Sevenz 3 Posted ... I'm having a weird problem, not sure where the problem comes from. I have a NAS with nextcloud on 192.168.2.100, using Singapore airVPN with MerlinWRT OpenVPN. I have configured/portforwarded properly without problem, but when I try to connect from within 192.168.2.100's browser, I get a "The site can't be reached. 185.200.116.203 takes too long to respond." I tried using my PC (192.168.2.99) which is connected to the VPN as well, I get the same "takes too long to respond". I manually enter 185.200.116.203:23232 from my phone (192.168.2.101) which doesn't use VPN, I can easily connect to 185.200.116.203:23232. I wonder what causes this? Is it DNS problem? I tried connecting from my laptop using Hongkong AirVPN, I can access it without problem too. This is my setting for the VPN. EDIT: Sorry if the above is not very clear, what I'm trying to achieve basically to access Nextcloud on my NAS with Singapore VPN using my PC within the same Singapore VPN. Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... With .100's and .101's browsers, did you append the port as well? Sent via Tapatalk. Means, I don't have a computer available now. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
flat4 93 Posted ... no, its not a dns issue, its a revese proxy kinda issue. since the phone its on the carrier network it can see the ip. I have same problem with my pfsense router, I run a let's encrypt, ngix and nextcloud. i can get to it from outside of my home network but nothing from within. I probably an easy fix but im to lazy to fix it. Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
Sevenz 3 Posted ... With .100's and .101's browsers, did you append the port as well? Sent via Tapatalk. Means, I don't have a computer available now. This is what I typed in every browsers "185.200.116.203:23232" no, its not a dns issue, its a revese proxy kinda issue. since the phone its on the carrier network it can see the ip. I have same problem with my pfsense router, I run a let's encrypt, ngix and nextcloud. i can get to it from outside of my home network but nothing from within. I probably an easy fix but im to lazy to fix it. Any idea where I can find the fix? Like what to google Yeah like you said, I can open Nextcloud and Transmission from phone and work but nothing from my PC (which uses the same VPN). Quote Share this post Link to post
