jean claud
Webrtc ip leak on IOS 11
I'm running ios11 beta 5 ( ipad) which is pretty close to the final version.
 Most of browsers are leaking excepted 4 (Safari, Firefox, Seiphnir and Yandex)
"Privacy focused" browsers are leaking too and you can see your local IP on Whoer.net  with Firefox Focus, Brave, Ghostery etc..
Dolphin, Opera and Opera Coast  are  leaking too , but it's not a surprise !
when you will update your ipad or phone to Ios 11 , please be carreful and test your browers before using them till they fix the problem.
PS and out of topic. I've found a fantastic util : ad block , anti adblock trackers block, Cookies manager, Domain block, script block etc... called 1Blocker, worth every penny.
To avoid Webrtc ip leak in safari (ios 11) tested in beta 11.7
Go to settings
Safari
          Advanced
                            Experimental Features
        Check "Remove legacy WebRTC API"
evidently it just works for Safari , all other browsers excepted Firefox and Sleipnir are leaking your ip  (dunno for google chrome, I refuse to use it)
