Not connected, Your IP: 216.73.216.217
Asif
authentication failure
Just renewed my subscription, and now i cant connect to any of the servers as i get authentication failure.please help
Fri May 25 03:26:18 2012 OpenVPN 2.2.1 Win32-MSVC++ [sSL] [LZO2] built on Jul 1 2011
Fri May 25 03:26:18 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri May 25 03:26:19 2012 LZO compression initialized
Fri May 25 03:26:19 2012 Control Channel MTU parms [ L:1590 D:138 EF:38 EB:0 ET:0 EL:0 ]
Fri May 25 03:26:19 2012 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri May 25 03:26:19 2012 Data Channel MTU parms [ L:1590 D:1300 EF:58 EB:135 ET:32 EL:0 AF:3/1 ]
Fri May 25 03:26:19 2012 Local Options hash (VER=V4): 'fd83fad0'
Fri May 25 03:26:19 2012 Expected Remote Options hash (VER=V4): '00a0a914'
Fri May 25 03:26:19 2012 UDPv4 link local: [undef]
Fri May 25 03:26:19 2012 UDPv4 link remote: 89.149.226.185:53
Fri May 25 03:26:19 2012 TLS: Initial packet from 89.149.226.185:53, sid=7786ab48 ee07fd27
Fri May 25 03:26:19 2012 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Fri May 25 03:26:25 2012 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
Fri May 25 03:26:25 2012 VERIFY OK: nsCertType=SERVER
Fri May 25 03:26:25 2012 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
Fri May 25 03:26:51 2012 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Fri May 25 03:26:51 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri May 25 03:26:51 2012 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Fri May 25 03:26:51 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri May 25 03:26:51 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Fri May 25 03:26:51 2012 [server] Peer Connection Initiated with 89.149.226.185:53
Fri May 25 03:26:53 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Fri May 25 03:26:54 2012 AUTH: Received AUTH_FAILED control message
Fri May 25 03:26:54 2012 TCP/UDP: Closing socket
Fri May 25 03:26:54 2012 SIGUSR1[soft,auth-failure] received, process restarting
Fri May 25 03:26:54 2012 Restart pause, 10 second(s)
Fri May 25 03:27:04 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri May 25 03:27:04 2012 Re-using SSL/TLS context
Fri May 25 03:27:04 2012 LZO compression initialized
Fri May 25 03:27:04 2012 Control Channel MTU parms [ L:1590 D:138 EF:38 EB:0 ET:0 EL:0 ]
Fri May 25 03:27:04 2012 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri May 25 03:27:04 2012 TCP/UDP: Preserving recently used remote address: 89.149.226.185:53
Fri May 25 03:27:04 2012 Data Channel MTU parms [ L:1590 D:1300 EF:58 EB:135 ET:32 EL:0 AF:3/1 ]
Fri May 25 03:27:04 2012 Local Options hash (VER=V4): 'fd83fad0'
Fri May 25 03:27:04 2012 Expected Remote Options hash (VER=V4): '00a0a914'
Fri May 25 03:27:04 2012 UDPv4 link local: [undef]
Fri May 25 03:27:04 2012 UDPv4 link remote: 89.149.226.185:53
Fri May 25 03:27:05 2012 TLS: Initial packet from 89.149.226.185:53, sid=d22e8386 909fec66
Fri May 25 03:27:08 2012 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
Fri May 25 03:27:08 2012 VERIFY OK: nsCertType=SERVER
Fri May 25 03:27:08 2012 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
Fri May 25 03:27:21 2012 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Fri May 25 03:27:21 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri May 25 03:27:21 2012 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Fri May 25 03:27:21 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri May 25 03:27:21 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Fri May 25 03:27:21 2012 [server] Peer Connection Initiated with 89.149.226.185:53
Fri May 25 03:27:23 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Fri May 25 03:27:24 2012 AUTH: Received AUTH_FAILED control message
Fri May 25 03:27:24 2012 TCP/UDP: Closing socket
Fri May 25 03:27:24 2012 SIGUSR1[soft,auth-failure] received, process restarting
