LujosoAgain
How Psiphon interacts with AirVpn?
Hi, i noticed that when i'm connected with AirVPN and activate psiphon my ip change and when i verify it with "ip leak website" it shows me my Psiphon ip instead of the AirVpn ip
Did some research as I have never used Psiphon. On Android, it establishes a VPN connection to route traffic through it and thus cannot be used with AirVPN, as the second VPN established will override the first. Now on Windows, the same kind of thing happens in VPN mode, but you have options. You can run Psiphon in proxy mode and configure apps accordingly, which would tunnel Psiphon through AirVPN but result in your Psiphon IP as the one visible on the internet. You could also setup the official OpenVPN client with manual routes to accomplish similar results. But, depending on your case, either AirVPN is not working or Psiphon is being tunneled over AirVPN.
