drac0
Cant connect with eddie
Hi guys, suddenly i cant connect to any server using eddie client. here is my log. Please advice on below
I 2017.05.07 16:06:45 - Eddie client version: 2.12.4 / windows_x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1, Mono/.Net Framework: v2.0.50727
. 2017.05.07 16:06:45 - Reading options from C:\Users\Drac0\AppData\Local\AirVPN\AirVPN.xml
. 2017.05.07 16:06:45 - Data path: C:\Users\Drac0\AppData\Local\AirVPN
. 2017.05.07 16:06:45 - Application path: D:\Program Files\AirVPN
. 2017.05.07 16:06:45 - Executable path: D:\Program Files\AirVPN\AirVPN.exe
. 2017.05.07 16:06:45 - Command line arguments (1): path="home"
. 2017.05.07 16:06:45 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
I 2017.05.07 16:06:48 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
I 2017.05.07 16:06:48 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09 (D:\Program Files\AirVPN\openvpn.exe)
I 2017.05.07 16:06:48 - SSH - Version: plink 0.67 (D:\Program Files\AirVPN\plink.exe)
I 2017.05.07 16:06:48 - SSL - Version: stunnel 5.40 (D:\Program Files\AirVPN\stunnel.exe)
I 2017.05.07 16:06:48 - curl - Version: 7.34.0 (D:\Program Files\AirVPN\curl.exe)
I 2017.05.07 16:06:48 - Certification Authorities: D:\Program Files\AirVPN\cacert.pem
! 2017.05.07 16:06:48 - Ready
. 2017.05.07 16:06:48 - Updating systems & servers data ...
. 2017.05.07 16:06:49 - Systems & servers data update completed
I 2017.05.07 16:06:50 - Session starting.
. 2017.05.07 16:06:50 - IPv6 disabled with packet filtering.
I 2017.05.07 16:06:54 - Checking authorization ...
! 2017.05.07 16:06:54 - Connecting to Salm (Netherlands, Alblasserdam)
. 2017.05.07 16:06:54 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.05.07 16:06:54 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.05.07 16:06:54 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.05.07 16:06:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.05.07 16:06:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 16:06:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 16:06:54 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.19:443
. 2017.05.07 16:06:54 - OpenVPN > Socket Buffers: R=[8192->262144] S=[64512->262144]
. 2017.05.07 16:06:54 - OpenVPN > UDP link local: (not bound)
. 2017.05.07 16:06:54 - OpenVPN > UDP link remote: [AF_INET]213.152.161.19:443
. 2017.05.07 16:07:26 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2017.05.07 16:07:26 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.05.07 16:07:31 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2017.05.07 16:07:31 - Disconnecting
. 2017.05.07 16:07:31 - Connection terminated.
I 2017.05.07 16:07:34 - Checking authorization ...
! 2017.05.07 16:07:34 - Connecting to Gienah (Netherlands, Alblasserdam)
. 2017.05.07 16:07:34 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.05.07 16:07:34 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.05.07 16:07:34 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.05.07 16:07:34 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.05.07 16:07:34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 16:07:34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 16:07:34 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.93:443
. 2017.05.07 16:07:34 - OpenVPN > Socket Buffers: R=[8192->262144] S=[64512->262144]
. 2017.05.07 16:07:34 - OpenVPN > UDP link local: (not bound)
. 2017.05.07 16:07:34 - OpenVPN > UDP link remote: [AF_INET]213.152.162.93:443
! 2017.05.07 16:07:54 - Disconnecting
. 2017.05.07 16:07:55 - Connection terminated.
I 2017.05.07 16:07:55 - Cancel requested.
. 2017.05.07 16:07:55 - IPv6 restored with packet filtering.
. 2017.05.07 16:07:55 - Flushing DNS
! 2017.05.07 16:08:01 - Session terminated.
I 2017.05.07 16:08:17 - Session starting.
. 2017.05.07 16:08:17 - IPv6 disabled with packet filtering.
I 2017.05.07 16:08:17 - Checking authorization ...
! 2017.05.07 16:08:17 - Connecting to Gienah (Netherlands, Alblasserdam)
. 2017.05.07 16:08:17 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.05.07 16:08:17 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.05.07 16:08:17 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.05.07 16:08:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.05.07 16:08:17 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 16:08:17 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 16:08:17 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.93:443
. 2017.05.07 16:08:17 - OpenVPN > Socket Buffers: R=[8192->262144] S=[64512->262144]
. 2017.05.07 16:08:17 - OpenVPN > UDP link local: (not bound)
. 2017.05.07 16:08:17 - OpenVPN > UDP link remote: [AF_INET]213.152.162.93:443
. 2017.05.07 16:08:49 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2017.05.07 16:08:49 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.05.07 16:08:54 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2017.05.07 16:08:54 - Disconnecting
. 2017.05.07 16:08:54 - Connection terminated.
I 2017.05.07 16:08:57 - Checking authorization ...
! 2017.05.07 16:08:57 - Connecting to Orion (Netherlands, Alblasserdam)
. 2017.05.07 16:08:57 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.05.07 16:08:57 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.05.07 16:08:57 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.05.07 16:08:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.05.07 16:08:57 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 16:08:57 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 16:08:57 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.238:443
. 2017.05.07 16:08:57 - OpenVPN > Socket Buffers: R=[8192->262144] S=[64512->262144]
. 2017.05.07 16:08:57 - OpenVPN > UDP link local: (not bound)
. 2017.05.07 16:08:57 - OpenVPN > UDP link remote: [AF_INET]213.152.161.238:443
. 2017.05.07 16:09:29 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2017.05.07 16:09:29 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.05.07 16:09:34 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2017.05.07 16:09:34 - Disconnecting
. 2017.05.07 16:09:34 - Connection terminated.
I 2017.05.07 16:09:37 - Checking authorization ...
! 2017.05.07 16:09:38 - Connecting to Hyadum (Netherlands, Alblasserdam)
. 2017.05.07 16:09:38 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.05.07 16:09:38 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.05.07 16:09:38 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.05.07 16:09:38 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.05.07 16:09:38 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 16:09:38 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 16:09:38 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.34:443
. 2017.05.07 16:09:38 - OpenVPN > Socket Buffers: R=[8192->262144] S=[64512->262144]
. 2017.05.07 16:09:38 - OpenVPN > UDP link local: (not bound)
. 2017.05.07 16:09:38 - OpenVPN > UDP link remote: [AF_INET]213.152.161.34:443
! 2017.05.07 16:10:04 - Disconnecting
. 2017.05.07 16:10:04 - Connection terminated.
I 2017.05.07 16:10:04 - Cancel requested.
. 2017.05.07 16:10:04 - IPv6 restored with packet filtering.
. 2017.05.07 16:10:04 - Flushing DNS
! 2017.05.07 16:10:10 - Session terminated.
if you have a 3rd party firewall such as Avast, try disabling the firewall before you connect, then once you're connected, reconnect the firewall..
