rageatm
Can't port forward
Go to your client area tab in airvpn.org website.  click on forward ports on the left column of the web page.  Let airvpn assign a port automaticall udp or tcp.  Make sure the p2p client you are using is listening on that port.  EX; bittorent settings should show listening port as you put in the port assigned by airvpn.  Make sure random ports are not selected.
