twc779 0 Posted ... Hi all, I recently renewed my subscription for 3 months and for the first few days everything was flawless like it always has been, in terms of speed. However, in the past few days I have been having a lot of trouble. 99% of my VPN usage is related to torrenting. My ISP speeds are about 150-170mbps up and down, though for some reason when connected to USA, Canada, Netherlands, etc. servers. I have about 20-30mbps down and 80-100 up. I have tried changing the buffer size to 256 and 512, neither worked. I am really at a loss here. I tried fast.com and speedtest.net with similar results, with speedtest showing much faster upload than download. Thanks! Quote Share this post Link to post
jego 0 Posted ... I am having the same issue since two days. I am getting 100Mbits without VPN and when connected to the VPN (various servers) I only get 6-9Mbits. I tried SSL tunneling but it does not help. Quote Share this post Link to post
Tech Jedi Alex 1580 Posted ... Mr. twc779, is your OpenVPN client a mute? You did not post your logs. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
twc779 0 Posted ... Mr. twc779, is your OpenVPN client a mute? You did not post your logs. . 2017.06.15 12:49:10 - Updating systems & servers data .... 2017.06.15 12:49:11 - Systems & servers data update completed. 2017.06.15 12:59:12 - Updating systems & servers data .... 2017.06.15 12:59:13 - Systems & servers data update completed. 2017.06.15 13:09:15 - Updating systems & servers data .... 2017.06.15 13:09:15 - Systems & servers data update completed. 2017.06.15 13:19:17 - Updating systems & servers data .... 2017.06.15 13:19:17 - Systems & servers data update completed. 2017.06.15 13:29:19 - Updating systems & servers data .... 2017.06.15 13:29:19 - Systems & servers data update completed. 2017.06.15 13:39:21 - Updating systems & servers data .... 2017.06.15 13:39:22 - Systems & servers data update completed. 2017.06.15 13:49:23 - Updating systems & servers data .... 2017.06.15 13:49:24 - Systems & servers data update completed. 2017.06.15 13:59:25 - Updating systems & servers data .... 2017.06.15 13:59:26 - Systems & servers data update completed. 2017.06.15 14:09:27 - Updating systems & servers data .... 2017.06.15 14:09:28 - Systems & servers data update completed. 2017.06.15 14:19:30 - Updating systems & servers data .... 2017.06.15 14:19:30 - Systems & servers data update completed. 2017.06.15 14:29:32 - Updating systems & servers data .... 2017.06.15 14:29:32 - Systems & servers data update completed. 2017.06.15 14:39:34 - Updating systems & servers data .... 2017.06.15 14:39:35 - Systems & servers data update completed. 2017.06.15 14:49:36 - Updating systems & servers data .... 2017.06.15 14:49:37 - Systems & servers data update completed. 2017.06.15 14:59:38 - Updating systems & servers data .... 2017.06.15 14:59:39 - Systems & servers data update completed. 2017.06.15 15:09:07 - Shutdown in progress. 2017.06.15 15:09:08 - Shutdown complete. 2017.06.15 20:51:18 - Data path: C:\Program Files\AirVPN. 2017.06.15 20:51:18 - Application path: C:\Program Files\AirVPN. 2017.06.15 20:51:18 - Executable path: C:\Program Files\AirVPN\AirVPN.exe. 2017.06.15 20:51:18 - Command line arguments (0):. 2017.06.15 20:51:18 - Operating System: Microsoft Windows NT 10.0.15063.0. 2017.06.15 20:51:18 - Shell of 'C:\Program Files\AirVPN\openvpn.exe','--version' done sync in 94 ms, Output: OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017. 2017.06.15 20:51:18 - library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.06.15 20:51:18 - Windows version 6.2 (Windows 8 or greater) 64bit. 2017.06.15 20:51:18 - Originally developed by James Yonan. 2017.06.15 20:51:18 - Copyright © 2002-2017 OpenVPN Technologies, Inc. <sales@openvpn.net>. 2017.06.15 20:51:18 - Compile time defines: enable_async_push=no enable_comp_stub=no enable_crypto=yes enable_crypto_ofb_cfb=yes enable_debug=yes enable_def_auth=yes enable_dlopen=unknown enable_dlopen_self=unknown enable_dlopen_self_static=unknown enable_fast_install=needless enable_fragment=yes enable_iproute2=no enable_libtool_lock=yes enable_lz4=yes enable_lzo=yes enable_management=yes enable_multi=yes enable_multihome=yes enable_pam_dlopen=no enable_pedantic=no enable_pf=yes enable_pkcs11=yes enable_plugin_auth_pam=no enable_plugin_down_root=no enable_plugins=yes enable_port_share=yes enable_selinux=no enable_server=yes enable_shared=yes enable_shared_with_static_runtimes=yes enable_small=no enable_static=yes enable_strict=no enable_strict_options=no enable_systemd=no enable_werror=no enable_win32_dll=yes enable_x509_alt_username=no with_crypto_library=openssl with_gnu_ld=yes with_mem_check=no with_plugindir='$(libdir)/openvpn/plugins' with_special_build= with_sysroot=no. 2017.06.15 20:51:18 - Shell of 'C:\Program Files\AirVPN\plink.exe','-V' done sync in 47 ms, Output: plink: Release 0.67. 2017.06.15 20:51:18 - Shell of 'C:\Program Files\AirVPN\stunnel.exe','-version' done sync in 78 ms, Output: stunnel 5.40 on x86-pc-mingw32-gnu platform. 2017.06.15 20:51:18 - Compiled/running with OpenSSL 1.0.2k 26 Jan 2017. 2017.06.15 20:51:18 - Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI. 2017.06.15 20:51:18 - Global options:. 2017.06.15 20:51:18 - RNDbytes = 64. 2017.06.15 20:51:18 - RNDoverwrite = yes. 2017.06.15 20:51:18 - taskbar = yes. 2017.06.15 20:51:18 - Service-level options:. 2017.06.15 20:51:18 - ciphers = HIGH:!DH:!aNULL:!SSLv2. 2017.06.15 20:51:18 - curve = prime256v1. 2017.06.15 20:51:18 - debug = notice. 2017.06.15 20:51:18 - logId = sequential. 2017.06.15 20:51:18 - options = NO_SSLv2. 2017.06.15 20:51:18 - options = NO_SSLv3. 2017.06.15 20:51:18 - sessionCacheSize = 1000. 2017.06.15 20:51:18 - sessionCacheTimeout = 300 seconds. 2017.06.15 20:51:18 - stack = 65536 bytes. 2017.06.15 20:51:18 - TIMEOUTbusy = 300 seconds. 2017.06.15 20:51:18 - TIMEOUTclose = 60 seconds. 2017.06.15 20:51:18 - TIMEOUTconnect = 10 seconds. 2017.06.15 20:51:18 - TIMEOUTidle = 43200 seconds. 2017.06.15 20:51:18 - verify = none. 2017.06.15 20:51:18 - Shell of 'C:\Program Files\AirVPN\curl.exe','--version' done sync in 78 ms, Output: curl 7.34.0 (x86_64-pc-win32) libcurl/7.34.0 OpenSSL/1.0.0k zlib/1.2.8 WinIDN libssh2/1.4.3 librtmp/2.3. 2017.06.15 20:51:18 - Protocols: dict file ftp ftps gopher http https imap imaps ldap pop3 pop3s rtmp rtsp scp sftp smtp smtps telnet tftp. 2017.06.15 20:51:18 - Features: AsynchDNS GSS-Negotiate IDN Largefile NTLM SSL SSPI libzI 2017.06.15 20:51:18 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2I 2017.06.15 20:51:18 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09 (C:\Program Files\AirVPN\openvpn.exe)I 2017.06.15 20:51:18 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)I 2017.06.15 20:51:18 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)I 2017.06.15 20:51:18 - curl - Version: 7.34.0 (C:\Program Files\AirVPN\curl.exe)I 2017.06.15 20:51:18 - Certification Authorities: C:\Program Files\AirVPN\cacert.pem! 2017.06.15 20:51:19 - Ready. 2017.06.15 20:51:19 - Updating systems & servers data .... 2017.06.15 20:51:19 - Systems & servers data update completedI 2017.06.15 20:51:30 - Session starting.. 2017.06.15 20:51:30 - IPv6 disabled with packet filtering.I 2017.06.15 20:51:30 - Checking authorization ...! 2017.06.15 20:51:30 - Connecting to Rasalas (United States, Newark, New Jersey). 2017.06.15 20:51:30 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017. 2017.06.15 20:51:30 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2017.06.15 20:51:30 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.06.15 20:51:30 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.06.15 20:51:30 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.15 20:51:30 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.15 20:51:30 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.120.44.138:443. 2017.06.15 20:51:30 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2017.06.15 20:51:30 - OpenVPN > UDP link local: (not bound). 2017.06.15 20:51:30 - OpenVPN > UDP link remote: [AF_INET]64.120.44.138:443. 2017.06.15 20:51:30 - OpenVPN > TLS: Initial packet from [AF_INET]64.120.44.138:443, sid=7749fa81 202eb84f. 2017.06.15 20:51:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.06.15 20:51:31 - OpenVPN > Validating certificate key usage. 2017.06.15 20:51:31 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.06.15 20:51:31 - OpenVPN > VERIFY KU OK. 2017.06.15 20:51:31 - OpenVPN > Validating certificate extended key usage. 2017.06.15 20:51:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.06.15 20:51:31 - OpenVPN > VERIFY EKU OK. 2017.06.15 20:51:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.06.15 20:51:31 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.06.15 20:51:31 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]64.120.44.138:443. 2017.06.15 20:51:32 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.06.15 20:51:32 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.42.165 255.255.0.0'. 2017.06.15 20:51:32 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.06.15 20:51:32 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2017.06.15 20:51:32 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.06.15 20:51:32 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.06.15 20:51:32 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.06.15 20:51:32 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.06.15 20:51:32 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.15 20:51:32 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.15 20:51:32 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.15 20:51:32 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.15 20:51:32 - OpenVPN > interactive service msg_channel=0. 2017.06.15 20:51:32 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=5 HWADDR=2c:4d:54:4c:62:3b. 2017.06.15 20:51:32 - OpenVPN > open_tun. 2017.06.15 20:51:32 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{0652BE28-10B3-455B-8C65-FC74A6034429}.tap. 2017.06.15 20:51:32 - OpenVPN > TAP-Windows Driver Version 9.21. 2017.06.15 20:51:32 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.42.165/255.255.0.0 [sUCCEEDED]. 2017.06.15 20:51:32 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.42.165/255.255.0.0 on interface {0652BE28-10B3-455B-8C65-FC74A6034429} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2017.06.15 20:51:32 - OpenVPN > Successful ARP Flush on interface [2] {0652BE28-10B3-455B-8C65-FC74A6034429}. 2017.06.15 20:51:32 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0. 2017.06.15 20:51:37 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2017.06.15 20:51:37 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 64.120.44.138 MASK 255.255.255.255 192.168.1.1. 2017.06.15 20:51:37 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2017.06.15 20:51:37 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.06.15 20:51:37 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.06.15 20:51:37 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2017.06.15 20:51:37 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.06.15 20:51:37 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.06.15 20:51:37 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2017.06.15 20:51:37 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.06.15 20:51:37 - Starting Management Interface. 2017.06.15 20:51:37 - OpenVPN > Initialization Sequence Completed. 2017.06.15 20:51:37 - DNS leak protection with packet filtering enabled.. 2017.06.15 20:51:37 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1). 2017.06.15 20:51:38 - Flushing DNS. 2017.06.15 20:51:38 - Shell of 'cmd.exe','/c ipconfig /flushdns' done sync in 94 ms, Output: Windows IP Configuration. 2017.06.15 20:51:38 - Successfully flushed the DNS Resolver Cache.. 2017.06.15 20:51:41 - Shell of 'cmd.exe','/c ipconfig /registerdns' done sync in 3078 ms, Output: Windows IP Configuration. 2017.06.15 20:51:41 - Registration of the DNS resource records for all adapters of this computer has been initiated. Any errors will be reported in the Event Viewer in 15 minutes.I 2017.06.15 20:51:41 - Checking routeI 2017.06.15 20:51:41 - Checking DNS! 2017.06.15 20:51:53 - Connected.. 2017.06.15 20:51:53 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2017.06.15 20:51:53 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info Fixed: I fixed this issue by changing the Eddie client protocol to SSH rather than automatic. EDIT: Haven't changed a thing since SSH and now it's down to 30mbps down and like 4 up... Quote Share this post Link to post
