guppy
Android openVPN client for TAP mode?
After banging my head against this for two days I realize that it's because I need TAP not TUN   and  "OpenVPN for Android" can't do this.
The client named simply "OpenVPN Client" by colucci-web.it claims to be the only client to be able to use TAP without root - but given that their site says "under construction" http://www.colucci-web.it/home/ I'm a litte weary of paying for/installing the app. Just doesn't seem all that legit
Does anyone know of a way to use an "on demand" TAP bridge on android, or is the "OpenVPN Client" indeed legit?
(my router also supports PPTP, but I know even less about this vpn than I do openvpn)
OpenVPN clients on Android in 2017 use the VPNService API of Android for establishing and maintaining VPN tunnels without root access. This API only ever supported tun mode.
I faintly remember a project which could emulate OpenVPN tun and tap mode through the use of Android's built-in IPsec, but that was before the VPNService API with Froyo/Gingerbread. The project is likely dead.
