Not connected, Your IP: 216.73.216.47
filof
Slow DL speeds
Hello all, a new AirVPNer here.
I just have migrated to AirVPN from another VPN service after reading the recommendations on reddit.
I use AirVPN mostly on my Android box with OpenVPN for Android from Turkey. I created the config file accordingly using the configurator for TCP.
First I have created the config file just with the selection of Europe. The DL speed was low.
Then I have created the config file per certain European countries. Germany worked for me for the first time, but on the second day Germany was slow as well as Netherlands, Austria and Bulgaria, so I picked a few "not so busy" servers. After fiddling for 10 minutes, I was able to find a server that gave me 6-7Mbps.
It was pretty much random, on which server I am able to get normal DL speed. So I do not know if the problem was my configuration or the busyness of AirVPN servers. I would appreciate if you could check two logs that I took now after connecting the servers that were not able to pass 1.5Mbps on speedtest.net (without VPN I get ~25Mbps), and kindly direct me to the problem so I can solve it and enjoy AirVPN?
Thank you all in advance!
Log-1
2017-06-13 14:10:07 official build 0.6.66 running on Amlogic MINIM8S II (p212), Android 6.0.1 (MHC19J) API 23, ABI armeabi-v7a, (Amlogic/p212/p212:6.0.1/MHC19J/20161013:userdebug/test-keys)
2017-06-13 14:10:08 Building configuration…
2017-06-13 14:10:08 New OpenVPN Status (VPN_GENERATE_CONFIG->LEVEL_START):
2017-06-13 14:10:08 MANAGEMENT: CMD 'signal SIGINT'
2017-06-13 14:10:08 TCP/UDP: Closing socket
2017-06-13 14:10:08 Sorry, deleting routes on Android is not possible. The VpnService API allows routes to be set on connect only.
2017-06-13 14:10:08 Closing TUN/TAP interface
2017-06-13 14:10:08 SIGINT[hard,] received, process exiting
2017-06-13 14:10:08 MANAGEMENT: >STATE:1497352208,EXITING,SIGINT,,,,,
2017-06-13 14:10:09 started Socket Thread
2017-06-13 14:10:09 Network Status: CONNECTED  to WIFI "BrkCgl"
2017-06-13 14:10:09 Debug state info: CONNECTED  to WIFI "BrkCgl", pause: userPause, shouldbeconnected: true, network: SHOULDBECONNECTED
2017-06-13 14:10:09 P:Initializing Google Breakpad!
2017-06-13 14:10:09 Current Parameter Settings:
2017-06-13 14:10:09   config = '/data/user/0/de.blinkt.openvpn/cache/android.conf'
2017-06-13 14:10:09   mode = 0
2017-06-13 14:10:09   show_ciphers = DISABLED
2017-06-13 14:10:09   show_digests = DISABLED
2017-06-13 14:10:09   show_engines = DISABLED
2017-06-13 14:10:09   genkey = DISABLED
2017-06-13 14:10:09 Waiting 0s seconds between connection attempt
2017-06-13 14:10:09   key_pass_file = '[uNDEF]'
2017-06-13 14:10:09   show_tls_ciphers = DISABLED
2017-06-13 14:10:09   connect_retry_max = 0
2017-06-13 14:10:09 Connection profiles [0]:
2017-06-13 14:10:09   proto = tcp-client
2017-06-13 14:10:09   local = '[uNDEF]'
2017-06-13 14:10:09   local_port = '[uNDEF]'
2017-06-13 14:10:09   remote = 'europe.vpn.airdns.org'
2017-06-13 14:10:09   remote_port = '80'
2017-06-13 14:10:09   remote_float = DISABLED
2017-06-13 14:10:09   bind_defined = DISABLED
2017-06-13 14:10:09   bind_local = DISABLED
2017-06-13 14:10:09   bind_ipv6_only = DISABLED
2017-06-13 14:10:09   connect_retry_seconds = 2
2017-06-13 14:10:09   connect_timeout = 120
2017-06-13 14:10:09   socks_proxy_server = '[uNDEF]'
2017-06-13 14:10:09   socks_proxy_port = '[uNDEF]'
2017-06-13 14:10:09   tun_mtu = 1500
2017-06-13 14:10:09   tun_mtu_defined = ENABLED
2017-06-13 14:10:09   link_mtu = 1500
2017-06-13 14:10:09   link_mtu_defined = DISABLED
2017-06-13 14:10:09   tun_mtu_extra = 0
2017-06-13 14:10:09   tun_mtu_extra_defined = DISABLED
2017-06-13 14:10:09   mtu_discover_type = -1
2017-06-13 14:10:09   fragment = 0
2017-06-13 14:10:09   mssfix = 1450
2017-06-13 14:10:09   explicit_exit_notification = 0
2017-06-13 14:10:09 Connection profiles END
2017-06-13 14:10:09   remote_random = DISABLED
2017-06-13 14:10:09   ipchange = '[uNDEF]'
2017-06-13 14:10:09   dev = 'tun'
2017-06-13 14:10:09   dev_type = '[uNDEF]'
2017-06-13 14:10:09   dev_node = '[uNDEF]'
2017-06-13 14:10:09   lladdr = '[uNDEF]'
2017-06-13 14:10:09   topology = 1
2017-06-13 14:10:09   ifconfig_local = '[uNDEF]'
2017-06-13 14:10:09   ifconfig_remote_netmask = '[uNDEF]'
2017-06-13 14:10:09   ifconfig_noexec = DISABLED
2017-06-13 14:10:09   ifconfig_nowarn = ENABLED
2017-06-13 14:10:09   ifconfig_ipv6_local = '[uNDEF]'
2017-06-13 14:10:09   ifconfig_ipv6_netbits = 0
2017-06-13 14:10:09   ifconfig_ipv6_remote = '[uNDEF]'
2017-06-13 14:10:09   shaper = 0
2017-06-13 14:10:09   mtu_test = 0
2017-06-13 14:10:09   mlock = DISABLED
2017-06-13 14:10:09   keepalive_ping = 0
2017-06-13 14:10:09   keepalive_timeout = 0
2017-06-13 14:10:09   inactivity_timeout = 0
2017-06-13 14:10:09   ping_send_timeout = 0
2017-06-13 14:10:09   ping_rec_timeout = 0
2017-06-13 14:10:09   ping_rec_timeout_action = 0
2017-06-13 14:10:09   ping_timer_remote = DISABLED
2017-06-13 14:10:09   remap_sigusr1 = 0
2017-06-13 14:10:09   persist_tun = ENABLED
2017-06-13 14:10:09   persist_local_ip = DISABLED
2017-06-13 14:10:09   persist_remote_ip = DISABLED
2017-06-13 14:10:09   persist_key = DISABLED
2017-06-13 14:10:09   passtos = DISABLED
2017-06-13 14:10:09   resolve_retry_seconds = 1000000000
2017-06-13 14:10:09   resolve_in_advance = ENABLED
2017-06-13 14:10:09   username = '[uNDEF]'
2017-06-13 14:10:09   groupname = '[uNDEF]'
2017-06-13 14:10:09   chroot_dir = '[uNDEF]'
2017-06-13 14:10:09   cd_dir = '[uNDEF]'
2017-06-13 14:10:09   writepid = '[uNDEF]'
2017-06-13 14:10:09   up_script = '[uNDEF]'
2017-06-13 14:10:09   down_script = '[uNDEF]'
2017-06-13 14:10:09   down_pre = DISABLED
2017-06-13 14:10:09   up_restart = DISABLED
2017-06-13 14:10:09   up_delay = DISABLED
2017-06-13 14:10:09   daemon = DISABLED
2017-06-13 14:10:09   inetd = 0
2017-06-13 14:10:09   log = DISABLED
2017-06-13 14:10:09   suppress_timestamps = DISABLED
2017-06-13 14:10:09   machine_readable_output = ENABLED
2017-06-13 14:10:09   nice = 0
2017-06-13 14:10:09   verbosity = 4
2017-06-13 14:10:09   mute = 0
2017-06-13 14:10:09   gremlin = 0
2017-06-13 14:10:09   status_file = '[uNDEF]'
2017-06-13 14:10:09   status_file_version = 1
2017-06-13 14:10:09   status_file_update_freq = 60
2017-06-13 14:10:09   occ = ENABLED
2017-06-13 14:10:09   rcvbuf = 262144
2017-06-13 14:10:09   sndbuf = 262144
2017-06-13 14:10:09   sockflags = 0
2017-06-13 14:10:09   fast_io = DISABLED
2017-06-13 14:10:09   comp.alg = 2
2017-06-13 14:10:09   comp.flags = 1
2017-06-13 14:10:09   route_script = '[uNDEF]'
2017-06-13 14:10:09   route_default_gateway = '[uNDEF]'
2017-06-13 14:10:09   route_default_metric = 0
2017-06-13 14:10:09   route_noexec = DISABLED
2017-06-13 14:10:09   route_delay = 0
2017-06-13 14:10:09   route_delay_window = 30
2017-06-13 14:10:09   route_delay_defined = DISABLED
2017-06-13 14:10:09   route_nopull = DISABLED
2017-06-13 14:10:09   route_gateway_via_dhcp = DISABLED
2017-06-13 14:10:09   allow_pull_fqdn = DISABLED
2017-06-13 14:10:09   management_addr = '/data/user/0/de.blinkt.openvpn/cache/mgmtsocket'
2017-06-13 14:10:09   management_port = 'unix'
2017-06-13 14:10:09   management_user_pass = '[uNDEF]'
2017-06-13 14:10:09   management_log_history_cache = 250
2017-06-13 14:10:09   management_echo_buffer_size = 100
2017-06-13 14:10:09   management_write_peer_info_file = '[uNDEF]'
2017-06-13 14:10:09   management_client_user = '[uNDEF]'
2017-06-13 14:10:09   management_client_group = '[uNDEF]'
2017-06-13 14:10:09   management_flags = 4390
2017-06-13 14:10:09   shared_secret_file = '[uNDEF]'
2017-06-13 14:10:09   key_direction = 1
2017-06-13 14:10:09   ciphername = 'AES-256-CBC'
2017-06-13 14:10:09   ncp_enabled = ENABLED
2017-06-13 14:10:09   ncp_ciphers = 'AES-256-GCM:AES-128-GCM'
2017-06-13 14:10:09   authname = 'SHA1'
2017-06-13 14:10:09   prng_hash = 'SHA1'
2017-06-13 14:10:09   prng_nonce_secret_len = 16
2017-06-13 14:10:09   keysize = 0
2017-06-13 14:10:09   engine = DISABLED
2017-06-13 14:10:09   replay = ENABLED
2017-06-13 14:10:09   mute_replay_warnings = DISABLED
2017-06-13 14:10:09   replay_window = 64
2017-06-13 14:10:09   replay_time = 15
2017-06-13 14:10:09   packet_id_file = '[uNDEF]'
2017-06-13 14:10:09   test_crypto = DISABLED
2017-06-13 14:10:09   tls_server = DISABLED
2017-06-13 14:10:09   tls_client = ENABLED
2017-06-13 14:10:09   key_method = 2
2017-06-13 14:10:09   ca_file = '[[iNLINE]]'
2017-06-13 14:10:09   ca_path = '[uNDEF]'
2017-06-13 14:10:09   dh_file = '[uNDEF]'
2017-06-13 14:10:09   cert_file = '[[iNLINE]]'
2017-06-13 14:10:09   extra_certs_file = '[uNDEF]'
2017-06-13 14:10:09   priv_key_file = '[[iNLINE]]'
2017-06-13 14:10:09   pkcs12_file = '[uNDEF]'
2017-06-13 14:10:09   cipher_list = '[uNDEF]'
2017-06-13 14:10:09   tls_verify = '[uNDEF]'
2017-06-13 14:10:09   tls_export_cert = '[uNDEF]'
2017-06-13 14:10:09   verify_x509_type = 0
2017-06-13 14:10:09   verify_x509_name = '[uNDEF]'
2017-06-13 14:10:09   crl_file = '[uNDEF]'
2017-06-13 14:10:09   ns_cert_type = 0
2017-06-13 14:10:09   remote_cert_ku = 65535
2017-06-13 14:10:09   remote_cert_ku = 0
2017-06-13 14:10:09   remote_cert_eku = 'TLS Web Server Authentication'
2017-06-13 14:10:09   ssl_flags = 0
2017-06-13 14:10:09   tls_timeout = 2
2017-06-13 14:10:09   renegotiate_bytes = -1
2017-06-13 14:10:09   renegotiate_packets = 0
2017-06-13 14:10:09   renegotiate_seconds = 3600
2017-06-13 14:10:09   handshake_window = 60
2017-06-13 14:10:09   transition_window = 3600
2017-06-13 14:10:09   single_session = DISABLED
2017-06-13 14:10:09   push_peer_info = DISABLED
2017-06-13 14:10:09   tls_exit = DISABLED
2017-06-13 14:10:09   tls_auth_file = '[[iNLINE]]'
2017-06-13 14:10:09   tls_crypt_file = '[uNDEF]'
2017-06-13 14:10:09   client = ENABLED
2017-06-13 14:10:09   pull = ENABLED
2017-06-13 14:10:09   auth_user_pass_file = '[uNDEF]'
2017-06-13 14:10:09 OpenVPN 2.5-icsopenvpn [git:icsopenvpn-a3a71dc0a6604559] android-14-armeabi-v7a [sSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 11 2017
2017-06-13 14:10:09 library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
2017-06-13 14:10:09 MANAGEMENT: Connected to management server at /data/user/0/de.blinkt.openvpn/cache/mgmtsocket
2017-06-13 14:10:09 MANAGEMENT: CMD 'hold release'
2017-06-13 14:10:09 MANAGEMENT: CMD 'bytecount 2'
2017-06-13 14:10:09 MANAGEMENT: CMD 'proxy NONE'
2017-06-13 14:10:09 MANAGEMENT: CMD 'state on'
2017-06-13 14:10:10 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-06-13 14:10:10 New OpenVPN Status (TCP_CONNECT->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): ,,,,,
2017-06-13 14:10:10 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-06-13 14:10:10 LZO compression initializing
2017-06-13 14:10:10 Control Channel MTU parms [ L:1624 D:1182 EF:68 EB:0 ET:0 EL:3 ]
2017-06-13 14:10:10 Data Channel MTU parms [ L:1624 D:1450 EF:124 EB:406 ET:0 EL:3 ]
2017-06-13 14:10:10 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_CLIENT,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
2017-06-13 14:10:10 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_SERVER,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
2017-06-13 14:10:10 TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.243:80
2017-06-13 14:10:10 Socket Buffers: R=[1048576->425984] S=[524288->425984]
2017-06-13 14:10:10 Attempting to establish TCP connection with [AF_INET]213.152.161.243:80 [nonblock]
2017-06-13 14:10:10 MANAGEMENT: >STATE:1497352210,TCP_CONNECT,,,,,,
2017-06-13 14:10:10 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2017-06-13 14:10:11 TCP connection established with [AF_INET]213.152.161.243:80
2017-06-13 14:10:11 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2017-06-13 14:10:11 New OpenVPN Status (WAIT->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): ,,,,,
2017-06-13 14:10:11 TCP_CLIENT link local: (not bound)
2017-06-13 14:10:11 TCP_CLIENT link remote: [AF_INET]213.152.161.243:80
2017-06-13 14:10:11 MANAGEMENT: >STATE:1497352211,WAIT,,,,,,
2017-06-13 14:10:11 New OpenVPN Status (AUTH->LEVEL_CONNECTING_SERVER_REPLIED): ,,,,,
2017-06-13 14:10:11 MANAGEMENT: >STATE:1497352211,AUTH,,,,,,
2017-06-13 14:10:11 TLS: Initial packet from [AF_INET]213.152.161.243:80, sid=7993ea16 c75e554d
2017-06-13 14:10:11 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
2017-06-13 14:10:11 VERIFY KU OK
2017-06-13 14:10:11 Validating certificate extended key usage
2017-06-13 14:10:11 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
2017-06-13 14:10:11 VERIFY EKU OK
2017-06-13 14:10:11 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cygnus, emailAddress=info@airvpn.org
2017-06-13 14:10:12 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
2017-06-13 14:10:12 [Cygnus] Peer Connection Initiated with [AF_INET]213.152.161.243:80
2017-06-13 14:10:13 New OpenVPN Status (GET_CONFIG->LEVEL_CONNECTING_SERVER_REPLIED): ,,,,,
2017-06-13 14:10:13 MANAGEMENT: >STATE:1497352213,GET_CONFIG,,,,,,
2017-06-13 14:10:13 SENT CONTROL [Cygnus]: 'PUSH_REQUEST' (status=1)
2017-06-13 14:10:13 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.7.0.1,comp-lzo no,route-gateway 10.7.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.7.0.49 255.255.0.0,peer-id 0,cipher AES-256-GCM'
2017-06-13 14:10:13 OPTIONS IMPORT: timers and/or timeouts modified
2017-06-13 14:10:13 OPTIONS IMPORT: compression parms modified
2017-06-13 14:10:13 OPTIONS IMPORT: --ifconfig/up options modified
2017-06-13 14:10:13 OPTIONS IMPORT: route options modified
2017-06-13 14:10:13 OPTIONS IMPORT: route-related options modified
2017-06-13 14:10:13 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2017-06-13 14:10:13 OPTIONS IMPORT: peer-id set
2017-06-13 14:10:13 New OpenVPN Status (ASSIGN_IP->LEVEL_CONNECTING_SERVER_REPLIED): ,10.7.0.49,,,,
2017-06-13 14:10:13 OPTIONS IMPORT: adjusting link_mtu to 1627
2017-06-13 14:10:13 OPTIONS IMPORT: data channel crypto options modified
2017-06-13 14:10:13 Data Channel MTU parms [ L:1555 D:1450 EF:55 EB:406 ET:0 EL:3 ]
2017-06-13 14:10:13 Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
2017-06-13 14:10:13 Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
2017-06-13 14:10:13 ROUTE_GATEWAY 127.100.103.119/255.0.0.0 IFACE=lo HWADDR=00:00:00:00:00:00
2017-06-13 14:10:13 do_ifconfig, tt->did_ifconfig_ipv6_setup=0
2017-06-13 14:10:13 MANAGEMENT: >STATE:1497352213,ASSIGN_IP,,10.7.0.49,,,,
2017-06-13 14:10:13 MANAGEMENT: CMD 'needok 'IFCONFIG' ok'
2017-06-13 14:10:13 MANAGEMENT: CMD 'needok 'ROUTE' ok'
2017-06-13 14:10:13 MANAGEMENT: CMD 'needok 'DNSSERVER' ok'
2017-06-13 14:10:13 MANAGEMENT: CMD 'needok 'PERSIST_TUN_ACTION' OPEN_BEFORE_CLOSE'
2017-06-13 14:10:13 Opening tun interface:
2017-06-13 14:10:13 Ignoring multicast route: 224.0.0.0/3
2017-06-13 14:10:13 Local IPv4: 10.7.0.49/16 IPv6: null MTU: 1500
2017-06-13 14:10:13 DNS Server: 10.7.0.1, Domain: null
2017-06-13 14:10:13 Routes: 0.0.0.0/010.7.0.0/16
2017-06-13 14:10:13 Routes excluded: 192.168.1.23/24
2017-06-13 14:10:13 VpnService routes installed: 0.0.0.0/1128.0.0.0/2192.0.0.0/9192.128.0.0/11192.160.0.0/13192.168.0.0/24192.168.2.0/23192.168.4.0/22192.168.8.0/21192.168.16.0/20192.168.32.0/19192.168.64.0/18192.168.128.0/17192.169.0.0/16192.170.0.0/15192.172.0.0/14192.176.0.0/12192.192.0.0/10193.0.0.0/8194.0.0.0/7196.0.0.0/6200.0.0.0/5208.0.0.0/4224.0.0.0/3
2017-06-13 14:10:13 Disallowed VPN apps:
2017-06-13 14:10:13 MANAGEMENT: CMD 'needok 'OPENTUN' ok'
2017-06-13 14:10:13 Initialization Sequence Completed
2017-06-13 14:10:13 MANAGEMENT: >STATE:1497352213,CONNECTED,SUCCESS,10.7.0.49,213.152.161.243,80,192.168.1.23,39316
2017-06-13 14:10:13 New OpenVPN Status (CONNECTED->LEVEL_CONNECTED): SUCCESS,10.7.0.49,213.152.161.243,80,192.168.1.23,39316
2017-06-13 14:10:14 New OpenVPN Status (CONNECTED->LEVEL_CONNECTED): SUCCESS,10.7.0.49,213.152.161.243,80,192.168.1.23,39316
2017-06-13 14:10:14 Debug state info: CONNECTED  to WIFI "BrkCgl", pause: userPause, shouldbeconnected: true, network: SHOULDBECONNECTED
Log-2
2017-06-13 17:26:13 official build 0.6.66 running on Amlogic MINIM8S II (p212), Android 6.0.1 (MHC19J) API 23, ABI armeabi-v7a, (Amlogic/p212/p212:6.0.1/MHC19J/20161013:userdebug/test-keys)
2017-06-13 17:26:13 Building configuration…
2017-06-13 17:26:13 New OpenVPN Status (VPN_GENERATE_CONFIG->LEVEL_START):
2017-06-13 17:26:13 MANAGEMENT: CMD 'signal SIGINT'
2017-06-13 17:26:13 TCP/UDP: Closing socket
2017-06-13 17:26:13 Sorry, deleting routes on Android is not possible. The VpnService API allows routes to be set on connect only.
2017-06-13 17:26:13 Closing TUN/TAP interface
2017-06-13 17:26:13 SIGINT[hard,] received, process exiting
2017-06-13 17:26:13 MANAGEMENT: >STATE:1497363973,EXITING,SIGINT,,,,,
2017-06-13 17:26:14 started Socket Thread
2017-06-13 17:26:14 Network Status: CONNECTED  to WIFI "BrkCgl"
2017-06-13 17:26:14 Debug state info: CONNECTED  to WIFI "BrkCgl", pause: userPause, shouldbeconnected: true, network: SHOULDBECONNECTED
2017-06-13 17:26:14 P:Initializing Google Breakpad!
2017-06-13 17:26:14 Current Parameter Settings:
2017-06-13 17:26:14   config = '/data/user/0/de.blinkt.openvpn/cache/android.conf'
2017-06-13 17:26:14   mode = 0
2017-06-13 17:26:14 Waiting 0s seconds between connection attempt
2017-06-13 17:26:14   show_ciphers = DISABLED
2017-06-13 17:26:14   show_digests = DISABLED
2017-06-13 17:26:14   show_engines = DISABLED
2017-06-13 17:26:14   genkey = DISABLED
2017-06-13 17:26:14   key_pass_file = '[uNDEF]'
2017-06-13 17:26:14   show_tls_ciphers = DISABLED
2017-06-13 17:26:14   connect_retry_max = 0
2017-06-13 17:26:14 Connection profiles [0]:
2017-06-13 17:26:14   proto = tcp-client
2017-06-13 17:26:14   local = '[uNDEF]'
2017-06-13 17:26:14   local_port = '[uNDEF]'
2017-06-13 17:26:14   remote = 'gb.vpn.airdns.org'
2017-06-13 17:26:14   remote_port = '443'
2017-06-13 17:26:14   remote_float = DISABLED
2017-06-13 17:26:14   bind_defined = DISABLED
2017-06-13 17:26:15   bind_local = DISABLED
2017-06-13 17:26:15   bind_ipv6_only = DISABLED
2017-06-13 17:26:15   connect_retry_seconds = 2
2017-06-13 17:26:15   connect_timeout = 120
2017-06-13 17:26:15   socks_proxy_server = '[uNDEF]'
2017-06-13 17:26:15   socks_proxy_port = '[uNDEF]'
2017-06-13 17:26:15   tun_mtu = 1500
2017-06-13 17:26:15   tun_mtu_defined = ENABLED
2017-06-13 17:26:15   link_mtu = 1500
2017-06-13 17:26:15   link_mtu_defined = DISABLED
2017-06-13 17:26:15   tun_mtu_extra = 0
2017-06-13 17:26:15   tun_mtu_extra_defined = DISABLED
2017-06-13 17:26:15   mtu_discover_type = -1
2017-06-13 17:26:15   fragment = 0
2017-06-13 17:26:15   mssfix = 1450
2017-06-13 17:26:15   explicit_exit_notification = 0
2017-06-13 17:26:15 Connection profiles END
2017-06-13 17:26:15   remote_random = DISABLED
2017-06-13 17:26:15   ipchange = '[uNDEF]'
2017-06-13 17:26:15   dev = 'tun'
2017-06-13 17:26:15   dev_type = '[uNDEF]'
2017-06-13 17:26:15   dev_node = '[uNDEF]'
2017-06-13 17:26:15   lladdr = '[uNDEF]'
2017-06-13 17:26:15   topology = 1
2017-06-13 17:26:15   ifconfig_local = '[uNDEF]'
2017-06-13 17:26:15   ifconfig_remote_netmask = '[uNDEF]'
2017-06-13 17:26:15   ifconfig_noexec = DISABLED
2017-06-13 17:26:15   ifconfig_nowarn = ENABLED
2017-06-13 17:26:15   ifconfig_ipv6_local = '[uNDEF]'
2017-06-13 17:26:15   ifconfig_ipv6_netbits = 0
2017-06-13 17:26:15   ifconfig_ipv6_remote = '[uNDEF]'
2017-06-13 17:26:15   shaper = 0
2017-06-13 17:26:15   mtu_test = 0
2017-06-13 17:26:15   mlock = DISABLED
2017-06-13 17:26:15   keepalive_ping = 0
2017-06-13 17:26:15   keepalive_timeout = 0
2017-06-13 17:26:15   inactivity_timeout = 0
2017-06-13 17:26:15   ping_send_timeout = 0
2017-06-13 17:26:15   ping_rec_timeout = 0
2017-06-13 17:26:15   ping_rec_timeout_action = 0
2017-06-13 17:26:15   ping_timer_remote = DISABLED
2017-06-13 17:26:15   remap_sigusr1 = 0
2017-06-13 17:26:15   persist_tun = ENABLED
2017-06-13 17:26:15   persist_local_ip = DISABLED
2017-06-13 17:26:15   persist_remote_ip = DISABLED
2017-06-13 17:26:15   persist_key = DISABLED
2017-06-13 17:26:15   passtos = DISABLED
2017-06-13 17:26:15   resolve_retry_seconds = 1000000000
2017-06-13 17:26:15   resolve_in_advance = ENABLED
2017-06-13 17:26:15   username = '[uNDEF]'
2017-06-13 17:26:15   groupname = '[uNDEF]'
2017-06-13 17:26:15   chroot_dir = '[uNDEF]'
2017-06-13 17:26:15   cd_dir = '[uNDEF]'
2017-06-13 17:26:15   writepid = '[uNDEF]'
2017-06-13 17:26:15   up_script = '[uNDEF]'
2017-06-13 17:26:15   down_script = '[uNDEF]'
2017-06-13 17:26:15   down_pre = DISABLED
2017-06-13 17:26:15   up_restart = DISABLED
2017-06-13 17:26:15   up_delay = DISABLED
2017-06-13 17:26:15   daemon = DISABLED
2017-06-13 17:26:15   inetd = 0
2017-06-13 17:26:15   log = DISABLED
2017-06-13 17:26:15   suppress_timestamps = DISABLED
2017-06-13 17:26:15   machine_readable_output = ENABLED
2017-06-13 17:26:15   nice = 0
2017-06-13 17:26:15   verbosity = 4
2017-06-13 17:26:15   mute = 0
2017-06-13 17:26:15   gremlin = 0
2017-06-13 17:26:15   status_file = '[uNDEF]'
2017-06-13 17:26:15   status_file_version = 1
2017-06-13 17:26:15   status_file_update_freq = 60
2017-06-13 17:26:15   occ = ENABLED
2017-06-13 17:26:15   rcvbuf = 0
2017-06-13 17:26:15   sndbuf = 0
2017-06-13 17:26:15   sockflags = 0
2017-06-13 17:26:15   fast_io = DISABLED
2017-06-13 17:26:15   comp.alg = 2
2017-06-13 17:26:15   comp.flags = 1
2017-06-13 17:26:15   route_script = '[uNDEF]'
2017-06-13 17:26:15   route_default_gateway = '[uNDEF]'
2017-06-13 17:26:15   route_default_metric = 0
2017-06-13 17:26:15   route_noexec = DISABLED
2017-06-13 17:26:15   route_delay = 0
2017-06-13 17:26:15   route_delay_window = 30
2017-06-13 17:26:15   route_delay_defined = DISABLED
2017-06-13 17:26:15   route_nopull = DISABLED
2017-06-13 17:26:15   route_gateway_via_dhcp = DISABLED
2017-06-13 17:26:15   allow_pull_fqdn = DISABLED
2017-06-13 17:26:15   management_addr = '/data/user/0/de.blinkt.openvpn/cache/mgmtsocket'
2017-06-13 17:26:15   management_port = 'unix'
2017-06-13 17:26:15   management_user_pass = '[uNDEF]'
2017-06-13 17:26:15   management_log_history_cache = 250
2017-06-13 17:26:15   management_echo_buffer_size = 100
2017-06-13 17:26:15   management_write_peer_info_file = '[uNDEF]'
2017-06-13 17:26:15   management_client_user = '[uNDEF]'
2017-06-13 17:26:15   management_client_group = '[uNDEF]'
2017-06-13 17:26:15   management_flags = 4390
2017-06-13 17:26:15   shared_secret_file = '[uNDEF]'
2017-06-13 17:26:15   key_direction = 1
2017-06-13 17:26:15   ciphername = 'AES-256-CBC'
2017-06-13 17:26:15   ncp_enabled = ENABLED
2017-06-13 17:26:15   ncp_ciphers = 'AES-256-GCM:AES-128-GCM'
2017-06-13 17:26:15   authname = 'SHA1'
2017-06-13 17:26:15   prng_hash = 'SHA1'
2017-06-13 17:26:15   prng_nonce_secret_len = 16
2017-06-13 17:26:15   keysize = 0
2017-06-13 17:26:15   engine = DISABLED
2017-06-13 17:26:15   replay = ENABLED
2017-06-13 17:26:15   mute_replay_warnings = DISABLED
2017-06-13 17:26:15   replay_window = 64
2017-06-13 17:26:15   replay_time = 15
2017-06-13 17:26:15   packet_id_file = '[uNDEF]'
2017-06-13 17:26:15   test_crypto = DISABLED
2017-06-13 17:26:15   tls_server = DISABLED
2017-06-13 17:26:15   tls_client = ENABLED
2017-06-13 17:26:15   key_method = 2
2017-06-13 17:26:15   ca_file = '[[iNLINE]]'
2017-06-13 17:26:15   ca_path = '[uNDEF]'
2017-06-13 17:26:15   dh_file = '[uNDEF]'
2017-06-13 17:26:15   cert_file = '[[iNLINE]]'
2017-06-13 17:26:15   extra_certs_file = '[uNDEF]'
2017-06-13 17:26:15   priv_key_file = '[[iNLINE]]'
2017-06-13 17:26:15   pkcs12_file = '[uNDEF]'
2017-06-13 17:26:15   cipher_list = '[uNDEF]'
2017-06-13 17:26:15   tls_verify = '[uNDEF]'
2017-06-13 17:26:15   tls_export_cert = '[uNDEF]'
2017-06-13 17:26:15   verify_x509_type = 0
2017-06-13 17:26:15   verify_x509_name = '[uNDEF]'
2017-06-13 17:26:15   crl_file = '[uNDEF]'
2017-06-13 17:26:15   ns_cert_type = 0
2017-06-13 17:26:15   remote_cert_ku = 65535
2017-06-13 17:26:15   remote_cert_ku = 0
2017-06-13 17:26:15   remote_cert_eku = 'TLS Web Server Authentication'
2017-06-13 17:26:15   ssl_flags = 0
2017-06-13 17:26:15   tls_timeout = 2
2017-06-13 17:26:15   renegotiate_bytes = -1
2017-06-13 17:26:15   renegotiate_packets = 0
2017-06-13 17:26:15   renegotiate_seconds = 3600
2017-06-13 17:26:15   handshake_window = 60
2017-06-13 17:26:15   transition_window = 3600
2017-06-13 17:26:15   single_session = DISABLED
2017-06-13 17:26:15   push_peer_info = DISABLED
2017-06-13 17:26:15   tls_exit = DISABLED
2017-06-13 17:26:15   tls_auth_file = '[[iNLINE]]'
2017-06-13 17:26:15   tls_crypt_file = '[uNDEF]'
2017-06-13 17:26:15   client = ENABLED
2017-06-13 17:26:15   pull = ENABLED
2017-06-13 17:26:15   auth_user_pass_file = '[uNDEF]'
2017-06-13 17:26:15 OpenVPN 2.5-icsopenvpn [git:icsopenvpn-a3a71dc0a6604559] android-14-armeabi-v7a [sSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 11 2017
2017-06-13 17:26:15 library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
2017-06-13 17:26:15 MANAGEMENT: Connected to management server at /data/user/0/de.blinkt.openvpn/cache/mgmtsocket
2017-06-13 17:26:15 MANAGEMENT: CMD 'hold release'
2017-06-13 17:26:15 MANAGEMENT: CMD 'proxy NONE'
2017-06-13 17:26:15 MANAGEMENT: CMD 'bytecount 2'
2017-06-13 17:26:15 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-06-13 17:26:15 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-06-13 17:26:15 LZO compression initializing
2017-06-13 17:26:15 Control Channel MTU parms [ L:1624 D:1182 EF:68 EB:0 ET:0 EL:3 ]
2017-06-13 17:26:15 Data Channel MTU parms [ L:1624 D:1450 EF:124 EB:406 ET:0 EL:3 ]
2017-06-13 17:26:15 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_CLIENT,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
2017-06-13 17:26:15 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_SERVER,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
2017-06-13 17:26:15 TCP/UDP: Preserving recently used remote address: [AF_INET]185.103.96.133:443
2017-06-13 17:26:15 Socket Buffers: R=[1048576->1048576] S=[524288->524288]
2017-06-13 17:26:15 Attempting to establish TCP connection with [AF_INET]185.103.96.133:443 [nonblock]
2017-06-13 17:26:15 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2017-06-13 17:26:15 MANAGEMENT: CMD 'state on'
2017-06-13 17:26:16 TCP connection established with [AF_INET]185.103.96.133:443
2017-06-13 17:26:16 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2017-06-13 17:26:16 TCP_CLIENT link local: (not bound)
2017-06-13 17:26:16 TCP_CLIENT link remote: [AF_INET]185.103.96.133:443
2017-06-13 17:26:16 MANAGEMENT: >STATE:1497363976,WAIT,,,,,,
2017-06-13 17:26:16 New OpenVPN Status (WAIT->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): ,,,,,
2017-06-13 17:26:16 MANAGEMENT: >STATE:1497363976,AUTH,,,,,,
2017-06-13 17:26:16 TLS: Initial packet from [AF_INET]185.103.96.133:443, sid=f3747792 0e7b1514
2017-06-13 17:26:16 New OpenVPN Status (AUTH->LEVEL_CONNECTING_SERVER_REPLIED): ,,,,,
2017-06-13 17:26:16 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
2017-06-13 17:26:16 VERIFY KU OK
2017-06-13 17:26:16 Validating certificate extended key usage
2017-06-13 17:26:16 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
2017-06-13 17:26:16 VERIFY EKU OK
2017-06-13 17:26:16 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
2017-06-13 17:26:17 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
2017-06-13 17:26:17 [server] Peer Connection Initiated with [AF_INET]185.103.96.133:443
2017-06-13 17:26:18 New OpenVPN Status (GET_CONFIG->LEVEL_CONNECTING_SERVER_REPLIED): ,,,,,
2017-06-13 17:26:18 MANAGEMENT: >STATE:1497363978,GET_CONFIG,,,,,,
2017-06-13 17:26:18 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2017-06-13 17:26:18 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.5.0.1,comp-lzo no,route-gateway 10.5.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.5.3.206 255.255.0.0'
2017-06-13 17:26:18 OPTIONS IMPORT: timers and/or timeouts modified
2017-06-13 17:26:18 OPTIONS IMPORT: compression parms modified
2017-06-13 17:26:18 OPTIONS IMPORT: --ifconfig/up options modified
2017-06-13 17:26:18 New OpenVPN Status (ASSIGN_IP->LEVEL_CONNECTING_SERVER_REPLIED): ,10.5.3.206,,,,
2017-06-13 17:26:18 OPTIONS IMPORT: route options modified
2017-06-13 17:26:18 OPTIONS IMPORT: route-related options modified
2017-06-13 17:26:18 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2017-06-13 17:26:18 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:406 ET:0 EL:3 ]
2017-06-13 17:26:18 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2017-06-13 17:26:18 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-06-13 17:26:18 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2017-06-13 17:26:18 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-06-13 17:26:18 ROUTE_GATEWAY 127.100.103.119/255.0.0.0 IFACE=lo HWADDR=00:00:00:00:00:00
2017-06-13 17:26:18 do_ifconfig, tt->did_ifconfig_ipv6_setup=0
2017-06-13 17:26:18 MANAGEMENT: >STATE:1497363978,ASSIGN_IP,,10.5.3.206,,,,
2017-06-13 17:26:18 Opening tun interface:
2017-06-13 17:26:18 MANAGEMENT: CMD 'needok 'IFCONFIG' ok'
2017-06-13 17:26:18 MANAGEMENT: CMD 'needok 'ROUTE' ok'
2017-06-13 17:26:18 MANAGEMENT: CMD 'needok 'DNSSERVER' ok'
2017-06-13 17:26:18 MANAGEMENT: CMD 'needok 'PERSIST_TUN_ACTION' OPEN_BEFORE_CLOSE'
2017-06-13 17:26:18 Ignoring multicast route: 224.0.0.0/3
2017-06-13 17:26:18 Local IPv4: 10.5.3.206/16 IPv6: null MTU: 1500
2017-06-13 17:26:18 DNS Server: 10.5.0.1, Domain: null
2017-06-13 17:26:18 Routes: 0.0.0.0/010.5.0.0/16
2017-06-13 17:26:18 Routes excluded: 192.168.1.23/24
2017-06-13 17:26:18 VpnService routes installed: 0.0.0.0/1128.0.0.0/2192.0.0.0/9192.128.0.0/11192.160.0.0/13192.168.0.0/24192.168.2.0/23192.168.4.0/22192.168.8.0/21192.168.16.0/20192.168.32.0/19192.168.64.0/18192.168.128.0/17192.169.0.0/16192.170.0.0/15192.172.0.0/14192.176.0.0/12192.192.0.0/10193.0.0.0/8194.0.0.0/7196.0.0.0/6200.0.0.0/5208.0.0.0/4224.0.0.0/3
2017-06-13 17:26:18 Disallowed VPN apps:
2017-06-13 17:26:19 MANAGEMENT: CMD 'needok 'OPENTUN' ok'
2017-06-13 17:26:19 Initialization Sequence Completed
2017-06-13 17:26:19 MANAGEMENT: >STATE:1497363979,CONNECTED,SUCCESS,10.5.3.206,185.103.96.133,443,192.168.1.23,60541
2017-06-13 17:26:19 New OpenVPN Status (CONNECTED->LEVEL_CONNECTED): SUCCESS,10.5.3.206,185.103.96.133,443,192.168.1.23,60541
2017-06-13 17:26:19 Debug state info: CONNECTED  to WIFI "BrkCgl", pause: userPause, shouldbeconnected: true, network: SHOULDBECONNECTED
@zhang888
Dear zhang888,
Thank you very much for your response. It is correct that the device is a crappy android box, having Amlogic S905X CPU and 2GB RAM, and I understand that there will be CPU limitations, but I doubt it is the issue.
I assume that, if the issue was related to CPU limitations, I would encounter similar slow DL speeds with all servers. However I do not. Some of the servers are giving me ~1Mbps, while others are around 10Mbps. It is hard trying to find a server supporting a normal DL speed (let's say around 5Mbps would be fine for my purpose) by connecting and testing all the time.
If you want, I can also put logs of the openvpn from a connection having a normal DL speed.
Posting new logs with AirVPN speedtest:
DE Server
Down: 1.089 Mbit/s Out, 1.046 Mbit/s In (96%), 1MB - Up: 2.951 Mbit/s Out, 2.982 Mbit/s In (101%), 20MB - Date: Thu, 15 Jun 2017 13:09:48 GMT - Buffers: 1MB/20MB - Laps: 3, Time: 236.09 secs
2017-06-15 16:09:07 official build 0.6.70 running on Amlogic MINIM8S II (p212), Android 6.0.1 (MHC19J) API 23, ABI armeabi-v7a, (Amlogic/p212/p212:6.0.1/MHC19J/20161013:userdebug/test-keys)
2017-06-15 16:09:08 Building configuration…
2017-06-15 16:09:08 New OpenVPN Status (VPN_GENERATE_CONFIG->LEVEL_START):
2017-06-15 16:09:08 MANAGEMENT: CMD 'signal SIGINT'
2017-06-15 16:09:08 TCP/UDP: Closing socket
2017-06-15 16:09:08 Sorry, deleting routes on Android is not possible. The VpnService API allows routes to be set on connect only.
2017-06-15 16:09:08 Closing TUN/TAP interface
2017-06-15 16:09:08 SIGINT[hard,] received, process exiting
2017-06-15 16:09:08 MANAGEMENT: >STATE:1497532148,EXITING,SIGINT,,,,,
2017-06-15 16:09:09 started Socket Thread
2017-06-15 16:09:09 Network Status: CONNECTED  to WIFI "BrkCgl"
2017-06-15 16:09:09 Debug state info: CONNECTED  to WIFI "BrkCgl", pause: userPause, shouldbeconnected: true, network: SHOULDBECONNECTED
2017-06-15 16:09:09 P:Initializing Google Breakpad!
2017-06-15 16:09:09 Waiting 0s seconds between connection attempt
2017-06-15 16:09:09 Current Parameter Settings:
2017-06-15 16:09:09   config = '/data/user/0/de.blinkt.openvpn/cache/android.conf'
2017-06-15 16:09:09   mode = 0
2017-06-15 16:09:09   show_ciphers = DISABLED
2017-06-15 16:09:09   show_digests = DISABLED
2017-06-15 16:09:09   show_engines = DISABLED
2017-06-15 16:09:09   genkey = DISABLED
2017-06-15 16:09:09   key_pass_file = '[uNDEF]'
2017-06-15 16:09:09   show_tls_ciphers = DISABLED
2017-06-15 16:09:09   connect_retry_max = 0
2017-06-15 16:09:09 Connection profiles [0]:
2017-06-15 16:09:09   proto = tcp-client
2017-06-15 16:09:09   local = '[uNDEF]'
2017-06-15 16:09:09   local_port = '[uNDEF]'
2017-06-15 16:09:09   remote = 'de.vpn.airdns.org'
2017-06-15 16:09:09   remote_port = '443'
2017-06-15 16:09:09   remote_float = DISABLED
2017-06-15 16:09:09   bind_defined = DISABLED
2017-06-15 16:09:09   bind_local = DISABLED
2017-06-15 16:09:09   bind_ipv6_only = DISABLED
2017-06-15 16:09:09   connect_retry_seconds = 2
2017-06-15 16:09:09   connect_timeout = 120
2017-06-15 16:09:09   socks_proxy_server = '[uNDEF]'
2017-06-15 16:09:09   socks_proxy_port = '[uNDEF]'
2017-06-15 16:09:09   tun_mtu = 1500
2017-06-15 16:09:09   tun_mtu_defined = ENABLED
2017-06-15 16:09:09   link_mtu = 1500
2017-06-15 16:09:09   link_mtu_defined = DISABLED
2017-06-15 16:09:09   tun_mtu_extra = 0
2017-06-15 16:09:09   tun_mtu_extra_defined = DISABLED
2017-06-15 16:09:09   mtu_discover_type = -1
2017-06-15 16:09:09   fragment = 0
2017-06-15 16:09:09   mssfix = 1450
2017-06-15 16:09:09   explicit_exit_notification = 0
2017-06-15 16:09:09 Connection profiles END
2017-06-15 16:09:09   remote_random = DISABLED
2017-06-15 16:09:09   ipchange = '[uNDEF]'
2017-06-15 16:09:09   dev = 'tun'
2017-06-15 16:09:09   dev_type = '[uNDEF]'
2017-06-15 16:09:09   dev_node = '[uNDEF]'
2017-06-15 16:09:09   lladdr = '[uNDEF]'
2017-06-15 16:09:09   topology = 1
2017-06-15 16:09:09   ifconfig_local = '[uNDEF]'
2017-06-15 16:09:09   ifconfig_remote_netmask = '[uNDEF]'
2017-06-15 16:09:09   ifconfig_noexec = DISABLED
2017-06-15 16:09:09   ifconfig_nowarn = ENABLED
2017-06-15 16:09:09   ifconfig_ipv6_local = '[uNDEF]'
2017-06-15 16:09:09   ifconfig_ipv6_netbits = 0
2017-06-15 16:09:09   ifconfig_ipv6_remote = '[uNDEF]'
2017-06-15 16:09:09   shaper = 0
2017-06-15 16:09:09   mtu_test = 0
2017-06-15 16:09:09   mlock = DISABLED
2017-06-15 16:09:09   keepalive_ping = 0
2017-06-15 16:09:09   keepalive_timeout = 0
2017-06-15 16:09:09   inactivity_timeout = 0
2017-06-15 16:09:09   ping_send_timeout = 0
2017-06-15 16:09:09   ping_rec_timeout = 0
2017-06-15 16:09:09   ping_rec_timeout_action = 0
2017-06-15 16:09:09   ping_timer_remote = DISABLED
2017-06-15 16:09:09   remap_sigusr1 = 0
2017-06-15 16:09:09   persist_tun = ENABLED
2017-06-15 16:09:10   persist_local_ip = DISABLED
2017-06-15 16:09:10   persist_remote_ip = DISABLED
2017-06-15 16:09:10   persist_key = DISABLED
2017-06-15 16:09:10   passtos = DISABLED
2017-06-15 16:09:10   resolve_retry_seconds = 1000000000
2017-06-15 16:09:10   resolve_in_advance = ENABLED
2017-06-15 16:09:10   username = '[uNDEF]'
2017-06-15 16:09:10   groupname = '[uNDEF]'
2017-06-15 16:09:10   chroot_dir = '[uNDEF]'
2017-06-15 16:09:10   cd_dir = '[uNDEF]'
2017-06-15 16:09:10   writepid = '[uNDEF]'
2017-06-15 16:09:10   up_script = '[uNDEF]'
2017-06-15 16:09:10   down_script = '[uNDEF]'
2017-06-15 16:09:10   down_pre = DISABLED
2017-06-15 16:09:10   up_restart = DISABLED
2017-06-15 16:09:10   up_delay = DISABLED
2017-06-15 16:09:10   daemon = DISABLED
2017-06-15 16:09:10   inetd = 0
2017-06-15 16:09:10   log = DISABLED
2017-06-15 16:09:10   suppress_timestamps = DISABLED
2017-06-15 16:09:10   machine_readable_output = ENABLED
2017-06-15 16:09:10   nice = 0
2017-06-15 16:09:10   verbosity = 4
2017-06-15 16:09:10   mute = 0
2017-06-15 16:09:10   gremlin = 0
2017-06-15 16:09:10   status_file = '[uNDEF]'
2017-06-15 16:09:10   status_file_version = 1
2017-06-15 16:09:10   status_file_update_freq = 60
2017-06-15 16:09:10   occ = ENABLED
2017-06-15 16:09:10   rcvbuf = 0
2017-06-15 16:09:10   sndbuf = 0
2017-06-15 16:09:10   sockflags = 0
2017-06-15 16:09:10   fast_io = DISABLED
2017-06-15 16:09:10   comp.alg = 2
2017-06-15 16:09:10   comp.flags = 1
2017-06-15 16:09:10   route_script = '[uNDEF]'
2017-06-15 16:09:10   route_default_gateway = '[uNDEF]'
2017-06-15 16:09:10   route_default_metric = 0
2017-06-15 16:09:10   route_noexec = DISABLED
2017-06-15 16:09:10   route_delay = 0
2017-06-15 16:09:10   route_delay_window = 30
2017-06-15 16:09:10   route_delay_defined = DISABLED
2017-06-15 16:09:10   route_nopull = DISABLED
2017-06-15 16:09:10   route_gateway_via_dhcp = DISABLED
2017-06-15 16:09:10   allow_pull_fqdn = DISABLED
2017-06-15 16:09:10   management_addr = '/data/user/0/de.blinkt.openvpn/cache/mgmtsocket'
2017-06-15 16:09:10   management_port = 'unix'
2017-06-15 16:09:10   management_user_pass = '[uNDEF]'
2017-06-15 16:09:10   management_log_history_cache = 250
2017-06-15 16:09:10   management_echo_buffer_size = 100
2017-06-15 16:09:10   management_write_peer_info_file = '[uNDEF]'
2017-06-15 16:09:10   management_client_user = '[uNDEF]'
2017-06-15 16:09:10   management_client_group = '[uNDEF]'
2017-06-15 16:09:10   management_flags = 4390
2017-06-15 16:09:10   shared_secret_file = '[uNDEF]'
2017-06-15 16:09:10   key_direction = 1
2017-06-15 16:09:10   ciphername = 'AES-256-CBC'
2017-06-15 16:09:10   ncp_enabled = ENABLED
2017-06-15 16:09:10   ncp_ciphers = 'AES-256-GCM:AES-128-GCM'
2017-06-15 16:09:10   authname = 'SHA1'
2017-06-15 16:09:10   prng_hash = 'SHA1'
2017-06-15 16:09:10   prng_nonce_secret_len = 16
2017-06-15 16:09:10   keysize = 0
2017-06-15 16:09:10   engine = DISABLED
2017-06-15 16:09:10   replay = ENABLED
2017-06-15 16:09:10   mute_replay_warnings = DISABLED
2017-06-15 16:09:10   replay_window = 64
2017-06-15 16:09:10   replay_time = 15
2017-06-15 16:09:10   packet_id_file = '[uNDEF]'
2017-06-15 16:09:10   test_crypto = DISABLED
2017-06-15 16:09:10   tls_server = DISABLED
2017-06-15 16:09:10   tls_client = ENABLED
2017-06-15 16:09:10   key_method = 2
2017-06-15 16:09:10   ca_file = '[[iNLINE]]'
2017-06-15 16:09:10   ca_path = '[uNDEF]'
2017-06-15 16:09:10   dh_file = '[uNDEF]'
2017-06-15 16:09:10   cert_file = '[[iNLINE]]'
2017-06-15 16:09:10   extra_certs_file = '[uNDEF]'
2017-06-15 16:09:10   priv_key_file = '[[iNLINE]]'
2017-06-15 16:09:10   pkcs12_file = '[uNDEF]'
2017-06-15 16:09:10   cipher_list = '[uNDEF]'
2017-06-15 16:09:10   tls_verify = '[uNDEF]'
2017-06-15 16:09:10   tls_export_cert = '[uNDEF]'
2017-06-15 16:09:10   verify_x509_type = 0
2017-06-15 16:09:10   verify_x509_name = '[uNDEF]'
2017-06-15 16:09:10   crl_file = '[uNDEF]'
2017-06-15 16:09:10   ns_cert_type = 0
2017-06-15 16:09:10   remote_cert_ku = 65535
2017-06-15 16:09:10   remote_cert_ku = 0
2017-06-15 16:09:10   remote_cert_eku = 'TLS Web Server Authentication'
2017-06-15 16:09:10   ssl_flags = 0
2017-06-15 16:09:10   tls_timeout = 2
2017-06-15 16:09:10   renegotiate_bytes = -1
2017-06-15 16:09:10   renegotiate_packets = 0
2017-06-15 16:09:10   renegotiate_seconds = 3600
2017-06-15 16:09:10   handshake_window = 60
2017-06-15 16:09:10   transition_window = 3600
2017-06-15 16:09:10   single_session = DISABLED
2017-06-15 16:09:10   push_peer_info = DISABLED
2017-06-15 16:09:10   tls_exit = DISABLED
2017-06-15 16:09:10   tls_auth_file = '[[iNLINE]]'
2017-06-15 16:09:10   tls_crypt_file = '[uNDEF]'
2017-06-15 16:09:10   client = ENABLED
2017-06-15 16:09:10   pull = ENABLED
2017-06-15 16:09:10   auth_user_pass_file = '[uNDEF]'
2017-06-15 16:09:10 OpenVPN 2.5-icsopenvpn [git:icsopenvpn-a3a71dc0a6604559] android-14-armeabi-v7a [sSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 29 2017
2017-06-15 16:09:10 library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.09
2017-06-15 16:09:10 MANAGEMENT: Connected to management server at /data/user/0/de.blinkt.openvpn/cache/mgmtsocket
2017-06-15 16:09:10 MANAGEMENT: CMD 'hold release'
2017-06-15 16:09:14 MANAGEMENT: CMD 'bytecount 2'
2017-06-15 16:09:14 MANAGEMENT: CMD 'proxy NONE'
2017-06-15 16:09:14 MANAGEMENT: CMD 'state on'
2017-06-15 16:09:15 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-06-15 16:09:15 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-06-15 16:09:15 New OpenVPN Status (TCP_CONNECT->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): ,,,,,
2017-06-15 16:09:15 LZO compression initializing
2017-06-15 16:09:15 Control Channel MTU parms [ L:1624 D:1182 EF:68 EB:0 ET:0 EL:3 ]
2017-06-15 16:09:15 Data Channel MTU parms [ L:1624 D:1450 EF:124 EB:406 ET:0 EL:3 ]
2017-06-15 16:09:15 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_CLIENT,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
2017-06-15 16:09:15 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_SERVER,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
2017-06-15 16:09:16 TCP/UDP: Preserving recently used remote address: [AF_INET]178.162.198.102:443
2017-06-15 16:09:16 Socket Buffers: R=[1048576->1048576] S=[524288->524288]
2017-06-15 16:09:16 Attempting to establish TCP connection with [AF_INET]178.162.198.102:443 [nonblock]
2017-06-15 16:09:16 MANAGEMENT: >STATE:1497532155,TCP_CONNECT,,,,,,
2017-06-15 16:09:16 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2017-06-15 16:09:17 TCP connection established with [AF_INET]178.162.198.102:443
2017-06-15 16:09:17 New OpenVPN Status (WAIT->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): ,,,,,
2017-06-15 16:09:17 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2017-06-15 16:09:17 TCP_CLIENT link local: (not bound)
2017-06-15 16:09:17 TCP_CLIENT link remote: [AF_INET]178.162.198.102:443
2017-06-15 16:09:17 MANAGEMENT: >STATE:1497532157,WAIT,,,,,,
2017-06-15 16:09:17 MANAGEMENT: >STATE:1497532157,AUTH,,,,,,
2017-06-15 16:09:17 TLS: Initial packet from [AF_INET]178.162.198.102:443, sid=123b9764 a9fd58b5
2017-06-15 16:09:17 New OpenVPN Status (AUTH->LEVEL_CONNECTING_SERVER_REPLIED): ,,,,,
2017-06-15 16:09:17 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
2017-06-15 16:09:17 VERIFY KU OK
2017-06-15 16:09:17 Validating certificate extended key usage
2017-06-15 16:09:17 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
2017-06-15 16:09:17 VERIFY EKU OK
2017-06-15 16:09:17 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Wezen, emailAddress=info@airvpn.org
2017-06-15 16:09:17 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
2017-06-15 16:09:17 [Wezen] Peer Connection Initiated with [AF_INET]178.162.198.102:443
2017-06-15 16:09:19 New OpenVPN Status (GET_CONFIG->LEVEL_CONNECTING_SERVER_REPLIED): ,,,,,
2017-06-15 16:09:19 MANAGEMENT: >STATE:1497532159,GET_CONFIG,,,,,,
2017-06-15 16:09:19 SENT CONTROL [Wezen]: 'PUSH_REQUEST' (status=1)
2017-06-15 16:09:19 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.5.0.1,comp-lzo no,route-gateway 10.5.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.5.0.205 255.255.0.0,peer-id 0,cipher AES-256-GCM'
2017-06-15 16:09:19 OPTIONS IMPORT: timers and/or timeouts modified
2017-06-15 16:09:19 OPTIONS IMPORT: compression parms modified
2017-06-15 16:09:19 OPTIONS IMPORT: --ifconfig/up options modified
2017-06-15 16:09:19 OPTIONS IMPORT: route options modified
2017-06-15 16:09:19 New OpenVPN Status (ASSIGN_IP->LEVEL_CONNECTING_SERVER_REPLIED): ,10.5.0.205,,,,
2017-06-15 16:09:19 OPTIONS IMPORT: route-related options modified
2017-06-15 16:09:19 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2017-06-15 16:09:19 OPTIONS IMPORT: peer-id set
2017-06-15 16:09:19 OPTIONS IMPORT: adjusting link_mtu to 1627
2017-06-15 16:09:19 OPTIONS IMPORT: data channel crypto options modified
2017-06-15 16:09:19 Data Channel MTU parms [ L:1555 D:1450 EF:55 EB:406 ET:0 EL:3 ]
2017-06-15 16:09:19 Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
2017-06-15 16:09:19 Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
2017-06-15 16:09:19 ROUTE_GATEWAY 127.100.103.119/255.0.0.0 IFACE=lo HWADDR=00:00:00:00:00:00
2017-06-15 16:09:19 do_ifconfig, tt->did_ifconfig_ipv6_setup=0
2017-06-15 16:09:19 MANAGEMENT: >STATE:1497532159,ASSIGN_IP,,10.5.0.205,,,,
2017-06-15 16:09:19 Opening tun interface:
2017-06-15 16:09:19 Ignoring multicast route: 224.0.0.0/3
2017-06-15 16:09:19 Local IPv4: 10.5.0.205/16 IPv6: null MTU: 1500
2017-06-15 16:09:19 DNS Server: 10.5.0.1, Domain: null
2017-06-15 16:09:19 Routes: 0.0.0.0/010.5.0.0/16
2017-06-15 16:09:19 Routes excluded: 192.168.1.23/24
2017-06-15 16:09:19 VpnService routes installed: 0.0.0.0/1128.0.0.0/2192.0.0.0/9192.128.0.0/11192.160.0.0/13192.168.0.0/24192.168.2.0/23192.168.4.0/22192.168.8.0/21192.168.16.0/20192.168.32.0/19192.168.64.0/18192.168.128.0/17192.169.0.0/16192.170.0.0/15192.172.0.0/14192.176.0.0/12192.192.0.0/10193.0.0.0/8194.0.0.0/7196.0.0.0/6200.0.0.0/5208.0.0.0/4224.0.0.0/3
2017-06-15 16:09:19 Disallowed VPN apps:
2017-06-15 16:09:19 MANAGEMENT: CMD 'needok 'IFCONFIG' ok'
2017-06-15 16:09:19 MANAGEMENT: CMD 'needok 'ROUTE' ok'
2017-06-15 16:09:19 MANAGEMENT: CMD 'needok 'DNSSERVER' ok'
2017-06-15 16:09:19 MANAGEMENT: CMD 'needok 'PERSIST_TUN_ACTION' OPEN_BEFORE_CLOSE'
2017-06-15 16:09:19 MANAGEMENT: CMD 'needok 'OPENTUN' ok'
2017-06-15 16:09:19 Initialization Sequence Completed
2017-06-15 16:09:19 MANAGEMENT: >STATE:1497532159,CONNECTED,SUCCESS,10.5.0.205,178.162.198.102,443,192.168.1.23,46849
2017-06-15 16:09:19 New OpenVPN Status (CONNECTED->LEVEL_CONNECTED): SUCCESS,10.5.0.205,178.162.198.102,443,192.168.1.23,46849
2017-06-15 16:09:19 Debug state info: CONNECTED  to WIFI "BrkCgl", pause: userPause, shouldbeconnected: true, network: SHOULDBECONNECTED
NL Server:
Down: 6.500 Mbit/s Out, 5.500 Mbit/s In (84%), 10MB - Up: 3.524 Mbit/s Out, 3.283 Mbit/s In (93%), 20MB - Date: Thu, 15 Jun 2017 13:46:35 GMT - Buffers: 10MB/20MB - Laps: 3, Time: 238.34 secs
2017-06-15 16:44:30 official build 0.6.70 running on Amlogic MINIM8S II (p212), Android 6.0.1 (MHC19J) API 23, ABI armeabi-v7a, (Amlogic/p212/p212:6.0.1/MHC19J/20161013:userdebug/test-keys)
2017-06-15 16:44:30 Building configuration…
2017-06-15 16:44:30 New OpenVPN Status (VPN_GENERATE_CONFIG->LEVEL_START):
2017-06-15 16:44:30 MANAGEMENT: CMD 'signal SIGINT'
2017-06-15 16:44:30 TCP/UDP: Closing socket
2017-06-15 16:44:30 Sorry, deleting routes on Android is not possible. The VpnService API allows routes to be set on connect only.
2017-06-15 16:44:30 Closing TUN/TAP interface
2017-06-15 16:44:31 SIGINT[hard,] received, process exiting
2017-06-15 16:44:31 MANAGEMENT: >STATE:1497534271,EXITING,SIGINT,,,,,
2017-06-15 16:44:31 started Socket Thread
2017-06-15 16:44:31 Network Status: CONNECTED  to WIFI "BrkCgl"
2017-06-15 16:44:31 Debug state info: CONNECTED  to WIFI "BrkCgl", pause: userPause, shouldbeconnected: true, network: SHOULDBECONNECTED
2017-06-15 16:44:32 Debug state info: CONNECTED  to WIFI "BrkCgl", pause: userPause, shouldbeconnected: true, network: SHOULDBECONNECTED
2017-06-15 16:44:32 P:Initializing Google Breakpad!
2017-06-15 16:44:32 Current Parameter Settings:
2017-06-15 16:44:32   config = '/data/user/0/de.blinkt.openvpn/cache/android.conf'
2017-06-15 16:44:32   mode = 0
2017-06-15 16:44:32   show_ciphers = DISABLED
2017-06-15 16:44:32   show_digests = DISABLED
2017-06-15 16:44:32   show_engines = DISABLED
2017-06-15 16:44:32   genkey = DISABLED
2017-06-15 16:44:32   key_pass_file = '[uNDEF]'
2017-06-15 16:44:32   show_tls_ciphers = DISABLED
2017-06-15 16:44:32 Waiting 0s seconds between connection attempt
2017-06-15 16:44:32   connect_retry_max = 0
2017-06-15 16:44:32 Connection profiles [0]:
2017-06-15 16:44:32   proto = tcp-client
2017-06-15 16:44:32   local = '[uNDEF]'
2017-06-15 16:44:32   local_port = '[uNDEF]'
2017-06-15 16:44:32   remote = 'nl.vpn.airdns.org'
2017-06-15 16:44:32   remote_port = '443'
2017-06-15 16:44:32   remote_float = DISABLED
2017-06-15 16:44:32   bind_defined = DISABLED
2017-06-15 16:44:32   bind_local = DISABLED
2017-06-15 16:44:32   bind_ipv6_only = DISABLED
2017-06-15 16:44:32   connect_retry_seconds = 2
2017-06-15 16:44:32   connect_timeout = 120
2017-06-15 16:44:32   socks_proxy_server = '[uNDEF]'
2017-06-15 16:44:32   socks_proxy_port = '[uNDEF]'
2017-06-15 16:44:32   tun_mtu = 1500
2017-06-15 16:44:32   tun_mtu_defined = ENABLED
2017-06-15 16:44:32   link_mtu = 1500
2017-06-15 16:44:32   link_mtu_defined = DISABLED
2017-06-15 16:44:32   tun_mtu_extra = 0
2017-06-15 16:44:32   tun_mtu_extra_defined = DISABLED
2017-06-15 16:44:32   mtu_discover_type = -1
2017-06-15 16:44:32   fragment = 0
2017-06-15 16:44:32   mssfix = 1450
2017-06-15 16:44:32   explicit_exit_notification = 0
2017-06-15 16:44:32 Connection profiles END
2017-06-15 16:44:32   remote_random = DISABLED
2017-06-15 16:44:32   ipchange = '[uNDEF]'
2017-06-15 16:44:32   dev = 'tun'
2017-06-15 16:44:32   dev_type = '[uNDEF]'
2017-06-15 16:44:32   dev_node = '[uNDEF]'
2017-06-15 16:44:32   lladdr = '[uNDEF]'
2017-06-15 16:44:32   topology = 1
2017-06-15 16:44:32   ifconfig_local = '[uNDEF]'
2017-06-15 16:44:32   ifconfig_remote_netmask = '[uNDEF]'
2017-06-15 16:44:32   ifconfig_noexec = DISABLED
2017-06-15 16:44:32   ifconfig_nowarn = ENABLED
2017-06-15 16:44:32   ifconfig_ipv6_local = '[uNDEF]'
2017-06-15 16:44:32   ifconfig_ipv6_netbits = 0
2017-06-15 16:44:32   ifconfig_ipv6_remote = '[uNDEF]'
2017-06-15 16:44:32   shaper = 0
2017-06-15 16:44:32   mtu_test = 0
2017-06-15 16:44:32   mlock = DISABLED
2017-06-15 16:44:32   keepalive_ping = 0
2017-06-15 16:44:32   keepalive_timeout = 0
2017-06-15 16:44:32   inactivity_timeout = 0
2017-06-15 16:44:32   ping_send_timeout = 0
2017-06-15 16:44:32   ping_rec_timeout = 0
2017-06-15 16:44:32   ping_rec_timeout_action = 0
2017-06-15 16:44:32   ping_timer_remote = DISABLED
2017-06-15 16:44:32   remap_sigusr1 = 0
2017-06-15 16:44:32   persist_tun = ENABLED
2017-06-15 16:44:32   persist_local_ip = DISABLED
2017-06-15 16:44:32   persist_remote_ip = DISABLED
2017-06-15 16:44:32   persist_key = DISABLED
2017-06-15 16:44:32   passtos = DISABLED
2017-06-15 16:44:32   resolve_retry_seconds = 1000000000
2017-06-15 16:44:32   resolve_in_advance = ENABLED
2017-06-15 16:44:32   username = '[uNDEF]'
2017-06-15 16:44:32   groupname = '[uNDEF]'
2017-06-15 16:44:32   chroot_dir = '[uNDEF]'
2017-06-15 16:44:32   cd_dir = '[uNDEF]'
2017-06-15 16:44:32   writepid = '[uNDEF]'
2017-06-15 16:44:32   up_script = '[uNDEF]'
2017-06-15 16:44:32   down_script = '[uNDEF]'
2017-06-15 16:44:32   down_pre = DISABLED
2017-06-15 16:44:32   up_restart = DISABLED
2017-06-15 16:44:32   up_delay = DISABLED
2017-06-15 16:44:32   daemon = DISABLED
2017-06-15 16:44:32   inetd = 0
2017-06-15 16:44:32   log = DISABLED
2017-06-15 16:44:32   suppress_timestamps = DISABLED
2017-06-15 16:44:32   machine_readable_output = ENABLED
2017-06-15 16:44:32   nice = 0
2017-06-15 16:44:32   verbosity = 4
2017-06-15 16:44:32   mute = 0
2017-06-15 16:44:32   gremlin = 0
2017-06-15 16:44:32   status_file = '[uNDEF]'
2017-06-15 16:44:32   status_file_version = 1
2017-06-15 16:44:32   status_file_update_freq = 60
2017-06-15 16:44:32   occ = ENABLED
2017-06-15 16:44:32   rcvbuf = 0
2017-06-15 16:44:32   sndbuf = 0
2017-06-15 16:44:32   sockflags = 0
2017-06-15 16:44:32   fast_io = DISABLED
2017-06-15 16:44:32   comp.alg = 2
2017-06-15 16:44:32   comp.flags = 1
2017-06-15 16:44:32   route_script = '[uNDEF]'
2017-06-15 16:44:32   route_default_gateway = '[uNDEF]'
2017-06-15 16:44:32   route_default_metric = 0
2017-06-15 16:44:32   route_noexec = DISABLED
2017-06-15 16:44:32   route_delay = 0
2017-06-15 16:44:32   route_delay_window = 30
2017-06-15 16:44:32   route_delay_defined = DISABLED
2017-06-15 16:44:32   route_nopull = DISABLED
2017-06-15 16:44:32   route_gateway_via_dhcp = DISABLED
2017-06-15 16:44:32   allow_pull_fqdn = DISABLED
2017-06-15 16:44:32   management_addr = '/data/user/0/de.blinkt.openvpn/cache/mgmtsocket'
2017-06-15 16:44:32   management_port = 'unix'
2017-06-15 16:44:32   management_user_pass = '[uNDEF]'
2017-06-15 16:44:32   management_log_history_cache = 250
2017-06-15 16:44:32   management_echo_buffer_size = 100
2017-06-15 16:44:32   management_write_peer_info_file = '[uNDEF]'
2017-06-15 16:44:32   management_client_user = '[uNDEF]'
2017-06-15 16:44:32   management_client_group = '[uNDEF]'
2017-06-15 16:44:32   management_flags = 4390
2017-06-15 16:44:32   shared_secret_file = '[uNDEF]'
2017-06-15 16:44:32   key_direction = 1
2017-06-15 16:44:32   ciphername = 'AES-256-CBC'
2017-06-15 16:44:32   ncp_enabled = ENABLED
2017-06-15 16:44:32   ncp_ciphers = 'AES-256-GCM:AES-128-GCM'
2017-06-15 16:44:32   authname = 'SHA1'
2017-06-15 16:44:32   prng_hash = 'SHA1'
2017-06-15 16:44:32   prng_nonce_secret_len = 16
2017-06-15 16:44:32   keysize = 0
2017-06-15 16:44:32   engine = DISABLED
2017-06-15 16:44:32   replay = ENABLED
2017-06-15 16:44:32   mute_replay_warnings = DISABLED
2017-06-15 16:44:32   replay_window = 64
2017-06-15 16:44:32   replay_time = 15
2017-06-15 16:44:32   packet_id_file = '[uNDEF]'
2017-06-15 16:44:32   test_crypto = DISABLED
2017-06-15 16:44:32   tls_server = DISABLED
2017-06-15 16:44:32   tls_client = ENABLED
2017-06-15 16:44:32   key_method = 2
2017-06-15 16:44:32   ca_file = '[[iNLINE]]'
2017-06-15 16:44:32   ca_path = '[uNDEF]'
2017-06-15 16:44:32   dh_file = '[uNDEF]'
2017-06-15 16:44:32   cert_file = '[[iNLINE]]'
2017-06-15 16:44:32   extra_certs_file = '[uNDEF]'
2017-06-15 16:44:32   priv_key_file = '[[iNLINE]]'
2017-06-15 16:44:32   pkcs12_file = '[uNDEF]'
2017-06-15 16:44:32   cipher_list = '[uNDEF]'
2017-06-15 16:44:32   tls_verify = '[uNDEF]'
2017-06-15 16:44:32   tls_export_cert = '[uNDEF]'
2017-06-15 16:44:32   verify_x509_type = 0
2017-06-15 16:44:32   verify_x509_name = '[uNDEF]'
2017-06-15 16:44:32   crl_file = '[uNDEF]'
2017-06-15 16:44:32   ns_cert_type = 0
2017-06-15 16:44:32   remote_cert_ku = 65535
2017-06-15 16:44:32   remote_cert_ku = 0
2017-06-15 16:44:32   remote_cert_eku = 'TLS Web Server Authentication'
2017-06-15 16:44:32   ssl_flags = 0
2017-06-15 16:44:32   tls_timeout = 2
2017-06-15 16:44:32   renegotiate_bytes = -1
2017-06-15 16:44:32   renegotiate_packets = 0
2017-06-15 16:44:32   renegotiate_seconds = 3600
2017-06-15 16:44:32   handshake_window = 60
2017-06-15 16:44:32   transition_window = 3600
2017-06-15 16:44:32   single_session = DISABLED
2017-06-15 16:44:32   push_peer_info = DISABLED
2017-06-15 16:44:32   tls_exit = DISABLED
2017-06-15 16:44:32   tls_auth_file = '[[iNLINE]]'
2017-06-15 16:44:32   tls_crypt_file = '[uNDEF]'
2017-06-15 16:44:32   client = ENABLED
2017-06-15 16:44:32   pull = ENABLED
2017-06-15 16:44:32   auth_user_pass_file = '[uNDEF]'
2017-06-15 16:44:32 OpenVPN 2.5-icsopenvpn [git:icsopenvpn-a3a71dc0a6604559] android-14-armeabi-v7a [sSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 29 2017
2017-06-15 16:44:32 library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.09
2017-06-15 16:44:32 MANAGEMENT: Connected to management server at /data/user/0/de.blinkt.openvpn/cache/mgmtsocket
2017-06-15 16:44:32 MANAGEMENT: CMD 'hold release'
2017-06-15 16:44:38 MANAGEMENT: CMD 'bytecount 2'
2017-06-15 16:44:38 MANAGEMENT: CMD 'proxy NONE'
2017-06-15 16:44:38 MANAGEMENT: CMD 'state on'
2017-06-15 16:44:39 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-06-15 16:44:39 New OpenVPN Status (TCP_CONNECT->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): ,,,,,
2017-06-15 16:44:39 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-06-15 16:44:39 LZO compression initializing
2017-06-15 16:44:39 Control Channel MTU parms [ L:1624 D:1182 EF:68 EB:0 ET:0 EL:3 ]
2017-06-15 16:44:39 Data Channel MTU parms [ L:1624 D:1450 EF:124 EB:406 ET:0 EL:3 ]
2017-06-15 16:44:39 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_CLIENT,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
2017-06-15 16:44:39 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_SERVER,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
2017-06-15 16:44:39 TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.83:443
2017-06-15 16:44:39 Socket Buffers: R=[1048576->1048576] S=[524288->524288]
2017-06-15 16:44:39 Attempting to establish TCP connection with [AF_INET]213.152.162.83:443 [nonblock]
2017-06-15 16:44:39 MANAGEMENT: >STATE:1497534279,TCP_CONNECT,,,,,,
2017-06-15 16:44:39 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2017-06-15 16:44:40 TCP connection established with [AF_INET]213.152.162.83:443
2017-06-15 16:44:40 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2017-06-15 16:44:40 TCP_CLIENT link local: (not bound)
2017-06-15 16:44:40 TCP_CLIENT link remote: [AF_INET]213.152.162.83:443
2017-06-15 16:44:40 MANAGEMENT: >STATE:1497534280,WAIT,,,,,,
2017-06-15 16:44:40 New OpenVPN Status (WAIT->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): ,,,,,
2017-06-15 16:44:41 MANAGEMENT: >STATE:1497534281,AUTH,,,,,,
2017-06-15 16:44:41 TLS: Initial packet from [AF_INET]213.152.162.83:443, sid=279891cb 83a5c33b
2017-06-15 16:44:41 New OpenVPN Status (AUTH->LEVEL_CONNECTING_SERVER_REPLIED): ,,,,,
2017-06-15 16:44:41 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
2017-06-15 16:44:41 VERIFY KU OK
2017-06-15 16:44:41 Validating certificate extended key usage
2017-06-15 16:44:41 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
2017-06-15 16:44:41 VERIFY EKU OK
2017-06-15 16:44:41 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
2017-06-15 16:44:42 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
2017-06-15 16:44:42 [server] Peer Connection Initiated with [AF_INET]213.152.162.83:443
2017-06-15 16:44:43 New OpenVPN Status (GET_CONFIG->LEVEL_CONNECTING_SERVER_REPLIED): ,,,,,
2017-06-15 16:44:43 MANAGEMENT: >STATE:1497534283,GET_CONFIG,,,,,,
2017-06-15 16:44:43 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2017-06-15 16:44:43 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.5.0.1,comp-lzo no,route-gateway 10.5.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.5.10.123 255.255.0.0'
2017-06-15 16:44:43 OPTIONS IMPORT: timers and/or timeouts modified
2017-06-15 16:44:43 OPTIONS IMPORT: compression parms modified
2017-06-15 16:44:43 New OpenVPN Status (ASSIGN_IP->LEVEL_CONNECTING_SERVER_REPLIED): ,10.5.10.123,,,,
2017-06-15 16:44:43 OPTIONS IMPORT: --ifconfig/up options modified
2017-06-15 16:44:43 OPTIONS IMPORT: route options modified
2017-06-15 16:44:43 OPTIONS IMPORT: route-related options modified
2017-06-15 16:44:43 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2017-06-15 16:44:43 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:406 ET:0 EL:3 ]
2017-06-15 16:44:43 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2017-06-15 16:44:43 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-06-15 16:44:43 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2017-06-15 16:44:43 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-06-15 16:44:43 ROUTE_GATEWAY 127.100.103.119/255.0.0.0 IFACE=lo HWADDR=00:00:00:00:00:00
2017-06-15 16:44:43 do_ifconfig, tt->did_ifconfig_ipv6_setup=0
2017-06-15 16:44:43 MANAGEMENT: >STATE:1497534283,ASSIGN_IP,,10.5.10.123,,,,
2017-06-15 16:44:43 MANAGEMENT: CMD 'needok 'IFCONFIG' ok'
2017-06-15 16:44:43 MANAGEMENT: CMD 'needok 'ROUTE' ok'
2017-06-15 16:44:43 MANAGEMENT: CMD 'needok 'DNSSERVER' ok'
2017-06-15 16:44:43 MANAGEMENT: CMD 'needok 'PERSIST_TUN_ACTION' OPEN_BEFORE_CLOSE'
2017-06-15 16:44:43 Opening tun interface:
2017-06-15 16:44:43 Ignoring multicast route: 224.0.0.0/3
2017-06-15 16:44:43 Local IPv4: 10.5.10.123/16 IPv6: null MTU: 1500
2017-06-15 16:44:43 DNS Server: 10.5.0.1, Domain: null
2017-06-15 16:44:43 Routes: 0.0.0.0/010.5.0.0/16
2017-06-15 16:44:43 Routes excluded: 192.168.1.23/24
2017-06-15 16:44:43 VpnService routes installed: 0.0.0.0/1128.0.0.0/2192.0.0.0/9192.128.0.0/11192.160.0.0/13192.168.0.0/24192.168.2.0/23192.168.4.0/22192.168.8.0/21192.168.16.0/20192.168.32.0/19192.168.64.0/18192.168.128.0/17192.169.0.0/16192.170.0.0/15192.172.0.0/14192.176.0.0/12192.192.0.0/10193.0.0.0/8194.0.0.0/7196.0.0.0/6200.0.0.0/5208.0.0.0/4224.0.0.0/3
2017-06-15 16:44:43 Disallowed VPN apps:
2017-06-15 16:44:43 MANAGEMENT: CMD 'needok 'OPENTUN' ok'
2017-06-15 16:44:43 Initialization Sequence Completed
2017-06-15 16:44:43 MANAGEMENT: >STATE:1497534283,CONNECTED,SUCCESS,10.5.10.123,213.152.162.83,443,192.168.1.23,52618
2017-06-15 16:44:43 New OpenVPN Status (CONNECTED->LEVEL_CONNECTED): SUCCESS,10.5.10.123,213.152.162.83,443,192.168.1.23,52618
2017-06-15 16:44:44 Debug state info: CONNECTED  to WIFI "BrkCgl", pause: userPause, shouldbeconnected: true, network: SHOULDBECONNECTED
GB Maidenhead Carinae:
Down: 8.480 Mbit/s Out, 7.850 Mbit/s In (92%), 10MB - Up: 3.635 Mbit/s Out, 3.543 Mbit/s In (97%), 20MB - Date: Thu, 15 Jun 2017 13:54:55 GMT - Buffers: 10MB/20MB - Laps: 3, Time: 206.47 secs
2017-06-15 16:53:54 official build 0.6.70 running on Amlogic MINIM8S II (p212), Android 6.0.1 (MHC19J) API 23, ABI armeabi-v7a, (Amlogic/p212/p212:6.0.1/MHC19J/20161013:userdebug/test-keys)
2017-06-15 16:53:55 Building configuration…
2017-06-15 16:53:55 New OpenVPN Status (VPN_GENERATE_CONFIG->LEVEL_START):
2017-06-15 16:53:55 MANAGEMENT: CMD 'signal SIGINT'
2017-06-15 16:53:55 TCP/UDP: Closing socket
2017-06-15 16:53:55 Sorry, deleting routes on Android is not possible. The VpnService API allows routes to be set on connect only.
2017-06-15 16:53:55 Closing TUN/TAP interface
2017-06-15 16:53:55 SIGINT[hard,] received, process exiting
2017-06-15 16:53:55 MANAGEMENT: >STATE:1497534835,EXITING,SIGINT,,,,,
2017-06-15 16:53:56 started Socket Thread
2017-06-15 16:53:56 Network Status: CONNECTED  to WIFI "BrkCgl"
2017-06-15 16:53:56 Debug state info: CONNECTED  to WIFI "BrkCgl", pause: userPause, shouldbeconnected: true, network: SHOULDBECONNECTED
2017-06-15 16:53:56 P:Initializing Google Breakpad!
2017-06-15 16:53:56 Current Parameter Settings:
2017-06-15 16:53:56 Waiting 0s seconds between connection attempt
2017-06-15 16:53:56   config = '/data/user/0/de.blinkt.openvpn/cache/android.conf'
2017-06-15 16:53:56   mode = 0
2017-06-15 16:53:56   show_ciphers = DISABLED
2017-06-15 16:53:56   show_digests = DISABLED
2017-06-15 16:53:56   show_engines = DISABLED
2017-06-15 16:53:56   genkey = DISABLED
2017-06-15 16:53:56   key_pass_file = '[uNDEF]'
2017-06-15 16:53:56   show_tls_ciphers = DISABLED
2017-06-15 16:53:56   connect_retry_max = 0
2017-06-15 16:53:56 Connection profiles [0]:
2017-06-15 16:53:56   proto = tcp-client
2017-06-15 16:53:56   local = '[uNDEF]'
2017-06-15 16:53:56   local_port = '[uNDEF]'
2017-06-15 16:53:56   remote = '94.229.74.90'
2017-06-15 16:53:56   remote_port = '443'
2017-06-15 16:53:56   remote_float = DISABLED
2017-06-15 16:53:56   bind_defined = DISABLED
2017-06-15 16:53:56   bind_local = DISABLED
2017-06-15 16:53:56   bind_ipv6_only = DISABLED
2017-06-15 16:53:56   connect_retry_seconds = 2
2017-06-15 16:53:56   connect_timeout = 120
2017-06-15 16:53:56   socks_proxy_server = '[uNDEF]'
2017-06-15 16:53:56   socks_proxy_port = '[uNDEF]'
2017-06-15 16:53:56   tun_mtu = 1500
2017-06-15 16:53:56   tun_mtu_defined = ENABLED
2017-06-15 16:53:56   link_mtu = 1500
2017-06-15 16:53:56   link_mtu_defined = DISABLED
2017-06-15 16:53:56   tun_mtu_extra = 0
2017-06-15 16:53:56   tun_mtu_extra_defined = DISABLED
2017-06-15 16:53:56   mtu_discover_type = -1
2017-06-15 16:53:56   fragment = 0
2017-06-15 16:53:56   mssfix = 1450
2017-06-15 16:53:56   explicit_exit_notification = 0
2017-06-15 16:53:56 Connection profiles END
2017-06-15 16:53:56   remote_random = DISABLED
2017-06-15 16:53:56   ipchange = '[uNDEF]'
2017-06-15 16:53:56   dev = 'tun'
2017-06-15 16:53:56   dev_type = '[uNDEF]'
2017-06-15 16:53:56   dev_node = '[uNDEF]'
2017-06-15 16:53:56   lladdr = '[uNDEF]'
2017-06-15 16:53:56   topology = 1
2017-06-15 16:53:56   ifconfig_local = '[uNDEF]'
2017-06-15 16:53:56   ifconfig_remote_netmask = '[uNDEF]'
2017-06-15 16:53:56   ifconfig_noexec = DISABLED
2017-06-15 16:53:56   ifconfig_nowarn = ENABLED
2017-06-15 16:53:56   ifconfig_ipv6_local = '[uNDEF]'
2017-06-15 16:53:56   ifconfig_ipv6_netbits = 0
2017-06-15 16:53:56   ifconfig_ipv6_remote = '[uNDEF]'
2017-06-15 16:53:56   shaper = 0
2017-06-15 16:53:56   mtu_test = 0
2017-06-15 16:53:56   mlock = DISABLED
2017-06-15 16:53:56   keepalive_ping = 0
2017-06-15 16:53:56   keepalive_timeout = 0
2017-06-15 16:53:56   inactivity_timeout = 0
2017-06-15 16:53:56   ping_send_timeout = 0
2017-06-15 16:53:56   ping_rec_timeout = 0
2017-06-15 16:53:56   ping_rec_timeout_action = 0
2017-06-15 16:53:56   ping_timer_remote = DISABLED
2017-06-15 16:53:56   remap_sigusr1 = 0
2017-06-15 16:53:56   persist_tun = ENABLED
2017-06-15 16:53:56   persist_local_ip = DISABLED
2017-06-15 16:53:56   persist_remote_ip = DISABLED
2017-06-15 16:53:56   persist_key = DISABLED
2017-06-15 16:53:56   passtos = DISABLED
2017-06-15 16:53:56   resolve_retry_seconds = 1000000000
2017-06-15 16:53:56   resolve_in_advance = ENABLED
2017-06-15 16:53:56   username = '[uNDEF]'
2017-06-15 16:53:56   groupname = '[uNDEF]'
2017-06-15 16:53:56   chroot_dir = '[uNDEF]'
2017-06-15 16:53:56   cd_dir = '[uNDEF]'
2017-06-15 16:53:56   writepid = '[uNDEF]'
2017-06-15 16:53:56   up_script = '[uNDEF]'
2017-06-15 16:53:56   down_script = '[uNDEF]'
2017-06-15 16:53:56   down_pre = DISABLED
2017-06-15 16:53:56   up_restart = DISABLED
2017-06-15 16:53:56   up_delay = DISABLED
2017-06-15 16:53:56   daemon = DISABLED
2017-06-15 16:53:56   inetd = 0
2017-06-15 16:53:56   log = DISABLED
2017-06-15 16:53:56   suppress_timestamps = DISABLED
2017-06-15 16:53:56   machine_readable_output = ENABLED
2017-06-15 16:53:56   nice = 0
2017-06-15 16:53:56   verbosity = 4
2017-06-15 16:53:56   mute = 0
2017-06-15 16:53:56   gremlin = 0
2017-06-15 16:53:56   status_file = '[uNDEF]'
2017-06-15 16:53:56   status_file_version = 1
2017-06-15 16:53:57   status_file_update_freq = 60
2017-06-15 16:53:57   occ = ENABLED
2017-06-15 16:53:57   rcvbuf = 262144
2017-06-15 16:53:57   sndbuf = 262144
2017-06-15 16:53:57   sockflags = 0
2017-06-15 16:53:57   fast_io = DISABLED
2017-06-15 16:53:57   comp.alg = 2
2017-06-15 16:53:57   comp.flags = 1
2017-06-15 16:53:57   route_script = '[uNDEF]'
2017-06-15 16:53:57   route_default_gateway = '[uNDEF]'
2017-06-15 16:53:57   route_default_metric = 0
2017-06-15 16:53:57   route_noexec = DISABLED
2017-06-15 16:53:57   route_delay = 0
2017-06-15 16:53:57   route_delay_window = 30
2017-06-15 16:53:57   route_delay_defined = DISABLED
2017-06-15 16:53:57   route_nopull = DISABLED
2017-06-15 16:53:57   route_gateway_via_dhcp = DISABLED
2017-06-15 16:53:57   allow_pull_fqdn = DISABLED
2017-06-15 16:53:57   management_addr = '/data/user/0/de.blinkt.openvpn/cache/mgmtsocket'
2017-06-15 16:53:57   management_port = 'unix'
2017-06-15 16:53:57   management_user_pass = '[uNDEF]'
2017-06-15 16:53:57   management_log_history_cache = 250
2017-06-15 16:53:57   management_echo_buffer_size = 100
2017-06-15 16:53:57   management_write_peer_info_file = '[uNDEF]'
2017-06-15 16:53:57   management_client_user = '[uNDEF]'
2017-06-15 16:53:57   management_client_group = '[uNDEF]'
2017-06-15 16:53:57   management_flags = 4390
2017-06-15 16:53:57   shared_secret_file = '[uNDEF]'
2017-06-15 16:53:57   key_direction = 1
2017-06-15 16:53:57   ciphername = 'AES-256-CBC'
2017-06-15 16:53:57   ncp_enabled = ENABLED
2017-06-15 16:53:57   ncp_ciphers = 'AES-256-GCM:AES-128-GCM'
2017-06-15 16:53:57   authname = 'SHA1'
2017-06-15 16:53:57   prng_hash = 'SHA1'
2017-06-15 16:53:57   prng_nonce_secret_len = 16
2017-06-15 16:53:57   keysize = 0
2017-06-15 16:53:57   engine = DISABLED
2017-06-15 16:53:57   replay = ENABLED
2017-06-15 16:53:57   mute_replay_warnings = DISABLED
2017-06-15 16:53:57   replay_window = 64
2017-06-15 16:53:57   replay_time = 15
2017-06-15 16:53:57   packet_id_file = '[uNDEF]'
2017-06-15 16:53:57   test_crypto = DISABLED
2017-06-15 16:53:57   tls_server = DISABLED
2017-06-15 16:53:57   tls_client = ENABLED
2017-06-15 16:53:57   key_method = 2
2017-06-15 16:53:57   ca_file = '[[iNLINE]]'
2017-06-15 16:53:57   ca_path = '[uNDEF]'
2017-06-15 16:53:57   dh_file = '[uNDEF]'
2017-06-15 16:53:57   cert_file = '[[iNLINE]]'
2017-06-15 16:53:57   extra_certs_file = '[uNDEF]'
2017-06-15 16:53:57   priv_key_file = '[[iNLINE]]'
2017-06-15 16:53:57   pkcs12_file = '[uNDEF]'
2017-06-15 16:53:57   cipher_list = '[uNDEF]'
2017-06-15 16:53:57   tls_verify = '[uNDEF]'
2017-06-15 16:53:57   tls_export_cert = '[uNDEF]'
2017-06-15 16:53:57   verify_x509_type = 0
2017-06-15 16:53:57   verify_x509_name = '[uNDEF]'
2017-06-15 16:53:57   crl_file = '[uNDEF]'
2017-06-15 16:53:57   ns_cert_type = 0
2017-06-15 16:53:57   remote_cert_ku = 65535
2017-06-15 16:53:57   remote_cert_ku = 0
2017-06-15 16:53:57   remote_cert_eku = 'TLS Web Server Authentication'
2017-06-15 16:53:57   ssl_flags = 0
2017-06-15 16:53:57   tls_timeout = 2
2017-06-15 16:53:57   renegotiate_bytes = -1
2017-06-15 16:53:57   renegotiate_packets = 0
2017-06-15 16:53:57   renegotiate_seconds = 3600
2017-06-15 16:53:57   handshake_window = 60
2017-06-15 16:53:57   transition_window = 3600
2017-06-15 16:53:57   single_session = DISABLED
2017-06-15 16:53:57   push_peer_info = DISABLED
2017-06-15 16:53:57   tls_exit = DISABLED
2017-06-15 16:53:57   tls_auth_file = '[[iNLINE]]'
2017-06-15 16:53:57   tls_crypt_file = '[uNDEF]'
2017-06-15 16:53:57   client = ENABLED
2017-06-15 16:53:57   pull = ENABLED
2017-06-15 16:53:57   auth_user_pass_file = '[uNDEF]'
2017-06-15 16:53:57 OpenVPN 2.5-icsopenvpn [git:icsopenvpn-a3a71dc0a6604559] android-14-armeabi-v7a [sSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 29 2017
2017-06-15 16:53:57 library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.09
2017-06-15 16:53:57 MANAGEMENT: Connected to management server at /data/user/0/de.blinkt.openvpn/cache/mgmtsocket
2017-06-15 16:53:57 MANAGEMENT: CMD 'hold release'
2017-06-15 16:53:57 MANAGEMENT: CMD 'proxy NONE'
2017-06-15 16:53:57 MANAGEMENT: CMD 'bytecount 2'
2017-06-15 16:53:57 MANAGEMENT: CMD 'state on'
2017-06-15 16:53:57 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-06-15 16:53:57 New OpenVPN Status (TCP_CONNECT->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): ,,,,,
2017-06-15 16:53:58 New OpenVPN Status (TCP_CONNECT->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): ,,,,,
2017-06-15 16:53:58 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-06-15 16:53:58 LZO compression initializing
2017-06-15 16:53:58 Control Channel MTU parms [ L:1624 D:1182 EF:68 EB:0 ET:0 EL:3 ]
2017-06-15 16:53:58 Data Channel MTU parms [ L:1624 D:1450 EF:124 EB:406 ET:0 EL:3 ]
2017-06-15 16:53:58 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_CLIENT,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
2017-06-15 16:53:58 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_SERVER,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
2017-06-15 16:53:58 TCP/UDP: Preserving recently used remote address: [AF_INET]94.229.74.90:443
2017-06-15 16:53:58 Socket Buffers: R=[1048576->425984] S=[524288->425984]
2017-06-15 16:53:58 Attempting to establish TCP connection with [AF_INET]94.229.74.90:443 [nonblock]
2017-06-15 16:53:58 MANAGEMENT: >STATE:1497534837,TCP_CONNECT,,,,,,
2017-06-15 16:53:58 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2017-06-15 16:53:59 TCP connection established with [AF_INET]94.229.74.90:443
2017-06-15 16:53:59 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2017-06-15 16:53:59 New OpenVPN Status (WAIT->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): ,,,,,
2017-06-15 16:53:59 New OpenVPN Status (AUTH->LEVEL_CONNECTING_SERVER_REPLIED): ,,,,,
2017-06-15 16:53:59 TCP_CLIENT link local: (not bound)
2017-06-15 16:53:59 TCP_CLIENT link remote: [AF_INET]94.229.74.90:443
2017-06-15 16:53:59 MANAGEMENT: >STATE:1497534839,WAIT,,,,,,
2017-06-15 16:53:59 MANAGEMENT: >STATE:1497534839,AUTH,,,,,,
2017-06-15 16:53:59 TLS: Initial packet from [AF_INET]94.229.74.90:443, sid=4ad251a8 cc5736ac
2017-06-15 16:53:59 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
2017-06-15 16:53:59 VERIFY KU OK
2017-06-15 16:53:59 Validating certificate extended key usage
2017-06-15 16:53:59 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
2017-06-15 16:53:59 VERIFY EKU OK
2017-06-15 16:53:59 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
2017-06-15 16:54:01 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
2017-06-15 16:54:01 [server] Peer Connection Initiated with [AF_INET]94.229.74.90:443
2017-06-15 16:54:02 MANAGEMENT: >STATE:1497534842,GET_CONFIG,,,,,,
2017-06-15 16:54:02 New OpenVPN Status (GET_CONFIG->LEVEL_CONNECTING_SERVER_REPLIED): ,,,,,
2017-06-15 16:54:02 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2017-06-15 16:54:02 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.5.0.1,comp-lzo no,route-gateway 10.5.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.5.6.75 255.255.0.0'
2017-06-15 16:54:02 OPTIONS IMPORT: timers and/or timeouts modified
2017-06-15 16:54:02 OPTIONS IMPORT: compression parms modified
2017-06-15 16:54:02 OPTIONS IMPORT: --ifconfig/up options modified
2017-06-15 16:54:02 OPTIONS IMPORT: route options modified
2017-06-15 16:54:02 OPTIONS IMPORT: route-related options modified
2017-06-15 16:54:02 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2017-06-15 16:54:02 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:406 ET:0 EL:3 ]
2017-06-15 16:54:02 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2017-06-15 16:54:02 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-06-15 16:54:02 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2017-06-15 16:54:02 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-06-15 16:54:02 ROUTE_GATEWAY 127.100.103.119/255.0.0.0 IFACE=lo HWADDR=00:00:00:00:00:00
2017-06-15 16:54:02 do_ifconfig, tt->did_ifconfig_ipv6_setup=0
2017-06-15 16:54:02 MANAGEMENT: >STATE:1497534842,ASSIGN_IP,,10.5.6.75,,,,
2017-06-15 16:54:02 New OpenVPN Status (ASSIGN_IP->LEVEL_CONNECTING_SERVER_REPLIED): ,10.5.6.75,,,,
2017-06-15 16:54:02 MANAGEMENT: CMD 'needok 'IFCONFIG' ok'
2017-06-15 16:54:02 MANAGEMENT: CMD 'needok 'ROUTE' ok'
2017-06-15 16:54:02 MANAGEMENT: CMD 'needok 'DNSSERVER' ok'
2017-06-15 16:54:02 MANAGEMENT: CMD 'needok 'PERSIST_TUN_ACTION' OPEN_BEFORE_CLOSE'
2017-06-15 16:54:02 Opening tun interface:
2017-06-15 16:54:02 Ignoring multicast route: 224.0.0.0/3
2017-06-15 16:54:02 Local IPv4: 10.5.6.75/16 IPv6: null MTU: 1500
2017-06-15 16:54:02 DNS Server: 10.5.0.1, Domain: null
2017-06-15 16:54:02 Routes: 0.0.0.0/010.5.0.0/16
2017-06-15 16:54:02 Routes excluded: 192.168.1.23/24
2017-06-15 16:54:02 VpnService routes installed: 0.0.0.0/1128.0.0.0/2192.0.0.0/9192.128.0.0/11192.160.0.0/13192.168.0.0/24192.168.2.0/23192.168.4.0/22192.168.8.0/21192.168.16.0/20192.168.32.0/19192.168.64.0/18192.168.128.0/17192.169.0.0/16192.170.0.0/15192.172.0.0/14192.176.0.0/12192.192.0.0/10193.0.0.0/8194.0.0.0/7196.0.0.0/6200.0.0.0/5208.0.0.0/4224.0.0.0/3
2017-06-15 16:54:02 Disallowed VPN apps:
2017-06-15 16:54:02 MANAGEMENT: CMD 'needok 'OPENTUN' ok'
2017-06-15 16:54:02 Initialization Sequence Completed
2017-06-15 16:54:02 MANAGEMENT: >STATE:1497534842,CONNECTED,SUCCESS,10.5.6.75,94.229.74.90,443,192.168.1.23,45619
2017-06-15 16:54:02 New OpenVPN Status (CONNECTED->LEVEL_CONNECTED): SUCCESS,10.5.6.75,94.229.74.90,443,192.168.1.23,45619
2017-06-15 16:54:02 Debug state info: CONNECTED  to WIFI "BrkCgl", pause: userPause, shouldbeconnected: true, network: SHOULDBECONNECTED
The difference between GB_Carinae and NL servers makes sense with the busyness of the servers. However as an example, there is problem with the DE server.
I am still trying to find out however at least for now, it seems that the number of the connections that I get ~1Mbps increases in the evening (for Europe).
Thanks for help in advance!
