NorvilleBarnes
AirVPN on Ubiquiti ER-Poe5
I tried 1 month subscription to build an AirVPN client on a pfSense platform. I couldn't accomplish,.
I'm back to determine if I can expect success with AirVPN on the EdgeMAX SELinux implementation in an EdgeRouter Poe5. This time, after doing a lot of homework, I found the US-based competitor PIA with a detailed description of the steps on an ER-Poe5. However, their example doesn't seem to provide enough information to resolve questions that might apply to AirVPN. I will begin:
For PIA there are pointers to important files, and a need to add rules to NAT & firewall:
  client
  dev-type tun
  proto udp
  remote us-florida.privateinternetaccess.com 1194
  resolv-retry infinite
  nobind
  persist-key
  persist-tun
  ca /config/auth/ca.crt
  tls-client
  remote-cert-tls server
  auth-user-pass /config/auth/auth-user-pass.txt
  comp-lzo
  verb 1
  reneg-sec 0
  crl-verify /config/auth/crl.pem
  route-nopull
For my .ovpn file for pfSense:
  client
  dev tun
  proto udp
  remote 198.203.28.42 443
  nobind
  persist-key
  persist-tun
  cipher AES-256-CBC
  comp-lzo no
  route-delay 5
  verb 3
  explicit-exit-notify 5
  <ca>          </ca>
  <cert>        </cert>
  <key>         </key>
  key-direction 1
  <tls-auth>    </tls-auth>
The differences are tremendous, making me wonder how the certificates, etc. are even found by OpenVPN. If you think it will be possible to accomplish my wishes, I will need some guidance.
I hope to use AirVPN, but I need assistance.
Where is the main question? If you ask if it is possible to use this device with AirVPN, the answer is yes.
The guide is just placing the right parameters in each option of your OpenVPN client setup page.
The difference between the guide for DD-WRT/AsusWRT and Ubiquiti is just little cosmetic GUI variations.
