.05 16:00:39 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.8.228/255.255.0.0 on interface {9B86EF66-5402-4D29-8A41-D0CCC932FA98} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2017.12.05 16:00:39 - OpenVPN > Successful ARP Flush on interface [15] {9B86EF66-5402-4D29-8A41-D0CCC932FA98}
. 2017.12.05 16:00:39 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.12.05 16:00:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:00:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:00:44 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:00:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:00:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:00:49 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:00:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:00:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:00:50 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:00:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:00:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:00:52 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:00:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:00:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:00:53 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:00:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:00:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:00:54 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:00:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:00:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:00:55 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:00:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:00:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:00:56 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:00:58 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:00:58 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:00:58 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:00:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:00:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:00:59 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:01:00 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:01:00 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:01:00 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:01:01 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:01:01 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:01:01 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:01:02 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:01:02 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:01:02 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:01:03 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:01:03 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:01:03 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:01:04 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:01:04 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:01:04 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:01:06 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:01:06 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:01:06 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:01:07 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:01:07 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:01:07 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:01:08 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:01:08 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:01:08 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:01:09 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:01:09 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:01:09 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:01:10 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:01:10 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:01:10 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:01:11 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:01:11 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:01:11 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:01:12 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:01:12 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:01:12 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:01:13 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:01:13 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:01:13 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:01:14 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:01:14 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 104.254.90.252 MASK 255.255.255.255 192.168.1.1
. 2017.12.05 16:01:14 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2017.12.05 16:01:14 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.12.05 16:01:14 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
W 2017.12.05 16:01:14 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.50.0.1
. 2017.12.05 16:01:14 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2017.12.05 16:01:14 - OpenVPN > Route addition fallback to route.exe
. 2017.12.05 16:01:14 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2017.12.05 16:01:14 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2017.12.05 16:01:14 - OpenVPN > SYSTEM ROUTING TABLE
. 2017.12.05 16:01:14 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=4 t=4 pr=3 a=4911 h=0 m=26/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 0.0.0.0 128.0.0.0 10.50.0.1 p=0 i=4 t=4 pr=3 a=450 h=0 m=26/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 38.132.107.146 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5402 h=0 m=26/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 38.132.127.74 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5366 h=0 m=26/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 104.254.90.202 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=450 h=0 m=25/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 104.254.90.252 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=25/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=12938 h=0 m=331/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=12938 h=0 m=331/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 128.0.0.0 128.0.0.0 10.50.0.1 p=0 i=4 t=4 pr=3 a=450 h=0 m=26/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.117.11 p=0 i=15 t=3 pr=2 a=1036 h=0 m=291/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 169.254.117.11 255.255.255.255 169.254.117.11 p=0 i=15 t=3 pr=2 a=1036 h=0 m=291/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.117.11 p=0 i=15 t=3 pr=2 a=1036 h=0 m=291/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 185.65.135.137 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=4954 h=0 m=26/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 185.65.135.140 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5002 h=0 m=26/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 185.65.135.145 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=4906 h=0 m=26/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.159 p=0 i=4 t=3 pr=2 a=12917 h=0 m=281/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 192.168.1.159 255.255.255.255 192.168.1.159 p=0 i=4 t=3 pr=2 a=12917 h=0 m=281/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.159 p=0 i=4 t=3 pr=2 a=12917 h=0 m=281/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=12938 h=0 m=331/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.159 p=0 i=4 t=3 pr=2 a=12924 h=0 m=281/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.117.11 p=0 i=15 t=3 pr=2 a=1046 h=0 m=291/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.159 p=0 i=4 t=3 pr=2 a=12924 h=0 m=281/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.117.11 p=0 i=15 t=3 pr=2 a=1046 h=0 m=291/0/0/0/0
. 2017.12.05 16:01:14 - OpenVPN > SYSTEM ADAPTER LIST
. 2017.12.05 16:01:14 - OpenVPN > Realtek PCIe GBE Family Controller
. 2017.12.05 16:01:14 - OpenVPN >   Index = 4
. 2017.12.05 16:01:14 - OpenVPN >   GUID = {CB15EFF2-6641-4EAF-AE9F-1232CFE441C6}
. 2017.12.05 16:01:14 - OpenVPN >   IP = 192.168.1.159/255.255.255.0
. 2017.12.05 16:01:14 - OpenVPN >   MAC = 4c:cc:6a:d3:da:67
. 2017.12.05 16:01:14 - OpenVPN >   GATEWAY = 192.168.1.1/255.255.255.255
. 2017.12.05 16:01:14 - OpenVPN >   DHCP SERV = 192.168.1.1/255.255.255.255
. 2017.12.05 16:01:14 - OpenVPN >   DHCP LEASE OBTAINED = Tue Dec 05 12:25:56 2017
. 2017.12.05 16:01:14 - OpenVPN >   DHCP LEASE EXPIRES  = Wed Dec 06 12:25:56 2017
. 2017.12.05 16:01:14 - OpenVPN >   DNS SERV = 192.168.1.1/255.255.255.255
. 2017.12.05 16:01:14 - OpenVPN > TunnelBear Adapter V9
. 2017.12.05 16:01:14 - OpenVPN >   Index = 5
. 2017.12.05 16:01:14 - OpenVPN >   GUID = {F9D11350-8244-4CEF-8CC9-53C915CEA077}
. 2017.12.05 16:01:14 - OpenVPN >   IP = 0.0.0.0/0.0.0.0
. 2017.12.05 16:01:14 - OpenVPN >   MAC = 00:ff:f9:d1:13:50
. 2017.12.05 16:01:14 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2017.12.05 16:01:14 - OpenVPN >   DHCP LEASE OBTAINED = Tue Dec 05 16:01:14 2017
. 2017.12.05 16:01:14 - OpenVPN >   DHCP LEASE EXPIRES  = Tue Dec 05 16:01:14 2017
. 2017.12.05 16:01:14 - OpenVPN > TAP-Windows Adapter V9
. 2017.12.05 16:01:14 - OpenVPN >   Index = 15
. 2017.12.05 16:01:14 - OpenVPN >   GUID = {9B86EF66-5402-4D29-8A41-D0CCC932FA98}
. 2017.12.05 16:01:14 - OpenVPN >   IP = 169.254.117.11/255.255.0.0
. 2017.12.05 16:01:14 - OpenVPN >   MAC = 00:ff:9b:86:ef:66
. 2017.12.05 16:01:14 - OpenVPN >   DHCP SERV = 0.0.0.0/255.255.255.255
. 2017.12.05 16:01:14 - Interface Ethernet 3 metric changed from Automatic to 3, layer IPv4
. 2017.12.05 16:01:14 - Interface Ethernet 3 metric changed from Automatic to 3, layer IPv6
. 2017.12.05 16:01:14 - DNS leak protection with packet filtering enabled.
. 2017.12.05 16:01:14 - Flushing DNS
. 2017.12.05 16:01:17 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
! 2017.12.05 16:01:17 - Disconnecting
. 2017.12.05 16:01:17 - Sending management termination signal
. 2017.12.05 16:01:17 - Management - Send 'signal SIGTERM'
. 2017.12.05 16:01:18 - Connection terminated.
. 2017.12.05 16:01:18 - DNS leak protection with packet filtering disabled.
. 2017.12.05 16:01:18 - Interface Ethernet 3 metric restored from 3 to Automatic, layer IPv4
. 2017.12.05 16:01:18 - Interface Ethernet 3 metric restored from 3 to Automatic, layer IPv6
I 2017.12.05 16:01:21 - Cancel requested.
. 2017.12.05 16:01:21 - IPv6 restored with packet filtering.
! 2017.12.05 16:01:21 - Session terminated.
! 2017.12.05 16:01:34 - Deactivation of Network Lock
I 2017.12.05 16:06:32 - Session starting.
. 2017.12.05 16:06:32 - IPv6 disabled with packet filtering.
I 2017.12.05 16:06:32 - Checking authorization ...
! 2017.12.05 16:06:32 - Connecting to Alhena (Canada, Toronto, Ontario)
. 2017.12.05 16:06:33 - OpenVPN > OpenVPN 2.4.3 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jun 23 2017
. 2017.12.05 16:06:33 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.12.05 16:06:33 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2017.12.05 16:06:33 - Connection to OpenVPN Management Interface
. 2017.12.05 16:06:33 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.12.05 16:06:33 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:06:33 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:06:33 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]162.219.176.4:1194
. 2017.12.05 16:06:33 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.12.05 16:06:33 - OpenVPN > Attempting to establish TCP connection with [AF_INET]162.219.176.4:1194 [nonblock]
. 2017.12.05 16:06:33 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.12.05 16:06:34 - OpenVPN > TCP connection established with [AF_INET]162.219.176.4:1194
. 2017.12.05 16:06:34 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2017.12.05 16:06:34 - OpenVPN > TCP_CLIENT link remote: [AF_INET]162.219.176.4:1194
. 2017.12.05 16:06:34 - OpenVPN > TLS: Initial packet from [AF_INET]162.219.176.4:1194, sid=13d7193d 0511488c
. 2017.12.05 16:06:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.12.05 16:06:34 - OpenVPN > VERIFY KU OK
. 2017.12.05 16:06:34 - OpenVPN > Validating certificate extended key usage
. 2017.12.05 16:06:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.12.05 16:06:34 - OpenVPN > VERIFY EKU OK
. 2017.12.05 16:06:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.12.05 16:06:34 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.12.05 16:06:34 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]162.219.176.4:1194
. 2017.12.05 16:06:36 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.12.05 16:06:36 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.0.41 255.255.0.0'
. 2017.12.05 16:06:36 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.12.05 16:06:36 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.12.05 16:06:36 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.12.05 16:06:36 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.12.05 16:06:36 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.12.05 16:06:36 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.12.05 16:06:36 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.12.05 16:06:36 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:06:36 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.12.05 16:06:36 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:06:36 - OpenVPN > interactive service msg_channel=0
. 2017.12.05 16:06:36 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=4 HWADDR=4c:cc:6a:d3:da:67
. 2017.12.05 16:06:36 - OpenVPN > open_tun
. 2017.12.05 16:06:36 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{9B86EF66-5402-4D29-8A41-D0CCC932FA98}.tap
. 2017.12.05 16:06:36 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.12.05 16:06:36 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.0.41/255.255.0.0 [sUCCEEDED]
. 2017.12.05 16:06:36 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.0.41/255.255.0.0 on interface {9B86EF66-5402-4D29-8A41-D0CCC932FA98} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2017.12.05 16:06:36 - OpenVPN > Successful ARP Flush on interface [15] {9B86EF66-5402-4D29-8A41-D0CCC932FA98}
. 2017.12.05 16:06:36 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.12.05 16:06:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:06:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:06:41 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:06:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:06:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:06:46 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:06:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:06:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:06:47 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:06:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:06:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:06:48 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:06:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:06:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:06:49 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:06:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:06:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:06:50 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:06:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:06:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:06:51 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:06:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:06:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:06:52 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:06:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:06:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:06:53 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:06:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:06:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:06:55 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:06:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:06:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:06:56 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:06:57 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:06:57 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:06:57 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:06:58 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:06:58 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:06:58 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:06:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:06:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:06:59 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:07:00 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:07:00 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:07:00 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:07:01 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:07:01 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:07:01 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:07:02 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:07:02 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:07:02 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:07:04 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:07:04 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:07:04 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:07:05 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:07:05 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:07:05 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:07:06 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:07:06 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:07:06 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:07:07 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:07:07 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:07:07 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:07:08 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:07:08 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:07:08 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:07:09 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:07:09 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:07:09 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:07:10 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:07:10 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:07:10 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:07:12 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:07:12 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 162.219.176.4 MASK 255.255.255.255 192.168.1.1
. 2017.12.05 16:07:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2017.12.05 16:07:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.12.05 16:07:12 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
W 2017.12.05 16:07:12 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.50.0.1
. 2017.12.05 16:07:12 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2017.12.05 16:07:12 - OpenVPN > Route addition fallback to route.exe
. 2017.12.05 16:07:12 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2017.12.05 16:07:12 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2017.12.05 16:07:12 - OpenVPN > SYSTEM ROUTING TABLE
. 2017.12.05 16:07:12 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=4 t=4 pr=3 a=5268 h=0 m=26/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 0.0.0.0 128.0.0.0 10.50.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 38.132.107.146 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5759 h=0 m=26/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 38.132.127.74 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5724 h=0 m=26/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 104.254.90.202 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=808 h=0 m=25/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=13296 h=0 m=331/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=13296 h=0 m=331/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 128.0.0.0 128.0.0.0 10.50.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 162.219.176.4 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=25/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.117.11 p=0 i=15 t=3 pr=2 a=1394 h=0 m=291/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 169.254.117.11 255.255.255.255 169.254.117.11 p=0 i=15 t=3 pr=2 a=1394 h=0 m=291/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.117.11 p=0 i=15 t=3 pr=2 a=1394 h=0 m=291/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 185.65.135.137 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5312 h=0 m=26/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 185.65.135.140 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5360 h=0 m=26/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 185.65.135.145 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5264 h=0 m=26/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.159 p=0 i=4 t=3 pr=2 a=13275 h=0 m=281/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 192.168.1.159 255.255.255.255 192.168.1.159 p=0 i=4 t=3 pr=2 a=13275 h=0 m=281/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.159 p=0 i=4 t=3 pr=2 a=13275 h=0 m=281/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=13296 h=0 m=331/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.159 p=0 i=4 t=3 pr=2 a=13281 h=0 m=281/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.117.11 p=0 i=15 t=3 pr=2 a=1404 h=0 m=291/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.159 p=0 i=4 t=3 pr=2 a=13281 h=0 m=281/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.117.11 p=0 i=15 t=3 pr=2 a=1404 h=0 m=291/0/0/0/0
. 2017.12.05 16:07:12 - OpenVPN > SYSTEM ADAPTER LIST
. 2017.12.05 16:07:12 - OpenVPN > Realtek PCIe GBE Family Controller
. 2017.12.05 16:07:12 - OpenVPN >   Index = 4
. 2017.12.05 16:07:12 - OpenVPN >   GUID = {CB15EFF2-6641-4EAF-AE9F-1232CFE441C6}
. 2017.12.05 16:07:12 - OpenVPN >   IP = 192.168.1.159/255.255.255.0
. 2017.12.05 16:07:12 - OpenVPN >   MAC = 4c:cc:6a:d3:da:67
. 2017.12.05 16:07:12 - OpenVPN >   GATEWAY = 192.168.1.1/255.255.255.255
. 2017.12.05 16:07:12 - OpenVPN >   DHCP SERV = 192.168.1.1/255.255.255.255
. 2017.12.05 16:07:12 - OpenVPN >   DHCP LEASE OBTAINED = Tue Dec 05 12:25:57 2017
. 2017.12.05 16:07:12 - OpenVPN >   DHCP LEASE EXPIRES  = Wed Dec 06 12:25:57 2017
. 2017.12.05 16:07:12 - OpenVPN >   DNS SERV = 192.168.1.1/255.255.255.255
. 2017.12.05 16:07:12 - OpenVPN > TunnelBear Adapter V9
. 2017.12.05 16:07:12 - OpenVPN >   Index = 5
. 2017.12.05 16:07:12 - OpenVPN >   GUID = {F9D11350-8244-4CEF-8CC9-53C915CEA077}
. 2017.12.05 16:07:12 - OpenVPN >   IP = 0.0.0.0/0.0.0.0
. 2017.12.05 16:07:12 - OpenVPN >   MAC = 00:ff:f9:d1:13:50
. 2017.12.05 16:07:12 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2017.12.05 16:07:12 - OpenVPN >   DHCP LEASE OBTAINED = Tue Dec 05 16:07:12 2017
. 2017.12.05 16:07:12 - OpenVPN >   DHCP LEASE EXPIRES  = Tue Dec 05 16:07:12 2017
. 2017.12.05 16:07:12 - OpenVPN > TAP-Windows Adapter V9
. 2017.12.05 16:07:12 - OpenVPN >   Index = 15
. 2017.12.05 16:07:12 - OpenVPN >   GUID = {9B86EF66-5402-4D29-8A41-D0CCC932FA98}
. 2017.12.05 16:07:12 - OpenVPN >   IP = 169.254.117.11/255.255.0.0
. 2017.12.05 16:07:12 - OpenVPN >   MAC = 00:ff:9b:86:ef:66
. 2017.12.05 16:07:12 - OpenVPN >   DHCP SERV = 0.0.0.0/255.255.255.255
. 2017.12.05 16:07:12 - Interface Ethernet 3 metric changed from Automatic to 3, layer IPv4
. 2017.12.05 16:07:12 - Interface Ethernet 3 metric changed from Automatic to 3, layer IPv6
. 2017.12.05 16:07:12 - DNS leak protection with packet filtering enabled.
. 2017.12.05 16:07:12 - Flushing DNS
. 2017.12.05 16:07:15 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
! 2017.12.05 16:07:15 - Disconnecting
. 2017.12.05 16:07:15 - Sending management termination signal
. 2017.12.05 16:07:15 - Management - Send 'signal SIGTERM'
. 2017.12.05 16:07:15 - Connection terminated.
. 2017.12.05 16:07:15 - DNS leak protection with packet filtering disabled.
. 2017.12.05 16:07:15 - Interface Ethernet 3 metric restored from 3 to Automatic, layer IPv4
. 2017.12.05 16:07:15 - Interface Ethernet 3 metric restored from 3 to Automatic, layer IPv6
I 2017.12.05 16:07:18 - Cancel requested.
. 2017.12.05 16:07:18 - IPv6 restored with packet filtering.
! 2017.12.05 16:07:18 - Session terminated.
! 2017.12.05 16:08:24 - Activation of Network Lock - Windows Filtering Platform
! 2017.12.05 16:08:24 - Deactivation of Network Lock
! 2017.12.05 16:08:26 - Activation of Network Lock - Windows Filtering Platform
I 2017.12.05 16:08:28 - Session starting.
. 2017.12.05 16:08:28 - IPv6 disabled with packet filtering.
I 2017.12.05 16:08:28 - Checking authorization ...
! 2017.12.05 16:08:28 - Connecting to Mintaka (Canada, Toronto, Ontario)
. 2017.12.05 16:08:29 - OpenVPN > OpenVPN 2.4.3 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jun 23 2017
. 2017.12.05 16:08:29 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.12.05 16:08:29 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2017.12.05 16:08:29 - Connection to OpenVPN Management Interface
. 2017.12.05 16:08:29 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.12.05 16:08:29 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:08:29 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:08:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.220:1194
. 2017.12.05 16:08:29 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.12.05 16:08:29 - OpenVPN > Attempting to establish TCP connection with [AF_INET]184.75.223.220:1194 [nonblock]
. 2017.12.05 16:08:29 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.12.05 16:08:30 - OpenVPN > TCP connection established with [AF_INET]184.75.223.220:1194
. 2017.12.05 16:08:30 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2017.12.05 16:08:30 - OpenVPN > TCP_CLIENT link remote: [AF_INET]184.75.223.220:1194
. 2017.12.05 16:08:30 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.220:1194, sid=bf4a242c b3dbe07e
. 2017.12.05 16:08:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.12.05 16:08:30 - OpenVPN > VERIFY KU OK
. 2017.12.05 16:08:30 - OpenVPN > Validating certificate extended key usage
. 2017.12.05 16:08:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.12.05 16:08:30 - OpenVPN > VERIFY EKU OK
. 2017.12.05 16:08:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.12.05 16:08:30 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.12.05 16:08:30 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.220:1194
. 2017.12.05 16:08:31 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.12.05 16:08:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.1.61 255.255.0.0'
. 2017.12.05 16:08:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.12.05 16:08:31 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.12.05 16:08:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.12.05 16:08:31 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.12.05 16:08:31 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.12.05 16:08:31 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.12.05 16:08:31 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.12.05 16:08:31 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:08:31 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.12.05 16:08:31 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:08:31 - OpenVPN > interactive service msg_channel=0
. 2017.12.05 16:08:31 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=4 HWADDR=4c:cc:6a:d3:da:67
. 2017.12.05 16:08:31 - OpenVPN > open_tun
. 2017.12.05 16:08:32 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{9B86EF66-5402-4D29-8A41-D0CCC932FA98}.tap
. 2017.12.05 16:08:32 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.12.05 16:08:32 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.1.61/255.255.0.0 [sUCCEEDED]
. 2017.12.05 16:08:32 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.1.61/255.255.0.0 on interface {9B86EF66-5402-4D29-8A41-D0CCC932FA98} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2017.12.05 16:08:32 - OpenVPN > Successful ARP Flush on interface [15] {9B86EF66-5402-4D29-8A41-D0CCC932FA98}
. 2017.12.05 16:08:32 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.12.05 16:08:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:37 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:41 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:42 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:43 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:44 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:46 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:47 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:48 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:49 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:50 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:51 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:52 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:53 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:54 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:55 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:56 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:57 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:57 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:57 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:58 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:58 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:58 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:08:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:08:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:08:59 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:01 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:01 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:01 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:02 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:02 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:02 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:03 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:03 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:03 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:05 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:05 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:05 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:06 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:06 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.223.220 MASK 255.255.255.255 192.168.1.1
. 2017.12.05 16:09:06 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2017.12.05 16:09:06 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.12.05 16:09:06 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
W 2017.12.05 16:09:06 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.50.0.1
. 2017.12.05 16:09:06 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2017.12.05 16:09:06 - OpenVPN > Route addition fallback to route.exe
. 2017.12.05 16:09:06 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2017.12.05 16:09:06 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2017.12.05 16:09:06 - OpenVPN > SYSTEM ROUTING TABLE
. 2017.12.05 16:09:06 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=4 t=4 pr=3 a=5382 h=0 m=26/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 0.0.0.0 128.0.0.0 10.50.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 38.132.107.146 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5873 h=0 m=26/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 38.132.127.74 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5838 h=0 m=26/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 104.254.90.202 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=922 h=0 m=25/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=13410 h=0 m=331/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=13410 h=0 m=331/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 128.0.0.0 128.0.0.0 10.50.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.117.11 p=0 i=15 t=3 pr=2 a=1508 h=0 m=291/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 169.254.117.11 255.255.255.255 169.254.117.11 p=0 i=15 t=3 pr=2 a=1508 h=0 m=291/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.117.11 p=0 i=15 t=3 pr=2 a=1508 h=0 m=291/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 184.75.223.220 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=25/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 185.65.135.137 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5426 h=0 m=26/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 185.65.135.140 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5474 h=0 m=26/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 185.65.135.145 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5378 h=0 m=26/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.159 p=0 i=4 t=3 pr=2 a=13389 h=0 m=281/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 192.168.1.159 255.255.255.255 192.168.1.159 p=0 i=4 t=3 pr=2 a=13389 h=0 m=281/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.159 p=0 i=4 t=3 pr=2 a=13389 h=0 m=281/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=13410 h=0 m=331/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.159 p=0 i=4 t=3 pr=2 a=13395 h=0 m=281/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.117.11 p=0 i=15 t=3 pr=2 a=1518 h=0 m=291/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.159 p=0 i=4 t=3 pr=2 a=13395 h=0 m=281/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.117.11 p=0 i=15 t=3 pr=2 a=1518 h=0 m=291/0/0/0/0
. 2017.12.05 16:09:06 - OpenVPN > SYSTEM ADAPTER LIST
. 2017.12.05 16:09:06 - OpenVPN > Realtek PCIe GBE Family Controller
. 2017.12.05 16:09:06 - OpenVPN >   Index = 4
. 2017.12.05 16:09:06 - OpenVPN >   GUID = {CB15EFF2-6641-4EAF-AE9F-1232CFE441C6}
. 2017.12.05 16:09:06 - OpenVPN >   IP = 192.168.1.159/255.255.255.0
. 2017.12.05 16:09:06 - OpenVPN >   MAC = 4c:cc:6a:d3:da:67
. 2017.12.05 16:09:06 - OpenVPN >   GATEWAY = 192.168.1.1/255.255.255.255
. 2017.12.05 16:09:06 - OpenVPN >   DHCP SERV = 192.168.1.1/255.255.255.255
. 2017.12.05 16:09:06 - OpenVPN >   DHCP LEASE OBTAINED = Tue Dec 05 12:25:57 2017
. 2017.12.05 16:09:06 - OpenVPN >   DHCP LEASE EXPIRES  = Wed Dec 06 12:25:57 2017
. 2017.12.05 16:09:06 - OpenVPN >   DNS SERV = 192.168.1.1/255.255.255.255
. 2017.12.05 16:09:06 - OpenVPN > TunnelBear Adapter V9
. 2017.12.05 16:09:06 - OpenVPN >   Index = 5
. 2017.12.05 16:09:06 - OpenVPN >   GUID = {F9D11350-8244-4CEF-8CC9-53C915CEA077}
. 2017.12.05 16:09:06 - OpenVPN >   IP = 0.0.0.0/0.0.0.0
. 2017.12.05 16:09:06 - OpenVPN >   MAC = 00:ff:f9:d1:13:50
. 2017.12.05 16:09:06 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2017.12.05 16:09:06 - OpenVPN >   DHCP LEASE OBTAINED = Tue Dec 05 16:09:06 2017
. 2017.12.05 16:09:06 - OpenVPN >   DHCP LEASE EXPIRES  = Tue Dec 05 16:09:06 2017
. 2017.12.05 16:09:06 - OpenVPN > TAP-Windows Adapter V9
. 2017.12.05 16:09:06 - OpenVPN >   Index = 15
. 2017.12.05 16:09:06 - OpenVPN >   GUID = {9B86EF66-5402-4D29-8A41-D0CCC932FA98}
. 2017.12.05 16:09:06 - OpenVPN >   IP = 169.254.117.11/255.255.0.0
. 2017.12.05 16:09:06 - OpenVPN >   MAC = 00:ff:9b:86:ef:66
. 2017.12.05 16:09:06 - OpenVPN >   DHCP SERV = 0.0.0.0/255.255.255.255
. 2017.12.05 16:09:06 - Interface Ethernet 3 metric changed from Automatic to 3, layer IPv4
. 2017.12.05 16:09:06 - Interface Ethernet 3 metric changed from Automatic to 3, layer IPv6
. 2017.12.05 16:09:06 - DNS leak protection with packet filtering enabled.
. 2017.12.05 16:09:06 - Flushing DNS
. 2017.12.05 16:09:09 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
! 2017.12.05 16:09:09 - Disconnecting
. 2017.12.05 16:09:09 - Sending management termination signal
. 2017.12.05 16:09:09 - Management - Send 'signal SIGTERM'
. 2017.12.05 16:09:09 - Connection terminated.
. 2017.12.05 16:09:09 - DNS leak protection with packet filtering disabled.
. 2017.12.05 16:09:09 - Interface Ethernet 3 metric restored from 3 to Automatic, layer IPv4
. 2017.12.05 16:09:09 - Interface Ethernet 3 metric restored from 3 to Automatic, layer IPv6
I 2017.12.05 16:09:11 - Cancel requested.
. 2017.12.05 16:09:11 - IPv6 restored with packet filtering.
! 2017.12.05 16:09:11 - Session terminated.
I 2017.12.05 16:09:20 - Session starting.
. 2017.12.05 16:09:20 - IPv6 disabled with packet filtering.
I 2017.12.05 16:09:20 - Checking authorization ...
! 2017.12.05 16:09:20 - Connecting to Sualocin (Canada, Toronto, Ontario)
. 2017.12.05 16:09:20 - OpenVPN > OpenVPN 2.4.3 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jun 23 2017
. 2017.12.05 16:09:20 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.12.05 16:09:20 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2017.12.05 16:09:20 - Connection to OpenVPN Management Interface
. 2017.12.05 16:09:20 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.12.05 16:09:20 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:09:20 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:09:20 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.42:443
. 2017.12.05 16:09:20 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.12.05 16:09:20 - OpenVPN > UDP link local: (not bound)
. 2017.12.05 16:09:20 - OpenVPN > UDP link remote: [AF_INET]184.75.221.42:443
. 2017.12.05 16:09:20 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.12.05 16:09:20 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.42:443, sid=a79bcb23 dbf83b09
. 2017.12.05 16:09:20 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.12.05 16:09:20 - OpenVPN > VERIFY KU OK
. 2017.12.05 16:09:20 - OpenVPN > Validating certificate extended key usage
. 2017.12.05 16:09:20 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.12.05 16:09:20 - OpenVPN > VERIFY EKU OK
. 2017.12.05 16:09:20 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.12.05 16:09:21 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.12.05 16:09:21 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.42:443
. 2017.12.05 16:09:22 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.12.05 16:09:22 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.25.34 255.255.0.0'
. 2017.12.05 16:09:22 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.12.05 16:09:22 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.12.05 16:09:22 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.12.05 16:09:22 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.12.05 16:09:22 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.12.05 16:09:22 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.12.05 16:09:22 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.12.05 16:09:22 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:09:22 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.12.05 16:09:22 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:09:22 - OpenVPN > interactive service msg_channel=0
. 2017.12.05 16:09:22 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=4 HWADDR=4c:cc:6a:d3:da:67
. 2017.12.05 16:09:22 - OpenVPN > open_tun
. 2017.12.05 16:09:22 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{9B86EF66-5402-4D29-8A41-D0CCC932FA98}.tap
. 2017.12.05 16:09:22 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.12.05 16:09:22 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.25.34/255.255.0.0 [sUCCEEDED]
. 2017.12.05 16:09:22 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.25.34/255.255.0.0 on interface {9B86EF66-5402-4D29-8A41-D0CCC932FA98} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.12.05 16:09:22 - OpenVPN > Successful ARP Flush on interface [15] {9B86EF66-5402-4D29-8A41-D0CCC932FA98}
. 2017.12.05 16:09:22 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.12.05 16:09:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:27 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:32 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:34 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:35 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:36 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:37 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:39 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:40 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:41 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:42 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:43 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:44 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:45 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:45 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:45 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:46 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:47 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:48 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:49 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:50 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:51 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:52 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:53 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:55 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:09:56 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:09:57 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:09:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.221.42 MASK 255.255.255.255 192.168.1.1
. 2017.12.05 16:09:57 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2017.12.05 16:09:57 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.12.05 16:09:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
W 2017.12.05 16:09:57 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2017.12.05 16:09:57 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2017.12.05 16:09:57 - OpenVPN > Route addition fallback to route.exe
. 2017.12.05 16:09:57 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2017.12.05 16:09:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.12.05 16:09:57 - OpenVPN > SYSTEM ROUTING TABLE
. 2017.12.05 16:09:57 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=4 t=4 pr=3 a=5434 h=0 m=26/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 38.132.107.146 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5925 h=0 m=26/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 38.132.127.74 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5889 h=0 m=26/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 104.254.90.202 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=973 h=0 m=25/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=13461 h=0 m=331/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=13461 h=0 m=331/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.117.11 p=0 i=15 t=3 pr=2 a=1559 h=0 m=291/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 169.254.117.11 255.255.255.255 169.254.117.11 p=0 i=15 t=3 pr=2 a=1559 h=0 m=291/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.117.11 p=0 i=15 t=3 pr=2 a=1559 h=0 m=291/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 184.75.221.42 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=25/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 185.65.135.137 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5477 h=0 m=26/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 185.65.135.140 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5525 h=0 m=26/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 185.65.135.145 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5429 h=0 m=26/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.159 p=0 i=4 t=3 pr=2 a=13440 h=0 m=281/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 192.168.1.159 255.255.255.255 192.168.1.159 p=0 i=4 t=3 pr=2 a=13440 h=0 m=281/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.159 p=0 i=4 t=3 pr=2 a=13440 h=0 m=281/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=13461 h=0 m=331/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.159 p=0 i=4 t=3 pr=2 a=13447 h=0 m=281/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.117.11 p=0 i=15 t=3 pr=2 a=1569 h=0 m=291/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.159 p=0 i=4 t=3 pr=2 a=13447 h=0 m=281/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.117.11 p=0 i=15 t=3 pr=2 a=1569 h=0 m=291/0/0/0/0
. 2017.12.05 16:09:57 - OpenVPN > SYSTEM ADAPTER LIST
. 2017.12.05 16:09:57 - OpenVPN > Realtek PCIe GBE Family Controller
. 2017.12.05 16:09:57 - OpenVPN >   Index = 4
. 2017.12.05 16:09:57 - OpenVPN >   GUID = {CB15EFF2-6641-4EAF-AE9F-1232CFE441C6}
. 2017.12.05 16:09:57 - OpenVPN >   IP = 192.168.1.159/255.255.255.0
. 2017.12.05 16:09:57 - OpenVPN >   MAC = 4c:cc:6a:d3:da:67
. 2017.12.05 16:09:57 - OpenVPN >   GATEWAY = 192.168.1.1/255.255.255.255
. 2017.12.05 16:09:57 - OpenVPN >   DHCP SERV = 192.168.1.1/255.255.255.255
. 2017.12.05 16:09:57 - OpenVPN >   DHCP LEASE OBTAINED = Tue Dec 05 12:25:56 2017
. 2017.12.05 16:09:57 - OpenVPN >   DHCP LEASE EXPIRES  = Wed Dec 06 12:25:56 2017
. 2017.12.05 16:09:57 - OpenVPN >   DNS SERV = 192.168.1.1/255.255.255.255
. 2017.12.05 16:09:57 - OpenVPN > TunnelBear Adapter V9
. 2017.12.05 16:09:57 - OpenVPN >   Index = 5
. 2017.12.05 16:09:57 - OpenVPN >   GUID = {F9D11350-8244-4CEF-8CC9-53C915CEA077}
. 2017.12.05 16:09:57 - OpenVPN >   IP = 0.0.0.0/0.0.0.0
. 2017.12.05 16:09:57 - OpenVPN >   MAC = 00:ff:f9:d1:13:50
. 2017.12.05 16:09:57 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2017.12.05 16:09:57 - OpenVPN >   DHCP LEASE OBTAINED = Tue Dec 05 16:09:57 2017
. 2017.12.05 16:09:57 - OpenVPN >   DHCP LEASE EXPIRES  = Tue Dec 05 16:09:57 2017
. 2017.12.05 16:09:57 - OpenVPN > TAP-Windows Adapter V9
. 2017.12.05 16:09:57 - OpenVPN >   Index = 15
. 2017.12.05 16:09:57 - OpenVPN >   GUID = {9B86EF66-5402-4D29-8A41-D0CCC932FA98}
. 2017.12.05 16:09:57 - OpenVPN >   IP = 169.254.117.11/255.255.0.0
. 2017.12.05 16:09:57 - OpenVPN >   MAC = 00:ff:9b:86:ef:66
. 2017.12.05 16:09:57 - OpenVPN >   DHCP SERV = 0.0.0.0/255.255.255.255
. 2017.12.05 16:09:57 - Interface Ethernet 3 metric changed from Automatic to 3, layer IPv4
. 2017.12.05 16:09:57 - Interface Ethernet 3 metric changed from Automatic to 3, layer IPv6
. 2017.12.05 16:09:57 - DNS leak protection with packet filtering enabled.
. 2017.12.05 16:09:57 - Flushing DNS
. 2017.12.05 16:10:00 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
! 2017.12.05 16:10:00 - Disconnecting
. 2017.12.05 16:10:00 - Sending management termination signal
. 2017.12.05 16:10:00 - Management - Send 'signal SIGTERM'
. 2017.12.05 16:10:05 - Connection terminated.
. 2017.12.05 16:10:05 - DNS leak protection with packet filtering disabled.
. 2017.12.05 16:10:05 - Interface Ethernet 3 metric restored from 3 to Automatic, layer IPv4
. 2017.12.05 16:10:05 - Interface Ethernet 3 metric restored from 3 to Automatic, layer IPv6
I 2017.12.05 16:10:05 - Cancel requested.
. 2017.12.05 16:10:05 - IPv6 restored with packet filtering.
! 2017.12.05 16:10:05 - Session terminated.
. 2017.12.05 16:10:34 - Updating systems & servers data ...
. 2017.12.05 16:10:34 - Systems & servers data update completed
! 2017.12.05 16:11:31 - Deactivation of Network Lock
I 2017.12.05 16:17:47 - Session starting.
. 2017.12.05 16:17:47 - IPv6 disabled with packet filtering.
I 2017.12.05 16:17:47 - Checking authorization ...
! 2017.12.05 16:17:47 - Connecting to Enif (Canada, Toronto, Ontario)
. 2017.12.05 16:17:48 - OpenVPN > OpenVPN 2.4.3 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jun 23 2017
. 2017.12.05 16:17:48 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.12.05 16:17:48 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2017.12.05 16:17:48 - Connection to OpenVPN Management Interface
. 2017.12.05 16:17:48 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.12.05 16:17:48 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:17:48 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:17:48 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.242:443
. 2017.12.05 16:17:48 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.12.05 16:17:48 - OpenVPN > UDP link local: (not bound)
. 2017.12.05 16:17:48 - OpenVPN > UDP link remote: [AF_INET]104.254.90.242:443
. 2017.12.05 16:17:48 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.12.05 16:17:48 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.242:443, sid=3f5fdd73 938733fc
. 2017.12.05 16:17:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.12.05 16:17:48 - OpenVPN > VERIFY KU OK
. 2017.12.05 16:17:48 - OpenVPN > Validating certificate extended key usage
. 2017.12.05 16:17:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.12.05 16:17:48 - OpenVPN > VERIFY EKU OK
. 2017.12.05 16:17:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.12.05 16:17:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.12.05 16:17:48 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.254.90.242:443
. 2017.12.05 16:17:49 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.12.05 16:17:49 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.123.164 255.255.0.0'
. 2017.12.05 16:17:49 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.12.05 16:17:49 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.12.05 16:17:49 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.12.05 16:17:49 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.12.05 16:17:49 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.12.05 16:17:49 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.12.05 16:17:49 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.12.05 16:17:49 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:17:49 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.12.05 16:17:49 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.05 16:17:49 - OpenVPN > interactive service msg_channel=0
. 2017.12.05 16:17:49 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=4 HWADDR=4c:cc:6a:d3:da:67
. 2017.12.05 16:17:49 - OpenVPN > open_tun
. 2017.12.05 16:17:49 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{9B86EF66-5402-4D29-8A41-D0CCC932FA98}.tap
. 2017.12.05 16:17:49 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.12.05 16:17:49 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.123.164/255.255.0.0 [sUCCEEDED]
. 2017.12.05 16:17:49 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.123.164/255.255.0.0 on interface {9B86EF66-5402-4D29-8A41-D0CCC932FA98} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.12.05 16:17:49 - OpenVPN > Successful ARP Flush on interface [15] {9B86EF66-5402-4D29-8A41-D0CCC932FA98}
. 2017.12.05 16:17:49 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.12.05 16:17:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:17:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:17:54 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:17:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:17:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:17:59 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:00 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:00 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:00 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:01 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:01 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:01 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:02 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:02 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:02 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:03 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:03 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:03 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:04 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:04 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:04 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:05 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:05 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:05 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:06 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:06 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:06 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:07 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:07 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:07 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:08 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:08 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:08 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:09 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:09 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:09 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:10 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:10 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:10 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:11 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:11 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:12 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:13 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:13 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:13 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:14 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:15 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:15 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:15 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:16 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:16 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:16 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:17 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:17 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:17 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:18 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:18 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:18 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:19 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:19 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:19 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:20 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:20 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:20 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:21 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:21 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:22 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:22 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:22 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:23 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:23 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.12.05 16:18:23 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.12.05 16:18:24 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.12.05 16:18:24 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 104.254.90.242 MASK 255.255.255.255 192.168.1.1
. 2017.12.05 16:18:24 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2017.12.05 16:18:24 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.12.05 16:18:24 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
W 2017.12.05 16:18:24 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2017.12.05 16:18:24 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2017.12.05 16:18:24 - OpenVPN > Route addition fallback to route.exe
. 2017.12.05 16:18:24 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2017.12.05 16:18:24 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.12.05 16:18:24 - OpenVPN > SYSTEM ROUTING TABLE
. 2017.12.05 16:18:24 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=4 t=4 pr=3 a=5941 h=0 m=26/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 38.132.107.146 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=6432 h=0 m=26/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 38.132.127.74 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=6397 h=0 m=26/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 104.254.90.202 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=1481 h=0 m=25/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 104.254.90.242 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=25/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=13969 h=0 m=331/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=13969 h=0 m=331/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.117.11 p=0 i=15 t=3 pr=2 a=2067 h=0 m=291/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 169.254.117.11 255.255.255.255 169.254.117.11 p=0 i=15 t=3 pr=2 a=2067 h=0 m=291/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.117.11 p=0 i=15 t=3 pr=2 a=2067 h=0 m=291/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 185.65.135.137 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5985 h=0 m=26/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 185.65.135.140 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=6033 h=0 m=26/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 185.65.135.145 255.255.255.255 192.168.1.1 p=0 i=4 t=4 pr=3 a=5937 h=0 m=26/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.159 p=0 i=4 t=3 pr=2 a=13948 h=0 m=281/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 192.168.1.159 255.255.255.255 192.168.1.159 p=0 i=4 t=3 pr=2 a=13948 h=0 m=281/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.159 p=0 i=4 t=3 pr=2 a=13948 h=0 m=281/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=13969 h=0 m=331/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.159 p=0 i=4 t=3 pr=2 a=13954 h=0 m=281/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.117.11 p=0 i=15 t=3 pr=2 a=2077 h=0 m=291/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.159 p=0 i=4 t=3 pr=2 a=13954 h=0 m=281/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.117.11 p=0 i=15 t=3 pr=2 a=2077 h=0 m=291/0/0/0/0
. 2017.12.05 16:18:24 - OpenVPN > SYSTEM ADAPTER LIST
. 2017.12.05 16:18:24 - OpenVPN > Realtek PCIe GBE Family Controller
. 2017.12.05 16:18:24 - OpenVPN >   Index = 4
. 2017.12.05 16:18:24 - OpenVPN >   GUID = {CB15EFF2-6641-4EAF-AE9F-1232CFE441C6}
. 2017.12.05 16:18:24 - OpenVPN >   IP = 192.168.1.159/255.255.255.0
. 2017.12.05 16:18:24 - OpenVPN >   MAC = 4c:cc:6a:d3:da:67
. 2017.12.05 16:18:24 - OpenVPN >   GATEWAY = 192.168.1.1/255.255.255.255
. 2017.12.05 16:18:24 - OpenVPN >   DHCP SERV = 192.168.1.1/255.255.255.255
. 2017.12.05 16:18:24 - OpenVPN >   DHCP LEASE OBTAINED = Tue Dec 05 12:25:56 2017
. 2017.12.05 16:18:24 - OpenVPN >   DHCP LEASE EXPIRES  = Wed Dec 06 12:25:56 2017
. 2017.12.05 16:18:24 - OpenVPN >   DNS SERV = 192.168.1.1/255.255.255.255
. 2017.12.05 16:18:24 - OpenVPN > TunnelBear Adapter V9
. 2017.12.05 16:18:24 - OpenVPN >   Index = 5
. 2017.12.05 16:18:24 - OpenVPN >   GUID = {F9D11350-8244-4CEF-8CC9-53C915CEA077}
. 2017.12.05 16:18:24 - OpenVPN >   IP = 0.0.0.0/0.0.0.0
. 2017.12.05 16:18:24 - OpenVPN >   MAC = 00:ff:f9:d1:13:50
. 2017.12.05 16:18:24 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2017.12.05 16:18:24 - OpenVPN >   DHCP LEASE OBTAINED = Tue Dec 05 16:18:24 2017
. 2017.12.05 16:18:24 - OpenVPN >   DHCP LEASE EXPIRES  = Tue Dec 05 16:18:24 2017
. 2017.12.05 16:18:24 - OpenVPN > TAP-Windows Adapter V9
. 2017.12.05 16:18:24 - OpenVPN >   Index = 15
. 2017.12.05 16:18:24 - OpenVPN >   GUID = {9B86EF66-5402-4D29-8A41-D0CCC932FA98}
. 2017.12.05 16:18:24 - OpenVPN >   IP = 169.254.117.11/255.255.0.0
. 2017.12.05 16:18:24 - OpenVPN >   MAC = 00:ff:9b:86:ef:66
. 2017.12.05 16:18:24 - OpenVPN >   DHCP SERV = 0.0.0.0/255.255.255.255
. 2017.12.05 16:18:24 - Interface Ethernet 3 metric changed from Automatic to 3, layer IPv4
. 2017.12.05 16:18:24 - Interface Ethernet 3 metric changed from Automatic to 3, layer IPv6
. 2017.12.05 16:18:24 - DNS leak protection with packet filtering enabled.
. 2017.12.05 16:18:25 - Flushing DNS
. 2017.12.05 16:18:28 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
! 2017.12.05 16:18:28 - Disconnecting
. 2017.12.05 16:18:28 - Sending management termination signal
. 2017.12.05 16:18:28 - Management - Send 'signal SIGTERM'
. 2017.12.05 16:18:33 - Connection terminated.
. 2017.12.05 16:18:33 - DNS leak protection with packet filtering disabled.
. 2017.12.05 16:18:33 - Interface Ethernet 3 metric restored from 3 to Automatic, layer IPv4
. 2017.12.05 16:18:33 - Interface Ethernet 3 metric restored from 3 to Automatic, layer IPv6
I 2017.12.05 16:18:33 - Cancel requested.
. 2017.12.05 16:18:33 - IPv6 restored with packet filtering.
! 2017.12.05 16:18:33 - Session terminated.
Network Interfaces:
Network Interface: Ethernet (Realtek PCIe GBE Family Controller, ID:{CB15EFF2-6641-4EAF-AE9F-1232CFE441C6}) - Ethernet - Up
Network Interface: Ethernet 3 (TAP-Windows Adapter V9, ID:{9B86EF66-5402-4D29-8A41-D0CCC932FA98}) - Ethernet - Down
Network Interface: Ethernet 2 (TunnelBear Adapter V9, ID:{F9D11350-8244-4CEF-8CC9-53C915CEA077}) - Ethernet - Down
Network Interface: Loopback Pseudo-Interface 1 (Software Loopback Interface 1, ID:{73EEF6A0-CD38-11E7-9AA5-806E6F6E6963}) - Loopback - Up
Network Interface: Teredo Tunneling Pseudo-Interface (Teredo Tunneling Pseudo-Interface, ID:{4CC9E4D9-D84B-4382-97B5-5FC2E545D12A}) - Tunnel - Up
Default gateways:
192.168.1.1, Realtek PCIe GBE Family Controller
::, Teredo Tunneling Pseudo-Interface
ipconfig /all:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : DESKTOP-U3J3AKB
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : fios-router.home
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . : fios-router.home
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . : 4C-CC-6A-D3-DA-67
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::24b4:c0e7:8abc:ed05%4(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.159(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Tuesday, December 5, 2017 12:25:57 PM
   Lease Expires . . . . . . . . . . : Wednesday, December 6, 2017 12:25:56 PM
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCP Server . . . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 55364714
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-20-DE-5E-13-4C-CC-6A-D3-DA-67
   DNS Servers . . . . . . . . . . . : 192.168.1.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Ethernet 3:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : TAP-Windows Adapter V9
   Physical Address. . . . . . . . . : 00-FF-9B-86-EF-66
Ethernet adapter Ethernet 2:
   Description . . . . . . . . . . . : TunnelBear Adapter V9
   Physical Address. . . . . . . . . : 00-FF-F9-D1-13-50
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
   Link-local IPv6 Address . . . . . : fe80::3438:1b77:3f57:fe60%2(Preferred)
   Default Gateway . . . . . . . . . : ::
   DHCPv6 IAID . . . . . . . . . . . : 218103808
   NetBIOS over Tcpip. . . . . . . . : Disabled
route print:
Interface List
  4...4c cc 6a d3 da 67 ......Realtek PCIe GBE Family Controller
 15...00 ff 9b 86 ef 66 ......TAP-Windows Adapter V9
  5...00 ff f9 d1 13 50 ......TunnelBear Adapter V9
  1...........................Software Loopback Interface 1
  2...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0      192.168.1.1    192.168.1.159     26
   38.132.107.146  255.255.255.255      192.168.1.1    192.168.1.159     26
    38.132.127.74  255.255.255.255      192.168.1.1    192.168.1.159     26
   104.254.90.202  255.255.255.255      192.168.1.1    192.168.1.159     25
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    331
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    331
   185.65.135.137  255.255.255.255      192.168.1.1    192.168.1.159     26
   185.65.135.140  255.255.255.255      192.168.1.1    192.168.1.159     26
   185.65.135.145  255.255.255.255      192.168.1.1    192.168.1.159     26
      192.168.1.0    255.255.255.0         On-link     192.168.1.159    281
    192.168.1.159  255.255.255.255         On-link     192.168.1.159    281
    192.168.1.255  255.255.255.255         On-link     192.168.1.159    281
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    331
        224.0.0.0        240.0.0.0         On-link     192.168.1.159    281
  255.255.255.255  255.255.255.255         On-link     192.168.1.159    281
Persistent Routes:
  None
IPv6 Route Table
Active Routes:
 If Metric Network Destination      Gateway
  2    331 ::/0                     On-link
  1    331 ::1/128                  On-link
  2    331 2001::/32                On-link
  4    281 fe80::/64                On-link
  2    331 fe80::/64                On-link
  4    281 fe80::24b4:c0e7:8abc:ed05/128
                                    On-link
  2    331 fe80::3438:1b77:3f57:fe60/128
                                    On-link
  1    331 ff00::/8                 On-link
  4    281 ff00::/8                 On-link
  2    331 ff00::/8                 On-link
Persistent Routes:
  None
Resolved my issue. For those who may come across this in the future, I did the following (not sure what exactly resolved the issue, but this worked for me): Reset network settings, restarted computer, opened the AirVPN file in my Windows C: drive, ran the tap-windows.exe application.
